Official OPPO BDP-103 Owner's Thread - Page 787 - AVS Forum | Home Theater Discussions And Reviews
 889Likes
Old 07-05-2016, 06:39 AM
Viper187's Avatar
Quoted: 78 Post(s)
So is the region chip from JVB Digital still the best one for the 103?
Viper187 is offline
Old 07-05-2016, 06:51 AM
RetroRick's Avatar
Originally Posted by Bob Pariseau View Post
Complaints to ROKU please.
Pulling a feature like this without even acknowledging it on ROKU's support pages is pretty dumb, but there you have it.
--Bob
Thanks, Bob. That says it all to me.
So do you know of a good alternative for me other than upgrading to a newer Roku stick?
My first inclination is definitely NOT to reward their behavior with another purchase.
--Rick
BTW, I contacted Roku about this issue, and a guy named Riswan from customer support wrote back that probably my internet speed wasn't fast enough, so it automatically downgraded to 720p. That made me angry to begin with, since my question clearly showed enough knowledge to know that this was not the case and I was intelligent enough to know to rule that out. But now learning this was something that has already been brought to their attention, I'm even more angry with them.
RetroRick is offline
Old 07-05-2016, 07:12 AM
bigdogaxis's Avatar
Quoted: 129 Post(s)
Liked: 90
VUDU did something similar, removing 7 channel audio HDX movies in favor of the UHD format. I see the writing on the wall, so I am back to buying shiny discs.
My equipment: JVC RS-55, SI Performance 120" 1.3 gain, OPPO BDP-105, ANTHEM MRX-1120, Roomie-iPad, QNAP 469L NAS, ROKU 4, ATV, DTV HR34-500, PS3, XBOX 360. ML Source (F), Matinee (C), MotionFX (S), Motion4 (.4), (2) Depth-i subs. M/ASlim5 Rack, CalMAN 5 Enthusiast/C6 meter.
bigdogaxis is offline
Old 07-05-2016, 07:25 AM
hernanu's Avatar
Quoted: 604 Post(s)
Liked: 1093
Haven't seen that in VUDU. Will have to double check at home, but just checked "Pirates of the Caribbean Stranger tides" and it's at 7.1 for HDX.
Some of the UHD titles are coming in with lossy Dolby Atmos. So far, VUDU has been good for me, obviously if it changes, so will my viewing habits, but I don't see it.
hernanu is offline
Old 07-05-2016, 07:28 AM
mjay71's Avatar
Liked: 0
^ No idea on where to find meaningful HDMI jitter info.
Keep in mind that SACD's use of DSD digital audio format has substantial built in noise above 50kHz (an artifact of quantization "Noise Shaping" which has nothing to do with the quality of the gear used or the quality taken in the recording and mastering process). When using 88kHz digital output, that's automatically suppressed by Nyquist theory. When using the player's built in DACs for direct conversion of DSD to Analog, a 50kHz filter is built into the conversion.
I
But if you convert SACD DSD to 176kHz LPCM and send that to a DAC that has no clue it came from an SACD, that filtering is likely not present in the conversion. This noise is almost certainly too high up to detect by even golden ears, but it is not good for downstream equipment. In essence, the portion of the signal frequencies in 176kHz above what 88kHz carries is not something you really want to preserve when playing SACD.
Which means, if you are wondering whether the external DAC is better than the OPPO DAC for SACD, it's safer to compare 88kHz from SACD through it unless you know it was specifically designed to include the 50kHz filter.
--Bob
If I am understanding this correctly, applying dithering only without noise shaping to a conversion would not push noise into the higher frequencies, and therefore be a safer alternative for high frequency conversions?
mjay71 is offline
Old 07-05-2016, 07:30 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2684 Post(s)
Liked: 3434
^ The noise is built into the content on the disc. Without "Noise Shaping" in the recording process, the noise actually appears in the audible frequencies. That's why Noise Shaping is applied. It pushes the noise up to inaudible frequencies, at the expense of making the noise (now moved up there) even worse.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
Old 07-05-2016, 08:19 AM
mjay71's Avatar
Liked: 0
--Bob
With dithering, Is the noise that remains in the audible (and inaudible) frequencies safe for equipment, or still potentially harmful the way the high-frequency noise is with noise-shaping?
mjay71 is offline
Old 07-05-2016, 08:40 AM
Read the FAQ!
