Official OPPO BDP-105 Owner's Thread - Page 265 - AVS Forum | Home Theater Discussions And Reviews
 514Likes
post #7921 of 14120 Old 12-05-2013, 04:57 PM
BillJulyan's Avatar
Quoted: 26 Post(s)
Liked: 47
Originally Posted by Neuromancer View Post
Release date: December 5, 2013.
Category: Latest Official Release
Main Version: BDP10X-67-1204
Loader Version: 6U1000 or 7B1300 (BDP-103), 7B1300 (BDP-105, BDP-103D)
Sub Version: MCU103-05-0916 (BDP-103), MCU105-04-1113 (BDP-105), , MCU13D-01-0618 (BDP-103D), DB10X 131030 (BDP-103D)
19. Resolved a compatibility issue with JRiver Media Center software. Customers reported that after installing the latest Public Beta firmware BDP10X-67-1220B, they could no longer see the JRiver's DLNA server in the list of My Network. This issue has been resolved in the official release.
It works!
lanping09 likes this.
Bill Julyan
BillJulyan is offline
post #7922 of 14120 Old 12-05-2013, 05:00 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3570 Post(s)
Liked: 4648
eazyz,
^^ Also make sure you haven't accidentally enabled audio on your TV's built in speakers. Turning on the TV speakers in addition to normal Surround speakers usually results in a timing mismatch that can sound like an echoey room.
And if you are using Analog audio output with the Dedicated Stereo L/R jacks wired in lieu of the LF/RF pair from the multi-channel set, also check you have Stereo Signal set to FRONT LEFT/RIGHT.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #7923 of 14120 Old 12-05-2013, 05:42 PM
wse
wse's Avatar
Quoted: 2201 Post(s)
Liked: 805
Yes just in time :) OPPO rules I wish other manufacturers were that diligent!
wse is offline
post #7924 of 14120 Old 12-06-2013, 08:02 AM
gelly's Avatar
Hello,
I'm about to install the new update. Is there a easy way to copy my previous settings? Thanks
gelly is offline
post #7925 of 14120 Old 12-06-2013, 08:06 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3236 Post(s)
Liked: 2519
Originally Posted by gelly View Post
Hello,
Were you running the most recent beta? If so, the settings are retained from this point forward.
If not: they are not retained when you do the required Reset Factory Default. You can print out the OPPO BDP-103 Settings Checklist and mark it up with your local values.
This won't be necessary after the first time.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #7926 of 14120 Old 12-06-2013, 09:37 AM
thomaske's Avatar
I'm sorry if this has already been answered, but I just got my BDP-105. I want to use it as the A/V hub, feeding the TV via HDMI and the amp via 2-channel analog. I feed my DVR into the HDMI Input Back, so I don't have to change inputs on the TV. So far, I love everything about it...
EXCEPT
About 50 times a day (literally), the audio and video get out of sync with each other when using the DVR. I have read other comments about this happening, and saw in the July firmware release that there was a fix for a bug that occurs when switching audio formats that leads to this sync issue. I am assuming I'm on an older firmware rev than July, and that this is what I'm experiencing. My questions are:
1) Are there other issues that have been found over time that lead to the sync issues with inputs from HDMI being processed through the Oppo?
2) Does the July firmware upgrade get rid of this issue?
thomaske is offline
post #7927 of 14120 Old 12-06-2013, 11:28 AM
Lonely Raven's Avatar
Quoted: 34 Post(s)
Liked: 42
There was a firmware update a couple days ago, I'd check that out and see if that helps.
Lonely Raven is offline
post #7928 of 14120 Old 12-06-2013, 01:03 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
Am I too young to claim Alzheimer's?
I just downloaded the new FW upgrade from the internet. Did the Reset Factory Defaults > Erase Settings. Turned the power off, turned back on again.
Now, I can't connect back to the internet. Reinstalled FW from USB stick. Confirmed correct FW loaded. Still can not connect to internet.
Rebooted modem and router. Still no joy. DNS1 set to 8.8.8.8.
