Official OPPO BDP-103 Owner's Thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 860Likes
Old 11-24-2012, 05:18 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
Originally Posted by KONICA TECH View Post
When using the video processing section of the 103, can you stretch and zoom other sources?
It works for media files. I haven't tested the digital inputs.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
Old 11-24-2012, 05:48 PM
esh516's Avatar
Liked: 49
Thanks bill..
esh516 is offline
Old 11-24-2012, 06:26 PM
motoman's Avatar
Originally Posted by dolphinc View Post
103 came in today, I removed my 83 which actually made me sad because I love that player buy it is a true upgrade so all is good. I hooked it up to my Yamaha Advantage RX2000, ran the firmware update and through in The Avengers 3D and everything, worked, sounded and looked amazing. Very happy with the purchase.
Now I need to decide what to do with the 83.
My 83 has the region free kit in it so I just kept it in the rack with the new 103 for those blu-ray's that will not play in the 103 and it still gives me a backup player smile.gif Win,Win tongue.gif
motoman is offline
Old 11-24-2012, 07:07 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2263 Post(s)
Liked: 2825
-Bill
In the current firmware (1114B Public Beta), Zoom does not function for the HDMI Inputs. The Picture Adjustment settings ARE available.
OPPO has not made any statement about whether Zoom will be added to the HDMI Inputs in future firmware.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Old 11-24-2012, 07:21 PM
Read the FAQ!
Liked: 2825
Originally Posted by jboileau View Post
I have a small problem and wonder if its know. I can't recall if it as been discussed in this thread that I read since it started. Memory ain't what it used to be.
When I play a file, video with audio or audio only, there is always a second or two of audio missing. If I stop and start the file again the audio plays from the start.
Yes. This is a combination of the HDMI handshake needed to start the new audio stream and the delay in your AVR or sound processor for it to recognize the new digital input stream as properly formatted digital audio. If using Analog audio, try setting HDMI Audio OFF. If using HDMI Audio, try LPCM output instead of Bitstream (less recognition effort needed in your sound processor). Also, anything you do to improve the reliability of your HDMI connections will minimize the chances that an HDMI retry is needed during the handshake and thus also minimize his audio startup delay.
As you have discovered. If you Track Back to restart the first track, the problem doesn't happen (because the audio stream is already established).
--Bob
Old 11-24-2012, 07:29 PM
Read the FAQ!
Liked: 2825
Hi,
Just curious if there are settings worth exploring from the defaults? Sometimes defaults are meant to be a good starting point and to work with the vast majority of TVs and AVRs. But which are worth trying out to see if it makes a difference in a particuler setup. For example, is it worth changing deep color to anything else than off?
Pick an explicit output resolution (e.g., 1080p) instead of Auto. Pick an explicit HDMI Color Space setting instead of Auto. You can leave Auto for 1080p/24 and for 3D Mode.
There is no pat answer as to the best combo of HDMI Color Space and Deep Color settings. It depends on details of how your AVR and Display handle the video -- which may mean picking settings that avoid bugs in them. To start, try HDMI Color Space YCbCr 4:4:4 and Deep Color 36-bit.
If you search the BDP-93 thread for a post by me discussing "Ratatouille", Blu-ray, you'll find one suggested method of deciding which combo works "best" for your gear. If you can not spot a reason to prefer the higher Deep Color settings, then leave it OFF as that puts less bandwidth on the HDMI cable (less chance of handshake problems cropping up).
Pick an explicit choice for HDMI Audio -- either LPCM or Bitstream at your preference -- rather than Auto. If you pick LPCM, then you can leave Secondary Audio ON all the time without risk of audio quality loss. If you pick Bitstream, then only turn on Secondary Audio when you want to use a disc feature that needs it (usually a PIcture in Picture Commentary track on a Blu-ray disc).
I suggest you leave the Picture Adjustment settings at their factory default (0) values. Make all video adjustments for calibration or personal preference in your Display. Use the Picture Adjustment settings (such as Noise Reduction) if you need an adjustment that the Display can not provide.
