Official OPPO BDP-105 Owner's Thread - Page 142 - AVS Forum | Home Theater Discussions And Reviews
 504Likes
post #4231 of 14058 Old 03-17-2013, 01:00 AM
smaragd's Avatar
@ demusoke Try adding the covert art as an individual jpeg within the music folder, I have added cover art as a jpg named "folder.jpg" in every individual album folder containing flac or wave files and then cover art displays fine on my Oppo and Marantz receiver.
I use Mediamonkey to encode metadata and have a Synology DS211j.
smaragd is offline
post #4232 of 14058 Old 03-17-2013, 05:36 AM
BillP's Avatar
Quoted: 263 Post(s)
Liked: 202
I just joined the club and received by 105. When I hook it up this afternoon, it gets plugged into a Panamax surge suppressor unit. My AV equipment sits in a wall unit, and after setting the 105 up, it will be very difficult to get to the back again to unplug the 105 if it freezes (I noticed a few posts about it freezing, requiring one to unplug it). I could either plug it into a switched or unswitched plug in the back of the Panamax. Is there any downside to using a switched plug for the 105 so that all power is cut off to the unit when I turn off the Panamax (other than the inability to use Stand By mode, and needing to turn the Panamax on to watch a movie, which I need to do any way to turn on my amp/pre-amp)? My thinking is that turning off the Panamax could do the same thing as unplugging the 105 in case of a freeze. Thanks.
BillP is offline
post #4233 of 14058 Old 03-17-2013, 05:41 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2784 Post(s)
Liked: 2005
In the normal case you can shutdown the player with it's power off command before cutting power completely, right? I would recommend that.
Any SETUP changes you make are saved only at normal power down time.
Otherwise, I think cutting the power externally and pulling the plug would be the same thing.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #4234 of 14058 Old 03-17-2013, 05:44 AM
wmcclain's Avatar
Liked: 2005
Originally Posted by Tasdom View Post
Bill, thank you for the quick reply...
Firmware current......check
Persistent storage erased...check
Power down and back up......check
Re insert Skyfall and cross fingers............BINGO!!!!
You are a gentleman and a scholar. Thank you for the quick fix!!
This is caused by the Java program on the disc finding something in the player's Persistent Storage that confuses it. We have often suspected trainee programmers at the studios and authoring houses are at fault, but exactly what is happening is mysterious.
It is a problem less often now but still happens.
-Bill
wmcclain is offline
post #4235 of 14058 Old 03-17-2013, 07:35 AM
wse
wse's Avatar
Quoted: 2071 Post(s)
Liked: 756
Watched sky fall last night super picture, I was disapointed with the audio not as good as I have read elsewhere! The Oppo is still warming up only a few hours of listening
wse is offline
post #4236 of 14058 Old 03-17-2013, 09:13 AM
SergeantYnot's Avatar
Liked: 31
Your Oppo break-in period has nothing to do with your experience with Skyfall. As I previously stated, Skyfall is a mediocre soundtrack at best, hardly a worthy demo and filled with stock machine gun sounds and a few bass effects. A much better 007 demo would be Tomorrow Never Dies, the opening sequence alone has more explosions than all of Skyfall combined. If people are recommending the soundtrack, it will be because they liked the movie, not because it has a top audio soundtrack. Get a reference class movie in the Oppo, like Prometheus, in there asap!
SergeantYnot is offline
post #4237 of 14058 Old 03-17-2013, 10:18 AM
Jacob305's Avatar
Quoted: 81 Post(s)
Liked: 48
try the new dredd movie as well.
Jacob
Jacob305 is offline
post #4238 of 14058 Old 03-17-2013, 10:22 AM
JazzGuyy's Avatar
Quoted: 292 Post(s)
Liked: 286
Why is it that mediocre to lousy movies often have the best soundtracks? smile.gifsmile.gif
JazzGuyy is offline
post #4239 of 14058 Old 03-17-2013, 12:08 PM
jimshowalter's Avatar
Quoted: 52 Post(s)
Liked: 52
Nothing else to offer.
My system? Google for: Martin Logan 420 CLX Descent Stage Summit
jimshowalter is offline
post #4240 of 14058 Old 03-17-2013, 12:11 PM
Quoted: 52 Post(s)
Liked: 52
Originally Posted by Pokey77 View Post
Oppo: The cables are Class 1 as they are not designed to be installed in-wall".
In case you're curious what this in-wall rating is about: http://www.avsforum.com/t/1353010/do-i-have-to-use-in-wall-certified-hdmi-cables-behind-drywall#post_20827052.
post #4241 of 14058 Old 03-17-2013, 12:49 PM
wse
wse's Avatar
Liked: 756
Originally Posted by Jacob305 View Post
try the new dredd movie as well.Jacob
Yes it had great sound track really bad acting
wse is offline
post #4242 of 14058 Old 03-17-2013, 12:50 PM
BillP's Avatar
Quoted: 263 Post(s)
Liked: 202
-Bill
Thanks. Bill. Yes, I always turn everything off (CD player, etc) before turning off the Panamax. My concern is if I have the 105 plugged into an unswitched outlet, if it freezes, it would be a real pain to get to the back to unplug it. Sounds like no issues killing the power to it when not in use as long as it's turned off manually first.
BillP is offline
post #4243 of 14058 Old 03-17-2013, 12:51 PM
wse
wse's Avatar
Liked: 756
Yes I agree I had played some 2L Blu Ray music disc it was superb
wse is offline
post #4244 of 14058 Old 03-17-2013, 12:52 PM
JRDiAndrea's Avatar
QUESTION REGARDING BYPASSING THE 105 dac.
