Official OPPO BDP-105 Owner's Thread - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 512Likes
post #3061 of 14111 Old 01-20-2013, 07:20 PM
JRDiAndrea's Avatar
Originally Posted by Bob Pariseau View Post
Both of you should definitely write up the details of your cabling and settings, along with the bar-code numbers from the packaging of the discs you are using to replicate this problem, and email that to OPPO Tech Support.
Be sure to mention that it is happening with DVD-Audio discs as well.
I've not seen any indication of this being a wide-spread problem, so it may be peculiar to the particular discs you happen to be using, or to the specifics of your settings in the 105. For example whether or not Quick Start is in use. It may also be a case where the key factor is what you were playing in the 105 just prior to the problem surfacing each time. For example Pandora app, or a normal CD disc. Try to keep track of what you were last doing with the player prior to the problem and see if you can spot a pattern.
--Bob
For me this occurs with all discs.Ihave tried at least 20 and get the same results. Happens when Ifirst power my system up and after watching a bluray movie. Alway first get only 2 channels. Must then recycle the player and then plays correctly. Evrytime. At least its consistant.
JRDiAndrea is offline
post #3062 of 14111 Old 01-20-2013, 07:21 PM
Arrius's Avatar
Originally Posted by TrebleClef View Post
Sigh.
I guess I need to read your previously recommended FAQs or other threads, on how and where to configure this.
I suppose since I already have my 105 connected to my network via ethernet via it should be pretty straightforward. I'm assuming a setting somewhere in the sofrware (J River, et al)
Thanks. The help is much appreciated.
Hi TrebleClef,
I have MC18 streaming Multichannel files to the 105.
Here is a link on JRiver forum that explain a bit what settings are required. If you need more, just ask!
Best
Kami
Arrius is offline
post #3063 of 14111 Old 01-20-2013, 07:28 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1207 Post(s)
Liked: 1249
Sigh.
In J River, goto Tools -> Media Network and make sure that "Use Media Network to share this library and enable DLNA" is checked. Then under Advanced, make sure that "DLNA Server (share your media with other DLNA devices)" is checked. Then on the Oppo, under "Network" from the Home menu, the PC should show up as a DLNA server and you can then navigate to your Music, Photos, and Videos.
As an alternative, if you have a supported smart device (such as an iPhone or iPad), you can install the JRemote app and use J River as a DLNA Controller and the BDP-105 as a DLNA Renderer. This would allow you, for example, to select the music to play on your iPad (or other supported device) and have it actually play on the Oppo. This would give you a FAR better way to browse through your music than the file browser that's build into the Oppo, use playlists that you've defined in J River, etc.
All of this happens over your wired or wireless network connection - nothing to do with the USB ports.
gsr is offline
post #3064 of 14111 Old 01-20-2013, 08:46 PM
RouslanB's Avatar
Originally Posted by darkphader View Post
Like this?
Of course that's the cool part of TCP - it will re-transmit if necessary. Doesn't mean it will be necessary, nor does it mean a re-transmit will result in any real data loss.
Good performing wireless should be more than adequate for the Oppo's streaming needs.
Chris.
I am glad your WiFi is working fine. How many WiFi devices you have?
If you have 20 or 30 in close proximity the packet loss is likely to show up.
On MIT WiFi average packet loss is 2%. This type of packet loss may increase your latency and jitter and negatively impact your bandwidth especially if you are streaming from some distant location. Here is a couple of links if needed:
http://m.extremetech.com/extremetech/#!/entry/increasing-wireless-network-speed-by-1000-by-replacing-packets-with,50f8975294f4be7169354560
Another link is here:
http://fasterdata.es.net/network-tuning/tcp-issues-explained/
I prefer wired Ethernet at my place, but I am glad WiFi is working well for you
RouslanB is offline
post #3065 of 14111 Old 01-20-2013, 08:47 PM
falconsprint's Avatar
Tried the Rhapsody service today on my 105. Worked great until about 4 minute into a 10 minute track when suddenly the music skipped ahead about 4 minutes. The display time didn't jump, but the music certainly did (it was a track I was familiar with). When the music stopped the timer was in the 6 minutes out of 10 range and then switched to the next track. Since this doesn't happen when I play a track using the PC client I assume that this is an issue with the Rhapsody client on the 105. Can this be reported as a bug?
