Official OPPO BDP-103 Owner's Thread - Page 820 - AVS Forum | Home Theater Discussions And Reviews
 885Likes
post #24571 of 24580 Old 03-25-2017, 09:45 AM
J0HNNY H0PK1NS's Avatar
Quoted: 14 Post(s)
Speaker hiss/noise fixed no thanks to Oppo or Outlaw.
Since I opted to buy the Outlaw 5000 by itself instead of bundled Outlaw didn't want to give me any $ discount on a Model 975 once my issue arose. When I offered to take less of a discount and even a B-stock unit they ignored that email altogether and stopped replying. GREAT CUSTOMER SERVICE! Tempted to throw some electrical tape over the outlaw badges on my new equipment. This way I don't accidentally give them any business. I was able to find a 'like new' 975 from eBay and saved some money.
Anyway, once setup I've got no noise at all. Clear as day and the SQ and the PQ are great running 'Native' through the 975. The OSD compared to pretty much any other unit since 1995 leaves something to be desired.
Still can't complain about the setup. I love what I've got for the small living area that its in. Probably even a bit overkill in regard to wattage and the size display. Still working on hiding the last of the wiring and my wife hates the amount of equipment...but I don't care.
Thanks for all who helped me try to figure out the noise concern. I sincerely appreciate the replies.
KC-Technerd and shivaji like this.
Everything else < Kuro PLASMA
J0HNNY H0PK1NS is offline
post #24572 of 24580 Old 03-25-2017, 04:04 PM
ss3740's Avatar
Quoted: 121 Post(s)
Liked: 38
Hi
I tried researching on the old threads but I spent enough time ... I'll just ask . Today my old 103 took a dive . No Disc... Laser go bad? I tried it several times on several tried and true disc . Once it looked like it was going to go...it "loaded" for a second and then went off ( the swirly) ... I just ordered a 203 off of Crutchfield as we use it a lot . Any Ideas? I looked at Marantz's, as I have 8801 and thought it would sound good also.. but they don't have a 500 dollar DVR player. Its high dollar or nothing ..
ss3740 is offline
post #24573 of 24580 Old 03-25-2017, 04:14 PM
JazzGuyy's Avatar
Quoted: 298 Post(s)
Liked: 294
It may only mean that your laser head needs cleaning. I would suggest you call Oppo and get them to lead you through the cleaning procedure as a first step in fixing your problem.
JazzGuyy is online now
post #24574 of 24580 Old 03-25-2017, 04:15 PM
filmnut's Avatar
Quoted: 17 Post(s)
Try doing a factory reset on the 103. Failing that, if I were you I'd call Oppo customer support. If they can't fix it over the phone, they'll likely fix it on their dime.
I've heard the 203's are rather problematic. I'd try to fix the 103 first.
filmnut
filmnut is offline
post #24575 of 24580 Old 03-25-2017, 04:24 PM
JazzGuyy's Avatar
Quoted: 298 Post(s)
Liked: 294
Most of the 203 problems are being sorted out via firmware updates. Unless you have a projector, the 203 as of now with the latest beta firmware is pretty solid, with the exception of the HDMI input which still needs a little more work. With projectors, there are some 203 features that still don't give projectors the best results. Supposedly those are being worked on for a future firmware update. Dolby Vision should also be coming soon.
post #24576 of 24580 Old 03-25-2017, 04:41 PM
KC-Technerd's Avatar
Quoted: 78 Post(s)
Liked: 139
Originally Posted by ss3740 View Post
Hi
Here's some posts I'm aware regarding the same issue, including my own. If basic troubleshooting doesn't fix it, Oppo can fix it quickly as they did with mine. See the posts below for more details.
Post 24033
Post 24018
Post 23908
Post 23295
KC-Technerd is offline
post #24577 of 24580 Old 03-25-2017, 04:43 PM
ss3740's Avatar
Quoted: 121 Post(s)
Liked: 38
Thanks you guys . This is a valuable resource ...
I found the shipping invoice from A/V Science back in Jan of 2013...And the original shipping boxes . I'll send it back to Oppo. I'm thinking of a system for the garage anyway ....
ss3740 is offline
post #24578 of 24580 Unread Today, 08:08 AM
laugsbach's Avatar
Quoted: 158 Post(s)
Liked: 220
I have a 103 & 203 in my theater room and have set the remote code to "1" on the 103 & "2" on the 203. The 103 remote will power on/off both of the players but all the other buttons on both remotes work fine with their respective players...should I try different remote codes?
laugsbach is online now
post #24579 of 24580 Unread Today, 08:21 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2837 Post(s)
Liked: 2082
It shouldn't do that. I don't think so, at least. I've had three players and three remote codes at once and they did not power up or off together.
The anomaly I know of is if you cut power to the players completely. The hardware does not know its remote code until it powers up and fetches it from internal storage. Not a problem if they have been shut off but still on standby with power still connected.
So in that case any remote code will power up any player. The player wakes up, determines its remote code and responds only to the proper one thereafter. But they shouldn't power off together as you describe.
-Bill
laugsbach likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #24580 of 24580 Unread Today, 10:26 AM
laugsbach's Avatar
Quoted: 158 Post(s)
Liked: 220
That is it! I power both players completely off along with the AVR...
I got confused thinking the 103 remote was powering down the 203 also but it was only starting up the 203 while powering down the 103. I normally power on/off only one the Oppos at a time with the front panel power button after I switch on the power strip...
Thanks again Bill...
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
