Official OPPO BDP-103 Owner's Thread - Page 794 - AVS Forum | Home Theater Discussions And Reviews
 742Likes
post #23791 of 23819 Old 08-20-2016, 01:09 PM
645824's Avatar
Quoted: 27 Post(s)
input mode stuck when other device turns off
Hi,
I have the Oppo 103D and a ChannelMaster DVR+. The DVR+ is connected to the 103's "HDMI In-Back" port.
The problem I'm having is that the 103's input mode is stuck after I turn off the DVR+ if the DVR+ was the present input mode. I've reported this to Oppo, but they are finger-pointing. I'm running the latest firmware (updated using the CDROM technique last week).
This is very repeatable -- happens every time:
1. turn on 103D
2. turn on DVR+
3. select the 103D's "HDMI In-Back" port. This is where I have my DVR+ is plugged in.
4. TV works great.
5. turn off the DVR+
6. blank screen
7. using the 103D's remote's Input button, the menu doesn't appear on the screen. Its still just blank. Also, the 103D's front panel still says "HDMI In-Back". That doesn't change.
8. I also tried "Input" "1" "Enter" to get back to the 103D's default bluray player mode, but it is still stuck.
9. The 103D's remote's red power button doesn't turn the 103D off either until after a long delay... The only other way to get back is to turn the 103D off using the front-panel button.
10. once I power up the 103D again, it is in the default bluray mode and I can switch inputs again.
At this point, Oppo technical support isn't engaging. I reported it, they asked some questions, then silence. But the DVR+ is doing everything that it is supposed to -- it goes off, it goes on.
Once I turn the DVR+ back on, the 103D is happy again and I can change the inputs. It appears that when the DVR+ goes off, the 103D gets stuck and locks to the input mode.
Has anyone else had a similar problem?
Scott
645824 is offline
post #23792 of 23819 Old 08-20-2016, 06:54 PM
Liked: 0
Originally Posted by SeeMoreDigital View Post
Definitely yes with 5.1 Flac audio. I have not tested 7.1 Flac audio though...
works perfectly for me in a 7.1 format.
kevinopp is offline
post #23793 of 23819 Old 08-21-2016, 09:27 AM
ril850's Avatar
Quoted: 16 Post(s)
What is the remote code for 103?
Life is what you make it.......
ril850 is online now
post #23794 of 23819 Old 08-21-2016, 09:35 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 1351 Post(s)
Liked: 1347
Originally Posted by 645824 View Post
Hi,
1. turn on 103D
2. turn on DVR+
4. TV works great.
6. blank screen
Scott
Have you tried changing the OPPO Input to "Blu-ray Player" BEFORE turning off the DVR+?
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #23795 of 23819 Old 08-21-2016, 09:39 AM
Read the FAQ!
Liked: 1347
It's not clear what you are asking. If you are looking for a list of IR remote commands to use in programming a programmable remote, they are published in an Excel spreadsheet available on OPPO's Support page for the BDP-103 player:
http://www.oppodigital.com/blu-ray-b...3-Support.aspx
--Bob
post #23796 of 23819 Old 08-21-2016, 09:43 AM
ril850's Avatar
Quoted: 16 Post(s)
What is the remote code for the 103? Trying to program my Marantz remote to do some basic functions.
post #23797 of 23819 Old 08-21-2016, 09:44 AM
ril850's Avatar
Quoted: 16 Post(s)
Sorry for the double post, first one gave me an error message.
post #23798 of 23819 Old 08-21-2016, 09:49 AM
Read the FAQ!
Liked: 1347
Unless your Marantz remote is generally programmable (pretty unlikely) you are probably limited to the set of remote codes for "other devices" built into the Marantz remote -- plus possibly the ability to learn individual remote commands one by one.
The set of "other device" remote codes built into your Marantz remote should be listed in the Manual for your Marantz. If the OPPO players are not on that list then you are likely out of luck. Note that for all the basic functions (arrow buttons, play/pause, etc.) all the OPPO Blu-ray players from the BDP-83 onward share the same codes. So if you have *ANY* OPPO BDP-xxx player listed in the Marantz documentation on "other devices" for their remote then that one will do.