falconsprint is offline
post #3066 of 14111 Old 01-20-2013, 08:51 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3529 Post(s)
Liked: 4536
^ This is a known problem. OPPO Engineering is working the issue with Rhapsody.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #3067 of 14111 Old 01-20-2013, 10:23 PM
dmusoke's Avatar
Quoted: 369 Post(s)
Liked: 187
Originally Posted by tranle View Post
Originally Posted by dmusoke View Post
I know the distance settings in the 105 pertain to the MCH analogs but do they also work for the stereo outs?
Do you mean by setting the LF to 1ft and RF to 12ft ? In stereo there is really only 2 speakers.
No and yes, i know stereo is 2 speakers only.
Originally Posted by gnoto View Post
Originally Posted by gsr View Post
Only if they're configured as FL / FR. If they're set to the stereo downmix option, those settings don't apply.
You've tried it? Unfortunately, also in stereo downmix mode the settings are active.
The suprise is that the distance settings are active if downmix is set to stereo[biggrin.gif], contrary to what has been said earlier. Frankly, this is how it should be for i'd need the ability to set distanced for my XLR outs.
Nope, Nope Nopebiggrin.gif!
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #3068 of 14111 Old 01-21-2013, 05:29 AM
dudley07726's Avatar
Downloaded the new firmware yesterday (Main Version: BDP10X-38-1220). Went to watch a movie last night and noticed that the subwoofer was not working. It was before the firmware upgrade. Went to the speaker settings and it was off. It was definitely on before the upgrade. Do the upgrades sometimes do things like turning the sub off when it was on?
dudley07726 is offline
post #3069 of 14111 Old 01-21-2013, 05:35 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3176 Post(s)
Liked: 2461
The upgrade itself doesn't, but doing the Reset Defaults step will change many settings.
If you had a change without doing a reset, you should report that to OPPO.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #3070 of 14111 Old 01-21-2013, 05:51 AM
-Bill
I did not do a reset.
post #3071 of 14111 Old 01-21-2013, 05:58 AM
gnoto's Avatar
Originally Posted by stevepow View Post
Confirmed. However, the Trim is not active - just distance. Doesn't seem like the worst thing (unless where you sit for surround is different from stereo listening), but odd that Trim then doesn't also work. rolleyes.gif
I'm curious how you discovered this and how you tested it.
Steve
gnoto is offline
post #3072 of 14111 Old 01-21-2013, 06:37 AM
ehlarson's Avatar
Liked: 31
1) See the image I posted - no errors, therefore it really doesn't matter. If you have error prone wireless or wired you may have problems. The point is that wireless is not, in and of itself, inherently a problem.
2) UDP is only used for discovery - not a critical scenario.
1. Wireless is far more sensitive to interference. It is inherently less reliable.
2. Version 1.5 of uPnP can optionally use the RTP protocol for streaming, which normally uses UDP.
"Nature Abhors a Vacuum Tube" -  J. R. Pierce
ehlarson is offline
post #3073 of 14111 Old 01-21-2013, 08:19 AM
darkphader's Avatar
Just 10: two phones, two tablets, three Nooks, a laptop, a Panny GT50, and the Oppo.
My wireless headphones also run on the 2.4G band but do not connect to the AP. Was worried that they may cause enough interference (as they sit on top the Oppo) to be problematic, but fortunately not so.
Unlikely to happen here. I also don't see the average household with that many devices as well. If so maybe more than one AP is called for reliability.