It is wise to get familiar with a good audio and a good video calibration disc so that you can check and make sure there isn't some silly setup mistake that you've overlooked. Modern TVs have a ton of screwy settings all described as "enhancements", most all of which should be taken out and shot. Do check that you've disabled such stuff, and use the calibration discs to verify that things are basically working correctly -- i.e., that you haven't missed a setting that still needs to be shot. I recommend Spears & Munsil, Blu-ray for video and the AIX Audio Calibration, Blu-ray for audio.
--Bob
Old 11-24-2012, 07:48 PM
Read the FAQ!
Liked: 2825
Originally Posted by Greg121986 View Post
By rears, I am referring to the surround channels of my 5.1 setup. I am running the Oppo analog outputs directly into my Anthem PVA7 amplifier. NEO6 processing is set to off. All speakers are dead silent until I start playing a 2 channel audio source. As soon as I stop or pause the music, everything is dead silent. If there is 2 channel source audio playing, I get the static sound from the surrounds and center channel.
I tried running the surround speakers to a different amp channel of my amp. I did have them in the rears channel anyway, so now I have put them into the output labeled surrounds on my amp.
Playing my latest Blu Ray title, Queen Hungarian Rhapsody with 24/96 5.1 DTS-HD, there exists the same noise when running the 2 channel track, but I cannot tell if the noise exists while playing the 5.1 track. There doesn't seem to be any break in the surround channel audio so I can't tell. On my copy of The Dark Knight, the static is there when the rear channels are silent when running the 5.1 track.
If it was interference through the cables I would understand if it was always present when there was no source being fed to the amplifier. However, I do not buy the interference argument due to the fact that when there is no playback ALL channels are dead silent.
Send OPPO Tech Support an email with the details on what you've discovered, and the details of your setup/cabling. They may need to swap out your player for you. They are likely monitoring email even over the holiday weekend.
This may STILL be external Interference. When you stop playing audio the player mutes the outputs. So if it is picking up external interference of some sort, that would also be muted at that point.
The OPPO guys will likely have additional suggestions for diagnosing this, but they may just want to start with a player swap out as the fastest way to check for a player fault.
In the interim, simplify your setup as much as possible. In particular, if you have anything connected to the INPUTS of the OPPO, disconnect those and try again. That would include the HDMI Inputs and also the USB connections to hard drives. Also try disconnecting networking. Also try disconnecting the HDMI output to your TV and play a disc that doesn't require menus to function -- such as a regular CD. Basically, see if the problem exists when the ONLY connections to the OPPO are its power cord and the Analog outputs to your amp.
--Bob
Old 11-24-2012, 08:08 PM
Bryan Beckman's Avatar
I'm having difficulties configuring the 103 to talk to my Synology NAS over SMB. Even though "Save Password" is set to Yes, the 103 never remembers the password if I leave the Network section on the menu to do something else, or (obviously) if I power down the player and turn it back on again. Funny, it remembers my SMB user name and the number of characters in my password (because the correct number of masking asterisks are present), but unless I go in and manually re-enter the password myself it simply will not connect. And if I set up a user with a blank password (i.e., "guest"), the 103 won't connect at all.
I've owned the Synology device for nearly two years and kept it well maintained and up to date. Have any other Synology owners had these issues? Is login credential amnesia a known issue? I haven't seen it reported in this thread. Same with the blank password thing.
Bryan Beckman is offline
Old 11-24-2012, 08:17 PM
wmcclain's Avatar
Liked: 1921
I've reported problems with the acct/password being shown but not actually applied. It did seem to be working for a while.
-Bill
wmcclain is offline
Old 11-24-2012, 10:31 PM
CRITICALSHOT's Avatar
Quoted: 59 Post(s)
Liked: 52
If I have the Oppo connected to my preamp pro using analog outputs, can I connect a hdmi device (xbox/ps3) to the player and have it decode it (dd/dts)? I have a Lexicon DC 1 with the 8 channel analog input mod by the way.
https://www.youtube.com/watch?v=ln2iiTENgaw
"Life's tragedy is that we get old too soon and wise too late."
