Official OPPO BDP-103 Owner's Thread - Page 808 - AVS Forum | Home Theater Discussions And Reviews
 865Likes
post #24211 of 24463 Old 12-27-2016, 07:59 AM
gene9p's Avatar
Quoted: 31 Post(s)
Liked: 31
Originally Posted by Holiday121 View Post
Hmmm can only get audio still no video. Was working fine on My jvc RS46 with a different player. So its either
1. The oppo 103 instead of the old player
2. the new jvc Rs400
try a better HDMI cable. There is a signal loss going in and out of the Darblet that can effect the signal strength across the HDMI cable, especially a long run. I changed my cable when I upgraded my projector for this reason. It works fine now with 103, to Darblet, to projector.
Good quality HDMI cable from Monoprice .com did the trick.
gene9p is offline
post #24212 of 24463 Old 12-27-2016, 03:23 PM
fmalczewski's Avatar
Quoted: 102 Post(s)
Liked: 39
Originally Posted by pbarach View Post
When you put Audyssey in the loop, your DSD files are converted to PCM and then downsampled to 48 k samples per second in the AVR before the Audyssey and bass management circuitry gets them. The only way to stop this from happening is to set your receiver to PURE DIRECT--DSD is converted to analog without going through a PCM conversion along the way, but then you lose the use of Audyssey. On my system (Denon x4000 and Oppo 103), any advantage of going the PURE DIRECT route is outweighed by the benefits of using Audyssey despite the inevitable downsampling.
I was able once upon a time (when I had a Denon dvd player still participating in my system) to get the equivalent of PURE DIRECT DSD via DenonLink 3 to my Denon AVR. Always seemed something was missing, enough so that I'm fine with what Oppo provides in its stead. (That plus that Denon dvd player had a couple playback issues that I just didn't want to deal with any more, even though otherwise it was state of the art, when not acting up (it being the 5910ci); still have the same receiver and it's pretty much still doing fine (it being the 5805mk2, and no intention of replacing it until I have to - oh, and part of the reason I don't have to is all the nice settings the Oppos have that help overcome the mk2's shortcomings).)
fmalczewski is offline
post #24213 of 24463 Old 12-27-2016, 04:05 PM
pbarach's Avatar
Quoted: 324 Post(s)
Liked: 196
I have a denon DVD-3910 that I connected with DL3 to my previous Denon receiver. I still preferred the sound with Audyssey XT and the SVS SubEQ to the results I had with PURE DSD DIRECT.
I still have the Denon player, works fine in my headphone system with the excellent analog outputs to a Burson amp.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #24214 of 24463 Old 12-27-2016, 04:16 PM
Holiday121's Avatar
Quoted: 545 Post(s)
Liked: 147
Does the 103 have cinavia detection under the hdmi input? As if I used a external bluray player that did not have it to feed it to the input would it still upscale it to 4K?
Holiday121 is offline
post #24215 of 24463 Old 12-27-2016, 04:57 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2755 Post(s)
Liked: 1986
The 103 detects Cinavia only on optical media. Someone reported getting it on USB hard drive once; we never heard any more about that.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #24216 of 24463 Old 12-27-2016, 09:14 PM
rdgrimes's Avatar
Quoted: 2042 Post(s)
Liked: 1372
-Bill
As I recall, BDMV (AVCHD) folder structures will trip it on a HDD.
rdgrimes is offline
post #24217 of 24463 Old 12-28-2016, 05:04 AM
sheridd22's Avatar
Originally Posted by gene9p View Post
are both players powering up at the same time? The remote probably triggers both players.Try unplugging one from the receiver or better still one from power. See if that works. I believe you can set the remote to only work the one player so there is no conflict at the receivers end of two identical OPPO handshakes simultaneously. You might be able to set the receiver not to search for incoming signal as well. If you have that activated, definitely turn that feature off.
Yes, originally one remote operated both players but I set the 203 to switch 2 so now each remote only operates its respective machine.
Today planning following tests, change 203 hdmi cable, remove 203 hdmi cable from processor and run one hdmi cable from both machines and use only output from processor, so hopefully something will come to light during these tests.
sheridd22 is offline
post #24218 of 24463 Old 12-28-2016, 09:48 AM
sheridd22's Avatar
Changing 203 hdmi cable and removing 203 hdmi cable FROM PROCESSOR DIDN'T WORK.
