Official OPPO BDP-105 Owner's Thread - Page 238 - AVS Forum | Home Theater Discussions And Reviews
 501Likes
Old 09-07-2013, 03:05 PM
rdgrimes's Avatar
Quoted: 1997 Post(s)
Liked: 1329
Originally Posted by audiman View Post
I have no sound from my DTS MKV ripped files. Only video.
I was just playing an MKV with DTS-MA audio and it was fine. If you're using one of the earlier DTS codecs like lossy 96/24 or a couple others, the player will not decode those but should be able to bitstream them.
rdgrimes is offline
Old 09-07-2013, 03:17 PM
gelly's Avatar
Originally Posted by DanF8500 View Post
The 105's dacs are being "utilized" for every audio file/track the 105 processes. You are receiving the "benefits" of the dacs if you use any of the 105's analog outputs.
Thanks. Well I have the hard drive connected using USB. However I can only listen if my AVR is selected to BD(HDMI). I have analog out from oppo into my AVR via CD input.. However when I select this input on my AVR no sound is coming out.
gelly is offline
Old 09-07-2013, 04:27 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Gelly, I know of a few others who had this problem also. Has to be something in your AVR not set up properly. What AVR do you have? You might have to assign an input as active before you can use it....also, if you're using the 105's analog outs, make sure the 105's volume is not set to 0.
DanF8500 is offline
Old 09-07-2013, 05:50 PM
gelly's Avatar
thanks I'm using a marantz sr7005. Do you think i need to change a setting on my AVR?
gelly is offline
Old 09-07-2013, 06:08 PM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
If you are using your AVR for MV, you should set the OPPO's Volume to Fixed and 100. Make sure to turn down the AVR's MV before doing this.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is online now
Old 09-07-2013, 06:20 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1059 Post(s)
Liked: 987
If you're not getting any sound, then yes. The CD input on your Marantz is most likely configured by default to use either one of the HDMI or (more likely) one of the other digital audio inputs rather than the analog inputs. The first thing I would do is look at the manual. If you can't figure it out from reading the manual, I would suggest asking a question in the thread for your SR7005 - I'm sure there's a thread for it in the AVS receivers forum and those folks will know your receiver better than most of us in the Oppo threads.
gsr is online now
Old 09-08-2013, 12:13 PM
tranle's Avatar
Quoted: 65 Post(s)
DD MKV ripped files are playing fine. I have "unstoppable" in both DTS and DD and only the DD has sound.
Anyone can try this or is it a known issue? played fine on the oppo-95
When this happen, I usually check the following
  • Use the program mediainfo to check if you have really included an audio stream in your mkv and what type it is.
  • If there is really an audio stream, check with a headphone plugin directly into the 105 to check if the 105 can decode the audio stream.
  • If the headphone work, do a factory reset, if your avr cannot decode the audio, check if the 105 pluged in to a tv (no avr) to see if it works.
tranle is offline
Old 09-08-2013, 02:00 PM
audiman's Avatar
Quoted: 13 Post(s)
Liked: 26
here is the mediainfo: very strange to see only 2 channels in dts
Audio
Menu ID : 1 (0x1)
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Codec ID : 128
Duration : 1h 38mn
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 1.06 GiB (19%)
audiman is offline
Old 09-08-2013, 02:02 PM
rdgrimes's Avatar
Liked: 1329
Audio
Menu ID : 1 (0x1)
Format : PCM
Codec ID : 128
Duration : 1h 38mn
Bit depth : 16 bits
It's not DTS, its PCM.
rdgrimes is offline
Old 09-09-2013, 09:27 AM
tdo722's Avatar
Can the bdp-105 wake on lan? Oppo android remote app is useless to turn it on in standby mode.
tdo722 is offline
Old 09-09-2013, 09:33 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 987
The BDP-105 needs to be in "quick start" mode in order to be turned on over the network. When it's in "energy efficient" mode, the network card is turned off when it's in standby mode.
lanping09 and tdo722 like this.
gsr is online now
Old 09-09-2013, 10:53 AM
tdo722's Avatar
Thank you very much. Also do you know the power output for quick start mode? The manual said 0.5W for "energy efficient" mode but said none for "quick start" mode.
tdo722 is offline
Old 09-09-2013, 11:38 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
If there's no difference between normal power on and quick start, it looks like it could be 55 watts.
DanF8500 is offline
Old 09-09-2013, 11:40 AM - Thread Starter
Neuromancer's Avatar
Quoted: 81 Post(s)
Liked: 287
Something like 7watts.
Neuromancer is offline
Old 09-09-2013, 01:02 PM
tdo722's Avatar
Okay gents, I set it to "quick start" mode but I think something is wrong with my killawatt EZ p3 unit. It shows 0.00 amp, 0.00 watt. killawatt ez p3 unit is running for 5 minutes so I will check back when it clocked in at 60 minutes of running time and check the kwh to see if we got any movement. Very strange because I checked my laptop and it clocked in at around 125 watt with a 24" lcd and a router and some other peripherals like usb hdd, kb, and mouse and a usb hub.