I can understand that. My point is that good performing wireless is more than adequate for the Oppo and every end user should understand that. It doesn't mean that their wireless performance is currently good enough but in most cases it can be made so and very often for less than some properly installed drops. Self installed drops by someone without adequate knowledge and skills can also be problematic - a wire, in and of itself, does not guarantee great performance.
Chris
darkphader is offline
post #3074 of 14111 Old 01-21-2013, 09:05 AM
TrebleClef's Avatar
Originally Posted by Arrius View Post
Hi TrebleClef,
Best
Kami
Hey, that's great. I can't wait to try that out tonight!
Thank you very much.
What INPUT SOURCE do I set on the OPPO when it is receiving digital music via ethernet? FWIW, I have the 105 connected directly to my power amps.
TrebleClef is offline
post #3075 of 14111 Old 01-21-2013, 09:12 AM
TrebleClef's Avatar
OK, now I'm officially excited.
The compelling possiblity of tablet input aside, can I not control the music player from the excellent J River interface instead of the primitive OPPO presentation?
Thanks for your assistance.
post #3076 of 14111 Old 01-21-2013, 09:25 AM
obie_fl's Avatar
Liked: 33
The compeeling possiblity of tablet input aside, can I not control the music player from the excellent J River interface instead of the primitive OPPO presentation?
If you mean directly on the Oppo No.
obie_fl is offline
post #3077 of 14111 Old 01-21-2013, 09:56 AM
bgunn's Avatar
[...] We have a separate thread here on DLNA for OPPO.
-Bill
Can someone point me to this thread? Searching this thread for DLNA is unwieldy, and I havent been able to query multiple strings with any success.
If anyone would like to help me select DLNA software to stream (mostly) FLACs from a Win 7 laptop to an Oppo 105, I'd appreciate it. It's my goal to get this working today. I'd prefer freeware, but a trial on $oftware is acceptable as well (ala JRiver).
bgunn is offline
post #3078 of 14111 Old 01-21-2013, 10:19 AM
rdgrimes's Avatar
Quoted: 2343 Post(s)
Liked: 1674
Only thing you need for the 105 is very basic server function, since no transcoding is required or desired. oShare fits that description. It may be a little quirky, try to avoid making any changes to your "library" while the server is running. It will not offer the ability to "push" content, you have to "pull" it from the player.
rdgrimes is offline
post #3079 of 14111 Old 01-21-2013, 10:26 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1249
Yes, J River itself can also be the DLNA Controller and send the playback output to the Oppo. In the J River interface "Playing Now" section, your Oppo should show up as a choice. Select it and then select what you want to play and it should work.
The ability for the Oppo players to be DLNA renderers opens up a lot of options for controlling playback of your media files smile.gif.
gsr is offline
post #3080 of 14111 Old 01-21-2013, 10:28 AM
TrebleClef's Avatar
What I mean is PUSHING it to the OPPO via the rich, full featured J River GUI, versus PULLING it from the OPPO'S very rudimentary interface.
post #3081 of 14111 Old 01-21-2013, 10:31 AM
bgunn's Avatar
Originally Posted by rdgrimes View Post
[...] oShare fits that description.[...] It will not offer the ability to "push" content, you have to "pull" it from the player.
Thanks for the reply.
I guess "pushing" content is what I want to do. Otherwise I could just hook up my outboard USB drive to the Oppo and access it from there.
I'd like to have the USB drive connected to my laptop, select the FLAC I'd like to play and have it stream over my wireless network to the Oppo and have it play over the system the 105's connected to.