I've found a 'temporary' solution but still have the unanswered query of exactly what's happened.
I've removed the split a/v from the 103 and just fed one hdmi cable into the PROCESSOR and use one hdmi cable from the processor to the projector.
Both Oppo players are now producing sound and vision.
I'll follow up with both Oppo and Marantz support after the holidays are over.
post #24219 of 24463 Old 12-28-2016, 05:53 PM
Holiday121's Avatar
Quoted: 545 Post(s)
Liked: 147
So I ran a older bluray player to the hdmi in on the 103 and it plays just fine but does not give me atmos. When I put the disk in the direct oppo player tray it gives me atmos.
Does the hdmi in not support master hd and atmos?
post #24220 of 24463 Old 12-28-2016, 05:56 PM
wmcclain's Avatar
Liked: 1986
No, the 103 input does not support DTS Master HD or Dolby TrueHD. The 203 does.
-Bill
post #24221 of 24463 Old 12-28-2016, 06:09 PM
Holiday121's Avatar
Quoted: 545 Post(s)
Liked: 147
Sweet thanks
post #24222 of 24463 Old 12-29-2016, 10:00 AM
Liked: 0
Has anyone experienced jitter running HDMI audio from their laptop to the Oppo?
acdc7369 is offline
post #24223 of 24463 Old 12-29-2016, 06:07 PM
sharok's Avatar
Quoted: 225 Post(s)
Liked: 69
I used wireless HDMI (Nyrius) with a max range of about 100 feet (my range was about 5 feet) from my laptop to my Denon 3808 and I kept getting audio drop out occasionally.
I quit using it.
sharok is online now
post #24224 of 24463 Old 12-29-2016, 07:08 PM
pbarach's Avatar
Quoted: 324 Post(s)
Liked: 196
I quit using it.
Not sure if that's what the OP was asking about. Basically, as far as I (a non-engineer) can understand, jitter is a sampling clock error that affects the timing of the digitized audio and allegedly "smears" the stereo image (some people find it to be measurable but inaudible). You're talking about dropouts of a radio ("GigaXTreme") signal.
pbarach is offline
post #24225 of 24463 Old 12-29-2016, 08:23 PM
sharok's Avatar
Quoted: 225 Post(s)
Liked: 69
Sorry. I think I misunderstood.
post #24226 of 24463 Old 12-30-2016, 11:21 AM
JKR1963's Avatar
Quoted: 193 Post(s)
Liked: 88
Does Oppo provide the Amazon Prime App for US based users? Since we now have Amazon Prime in Canada......I want to get it on my 103. I think some of the electronics have had the Amazon App when I buy them, but then it removed from the unit when there is an update installed.
JKR1963 is offline
post #24227 of 24463 Old 12-30-2016, 11:52 AM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1256
Nope. It does have Netflix and vudu.
Mongo171 is offline
post #24228 of 24463 Old 12-30-2016, 12:14 PM
kokishin's Avatar
Quoted: 810 Post(s)
Liked: 487
Oppo 103 does not have Amazon support baked into it.
If you want Amazon Prime Videos and Music, I recommend you get an Amazon Fire TV Stick (cheapest) or an Amazon Fire TV. I have a Fire TV Stick mostly to enjoy Amazon Prime Music although it does a good job with videos as well.
My signature:
Link: avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me.
kokishin is offline
post #24229 of 24463 Old 12-30-2016, 01:21 PM
lujan's Avatar
Quoted: 1970 Post(s)
Liked: 799
You could also buy the Roku stick for Oppo which I did and it has Amazon Video on it. Don't know if they still sell it though?
lujan
135 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is online now
post #24230 of 24463 Old 12-30-2016, 01:35 PM
kokishin's Avatar
Quoted: 810 Post(s)
Liked: 487
Roku does not support Amazon Prime Music if that's important to the OP. Mrs K and I really like Amazon Prime Music so that is why I opted for the Fire TV Stick over a Roku. One cool feature of Amazon Prime Music is that they scroll the lyrics while playing a tune. Mrs K says it reminds her of karaoke. Commercial free as well (unlike free Pandora).
tnengr likes this.
My signature:
kokishin is offline
post #24231 of 24463 Old 12-31-2016, 06:43 PM
keyoctave's Avatar
Quoted: 41 Post(s)
Liked: 32
Purchased a hardly used 103 a few weeks ago to replace my aging but still excellent Sony bdp-550. Wow! What a player. Now i have to watch my blu-rays all over again!