Liked: 3434
^ I don't know.
--Bob
Old 07-05-2016, 09:52 AM
fmalczewski's Avatar
Quoted: 102 Post(s)
Liked: 40
Check ebay via Oppo bdp-103 105 USB Region Hardware Kit for the one I suggest. (Save your money, it works fine.)
gossamer88 likes this.
fmalczewski is offline
Old 07-05-2016, 11:25 AM
bigdogaxis's Avatar
Quoted: 129 Post(s)
Liked: 90
I should restate, VUDU removed the 7.1 collection in favor of UHD collection. I have the POTC collection on 7.1 discs.
On quick glance, currently VUDU offers only POTC On Stranger Tides in 7.1, other POTC titles are 5.1 DD.
Old 07-05-2016, 11:50 AM
hernanu's Avatar
Quoted: 604 Post(s)
Liked: 1093
That's the case on Bluray also.
Black Pearl - DD 5.1
Dead Man's Chest - DD 5.1
World's End - DD 5.1
Stranger Tides - DTS-HD-MA 7.1
At least in this case, VUDU reflects the blurays (no lossless, obviously).
hernanu is offline
Old 07-05-2016, 08:07 PM
rdgrimes's Avatar
Quoted: 2153 Post(s)
Liked: 1472
AFAIK, any UHF noise is potentially damaging to tweeters with the usual caveats of level and duration.
rdgrimes is online now
Old 07-05-2016, 08:15 PM
Oubadah's Avatar
Quoted: 31 Post(s)
Is the reported bit rate (visible via the info button) for video or video+audio?
Originally Posted by gossamer88 View Post
I personally have never used the YouTube app on the Oppo. Maybe not the answer you want, but I prefer the Chromecast for YouTube. It is super easy. Search and playing from your computer/tablet is a hellava lot easier IMO. My 2¢...
You can do that with the Oppo (pair the mobile device, search and play from that device via the Oppo). Well, theoretically at least. In my experience, this was another area of incompetency in the 103, and it would frequently hang when trying to cast youtube videos. I haven't tried it in a while, though.
Oubadah is offline
Old 07-05-2016, 09:59 PM
Liked: 0
Originally Posted by wmcclain View Post
What are the issues?
Are you accessing these files via DLNA or SMB?
Do you have USB drive you can connect directly to the OPPO? Do the files play ok in that case?
-Bill
Hey Bob
The playback will pause for few seconds and resumes. This happens very frequently particularly while playing large media files over 10 GB. When I copy the same into a USB Drive, I dont have that issue. Plz help
AKKS is offline
Old 07-05-2016, 10:03 PM
Quoted: 102 Post(s)
Liked: 40
Actually the early POTC blu-rays are LPCM 5.1 so quite lossless. (48kHz, 24-bit; the DD is only 640 kbps)
Old 07-06-2016, 08:44 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2862 Post(s)
Liked: 2131
Originally Posted by AKKS View Post
Hey Bob
That could be a network issue, or perhaps the server itself is stalling from resource contention, buffering or some other process running.
Do you have a choice between SMB and DLNA? What happens when you switch to the other?
Do you have any other way to test these files over the same network?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 07-06-2016, 09:45 AM
hernanu's Avatar
Quoted: 604 Post(s)
Liked: 1093
You're right, but I was talking about the VUDU version. Should have made that clearer.
hernanu is offline
Old 07-06-2016, 01:30 PM
apbarson's Avatar
Is there any benefit to using a BDP-103D over a standard BDP-103 along with a darbee darblet?
Does the oppo offer better video processing than the darblet, or is it the same? It will be connected through a Denon X6200 receiver to my tv.