Sorry, I should have been more detailed in my goals.
bgunn is offline
post #3082 of 14111 Old 01-21-2013, 10:59 AM
obie_fl's Avatar
Liked: 33
Sorry misunderstood of course it can push thanks to the 105 being a DMR (Digital Media Renderer) in addition to being a DMP (Player) .
obie_fl is offline
post #3083 of 14111 Old 01-21-2013, 11:02 AM
wmcclain's Avatar
Liked: 2461
-Bill
Here: http://www.avsforum.com/t/1215071/oppo-bdp-83-dlna-upnp-thread
-Bill
wmcclain is offline
post #3084 of 14111 Old 01-21-2013, 11:11 AM
Wayne Z's Avatar
Quoted: 12 Post(s)
I received a new BDP-105 a few days ago. I just want to ask a question about hookup without reading the 3,118 posts that are on this thread already. The 105 output can be connected in four ways: (1) HDMI 1 out for video and audio; (2) HDMI 2 out which allows DSD bitstream transmission to the AVR; (3) two analog channels out in either RCA or XLR (my Integra 80.3 does not have any XLR inputs); and, (4) eight analog channels out in which the Oppo decodes DSD, DVD-A or other multi-channel formats. The question is what are the advantages of using all four of these options? For instance, is there an advantage to using both options (3) and (4), or would that be unnecessary because, for two channel CDs, the FL and FR outputs from the eight channel analog are the same as the two channel analog outputs?
Wayne Z is offline
post #3085 of 14111 Old 01-21-2013, 11:15 AM
bgunn's Avatar
Well, I'm making progress, using the 105 owners manual, I was able to get my wireless talking to the Oppo. Now I just need some software to "push" my files to the Oppo. According to the manual (bullet 2 and 3 on pg 44), I can either:
  • Use a Digital Media Renderer (DMR) which requires a "DMR-capable media server."
  • Accessing a SMB/CIFS client. This 2nd option may already be available as Microsoft Windows Network which is likely part of Win7 Enterprise (the OS I'm using).
Anyone have suggestions on how to proceed? Thanks in Advance.
bgunn is offline
post #3086 of 14111 Old 01-21-2013, 11:22 AM
wmcclain's Avatar
Liked: 2461
The FAQ lists DMC programs people have reported using: Is the player a Digital Media Renderer?
If you have a Windows system on your network then SMB is available from it. NAS appliances often have SMB and DLNA. Linux users install SAMBA for SMB.
-Bill
wmcclain is offline
post #3087 of 14111 Old 01-21-2013, 11:35 AM
bgunn's Avatar
The FAQ lists DMC programs people have reported using: Is the player a Digital Media Renderer? [...]
Funny, I started off my quest by looking at the very next section of the FAQ "What are some DLNA servers?" When I thought a DLNA server was what I needed.
I think I'll try it with Windows Media Player until I find something limiting/maddening about it, or until someone pipes up with "dont use that POC, use this instead..."
Thanks again Bill for your help. I am trying to use the reference materials out there, but people's replies really do help clarify. I promise to patiently answer questions for other noobs once I get this thing working and am comfortable with the technology.
bgunn is offline
post #3088 of 14111 Old 01-21-2013, 12:06 PM - Thread Starter
Neuromancer's Avatar
Quoted: 95 Post(s)
Liked: 360
For DLNA DMP I like oShare.
For DLNA DMR I like JRiver Media Center or Foobar2000 if you need audio only.
Neuromancer is offline
post #3089 of 14111 Old 01-21-2013, 12:08 PM
Albval's Avatar
I have a PC at 25 ft. away of the 105 connected to the oppo HDMI input in the back, also connected the dedicated stereo analog outputs to CD inputs on the receiver.
I already install the OPPO software driver in the PC.
The results are very good, but I am not sure if in this way the oppo is processing the PC signal through the stereo ES9018 DAC section, or the PC needs to be specifically connected to the (USB DAC) to perform the best dedicated 2-channel analog output.
Thanks for your help
Alberto
Albval is offline
post #3090 of 14111 Old 01-21-2013, 12:16 PM
tyroneslothrop's Avatar
I bought an external IR remote sensor and plugged it into the IR IN port of the BDP-105 as it says to do on page 24 of the manual. However, it doesn't work. I assume because of an IR frequency mismatch with the remote control. Does anyone know what brand/models of external IR remote sensor(s) are known to work with the BDP-105?
tyroneslothrop is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