LG 55EG9100
Samsung 55HU8550 TH02
SEK-3500
Darbee DVP-5000S
Denon X3300W 5.2.2
Oppo BDP-103
keyoctave is offline
post #24232 of 24463 Old 01-01-2017, 11:53 AM
bguzman's Avatar
Quoted: 49 Post(s)
Liked: 518
Did the exact same thing yesterday. Purchased an "open box" BDP-103, with all accessories, from Best Buy to replace a Pioneer Elite BDP-62FD with a dead display. The Pio is a good universal player but required an unplug/plug in about once a month. Having had the BDP-83 for years I am well aware of all of the positives of this fine company and jumped at the chance to get a 103, especially when there is a big discount involved.
HT, Mitsubishi HC6500, 106" screen, Panasonic TC-P50G10, Oppo BDP-103, Toshiba A35, Panasonic LX-1000U, Pioneer Elite CLD-95, Faroudja NRS, DirecTV H21-100, PS3, Pioneer Elite SC-85, Def Tech; SM 450, CLR 2002, BP2X, Klipsch KSB 1.1(X4), Pro Sub 100, Polk PSW125
Old School, Sony PS-5500->Denon 103r->AU-320 SUT, Dual 1219->Shure M91ED, Kyocera DA-610cx, Pioneer SA-1000, Polk Monitor 10A
bguzman is offline
post #24233 of 24463 Old 01-02-2017, 06:56 AM
pbarach's Avatar
Quoted: 324 Post(s)
Liked: 196
I haven't had any trouble for some time in streaming files over WiFi from my Windows 10 PC using SMB shares (rather than an media server program). But suddenly Oppo began asking for a username and password. After some fiddling around, I discovered that some software program must have changed a setting to require a password for file sharing (the likely culprit is a Windows update or Malwarebytes, which I just installed).
If this happens to you, the solution is:
--Open Settings, then choose Network and Internet
--click on Sharing options
-- scroll to the bottom, then click the downward arrow next to All Networks
--Turn off Public folder sharing (to protect your privacy)
--Turn off password protected sharing
--click Save Changes
pbarach is offline
post #24234 of 24463 Old 01-02-2017, 10:14 AM
rdgrimes's Avatar
Liked: 1372
Ain't Windows file sharing a blast?
Keenan and pbarach like this.
rdgrimes is offline
post #24235 of 24463 Old 01-02-2017, 11:35 AM
Keenan's Avatar
Quoted: 2229 Post(s)
Liked: 2022
What was it Bob said? It's akin to black magic, requiring a live chicken to sacrifice in order to perform correctly? Something like that.
Keenan is online now
post #24236 of 24463 Old 01-02-2017, 12:01 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2446 Post(s)
Liked: 3078
^ See the Mac is a lot simpler: SMB file sharing from the Mac simply doesn't work. At all. And probably never will.
So you can stop wasting your time and just get on with your life.
--Bob
Keenan and gomo657 like this.
Bob Pariseau is online now
post #24237 of 24463 Old 01-02-2017, 02:36 PM
pbarach's Avatar
Quoted: 324 Post(s)
Liked: 196
Actually, it wasn't hard to set up SMB shares in Windows 7. Updating to Windows 10 changed the setting to require a password for file sharing. I changed it back and all was well until earlier this week, when something changed the setting again.
pbarach is offline
post #24238 of 24463 Old 01-02-2017, 02:40 PM
Keenan's Avatar
Liked: 2022
I have a combination of some Win 7 machines and a Win 10 machine and every once in awhile the Oppo asks me for login info, I usually just reboot the Oppo and maybe reboot the machine in question and everything is good again. I have no idea why that happens, but it's a minor annoyance at best.
post #24239 of 24463 Old 01-02-2017, 02:42 PM
pbarach's Avatar
Quoted: 324 Post(s)
Liked: 196
Yes, that happens to me occasionally, but the reboot of both the PC and Oppo didn't work this time--I had to (re)turn off the Windows setting to require a password for file sharing.
pbarach is offline
post #24240 of 24463 Old 01-04-2017, 07:54 AM
lancer77's Avatar
Are Oppo ever going to make the firmware released in July official?!
I know there was a problem with the initial release, but they then re-issued the EU version in October to correct it. Still Beta, however!
Is this delay a record??!
lancer77 is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
