Official OPPO BDP-105 Owner's Thread - Page 193 - AVS Forum | Home Theater Discussions And Reviews
 501Likes
Old 06-01-2013, 02:58 PM
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1328
Originally Posted by lordciriuz View Post
Hi!
I tried that but it didn't work. The player just doesn't show any message on the front display, not even the "Hello" message. It only lights the blue led and the soft buttons. I couldn't open the disc tray neither.
But the remote control power button works, I mean I could power on and power off the player through the remote control. Weird. I think it was a software problem, but I am not completely sure. I will follow Bob's advice and I won't upgrade the new unit until I get the confirmation from the technical support that I can do that, even with the DVD regionfree mod installed.
Ariel
You cannot flash firmware unless the player is able to boot. Only thing left to do is remove the region mod, if that's possible.
rdgrimes is offline
Old 06-01-2013, 03:10 PM
lordciriuz's Avatar
Yes. Anyway I have a new unit right now in replacement of the one with the issue. I don't really know if the mod could be easily removed or if the removal voids the dealers warranty.
Denon AVR-3313, Oppo BDP-105, Pioneer DVL-909
Technics SL-1200MK2
Dali Zensor 7, Dali Zensor 1, Dali Zensor Vokal
Focal SW700V, Monitor Audio BXFX
Optoma HD33, Furman Elite 10e i
Zotac ZBOX - PS3 - Harmony Smart
lordciriuz is offline
Old 06-01-2013, 04:52 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Only several hours of break-in, and the 105 is starting to sound better already. smile.gif Those analogue outs sounded a bit harsh to me right out of the box. I have no doubt they will only improve some more with a few more days break-in. One thing is for sure, the 105 has a lot more punch than my 93.
Brandon A. DuHamel
Founder & Editor-in-Chief
TheaterByte
GoldenBoy is offline
Old 06-01-2013, 05:45 PM
lanping09's Avatar
Originally Posted by GoldenBoy View Post
Now, for a complaint, and I see this has been discussed as well, but I've run into the issue with the player forcing the DSD output into PCM with my setup. I have the player attached via HDMI 1 and RCA Stereo Out L/R (on the AVR's CD input) to an Onkyo TX-NR818 and even with the SACD audio output set to DSD, it forces PCM unless I turn off HDMI audio output. rolleyes.gif Too many additional steps to remember when switching between BD, SACD, and Multichannel SACD.
EDIT: Let me add that the Onkyo 818 does in fact support input of a DSD bitstream, so I don't know why the Oppo would be forcing DSD to PCM with the HDMI audio turned on with this AVR.
Try HDMI 2 Out from OPPO. HDMI 1 Out only allows DSD->PCM on BDP-103/5.
lanping09 is offline
Old 06-01-2013, 06:22 PM
music first's Avatar
Quoted: 29 Post(s)
Originally Posted by Bob Pariseau View Post
That could be a symptom that your settings memory is failing. It's a pretty rare failure, but it happens.
Try this: Set the 105 to Energy Efficient instead of Quick Start. Check that your other settings are good.
Now power down the player normally -- do NOT simply cut off its power source. Settings are saved during the power down cycle.
Once the player is powered off, pull its power plug for about 10 seconds.
Plug back in and power up. Are your settings screwed up? If so, then your player needs warranty service. Give OPPO Tech Support a call.
Even if it passes this test, if you have another instance of the settings resetting, then call OPPO anyway and describe the repeated event. They'll get you fixed up.
--Bob
Bob,
Thank you. I tried that and the settings held. Seems to be OK now. I'll keep my fingers crossed. Thanks again.
E
Main system: Sony 930D 65 inch, Receiver - Yamaha RX-A3060, Front speakers - Ascend Acoustics towers with RAAL tweeters and a custom Ascend horizon center channel. Source - Oppo BDP105 and Lenova Windows 10 PC with Jriver media server. Surrounds - forthcoming..
music first is offline
Old 06-01-2013, 09:40 PM
athanikp's Avatar
Thanks Bob.
