What makes more expensive bluray dvd players better than cheaper ones - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-04-2012, 07:08 AM - Thread Starter
asere's Avatar
Quoted: 1376 Post(s)
Liked: 261
Like the Oppo's for example. What is different besides the connections or streaming features? Is the picture quality much better? More noticeable?
asere is online now
post #2 of 3 Old 10-04-2012, 08:12 AM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
There are a couple of existing threads that talk about higher priced player market:
http://www.avsforum.com/t/1142900/looks-the-high-end-is-avoiding-blu-ray-players-too
Here's a discussion on the topic: do all br player's produce the same quality:
http://www.avsforum.com/t/1187053/do-all-blu-ray-player-produce-same-quality
This thread deals directly with PQ comparison and the Secrets benchmark test:
http://www.avsforum.com/t/1337314/all-1080p-is-not-created-equal-a-blu-ray-player-benchmark
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
post #3 of 3 Old 10-04-2012, 10:06 AM
BillP's Avatar
Quoted: 258 Post(s)
Liked: 199
IMO, the main differences are better audio DACs (only important if you use analog audio outs), DVD upconversion, build quality, reliabilitty, customer support (all top notch with Oppo). If you just want a player for BluRay discs, Netflix/Vudu streaming, and will use digital audio outs (HDMI), then good quality reasonably priced players like Panny 220 and Sony 390 or 590 will be all you need.
BillP is offline
Reply Blu-ray Players
Sony Bdp S390 Blu Ray Disc Player , Sony Bdp S590 3d Blu Ray Disc Player