This week i will be installing a new pre-amp/DAC into my system. I have been using the 105 for CD, Bluray & streaming music files from my server on my home network via Ethernet connection. I am hoping to continue to pull files from the server using the 105 but bypass the 105 DAC sending the signal to the new preamp DAC. Has anyone done this? Any suggestions how this might be accomplished?
JRDiAndrea is offline
post #4245 of 14058 Old 03-17-2013, 01:06 PM
BillP's Avatar
Quoted: 263 Post(s)
Liked: 202
JRDiAndrea, kind of defeats the purpose of having the 105 (you could have bought the 103 instead). If I were you, I'd at least compare them to see which you like better (could be the 105's DAC is actually better).
BillP is offline
post #4246 of 14058 Old 03-17-2013, 01:08 PM
angelo's Avatar
dear sirs,
always waiting for more experiences using the 105 as a DAC connected to a pc music server with Foobar or Jriver connected by coaxial cable.
thanks a lot
angelo is offline
post #4247 of 14058 Old 03-17-2013, 01:33 PM
Kal Rubinson's Avatar
Quoted: 690 Post(s)
Liked: 471
Originally Posted by angelo View Post
dear sirs,
thanks a lot
See my May column........................depending on what you mean by coaxial cable.  wink.gif
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #4248 of 14058 Old 03-17-2013, 01:34 PM
JRDiAndrea's Avatar
The 105 is very good and capable. However what I am getting is a very serious piece. Shure, i do want to compare them....but to do so I need to figure out if I'm able to continue useing the 105 as a renderer but bypass it's DAC & send the signal to my outboard DAC.
post #4249 of 14058 Old 03-17-2013, 01:45 PM
Quoted: 690 Post(s)
Liked: 471
I'll bet you can since, supposedly, all outputs are always live.  I've been doing that with HDMI output and I will try it later with the coax.
Kal Rubinson
post #4250 of 14058 Old 03-17-2013, 01:45 PM
angelo's Avatar
I'll connect my emu 1012 by coaxial cable to the coax input of the 105's dac...
simple...
angelo is offline
post #4251 of 14058 Old 03-17-2013, 01:56 PM
JRDiAndrea's Avatar
I'm hoping so. Once I get my unit, which by the way, is the new Viola Crescendo, I will then be better able to determine the best connections. Obvious I will want to use one of the digital outs of the Oppo.....I'll be interested in learning of your experience. Will it be something we will be able to read about in an upcoming piece?
post #4252 of 14058 Old 03-17-2013, 02:00 PM
Quoted: 690 Post(s)
Liked: 471
simple...
Well, no, I have not done that (yet) but there is no reason it should not work.  S/PDIF is S/PDIF.
Kal Rubinson
post #4253 of 14058 Old 03-17-2013, 02:09 PM
Quoted: 690 Post(s)
Liked: 471
No, I will not be writing about it because I concentrate on multichannel and coax will not handle it.  However, I can test it for you by adding a coax interconnect to my current setup.  Get back to you as soon as I can.
Kal Rubinson
post #4254 of 14058 Old 03-17-2013, 02:20 PM
Paul Kile's Avatar
Yep, the dumbest movies always have lots of explosions and loud noises that show off surround systems. One notable exception is Das Boot - the sequence where they are descending below their maximum rated depth to avoid the destroyer's depth charges is amazing - the rivets popping and ricocheting around the interior make you feel like you are trapped with the crew.
Cheers,
Paul
Cheers,
Paul Kile
Paul Kile is offline
post #4255 of 14058 Old 03-17-2013, 02:28 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1087 Post(s)
Liked: 1056
Within the limitations of the output interfaces (the SPDIF outputs can't carry SACD content, for example), all outputs are always active. So you should be able to do the comparisons you're hoping to make
gsr is offline
post #4256 of 14058 Old 03-17-2013, 03:12 PM
Quoted: 690 Post(s)
Liked: 471
OK.  I just confirmed this:  I am using jRiver to "push" music to the Oppo over ethernet and the Oppo renders the audio via analog, HDMI and S/PDIF, simultaneously.  Of course, with DSF, only the first two work.
Kal Rubinson
post #4257 of 14058 Old 03-17-2013, 03:37 PM
JRDiAndrea's Avatar
Thx guys for responding. I'm excited to try myself.
post #4258 of 14058 Old 03-17-2013, 04:13 PM
dmusoke's Avatar
Quoted: 275 Post(s)
Liked: 145
So if the sound is so lousy(which may be true or not), how do you explain its recent Oscar Nomination for Sound Mixing according to an expose done recently by Home Theatre Magazine did in its Feb 2013 issue (last month).... http://www.hometheater.com/content/mix-master-sound-iskyfalli
Spin a few of sound re-recording mixer Greg P. Russell’s movies on a proper 5.1 or 7.1 system, and you’ll soon realize that this guy loves home theater. Having worked on more than 200 movies, including every Michael Bay opus since The Rock (although he freely admits “Armageddon was over the top”), Russell has crafted some of the most thrilling soundtracks of our generation. But behind even the most bombastic scenes are a lot of consideration, artistry, and know-how. At press time, he has received a total of 16 Academy Award nominations, including one for Sound Mixing for his most recent accomplishment, a masterful mulitchannel mix of the latest James Bond outing, Skyfall, directed by Sam Mendes.
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is offline
post #4259 of 14058 Old 03-17-2013, 06:42 PM
Pokey77's Avatar
I agree. Skyfall was a let down in the sould quality arena. Try Quantum of Solace. The opening scene is amazing. And as noted, Prometheus is reference class for sure in picture- and sound-quality.
Pokey77 is offline
post #4260 of 14058 Old 03-17-2013, 06:45 PM
Pokey77's Avatar
Thanks Jim.
Pokey77 is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