What am I missing?
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #7929 of 14120 Old 12-06-2013, 01:11 PM
wmcclain's Avatar
Liked: 2519
What am I missing?
It defaults to Ethernet. Had you been using Wireless before? DHCP or manual settings?
-Bill
post #7930 of 14120 Old 12-06-2013, 01:19 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
-Bill
Been wireless since I bought it. That's how I downloaded the FW upgrade today. I tried both DHCP and manual. Can't get either to work.
Mongo171 is offline
post #7931 of 14120 Old 12-06-2013, 01:27 PM
wmcclain's Avatar
Liked: 2519
Ok, but did you set Network Setup -> Internet Connection to Wireless ?
-Bill
post #7932 of 14120 Old 12-06-2013, 01:35 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
-Bill
Yes I did. I set it up and did get a connection.
I also went to Wireless Setting and it connected.
When I go to Connection Test, it doesn't connect.
Mongo171 is offline
post #7933 of 14120 Old 12-06-2013, 01:40 PM
wmcclain's Avatar
Liked: 2519
So you have ethernet connected and are getting good IP values back from the DHCP server?
You are getting good IP values from the DHCP server over wireless?
Is that the only thing that is failing?
-Bill
post #7934 of 14120 Old 12-06-2013, 02:08 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
-Bill
I don't have Ethernet connected. Router is upstairs, 105 is downstairs. I got good IP values from the router. I did get good IP values from both DHCP and manual over wireless.
That is the only thing I know that is failing right now.
Mongo171 is offline
post #7935 of 14120 Old 12-06-2013, 02:12 PM
wmcclain's Avatar
Liked: 2519
Connection Test goes all the way to OPPO's servers. If they are down the test will fail. If it still fails tomorrow then we should verify that Connection Test works for others and explore further.
-Bill
post #7936 of 14120 Old 12-06-2013, 02:24 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
-Bill
Sounds good, Bill. Thank you for your help.
Mongo171 is offline
post #7937 of 14120 Old 12-06-2013, 03:22 PM
Vocalpoint's Avatar
So - what's the vibe on this new firmware? Kinda scares the crap out of me - knowing that I can "never go back" if something goes south.
Can anyone comment on whether or not it's worth it and why. Seems like it is - but that could be just me...
Appreciate any "intel" from the field.
VP
Vocalpoint is offline
post #7938 of 14120 Old 12-06-2013, 03:28 PM
wmcclain's Avatar
Liked: 2519
VP
For your safety, Federal law prohibits us from telling you how great this firmware is.
The is official production firmware. If you bought a new player this is what would be installed (as soon as inventory moves through).
On the other hand: if you are happy with what you have, why rush? But: If you have trouble the first thing we will say is "upgrade to current firmware".
-Bill
post #7939 of 14120 Old 12-06-2013, 03:30 PM - Thread Starter
Neuromancer's Avatar
Quoted: 95 Post(s)
Liked: 360
The only problem people had with the previous Beta was the lack of JRiver support which is fixed in the Official Firmware. I see no reason not to use it.
Neuromancer is offline
post #7940 of 14120 Old 12-06-2013, 04:56 PM
wse
wse's Avatar
Liked: 805
wse is offline
post #7941 of 14120 Old 12-06-2013, 05:14 PM
Read the FAQ!
Liked: 4648
OPPO UK has now posted the Official 1204 firmware for the EU versions of the 103/105/103D
http://www.oppo-bluray.co.uk/customer-services/firmware-updates/
--Bob
post #7942 of 14120 Old 12-06-2013, 05:48 PM
Mike Zaaaaayyyy's Avatar
Hey everyone! New to this forum but not AVS had a bdp-93 love it ! Now today I just gotten the 105 after hrs of fooling around with it iam very happy with its audio and Picture! Perfect complete to my he Thearter! Just wanted to share the Oppo joy!