CRITICALSHOT is offline
Old 11-24-2012, 11:26 PM
Read the FAQ!
Liked: 2825
^ Yes. But only for the traditional, lossy DD and DTS Bitstreams. Not for TrueHD or DTS-HD MA. For those you need to use a Source device that can decode and send LPCM to the OPPO.
--Bob
CRITICALSHOT likes this.
Old 11-25-2012, 07:27 AM
obie_fl's Avatar
Liked: 33
^ I thought for some reason it did DTS-HD MA but not DD TrueHD. Why did I think that???
It is all a conspiracy to make me update my D2 to a D2v I tell you.
FWIW: My cable box seems to play pretty well with the 103's HDMI input.
obie_fl is offline
Old 11-25-2012, 07:34 AM
wmcclain's Avatar
Liked: 1921
Possibly a mix up with MKV audio codec support. DTS-HD was working from day 1 but TrueHD wasn't. It has started working in recent firmware.
-Bill
wmcclain is offline
Old 11-25-2012, 07:54 AM
obie_fl's Avatar
Liked: 33
Thanks BIll I'm sure that was it. So many options to keep tabs on I don't know how you beta guys keep it all straight.
Now if I could just push media with a Digital Media Controller server that has an iOS or Android interface I won't have to worry about the HDMI inputs. Oh yea make that server auto mount iso's too. biggrin.gif Maybe the upcoming XBMC?
obie_fl is offline
Old 11-25-2012, 08:43 AM
Brian-HD's Avatar
Quoted: 44 Post(s)
Liked: 41
Update:
Panny 500, Sony 790, Oppo 83/ se, Oppo 93/95 all work with my AVR
Anthem MRX and Oppo 103/5
Single HDMI cable with HDMI 1 LPCM works. Bitstreams does not.
Single HDMI cable with HDMI 2 LPCM and bitstreams are working fine.
Dual cables setup, HDMI 1 to display HDMI 2 to AVR LPCM and bitstreams work.
Sent: Wednesday, November 21, 2012 11:03 AM
To: Brian
Subject: RE: Message From Brian
We are aware that they do not exist on the BDP-83 and BDP-93 players. This is noted in the bug report issued for this observation. At this time we can only recommend splitting the signal or using LPCM as we have no solution to this error as we have not been able to replicate it in house with the Anthem receiver we own and our Beta Testers have not reported similar issues with their Anthem receivers. It is very possible that the issue is related to the firmware of the MRX700 which is why we had recommended contacting Anthem as they may already have beta firmware which you can try on your system.
Best Regards,
Customer Service
OPPO Digital, Inc.
2629B Terminal Blvd.
Mountain View, CA 94043
Service@oppodigital.com
Tel: 650-961-1118
Fax: 650-961-1119
________________________________________
Brian-HD is offline
Old 11-25-2012, 10:00 AM
pallepaf's Avatar
I can get Gracenote to work just fine for movie information but I can't find any MusicID functionality, i.e. get the 103 to tell me the name of a song that's currently playing in a movie. Doesn't the BDP-103 have MusicID?!
pallepaf is offline
Old 11-25-2012, 10:10 AM
ev700401's Avatar
I was ready to buy oppo 103, however in reading through this thread and elsewhere I see that iso and video_ts is not playable. Most of the comments relate to people who ripped discs to hard drives and playback off of those devices.
In my case, I'd be looking to play DVDs I created that have video_ts folders or DVD-A discs that have iso on them. I guess this would be the same whether it is a disc or a remote hard drive or server, the oppo will not play these formats even if on a physical disc?
If that is the case it is a deal breaker for me on this player.
ev700401 is offline
Old 11-25-2012, 10:13 AM
wmcclain's Avatar
Liked: 1921
No OPPO player has ever supported VIDEO_TS.