--Bob
post #23799 of 23819 Old 08-21-2016, 02:28 PM
WOLVERNOLE's Avatar
Quoted: 51 Post(s)
Liked: 24
Question Two BDP-103 questions:An HDMI-challenged poster question, and do new units have updat
SIAP. but as a HDMI-challenged old poster, I sure would appreciate a basic answer on compatibility. My seven year-old Panasonic Blu-ray is failing and I want to replace and start an upgrade. I have a seven year old Panny VT plasma that I want to get one more season out of, and likewise on a circa 2009 Denon AVR-2310CI, HDMI 1.3
As the Blu-ray is on its way out, I am between considering an Oppo BDP-103, OR a Panasonic (4K) UB900 (maybe available 9/01/2016)...OR wait (not cool) for the 4K Oppo (probably a lot of folks' dilemma).
Question on HDMI compatibility: Could I potentially still utilize my circa 2009 Denon AVR-2310CI, HDMI 1.3 with the Oppo BDP-103 (which I understand is HDMI 1.4 ) ?? and curious if this is okay, would I be able to expect an improvement in sound quality if I am using HDMI cables (and not audio-out) ??
Question on Oppo "updates": Sorry about in all likelihood an ignorant question, but if I was to purchase an Oppo BDP-103 next week, directly from Oppo, should I expect a unit that is the same (update-wise) as the units boxed at their circa 2012 initial manufacture date, OR, have they currently been building these same units and "applying" updates that are (relatively) current ?? I just never understood how that works.
Thank you so much for responses on these questions. Trust me when I say that you guys are very helpful with issues on here. Continues to be a GREAT site !
WOLVERNOLE is offline
post #23800 of 23819 Old 08-21-2016, 03:14 PM
Read the FAQ!
Liked: 1347
^ Second question first: OPPO players have the latest firmware installed that was available when the player was made. Now, regardless of how you purchase your OPPO, the box you get has not likely been sitting unsold for all THAT long, but as it turns out, OPPO just this past week released new firmware for the BDP-103, and so the odds are pretty good the player you buy this week will *NOT* have that new firmware installed. Even if you buy direct from OPPO.
Since you are posting here, you obviously have access to the Internet. If you connect your OPPO player to the Internet (via an Ethernet cable to the "router" in your house, or by telling the player how to connect to Wifi wireless networking in your house) the player can update its firmware over the Internet for you. It is quick and painless. And if the player already has the latest firmware, it will tell you so.
On your first question, you will not get the value you are paying for if you buy a new UHD -- sometimes called 4K -- player unless you also replace your TV with a new, UHD TV. If you are planning to run the video through the Denon, it too will need to be replaced with a UHD-capable AVR. The UHD players *WILL* work with older, non-UHD TVs and AVRs, but not up to their full potential.
Setting aside UHD/4K players, then, HDMI v1.4 is backwards compatible with HDMI v1.3, so you should have no problem using the OPPO BDP-103 with your current, HDMI-capable Denon AVR and Panasonic TV.
It's tough to predict what you will hear for audio, since I don't know the capabilities of your failing, Panasonic player. But if you've been using Analog (RCA) cables for audio from the Panasonic, odds are good you will hear better audio if you switch to having the Denon get its audio from the HDMI cable. That's simply because MOST Blu-ray players don't have particularly good Analog audio output electronics. There are certainly exceptions -- typically higher end Blu-ray players like the OPPO BDP-105. Even the OPPO BDP-103 is no slouch at Analog audio output. But generally speaking, if you can use HDMI for audio it is simpler, and "probably" better. (Doing Analog audio "right" is more complicated to set up, too.)
Finally, if you buy direct from the OPPO Digital web site, they offer an easy, 30 day return policy. All you risk is the shipping cost. So you can get the player and see for yourself if it is doing what you want. If not, give them a call and they will tell you how to do the return for refund.
