Official OPPO BDP-105 Owner's Thread - Page 292 - AVS Forum | Home Theater Discussions And Reviews
 518Likes
post #8731 of 14161 Old 01-16-2014, 11:28 AM
oneartist's Avatar
Quoted: 18 Post(s)
Originally Posted by DanF8500 View Post
The trim settings are inactive for the Dedicated Analog Stereo Outputs.
But, trim is adjustable using the analog outputs according to p.67 in the analog section:" if your receiver does not have such
functions (many receivers do not support channel trim for their multi-channel analog inputs), you may
adjust channel trim through the player"
oneartist is offline
post #8732 of 14161 Old 01-16-2014, 11:40 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1263 Post(s)
Liked: 1328
The trim settings are for the 7.1 multichannel analog outputs, not the dedicated stereo outputs.
gsr is online now
post #8733 of 14161 Old 01-16-2014, 12:09 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^^ Oneartist, there's no need to be concerned with a limited 105 volume range if you're going to get that Conrad Johnson tube amp and use the 105 as a preamp direct to your power stage. I set my max volume on my 105 to 40 when I use the player as a preamp to my Levinson amp. 40 levels of granularity is fine for me. How loud do you want to play your music? Or maybe I'm misunderstanding the reason you want more granularity/range? Playing at the input sensitivity of your power amp will be plenty loud!! To use the 105 direct to a power amp, and be able to utilize the full granularity/range of the 105's volume control, you would need a power amp that has an input sensitivity (or the ability to adjust its input gain) for 2 volts on its rca inputs or 4 volts on its xlr inputs. Or you can buy a passive line-level attenuator, and place that between your 105 and power amp. But I think all of this is unnecessary. You'll be fine with a 60% reduced range of volume granularity.
DanF8500 is offline
post #8734 of 14161 Old 01-16-2014, 12:31 PM
869884's Avatar
Originally Posted by Mongo171 View Post
On the top of the remote is an Input button. By pressing it, a Menu of Input Options pops up. Select the Input you're hooked up to.
Many thanks, Mongo!
869884 is offline
post #8735 of 14161 Old 01-16-2014, 12:58 PM
Mongo171's Avatar
Quoted: 983 Post(s)
Liked: 1409
Originally Posted by 869884 View Post
Many thanks, Mongo!
No problem. Enjoy!
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is online now
post #8736 of 14161 Old 01-16-2014, 01:10 PM
oneartist's Avatar
Quoted: 18 Post(s)
If it were just the MV45 tube amp that would be fine for the front R&L speakers, but the center speaker is powered by a bridged NAD 2200 amp and the side speakers are powered by a Parasound amp plus the powered subwoofer. Maybe the line atenuator will help balance everything?
post #8737 of 14161 Old 01-16-2014, 01:24 PM
oneartist's Avatar
Quoted: 18 Post(s)
I'm learning from Dan. I looked up the input sensitivity on all three amps. The tube MV45 is .8V, the NAD 2200 is .775V and the Parasound 750 is .7V. It appears the input sensitivity is just about equal. Thanks for the education.
post #8738 of 14161 Old 01-16-2014, 01:31 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Oh my!! I didn't realize you have a multi-channel configuration with multiple amps. You may not be able to accomplish everything you want with that kind of configuration utilizing the 105 direct to power amps without a pre-pro in the middle. You can certainly try though. If you're just playing 2-ch audio, there should be no problem, right? You won't need the other speakers/amps on, and your front L/R are full-range, correct? Or do you want your powered sub on in that config too? When you play multi-channel audio, then you can set the 105's speaker configuration to 5.1 downmix, and you'll then be able to adjust trim settings for your other speakers. Then if you set the "Stereo Signal" setting in the 105 to "Front L/R", your Front L/R muli-ch outputs on your 105 will be directed out its dedicated stereo outs. So you will have some adjustability of gain/output when you're in the multi-channel config/downmix mode on the 105.
