Official OPPO BDP-103 Owner's Thread - Page 795 - AVS Forum | Home Theater Discussions And Reviews
 741Likes
post #23821 of 23832 Unread 08-28-2016, 09:49 PM
Smarty-pants's Avatar
Quoted: 462 Post(s)
Liked: 298
Originally Posted by Paulisdead View Post
I couldn't find a reference to this issue:
The TIDAL section of the Media Control app is not working on my iPhone SE.
I can log in to TIDAL and search for a song, but it hangs when you press PLAY and does not sync with the Oppo player. My phone is currently on Ois 9.3.4 and the Media Control app is V4.0
Is this a common problem? Is there a work around? I noticed the latest firmware Beta mentions nothing about TIDAL.
First always make sure you are running the most current official version of firmware.
There was one released just a couple of weeks ago. http://oppodigital.com/blu-ray-bdp-1...3-Support.aspx
If your player is authorized for network access, you should be able to update the firmware with wifi or ethernet through the
settings menu of the player.
I don't currently have an active Tidal account, so I can't test it to corroborate, but you could try the iOS 9.3.5 update
and see if anything changes for the better.
Other things to try would be to do an Energy Efficient power cycle of the player.
To keep that simple, just power off the player, then pull the power cord from the back of the player or the power
socket it's plugged into, with it unplugged, press the power button on the player once, then plug it back in and turn it on.
You will also want to try exiting the Oppo MC app as well as all apps on your iPhone, clear the open background apps,
and then do a power cycle of your iPhone.
Try to do both procedures at the same time before you try re-entering the MC app or Tidal portion of the MC app.
In other words, start with a clean slate to see if that helps your issue.
Smarty-pants is offline
post #23822 of 23832 Unread 08-28-2016, 09:57 PM
Quoted: 462 Post(s)
Liked: 298
Originally Posted by green giant View Post
Quick question - Just got around to signing up for Amazon Prime. What is the best way to stream through the 103, and get full surround sound from Amazon Prime? Buy a stick?
Amazon sells different variations of the their streaming products or you can try something like a Roku,
or several other streaming boxes/sticks on the market.
Some offer Amazon streaming and some don't. Not all offer the best audio/video output either so you
will have to do some homework and decide which one is right for you according to specs and how much you're willing to spend.
post #23823 of 23832 Unread 08-29-2016, 03:29 AM
lancer77's Avatar
Originally Posted by genegold View Post
Got a notice for the latest firmware on startup today, but the download was very slow and kept running out of gas about 2/3 done. Tried USB, but for some time the old version was the one available on the new firmware page. Then all of a sudden, right after sending OPPO an email, it changed to the new one and I was able to install that. I'd go with the network version first, as the website links for USB aren't very clear.
Thanks for the response. I think what you're saying doesn't relate to the 'EU' version of the firmware though does it? I can only see the beta version still available on the Oppo UK site. (Apologies if you didn't see my later post clarifying I meant the EU version!).
lancer77 is offline
post #23824 of 23832 Unread 08-29-2016, 03:42 AM
pbarach's Avatar
Quoted: 262 Post(s)
Liked: 164
Any streaming device that can output Amazon Prime surround sound over HDMI will stream through the 103 without a hitch.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #23825 of 23832 Unread 08-29-2016, 08:25 AM
bgoering's Avatar
Quoted: 162 Post(s)
Liked: 47
Look for a MHL Roku stick, with that you can use the OPPO remote to control your steaming activity. I don't know if they still have it, but when I got my 103 there was one available I think just for the OPPO
bgoering is offline
post #23826 of 23832 Unread 08-29-2016, 09:19 AM
lujan's Avatar
Quoted: 1235 Post(s)
Liked: 374
Let me know if someone wants to trade a MHL Roku stick for a regular HDMI stick as I've never used my MHL Roku stick that I got directly from Oppo.
lujan
78 Ultra HD
831 HD
19 HD DVD
7 SD
lujan is offline
post #23827 of 23832 Unread 08-29-2016, 12:16 PM
Manic_D's Avatar
Quoted: 13 Post(s)
I updated to the latest firmware, and it seems that gapless playback is no longer gapless. There is a very brief gap, not huge but it's definitely there.
I tested with flac files, using the media control app from an SMB source and also with a USB drive attached to the player. Same results.
Manic_D is online now
post #23828 of 23832 Unread 08-29-2016, 12:42 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 1352 Post(s)
Liked: 1347
Get in touch with OPPO Tech Support, preferably with some sample files exhibiting the problem.
There were no changes related to Gapless announced for this firmware.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #23829 of 23832 Unread 08-29-2016, 03:26 PM
Read the FAQ!
Liked: 1347
^ Manic_D,
I just found out through Beta Tester channels that OPPO Engineering has confirmed a case where Gapless play nevertheless has a gap for FLAC files played from USB. The gap appears to be 5ms.
I don't know any more details yet. E.g., whether it is limited to particular formats in the FLAC files or to particular tools used to create the FLAC files. But it is confirmed that the failure is new. The same files don't have a gap when played in the prior OFFICIAL firmware.
OPPO Engineering is on the case.
Just in case the failure is file specific, it would STILL be good for you to get in touch with OPPO Tech Support and offer samples that exhibit the problem.
--Bob
post #23830 of 23832 Unread 08-29-2016, 03:41 PM
Manic_D's Avatar
Quoted: 13 Post(s)
Originally Posted by Bob Pariseau View Post
^ Manic_D,
--Bob
I am sending them a couple of flac files as they requested in their email response.
post #23831 of 23832 Unread 08-29-2016, 03:44 PM
genegold's Avatar
Quoted: 24 Post(s)
I was referring to the U.S. site and player. It's strange because in their emails OPPO kept assuming I have the Euro player, even though I mentioned having successfully gotten the update from the U.S. site (and I'm registered with them in the U.S.).
genegold is offline
post #23832 of 23832 Unread Today, 09:15 PM
Liked: 0
I'm very interesting in picking up an Oppo 103 to install this jailbreak firmware on. The only place I can find online selling keys is bd-mod.com. Anyone else have any experience with this bd-mod or know somewhere else to buy a key?
I'd love a 103 for its ability to play SACD and DVD-A. Being one of the few devices capability of ripping SACD is a big plus too. I want to jailbreak in order to play 1:1 Blu-ray iso and SACD iso stored on my network. The added jailbreak functionality would make this my dream player. A HTPC could have most of this functionality, but I don't think I'd ever get it set up in a user friendly manor.
johnestan is online now
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