ISO was supported on the -93 for about 6 months until the studios ordered the feature removed.
I don't know of a BR player that does either. You might be happier with a media server product: http://www.avsforum.com/f/39/networking-media-servers-amp-content-streamers
-Bill
wmcclain is offline
Old 11-25-2012, 10:32 AM
ev700401's Avatar
-Bill
Thank you for your reply.
This is concerning since I play discs burned with video_ts on a fairly regular basis.
A networked server with my music and video would be a monumental shift for me right now. I still play CDs and DVDs almost exclusively over media stored on computer devices.
So Oppo is out of my consideration, which is unfortunate. Any other universal player to consider perhaps?
Thanks again.
ev700401 is offline
Old 11-25-2012, 10:38 AM
TechwizEE's Avatar
A contribution to the list of AVRs having lip sync issues with the BDP-103... I use the Emotiva UMC-1 and am having lip sync issues with the BDP-103. Setup: HDMI1 out from the Oppo to HDMI1 in on the UMC. Then HDMI out from the UMC to HDMI1 in on my TV (M3D550KD). The UMC lip sync setting for this source is set to 0ms, which causes the UMC to automatically set the lip sync delay from the HDMI handshake.
I run into significant lip sync issues with all the blurays I've played in the Oppo. Streaming HD web video from Vudu and YouTube I've not had any lip sync issues. I've also not had lip sync issues playing standard DVDs through the Oppo. I've scanned this thread and seen several other folks are having BDP-103 bluray lip sync issues with their AVRs, which is a bit comforting. I'm not the only one. Looking forward to the next official firmware release from Oppo for the 103.
TechwizEE is offline
Old 11-25-2012, 10:52 AM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
Actually the Oppos should be able to play Video_TS folders burned onto a blank DVD using appropriate software. This is essentially just a normal DVD disc. My 83SE certainly can play them. I have burned a number of public domain files onto DVD using Nero and they all worked. I have heard nothing that would indicate later models can't play such discs. What can't be played is such structures on a USB-attached drive or over a network via DLNA or SMB.
JazzGuyy is offline
Old 11-25-2012, 10:57 AM
wmcclain's Avatar
Liked: 1921
That's correct. I was confused by the requirement to support VIDEO_TS.
When VIDEO_TS or ISO are properly burned to an optical disc they are just normal DVD Video like any other disc. All players, including OPPO, should support those.
Same for BDMV and Blu-ray ISO burned to a Blu-ray disc.
-Bill
wmcclain is offline
Old 11-25-2012, 11:42 AM
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1328
-Bill
Since you brought it up, I don't think its been mentioned yet in public that TrueHD is now partially supported in MKV files with the beta FW. The player must be set to LPCM output on HDMI, bitstreaming doesn't work. Analog output also works fine.
rdgrimes is offline
Old 11-25-2012, 12:02 PM
Duck05's Avatar
Quoted: 13 Post(s)
I decided for now to leave the 103 in the bedroom and the 83/Roku in the family room main home theater setup. I prefer the Roku Netflix interface over the 103 (maybe because I am more use to it, I guess) but definitely the 103 plays networked based videos and audios far superior to the other devices I have....
Fun to read this thread and see how the issues are being addressed and Oppo's commitment to resolving them. The Beta guys are awesome and proof that this model that Oppo has adopted to allow the Beta group to help develop their products keeps them FAR FAR ahead of any competition.
Duck05 is offline
Old 11-25-2012, 12:39 PM
ev700401's Avatar
-Bill
OK, this makes me feel better. I wasn't sure if playback on a physical disc or through usb would be treated differently by the unit.
I've always just made the DVDs with the video_ts folder as a data disc via Roxio and been able to play them in every DVD player. As for the DVD-A with the iso files, maybe that remains to be seen?
Thanks for the info.
ev700401 is offline
Old 11-25-2012, 12:58 PM
Manic_D's Avatar
Quoted: 13 Post(s)
Since the beta firmware, I have to sign in every single time to get the YouTube app to load My YouTube. (which means going to the PC and entering a code) It will not remember me.