I like the idea of using the darblet to process all video sources by connecting it to the output of the receiver, however I would buy the 103D if is better.
apbarson is offline
Old 07-06-2016, 01:35 PM
wmcclain's Avatar
Liked: 2131
The video results will be the same. You can route HDMI inputs through the OPPO, which is another option.
-Bill
Old 07-06-2016, 02:28 PM
LarryMagoo's Avatar
Quoted: 158 Post(s)
Liked: 57
Just FYI....I was told by Oppo that they are coming to market with a UHD player at the beginning of 2017....I thought I had bought my last Disc player (BD105)...but from what I know....apparently not yet...Love Oppo though...also use their HeadPhone /DAC Amp!
Sony XBR75X940D | Marantz AV8801 | SunFire Cinema Grand 5-Chan. | 5.2 system w/ 5 Monitor Audio Gold 2 Velodyne HGS 12's | Oppo BDP 105 | MAC Mini for Streaming, View on the XBR | Harmony Ultimate Remote | DDRC-88A| Comcast Internet 90Mb's | 2 Dedicated 20 AMP circuits. | Apple TV4 | Cans: Sennheiser HD 650 + Sennheiser HD 800S | Oppo HA-1 HEADPHONE AMP, Fed with my Schiit Yggdrasil DAC |
LarryMagoo is offline
Old 07-06-2016, 03:51 PM
Read the FAQ!
Liked: 3434
Your findings are correct. ROKU pushed out firmware some months back which eliminated 1080p output from this generation of ROKU hardware. There's never been any explanation from ROKU, and repeated complaints from multiple users have produced no resolution.
The way it appears to have gone down is this: This generation of ROKU hardware is incapable of 1080p/60 output. What you were seeing before was 1080p/24. If the content was available for streaming from ROKU at 1080p/24 (basically, if you were watching a movie), then with 1080p enabled in its settings, you got 1080p/24 streaming into the ROKU and 1080p/24 output to the OPPO. (Depending on your settings in the OPPO, that might be sent to your TV as 1080p/24 or 1080p/60, or whatever you selected for output resolution.)
If the content was NOT available for streaming at 1080p/24. The best you could get was 720p/60.
But with the new ROKU firmware, 1080p/24 content, and thus 1080p/24 output, went away.
It appears that the NEWER ROKU hardware is incapable of 1080p/24 output. Instead, it streams and outputs 1080p/60. Evidently ROKU wanted to use the same firmware for both the older and newer hardware, and the upshot is that there is still a 1080p setting for the generation of stick you have, but no 1080p/24 content to stream! At a guess, they pulled 1080p/24 content from their servers since the newer hardware made no use of it.
With no 1080p/24 content to stream, the stick you have streams 720p/60 content from ROKU's servers, and since the stick has no ability to scale that or change the frame rate, 720p/60 is what you get for output. I.e., the only way to get different resolution or frame rate out of that stick is for it to stream the desired resolution or frame rate as input from the ROKU servers.
Again, this is something ROKU did, and it has been that way for months now. OPPO has no way to fix it on their own. As with all the Internet streaming services, the service provider is in control of what they stream. So far, I've seen no posts that anyone has gotten an explanation or apology from ROKU nor any sort of promise that they are "looking at fixing it".
--Bob
***** This Bug Appears to be Fixed! *****
ROKU today pushed new software to the MHL version ROKU Streaming Stick. The new software is Version 7.2.0, Build 4100.
I just tested, and the MHL version ROKU Streaming Stick, running that software, is once again able to send 1080p/24 to the OPPO.
Huzzah!
--Bob
htwaits, Keenan, GreySkies and 1 others like this.
Old 07-06-2016, 06:33 PM
Coyote Waits
htwaits's Avatar
Quoted: 929 Post(s)
Liked: 2058
Originally Posted by LarryMagoo View Post
Just FYI....I was told by Oppo that they are coming to market with a UHD player at the beginning of 2017....I thought I had bought my last Disc player (BD105)...but from what I know....apparently not yet...Love Oppo though...also use their Headphone /DAC Amp!