Mike Zaaaaayyyy is offline
post #7943 of 14120 Old 12-07-2013, 12:48 AM
Pres2play's Avatar
Quoted: 616 Post(s)
Liked: 300
Hey, hey...it works! The player updated wirelessly in less than a minute and remembered all my settings. What a ******* nice machine!
Pres2play is offline
post #7944 of 14120 Old 12-07-2013, 04:20 AM
JazzGuyy's Avatar
Quoted: 327 Post(s)
Liked: 331
That new feature of memory for your settings is the nicest part of this firmware update for me. It makes firmware updates a breeze now when you don't have to spend that extra 5 to 10 minutes putting all your personal settings back in when a firmware upgrade needs a factory reset. It would be wonderful if this feature could be added to older models, like my secondary system 83SE. tongue.gif
JazzGuyy is online now
post #7945 of 14120 Old 12-07-2013, 05:17 AM
TKO1's Avatar
Liked: 65
If anyone here is accessing a NAS to play iTunes encoded (Apple Lossless - ALAC, MPEG-4 .m4a) audio files are you able to get the embedded cover art to display on the Oppo? If so, how did you do it?
Thanks in advance. Cheers.
TKO1 is offline
post #7946 of 14120 Old 12-07-2013, 05:42 AM
wmcclain's Avatar
Liked: 2519
Note to the uncautious: Reset Factory Default still wipes your settings. But:
(a) after the first time with the recent beta or current production firmware, the Reset is no longer required. (Usually -- I don't know if that will be true 100% of the time)
(b) you can now backup and restore your settings to a USB device, so even doing a Reset is much less painful.
-Bill
post #7947 of 14120 Old 12-07-2013, 08:07 AM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 226
On my unit, the latest upgrade did NOT change the network configuration - and yes, I DID do a factory reset when recommended during the upgrade.
I use a wired connection with manually-configured, fixed IP, DNS, and gateway addresses, (and fixed netmask, of course).
As this is not the default config, I expected these to be overwritten during the reset.
They were not - although all the other configuration was.
In my case, I was pleased with this, of course. But I wonder if this is the way things should have been...(?)
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #7948 of 14120 Old 12-07-2013, 08:11 AM
wmcclain's Avatar
Liked: 2519
You're probably correct; I never noticed because I use auto DHCP for networking and just presumed the player and router work it out.
At least one other setting is retained during Reset: the Remote Code Set. It would be cruel to change that. And Parent codes too, I think.
-Bill
post #7949 of 14120 Old 12-07-2013, 10:27 AM
edwardkim's Avatar
Problems with New Official Firmware (BDP10X-67-1204) on 105
1. Suddently, 105 stopped playing music which is stored on an attached USB hard/SSD drive. Then, 105 became unresponsive to PLAY button on Medial Control running (current version) on an iPad mini.
2. Subsquently, it displayed OFF on 105 panel for 'unlimited' time upon pressing OFF button on the Media Control (iPad mini).
3. It required me to press POWER button on 105 to complete the power down.
The above problems is persistent, and I decided to report these problems on this forum, after the 2 consequentive failures.
FYI
- I previously used the same version of Media Control on the same (and other) iPad and 105 with most recent public beta, without any problem.
- I have been using this 105 since Jan/13 without any problem prior to these failures.
Anyone else having the same problem?
edwardkim is offline
post #7950 of 14120 Old 12-07-2013, 11:35 AM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
OK...after further review, I reloaded the new FW from a USB stick. Reset Factory defaults and powered down.
Went into Network Setup > IP Setting > Manual. (Selecting Auto doesn't write anything to Connection Information.)
Then, Internet Connection > Wireless > Start New > Manual > Security Mode = None. Changed to WEP and entered Password > Connection Successful. Numbers written to Connection Information. However, Security Mode shows None.
Next, went to Wireless Setting > Start New > Manual > Security Mode = None. Changed to WEP and entered Password > Connection Successful.
Went to Connection Information > Security Mode = None.
Connection Test fails.
Carpal tunnel is setting in on my thumb.
Mongo171 is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