Manic_D is offline
Old 11-25-2012, 01:04 PM
pallepaf's Avatar
Could someone please help me out (see above)?
pallepaf is offline
Old 11-25-2012, 02:09 PM
John62's Avatar
I just pulled the trigger on the BDP-103. I am looking to replace a very old sony Blu-ray player and a dedicated CD player. My goal is to get both the best picture AND sound quality I can for both music and movies. I have 2 questions: 1. Can anyone tell me if it is better to use the scaler in the 103 or should I select a mode that will let my Kuro do the heavy lifting? and 2. What is is preferred connection method that will allow me to get the best sound for movies and music? Currently I have all my equipment (Cable box, blu-ray etc) running to my Denon 3808. The 3808 is set to video pass through with one HDMI cable running to my Kuro. Analog cables are used to connect my CD player to the AVR.
John62 is offline
Old 11-25-2012, 02:36 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
Is it worth sending a comment/feedback to Oppo about a missing feature that is actually useful for 7.1 soundtracks? When you discuss 5.1 sound, everything is well-understood and agreed-to. The surround channels should be placed to the side or slightly behind the main seats. But when it comes to 7.1 sound, it's like the wild west. Studios seem to coin-toss whether the 2 additional channels are placed to the side or to the back... let me explain a bit further...
If you have an amplifier that shows channel activity and there is a fly-over from back to front in a 7.1 soundtrack and you have your system wired so that the "surround" speakers are to the sides and the "surround back" speakers are in the back of the room, you will find that you have about a 50-50 chance of that flyover starting in the SIDE speakers, moving to the back, then jumping from back to front. The flyover SHOULD start in the back, move to the sides, then to the front. The only way we have to get correct channel orientation right now is to physically re-connect the pairs of surround speakers to do the right thing when there is a flyover in the sound track. Unfortuately, you'd have to preview the entire movie trying to determine which channel orientation was used for the 7.1 soundtrack BEFORE you watch the movie... that's a PAIN and a disappointment. I for one don't want to see random scenes from the movie before I watch the entire movie. And it really pisses me off that I could watch a good portion of the movie with the wrong speaker orientation just because there is no 1 standard for how studios encode 7.1 soundtracks. Widescreen Review magazine is the only magazine I'm aware of that documents the correct channel orientation for each 7.1 disc (in their online disc reviews, sometimes the print reviews mention channel orientation, sometimes not). I can go through my discs with 7.1 soundtracks and slip a little note in the cover as to what orientation should be used for that particular disc using the WSR disc review database. But I still have to physically change speaker connections to get the sound to the right channels. This only applies to native 7.1 soundtracks of course. If you expand 5.1 soundtracks to 7.1, that's always done correctly.
Oppo should be able to incorporate a channel swap feature (only if you select PCM 7.1 out, of course) that would allow owners to easily select the proper channel orientation for their 7.1 discs... and if this could be saved in persistent storage for future plays of the same disc, that would be awesome. With HARD things incorporated in the 103 like 4K upconversion, something like a solution to this 7.1 delimma should be fairly easy in comparison... maybe. The hard part is probably going to be that there may not be support for this in anybody's chip set and it would have to be some sort of custom-programmed solution.
I'm not sure why nobody else besides WSR has noticed that 7.1 soundtracks seem to have randomly selected side vs back orientations... perhaps nobody else is monitoring channel activity during playback like Gary Reber is doing. There has been at least one article in WSR where an industry insider admitted that there was no standardization of 7.1 channel orientation. It would be much easier to select 7.1 PCM output with side-side/back-back orientation or 7.1 PCM with side-back/back-side orientation than to have to re-wire the speakers to get the soundtrack to playback correctly.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
Old 11-25-2012, 02:41 PM
wmcclain's Avatar
Liked: 1921
Yes.
-Bill
wmcclain is offline
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