Update: I figured out why my killawatt unit did not report the correct watt. It appears that if you unplug the 105 then plug it back in, you would need to turn it on then turn it off for the quick start mode to operate. After all said and done, it reported 6 watts or 0.09 amp. That is equivalent to $5.36 a year out the window if I leave it on "quick start" mode. $5.36 is a very cheap price for convenient and to complete dump the original remote. All in all, now I can control the TV, bdp-105 and my laptop from my phone. My amp is auto on/off. I have no pre-amp. Centrally managed is what I love.
lanping09 likes this.
tdo722 is offline
Old 09-09-2013, 01:26 PM
audiman's Avatar
Quoted: 13 Post(s)
Liked: 26
the FPD displayed it as "dts". And i have a "no sound" from the pre-amp's FPD.
when i switch to pcm, the pre-amp shows all 5 channels but still no sound.
audiman is offline
Old 09-09-2013, 07:03 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
How is the Oppo connected? If you are using analog connections, is your processor set to handle analog input?
JazzGuyy is offline
Old 09-09-2013, 07:24 PM
audiman's Avatar
Quoted: 13 Post(s)
Liked: 26
set to handle both 7.1 and hdmi. I have no sound from both and no sound from the headphones.
audiman is offline
Old 09-09-2013, 08:07 PM
tranle's Avatar
Quoted: 65 Post(s)
If you do not have any sound from the headphone it mean that the oppo cannot decode the audio stream on your mkv.
I do not have at hand any mkv with PCM sound so I don't know. I do not recall if there was a case were PCM inside an mkv was not recognized.
You should open a case with oppo support and send them your mkv so they can check it. Or if you have a command line to rebuild one like you have that would also work. Also double check that the same mkv has no problem with play with something like vlc on your pc.
tranle is offline
Old 09-09-2013, 09:16 PM
rdgrimes's Avatar
Liked: 1329
Format : PCM
I may be wrong, but I think that's a flavor of LPCM that's unsupported. Your encode settings need to be changed to output your desired audio.
rdgrimes is offline
Old 09-10-2013, 07:12 AM
TKO1's Avatar
Liked: 65
Quick question --- what device are people choosing for the BDP-105 in the Logitech Harmony device database? I am experiencing some problems with the current device I chose with the powering on/off activities and hoping to resolve it with my Harmony 700.
Thanks in advance.
Cheers.
TKO1 is offline
Old 09-10-2013, 08:28 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 987
Thanks in advance.
Cheers.
For the codes that are common (which would include power on and power off), the BDP-83, BDP-93/95, and BDP-103/105 all use the same IR codes, so it really shouldn't matter which of these Oppo models you select on the Harmony. The only codes that are different are the new ones specific to the BDP-103/105, such as the Input and Netflix buttons.
gsr is online now
Old 09-10-2013, 09:19 AM
TKO1's Avatar
Liked: 65
I understand that. I just want to know which one of the user provided Oppo BDP-105s in the Logitech Harmony Database seems to have the best set of commands. The problem I am having is related to two activities using the BDP (one for watch movie, the other for Apple TV on Input 3) and switching between the two shuts off the Oppo due to the Power Toggle sequence which gets sent when AppleTV starts even though I have told the remote to leave the Oppo powered off when switching to a different activity.
Cheers.
TKO1 is offline
Old 09-10-2013, 09:29 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 987
Cheers.
I don't use a Logitech Harmony, so I can only give you general advise... But you should be selecting a BDP-105 code set that has discrete Power On / Power Off commands. If such a set doesn't exist, then select a BDP-103 code set that does. If the BDP-103 code sets don't, then select a BDP-93/BDP-95 or BDP-83 code set. If power on / power off commands are present, I would hope the Harmony would be smart enough to use those instead of the Power Toggle command. The point is that it isn't important that you specifically select the BDP-105 as the remote for the BDP-103 is identical and the remote for the older players has only very minor differences.
gsr is online now
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2263 Post(s)
Liked: 2825
^ You need to add the OPPO as an additional device in the set of devices for the Watch AppleTV activity. Then the Logitech will keep it powered on.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
Old 09-10-2013, 09:42 AM
Jacob305's Avatar
Quoted: 80 Post(s)
Liked: 48
my recent update on my harmony touch included the 103 code instead of the 93. it listed netflix, 3d and vudu, among other listings.
Jacob
Jacob305 is offline
Old 09-10-2013, 09:49 AM
TKO1's Avatar
Liked: 65
--Bob
I have already. If I start with everything powered off and choose either of the two activities I have that use the BDP-105 (Watch Blu-Ray or Watch Apple TV) everything works perfectly. But if I switch between them (e.g. listen to an SACD then deciding to listen to some music from the AppleTV connected on Input 3/HDMI) the Harmony sends the Power Toggle as it begins the other activity which turns it off because it is now on.
So that's why I asked for the "best" Oppo BDP-105 entry in the database hoping that maybe that one of them has the discrete codes for Power On and Power Off which I could use for the sequence in powering on etc. instead of Power Toggle but I also need to have the Input command to be able to select Input 3 or Input 1 which some of the older models didn't have.
Cheers.
TKO1 is offline
Old 09-10-2013, 09:54 AM
Read the FAQ!
Liked: 2825
^ Ah, OK. That just means you need to adjust the OPPO Device's definition for Power to use its two commands for Power ON and Power OFF instead of the single Power Toggle command. The standard database entry for the OPPO has all 3.
--Bob
Old 09-10-2013, 10:18 AM
TKO1's Avatar
Liked: 65
--Bob
And which one is that? Under what Device Category?
Cheers.
TKO1 is offline
Old 09-10-2013, 11:10 AM
Read the FAQ!
Liked: 2825
^ I haven't checked recently but there should be an OPPO BDP-105 under their Blu-ray Players category. Is that not the case?
My point was, the default setup in their database may be to use PowerToggle. You just change that to use PowerON and PowerOFF, which are also defined -- just not used by default.
--Bob
Oppo Bdp 105 Blu Ray Player