I am experiencing a low vocal and have set front L/R at -2dB and the Centre to +3db. Using the balanced connection will make the matters worse then. Better to stick with 7 channel analogue output then.
athanikp is offline
Old 06-01-2013, 09:42 PM
athanikp's Avatar
Originally Posted by jima4a View Post
The XPA5 is not a balanced amp so for short cable runs RCA is usually better.
The XPA5 is a balanced amp. It takes XLR connections and has a switch to change between Balanced and Unbalanced input.
athanikp is offline
Old 06-01-2013, 11:31 PM
Process53's Avatar
Liked: 24
If you use analog out always check your test tones in the speaker configuration. You may hear the rear speaker coming out of the rear and out of the front at the same time. In other words it is screwed up. Oppo has confirmed that this is a problem and they are working on a fix.
Oppo BDP-105 Player
Musical Paradise MP-301 MK3 Tube Amp x 2
Paradigm Studio 60 v.2 x 4 Speakers
Sony Bravia KDL-55W800C TV
Process53 is offline
Old 06-02-2013, 06:32 AM
Holzohr's Avatar
I'm sure this has been gone over a million times, but is cue file support only available from USB storage? I can't seem to see any cue files from my NAS. Also, I'm guessing there's no word on Oppo updating this thing to support DSD over DLNA either?
Oppo supports CUE files only via SMB, not via DLNA. When you look for DSD streaming, maybe this thread could be interesting for you. Or this Oppo and Cue Files
At the moment, I have an USB drive connected to the Oppo, with all my DSD files. Together with the MediaControlHD app it is the best way for DSD playback (imho).
DSD output works via HDMI Out 2 only.
Holzohr is offline
Old 06-02-2013, 08:57 AM
Oppo Beta Group
RichB's Avatar
Quoted: 869 Post(s)
Liked: 565
It has balanced inputs but I do not think it is fully balanced internally.
Neither is my Parasound, but I still use the balanced connections because they have reduced some noise at my speakers.
Mono price has affordable XLR cables so it not an expensive experiment.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
Old 06-02-2013, 12:30 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
which Parasound amp? Halo?
WestCoastD is online now
Old 06-02-2013, 03:24 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Too bad I only have an iPad 1, which Oppo doesn't support with their IOS 6-only Media Control App.
Ah, i see, I must have overlooked that in the manual. Not that I need DSD bitstreaming, the Onkyo 818 only converts it to PCM internally anyway, and sounds like rubbish doing it as well. It's just that it's a a bit of a nuisance having to change to separate settings every time I want to listen to stereo SACD via the analogue outs, and then have to remember to turn the HDMI back on and switch the AVR back to the HDMI input the Oppo is connected to as well.
Brandon A. DuHamel
TheaterByte
Old 06-02-2013, 03:31 PM
tranle's Avatar
Quoted: 65 Post(s)
Thanks Bob.
I had that symptom at one time. And I had one of the HDMI output going directly to my TV and the other one going video processor Anthem D2. And somehow my TV told the Oppo that it had only 2 speakers (that I am not using) and the oppo will either remove the center channel or attenuate it a lot (I could barely hear the dialog).
My solution was to remove the HDMI connection to the TV, do a factory reset, put back my settings and everything is fine now.
tranle is online now
Old 06-02-2013, 05:09 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
In reply to Holzohr, again, I logged into my NAS' SMB shares and accessed some DSD files stored on there and the 105 played them without issue. :-)
Thanks again.
EDIT: Well, there was one issue, the display doesn't update at all, it just stays stuck on the very first track I selected and also only shows the actual file names and not the meta data.
Brandon A. DuHamel
TheaterByte
Old 06-02-2013, 05:35 PM
Oppo Beta Group
RichB's Avatar
Quoted: 869 Post(s)
Liked: 565
Halo A51.