--Bob
post #23801 of 23819 Old 08-21-2016, 03:15 PM
ril850's Avatar
Quoted: 16 Post(s)
Thanks Bob well answered. Look like a universal remote for me
post #23802 of 23819 Old 08-21-2016, 10:26 PM
DSP5000's Avatar
There is an iPad oppo control software as far as I know, i haven't used it but I've seen it online.
So simply put you can select your movie file and play them, so far so good. Except the interface stinks!
I wonder how possible it would be to have an interface similar to infuse or plex for browsing your collection
and playing the file once chosen? That would be sweet!
DSP5000 is offline
post #23803 of 23819 Old 08-22-2016, 06:30 AM
LairdWilliams's Avatar
Quoted: 189 Post(s)
Liked: 211
You can do this now, but you need to be using DLNA to connect your media to your Oppo (as opposed to a file share or direct USB connection.) Then you can run Plex (or oShare, or jRiver) as your DLNA server and run a corresponding DLNA controller app on the iPad (like Plex, or Kinsky, or jRemote). You would then use the controller app on the iPad to browse your shows/music and "push" the music to the Oppo. I do this with jRiver/jRemote and it works great - very stable and reliable.
I went through a lot of frustration to get this to work well - so here are some thoughts to keep in mind should you choose to go this route:
1) "Matched sets" of Server and Controller are better. Yes, DLNA controllers and servers SHOULD interoperate and they do - to a very limited degree. I got much better results when I used a controller that was specifically designed to work with a given player. (My best results were with jRiver/jRemote and my second best results were in the Plex family).
2) A stable network environment is a must. Use fixed IPs for everything but the iPad. Use high-quality store-and-forward switching in your network and use wired connections for at least the server and also the Oppo if at all possible.
3) Make sure that the DLNA server is configured to do NO transcoding/media conversion when working with the Oppo. If you do this, ANY file that plays on the Oppo via USB will also work through DLNA. If you leave any transcoding turned on, you are asking for trouble.
4) You can forget getting gapless music playback if you go this way.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #23804 of 23819 Old 08-22-2016, 07:51 AM
DSP5000's Avatar
Interesting, What specific app on the iPad are you using?
DSP5000 is offline
post #23805 of 23819 Old 08-22-2016, 08:07 AM
Quoted: 189 Post(s)
Liked: 211
I have jRiver Media Center as the DLNA server and jRemote on the iPad as the controller.
The software was not free, but it was not all that expensive either and it was the most reliable in the end.
pashine likes this.
post #23806 of 23819 Old 08-22-2016, 09:51 AM
Draden1's Avatar
Quoted: 101 Post(s)
Liked: 44
I am wishing the oppo app could do this (cover art, metadata) for hd's connected via usb. My network connection is good but not great which allows me to play my dvd's over the network. Bluray's typically stutter/buffer to the point where I just plug the hd into the oppo directly with usb.
Not sure if oppo will ever put that functionality into their app?
Draden1 is online now
post #23807 of 23819 Old 08-23-2016, 04:35 AM
lancer77's Avatar
Is the latest beta firmware issued on 18 July likely to be made Official in the near future?
lancer77 is offline
post #23808 of 23819 Old 08-23-2016, 04:41 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 1923 Post(s)
Liked: 838
It was made official on August 12: http://oppodigital.com/blu-ray-bdp-1...3-Support.aspx
-Bill
obie_fl and gwsat like this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #23809 of 23819 Old 08-23-2016, 04:48 AM
lancer77's Avatar
-Bill
Thanks for the quick reply Bill. I'm not seeing anything for the 103EU that's official (sorry, should have specified that version first time!).
lancer77 is offline
post #23810 of 23819 Old 08-23-2016, 04:54 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 814 Post(s)
Liked: 626
You'll need to contact the EU distributor to find out when they plan to make the new version official. Each region needs to make minor changes such as setting the appropriate region code and add/remove a few apps and then run some of their own tests before releasing the firmware. Since Oppo Digital is based in the USA, new versions are made available here first.