My family used to visit my Grandparents in Brentwood back in the late thirties and the forties. I don't think there was anyone like your avatar within many many miles of Brentwood.
Maybe she is the granddaughter of my first girl friend (we were both five years old at the time) who I hung out with in Brentwood.
Simm and lairpost like this.
htwaits is offline
Old 07-06-2016, 07:40 PM
Oubadah's Avatar
Quoted: 31 Post(s)
Do you have the instructions for internal installation. I'm thinking of getting that kit, but I want to see the procedure first. I can't seem to find instructions, photos or a video anywhere.
Oubadah is offline
Old 07-07-2016, 12:00 AM
Quoted: 102 Post(s)
Liked: 40
This can easily be installed externally also (which is how I have it on both machines). But I do have instructions (my recollection is it's fairly straightforward, but I've not done it myself). I'll see if I can send them to you in a pm.
Edit: Didn't see a way to include PDF file in a pm. PM me with your email address and I can send you a copy. (If you already ordered it, the seller should be sending you the PDF shortly.)
Old 07-10-2016, 12:53 AM
Liked: 0
-Bill
Hey Bill
I access the files using the network menu on the home page of Oppo. I really donot know if it is DLNA or SMB? Where do I check that? Please help me here
AKKS
AKKS is offline
Old 07-10-2016, 12:54 AM
Liked: 0
-Bill
Hey Bill
AKKS
AKKS is offline
Old 07-10-2016, 01:49 AM
Oubadah's Avatar
Quoted: 31 Post(s)
Hey Bill
AKKS
I don't know if the Western Digital My Cloud has a DLNA server feature built into it, but DLNA and SMB sources all appear in the same list on the Oppo. if it's SMB, it will have the following generic icon next to it:
If it's DLNA, it'll have a different icon, probably a custom WD one in this case.
Oubadah is offline
Old 07-10-2016, 08:00 AM
RetroRick's Avatar
Huzzah!
--Bob
Yeah. That figures... virtually simultaneous with me paying them $60 for the current generation ROKU stick. Well, guess I get 1080p/60.
And when I complained about the bug, first their outsourced customer service told me to check my internet speed. (No, YOU are the problem ROKU.)
When I explained that was not the problem, their second response was that they don't recommend connecting the stick through another device and I should connect it directly to my TV.
a) Then I would have no sound. b) You made a deal with Oppo to sell/package/market your items together, but you don't recommend customers use them that way?!?!
I looked into replacing my stick with something from another company, but couldn't find anything on the market that would stream the same channels I've grown to love.
But I have seldom been more angry/unhappy with a company, and I look forward to the day that I no longer do business with or use products made by ROKU.
Old 07-10-2016, 09:26 AM
brianlvi3's Avatar
Quoted: 81 Post(s)
Hey guys,
I have an Oppo BDP 103, Epson 5020 and a Marantz pre/pro 7702. Has been working great, no problems. Put in a new blu ray last night, (The Witch) and during the movie at least half a dozen or more times the picture and sound would drop out for a few seconds. Then come back. The disc is still running. If I go back to that spot (rewind), it doesn't do it again.
I threw in one of my other blu rays that I know plays fine, it also did it on that one. Not too much, just a few times in a half hour. Same thing, if I rewind back to that spot, it doesn't do it again at that same spot exact time.
I have not done anything to my system for a while and I think I have the latest software is loaded. The only thing was a small power failure a few weeks ago. Everything else seems to be fine.
Thoughts before I go crazy here? Thanks again to alll!!!
Brian
Brian
brianlvi3 is offline
Old 07-10-2016, 09:56 AM
Quoted: 102 Post(s)
Liked: 40
Brian
Try re-seating your hdmi cables.
I had an hdmi cable go slightly loose which resulted in similar symptoms. (Probably did it myself, but maybe not.)
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