- Rich
RichB is online now
Old 06-02-2013, 06:56 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Yes, thanks, I didn't see your reply before Holzohr, who also gave the same response. I don't really need DSD out over HDMI, I just need the player NOT to force the playback into PCM just because it is attached to the AVR and set to bitstream. My solution is to simply turn off video out on HDMI 1 when I want to listen to SACDs on the analogue outs, because I prefer to have HDMI doing the deinterlacing on 1080i BDs and I don't want the added complication of running multiple cables either. Either way, it's a hassle I suppose.
Brandon A. DuHamel
TheaterByte
Old 06-03-2013, 08:49 AM
jd_alpha's Avatar
Hi All:
I'm running the stereo analogue outs on the Oppo105 to an Elite SC-57 AVR (to the "CD" RCA jacks). The AVR is flashing an "OVER" message that the output of the 105 is too "high" and that I should enable signal attenuation in the AVR. But the attenuation can't be activated in the AVR in the preferred "Analogue Direct" listening mode!
Is there a way to lower/attenuate the analogue stereo output from within the 105? Would swithcing the volume to variable from fixed and trying to lower the Oppo's volume that way fix the problem?
JD
jd_alpha is offline
Old 06-03-2013, 09:21 AM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
Originally Posted by jd_alpha View Post
Hi All:
JD
First, I am surprised that the AVR has any overload issued on this analog input if it is not re-digitizing the signal.  From your comment about "Analogue Direct," I would expect that no digitization should be involved but you should check for that.
Second, the answer is "yes" that making the VC variable will permit attenuation of the output.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 06-03-2013, 10:23 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Can anyone explain why Oppo has not bothered to "sort" their files/directories after reading them from either a network or usb drive? I would have thought that would be the first thing that should be implemented once the data is read from either source. Oppo has already updated their firmware a handful of times, but doesn't seem to treat sorting as a high priority. Gosh, it sure is a pain!! The strange thing is whatever Oppo does before displaying the files/directories on the screen, is very consistent....it's the same ordering, but just not sorted! frown.gif I know using a media server application, like JRiver, would solve all this, but I just don't like leaving my laptop on all day long, just to run a server application so I can run JRiver, and push audio files to the 105. I guess not enough users have brought this to Oppo's attention, as that is the only reason I can come up with why they haven't wanted to correct this trivial, yet very much needed feature.
DanF8500 is offline
Old 06-03-2013, 11:50 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
Don't know. It's possible they need an API hook from Mediatek that has not appeared yet. Years ago we had the same situation on sorting files on local storage, fixed eventually.
-Bill
DanF8500 likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 06-03-2013, 12:26 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
-Bill
I thought the Mediatek chip was only concerned with decoding the video signal. ?? I would think file/directory sorting would be handled internally, by the Oppo player, or the tcp/serial interface protocols.
DanF8500 is offline
Old 06-03-2013, 12:30 PM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
The MediaTek decoder is the entire brains of the player. So all functionality, from receiving and interpreting remote control commands to indexing files and de-interlacing and scaling DVD media, is handled by the MediaTek solution.
Neuromancer is offline
Old 06-03-2013, 02:27 PM
pvanosta's Avatar
Quoted: 40 Post(s)
Solved my Wifi (and hi-rez streaming) issues.
1. My Wifi extender (the one generating a 100% signal that the Oppo couldn't log on to) has an ethernet out, which I connected to the ethernet jack on the Oppo
2. Not only does the Oppo now play 24/96, but it even plays 24/192 files streamed from my DLNA server downstairs.
I also discovered the joys of playing DSD files from a usb drive.
Now I'm going to take a closer look at the Ipad app.
If I can get that OPPO Ipad app to access/browse/play my files from my DLNA app (Twonky) (similar to what I used to get on the Ipad app that came with the Cambridge Audio Stream Magic 6), I will be a totally happy camper.
pvanosta is offline
Old 06-03-2013, 03:29 PM
HowardV's Avatar
Quoted: 65 Post(s)
Liked: 52
I was at the Newport Beach audio show last weekend and saw the Dirac Live Room Correction Suite demo in one of the rooms. Unfortunately I didn't have time to stick around and ask my questions. But I did listen and it sounded impressive (and I don't generally care for room correction).
