Blu Ray Without Cinivia (s580) (s590) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 10-08-2012, 04:57 PM - Thread Starter
Paulb7873's Avatar
I have just recently discovered the whole cinivia thing and was expecting it really. I have a couple questions on finding a blu ray player with 3d playback that does not have it.
I went and picked up a sony s590 to begin with before i knew anything. the first thing i did was connect it to the internet and upgarde the firmware. It obviously had cinivia.
took it back
Compusa was selling a s580 so i picked one of them up and am testing it now. i know i can not upgrade the firmware. what setting on the blu ray would i change. i saw one that for notifications which i would want on i guess. i just dont want it to auto update.
Also, if i did nit update the firmware with the s590. would i have been ok? im not sure to much of what the differences are now but the s590 has a little prettier menu. no big deal i just want good looking blurays and netflix. my smart tv can do the rest.
THANKS PAUL
Paulb7873 is offline
post #2 of 18 Old 10-08-2012, 07:33 PM
Xylon's Avatar
Don't worry abour Cinavia unless you are "backing" up Blu-rays.
Xylon is offline
post #3 of 18 Old 10-08-2012, 10:50 PM
Rich86's Avatar
Quoted: 133 Post(s)
Liked: 67
Or ripping them to a server for playback via your blu-ray player.
I believe the S580 series got cinavia via a firmware update.
I also believe the S590 series was infected with cinavia out of the box.
The S570 series & older remain clean, as far as I know. Of course these S570 series machines are older, no longer in production and do not have all the bells and whistles some of the newer models have. But they do support streaming and 3D.
You should be able to set any of these players to not look for firmware updates.
Even if they do look, you can simply not permit it to install.
A long-time audio/video addict!
Rich86 is offline
post #4 of 18 Old 10-17-2012, 06:22 PM
sjstyle's Avatar
I have the S480 which I bought in October of last year. The original firmware was without Cinavia. The unit was without an Internet hookup for awhile, but when I did connect it again a few weeks ago, it alerted me to the newest firmware. Of course, I had the option to not upgrade. The only problem with that was none of the online streaming features worked as of that point and would not be restored until I upgraded the firmware.
Bear in mind, as I understand it, no player model introduced prior to 2012 is required to implement Cinavia technology. However, Sony is a major backer of the technology and willfully rolled it out to all of their products.
Doesn't matter to me at this point, as I do not rip Blu's or back them up in any way. Nevertheless, I don't like being forced to update my firmware if I want to use any of the added features of my player. After buying both an S350 and an S480 I can tell you I will never buy anything again with the Sony name. Not even so much as an SD card.
sjstyle is offline
post #5 of 18 Old 10-18-2012, 10:46 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 414
I recently tested Cinavia on my Sony S590 and it seems that it only blocks the disc copies. Streaming is fine. Most BD discs need a dual-layer BD-R disc to back up (unless you want to re-compress to fit into single layer). Currentlly a DL BD-R costs about $10/ea at retail store. It really is not cost efficient to make back discs. And since backup file streaming works fine, I don't think it means too much to me. Besides, not all BD discs contain Cinavia today.
Foxbat121 is online now
post #6 of 18 Old 10-18-2012, 11:11 AM
rdgrimes's Avatar
Quoted: 2396 Post(s)
Liked: 1717
Are you saying that you can play Cinavia encoded M2TS or MKV files on the Sony? Be sure to check past the 20-min mark.
Is that a Mediatek based player?
FWIW, currently only Sony BD releases are using Cinavia.
rdgrimes is online now
post #7 of 18 Old 10-18-2012, 11:36 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 414
I played a direct rip of Wrath of Titans on my Sony BX59/S590. The backup disc got audio muted pass 20-minute mark and a message displayed. The network streaming(m2ts, 1080p, DTS-HD MA) well passed 30 minutes without any of this issue.
post #8 of 18 Old 10-18-2012, 02:15 PM
rdgrimes's Avatar
Liked: 1717
Mediatek decoder in that? I assume so since the Oppos do the same thing and Sony uses Mediatek a lot. The bigger question might be if or when Sony decides to lean on Mediatek to remove that function.
You should get the same result if you wrap the title in an MKV container.
post #9 of 18 Old 10-18-2012, 02:18 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 414
I don't know.
Yes, but I can stream m2ts file without installing any 3rd party codec or software on my PC.
post #10 of 18 Old 10-19-2012, 12:29 PM
Rich86's Avatar
Quoted: 133 Post(s)
Liked: 67
Not True. The S570 and older model series remain cinavia free even after the latest firmware updates. My S350, S550 & S1000ES are on the most recent firmware, continue to perform perfectly and remain cinavia free.
Rich86 is offline
post #11 of 18 Old 10-21-2012, 12:43 AM
mariner888's Avatar
Greetings Rich86.
Would appreciate if you could kindly confirm if Sony BDP-s570 with firmware version M04.R.787 is cinavia free.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6939&mdl=BDPS570
Many thanks and best regards.
mariner888 is offline
post #12 of 18 Old 10-23-2012, 09:06 AM
Rich86's Avatar
Quoted: 133 Post(s)
Liked: 67
Originally Posted by mariner888 View Post
Greetings Rich86.
I do not have a S570 to test on, so I'm afraid I cannot personally confirm. But since the latest firmware (R.787) for the S570 is from August, 2011 - and there is no indication that it contains cinavia in the description on the Sony web-site, I expect you are safe in assuming it is cinavia free. I would definitely download it & save it in case you need it, even if you do not install it now (in case the next firmware release for the S570 DOES have cinavia).
Rich86 is offline
post #13 of 18 Old 10-23-2012, 03:53 PM
slimm's Avatar
I have the 570 and the 770 running the latest firmware. Both are Cinavia free
slimm is offline
post #14 of 18 Old 10-24-2012, 05:58 AM
mariner888's Avatar
Greetings Rich86.
Many thanks to both of you for the kind confirmation. Best regards.
post #15 of 18 Old 10-24-2012, 04:28 PM
slimm's Avatar
slimm is offline
post #16 of 18 Old 03-13-2015, 11:52 AM
MrEmoto's Avatar
Quoted: 205 Post(s)
Liked: 136
I believe that all Blu-Ray players made after February 1, 2012 had to have Cinavia on them as a condition of claiming they could play Blu-Ray.
Once can still find working older players, and sometimes one can find refurbished older players.
After those cr@p out, I don't know what we'll do. I back-up my discs and keep the factory one as reference and only play the copy. I don't want kids scratching or otherwise ruining the real one.
Panasonic VIERA TC-P55ST30 55-Inch 1080p 3D Plasma HDTV TV
Panasonic DMP-BDT360 3D Blu-ray Disc Player
Panasonic DMP-BDT215 3D Blu-ray Disc Player
Yamaha RX-V757 Receiver, Cambridge Soundworks Towers, JBL center, and assorted other speakers for 7.1
MrEmoto is offline
post #17 of 18 Old 03-13-2015, 01:40 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 414
You can just rip it and play the ripped files in many different ways without the restriction of Cinavia, including on S590 (it only detect Cinavia on discs).
post #18 of 18 Old 03-13-2015, 03:53 PM
Rich86's Avatar
Quoted: 133 Post(s)
Liked: 67
I've read in other posts that some newer cinavia enabled players are now also detecting cinavia corruption in the audio tracks from sources other than optical media. It's ok with me . . I have no need or intentions of buying a new player for many years, I expect.
Rich86 is offline
Reply Blu-ray Players
Sony Bdp S590 3d Blu Ray Disc Player