gsr is online now
post #23811 of 23819 Old 08-23-2016, 06:44 AM
susanandmark's Avatar
Quoted: 24 Post(s)
Is there anyway to disable the apps on this player? Or at least YouTube? It requires no sign in and there aren't parental controls. My nine-year-old has been sneaking to watch Minecraft videos. Easy to delete the app, lock phones, etc. but he's realized the Oppo is an open door. Anything other than pulling the Internet plug that will work? (Yes, we are also using discipline, but if I can also remove the means, he loses motive.)
susanandmark is offline
post #23812 of 23819 Old 08-23-2016, 07:07 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 814 Post(s)
Liked: 626
There isn't a way to disable or remove apps on the player. Something that might work is to configure your Internet router to block access to the Internet or certain domains from the Oppo player's IP or MAC address. Whether this can be done depends on what you're using for a router.
gsr is online now
post #23813 of 23819 Old 08-23-2016, 07:09 AM
GreySkies's Avatar
Quoted: 614 Post(s)
Liked: 426
I don't know if the app can be blocked, but can you block Youtube for your Oppo's IP address at your router?
GreySkies is offline
post #23814 of 23819 Old 08-23-2016, 07:51 AM
ckronengold's Avatar
Quoted: 51 Post(s)
Can't you do this by creating a shared / virtual / network folder pointing to your hard drives?
Media Room: Epson 5030 / Pioneer VSX-822 / OPPO-103
Paradigm Mini Monitors v2 / Atoms (rears) / CC-370
House Audio: Onkyo NR-709 & Monoprice in-wall speakers
Server: WHS2011, i5 2500k CPU
HTPC:Win8 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #23815 of 23819 Old 08-23-2016, 01:34 PM
shepdog's Avatar
Quoted: 44 Post(s)
Liked: 37
--Bob
I'm kinda in the same boat. I'm upgrading my entire system.
I have a Epson 5040ub projector on the way which is 4K capable.
My receiver is a Yamaha a840 which states it will pass-through 4K/60p and 3D however it is not HDCP 2.2-compliant and will not support copy-protected 4K video content.
How much 4K material is copy-protected?
If the oppo continues to have dual HDMI outputs will this alleviate the problem?
shepdog is online now
post #23816 of 23819 Old 08-23-2016, 04:07 PM
Read the FAQ!
Liked: 1347
^ The OPPO BDP-103 does not play any form of content which is already 4K, and thus does not need the newer copy protection created for such content -- things like UHD Blu-ray discs.
The OPPO 103 can upscale lesser resolution content to 4K output, which sounds like what your gear is intended to handle. That's done using the same style of copy protection as is used with normal Blu-ray discs.
--Bob
Rhythmx likes this.
post #23817 of 23819 Old Today, 02:45 PM
genegold's Avatar
Quoted: 23 Post(s)
Got a notice for the latest firmware on startup today, but the download was very slow and kept running out of gas about 2/3 done. Tried USB, but for some time the old version was the one available on the new firmware page. Then all of a sudden, right after sending OPPO an email, it changed to the new one and I was able to install that. I'd go with the network version first, as the website links for USB aren't very clear.
genegold is offline
post #23818 of 23819 Old Today, 02:51 PM
shepdog's Avatar
Quoted: 44 Post(s)
Liked: 37
--Bob
The projector plays 4K content. It arrived 4 days ago and I have been enjoying Netflix strange things and Marco Polo.
If it did not accept 4K, I would have already purchased the OPPO 103. Anxiously awaiting the 4K OPPO to drop
post #23819 of 23819 Old Today, 05:43 PM
Paulisdead's Avatar
I couldn't find a reference to this issue:
The TIDAL section of the Media Control app is not working on my iPhone SE.
I can log in to TIDAL and search for a song, but it hangs when you press PLAY and does not sync with the Oppo player. My phone is currently on Ois 9.3.4 and the Media Control app is V4.0
Is this a common problem? Is there a work around? I noticed the latest firmware Beta mentions nothing about TIDAL.
Paulisdead is online now
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