Dirac offers software that you install on your home theater computer (PC or Mac). Along with a Microphone, it measures your rooms acoustics (just like any other room correction device). Per their web page, all music "coming out of your PC" will be corrected. Here is a link:
http://www.dirac.se/en/consumer-products/dirac-rcs.aspx
I have my home computer (dedicated HTC) connected to my Oppo 105 via A-synch USB. Will Dirac be able to have an effect or is it bypassed? I play music through Foobar and Spotify on a Windows 7 PC. And I also have a laptop that can play Blu-Ray movies and has HDMI output. Could I connect my laptop's HDMI output to the Oppo's HDMI input to play a Blu-Ray movie through my computer and use Dirac?
Dirac has a 14 day free trial. I think it may be fun to get a microphone and start testing. But just wanted to know if anyone has tried this before.
P.S. - One major downfall of this software is that it can handle files up to 24/96. No 192Khz sampling.
Oppo BDP-105 Blu-Ray
Spectron Premiere MKII 7 Channel Class D Amp (500w x 7)
2 Anthony Gallo Reference SA Amps
5 Anthony Gallo Reference 3.5 Speakers
Sunfire Super JR Subwoofer
Sony Z2 Series laptop as dedicated HTPC
HowardV is offline
Old 06-03-2013, 04:10 PM
pvanosta's Avatar
Quoted: 40 Post(s)
@HowardV :
I just read this on the Dirac web site:
"The Dirac Live room calibration tool requires a microphone for the acoustic measurements and works with standard sound cards and USB DAC:s. It is simple to use and requires no specialist knowledge. You take the measurements, the software figures out the rest! If you are an advanced user, you can however edit the target frequency response to your own liking."
If you feed a usb signal from your Dirac-powered laptop to your Oppo's USB asynchronous input, it (the OPPO) functions like a USB DAC for all intents and purposes.
So the short answer is that it should work with the Oppo, playing music from your laptop.
The other question (Blu-ray from laptop HDMI out to OPPO HDMI in) you'll have to try and let us know smile.gif
pvanosta is offline
Old 06-03-2013, 04:18 PM
beatmachine's Avatar
oh boy...All was fine with the 105. UNTIL latest FW upgrade.. dropped frames on DVR (slow and sluggish- live sports almost look like jittery film) SEVERE lipsync even with Netflix content.
Constant lockups navigating through Netflix. Only a power down/off solves the issue for 20 min max. All was fine with previous FW , however i don't think I can downgrade a fw.
Ideas?
thanks guys
beatmachine is offline
Old 06-03-2013, 04:22 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
Ideas?
thanks guys
You can downgrade if it's beta firmware. Otherwise no.
JazzGuyy is offline
pvanosta's Avatar
Quoted: 40 Post(s)
@beatmachine
Not to hijack your posting, but what FW upgrade did you install and when and what were the supposed fixes in that FW update please?
pvanosta is offline
Old 06-03-2013, 04:25 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2260 Post(s)
Liked: 2824
Ideas?
thanks guys
Which firmware are you talking about? If you've just installed the "Official" 0422 firmware, then I recommend you download and install the Public Beta 0522B firmware which will fix most of these issues -- the player lockups at the end of viewing in Netflix are stil being worked on.
The Public Beta firmware does not install over the network. If you have a US model player, download it from the OPPO Digital web site for installation from a USB stick or hard drive. If you have a European model player, download it from the OPPO UK web site.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
Old 06-03-2013, 04:26 PM
Read the FAQ!
Liked: 2824
Originally Posted by pvanosta View Post
@beatmachine
Check the first post of the BDP-103 Owner's Thread for a list of firmware versions and release notes.
--Bob
Oppo Bdp 105 Blu Ray Player