I just saw your above post.....that's pretty positive....all your amp's input sensitivities are nearly identical.
DanF8500 is offline
post #8739 of 14161 Old 01-16-2014, 02:28 PM
Holzohr's Avatar
Just my two cents for a way to use the Oppo's 105D USB DAC for DSD playback (sorry when it was already mentioned in the thread). People who have a Squeezebox Touch can connect it to the Oppo's USB DAC (the EDO app must be installed on the SBT) by USB cable. The SBT (as every 176.4kHz capable streamer) can pass on the DoP files to the USB DAC.
Yet another way is Daphile. It is a kind of LMS OS based on Gentoo Linux. I have installed it on a small fanless WOL-ready nettop. Now it's hidden in the hifi-rack. I use it with an extern DoP-ready USB-DAC. With iPeng or each other Squeezebox app you can control the music playback. The installation and setup is very easy. No need to have skills in Linux.
Advantages opposite to the SBT are USB-hotplugging, DSD128 playback and DSD to DoP converting on-the-fly.
Holzohr is offline
post #8740 of 14161 Old 01-16-2014, 02:31 PM
oneartist's Avatar
Quoted: 18 Post(s)
This is exactly what I have. I'm patiently waiting until Saturday when I pickup the MV45. The local guy I'm buying it from has it in the shop to have a final BIAS adjustment. This thing was completely restored two years ago and I'm glad I jumped on it. I'll connect the MV45 to the stereo outs and adjust the other amps using the analog trim settings. I'll have to play with the powered sub. Thanks for all your help.
post #8741 of 14161 Old 01-16-2014, 02:48 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
So, what external clock is being used when you have the SBT connected to the usb dac input? I was told that the 105D's usb dac input is reliant on an external clock (a pc/laptop) for DSD DoP playback functionality.
DanF8500 is offline
post #8742 of 14161 Old 01-16-2014, 09:20 PM
Holzohr's Avatar
^ Is the USB DAC from the Oppo 105D not DoP-ready?? Usually, the USB DAC is the "external clock". From my own experience the SBT (with the EDO app) works well with the Oppo 105 USB DAC "out-of-the-box", so it should be the same with the Oppo 105D USB DAC and its updated XMOS chip. My USB DAC (Matrix X-Sabre) is using a XMOS chip, too. The Daphile system recognizes it as "Squeezebox", as an extern player.
Holzohr is offline
post #8743 of 14161 Old 01-16-2014, 10:19 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ I received a couple of replies from Neuromancer a couple days ago regarding this:
The clock in the OPPO can't do DSD128. The Asynchronous USB in the BDP-105D can do DSD64 and DSD128 as the computer, not the player, is doing the clocking. Bandwidth limitations keep it from doing DSD256, however.
When using DSD over USB, SMB or physical disc the clocking is done in the MediaTek decoder. The decoder was built around the SACD DSD specifications, which is DSD64, so there was no anticipation for needing to support DSD128 or DSD256.
DanF8500 is offline
post #8744 of 14161 Old 01-17-2014, 01:09 AM
Holzohr's Avatar
^ Oh, that sounds quite complicated to me eek.gif I thought that the Oppo 105D's USB DAC is working like any other (standalone) DSD/DoP-ready USB DAC.
Holzohr is offline
post #8745 of 14161 Old 01-17-2014, 04:51 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 354
^ Man does anybody besides me think that 3/4 of all the owners of these oppos are all IT specialists? This is soooo confusing reading all these posts about dop, dope smb, nas. What plays. What wont play. My head is spinning. I guess I will need about 10 years of education to catch up on all this.
Bill Mac and Smarty-pants like this.
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is offline
post #8746 of 14161 Old 01-17-2014, 05:06 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3325 Post(s)
Liked: 2595
I am pretty much optical disc-oriented myself, which is a relatively simple environment. Which the studios still try to dick up.
But the world wants to go disc-less. This frontier is not quite settled yet and the content owners want you there only on their terms, and this results in much technical messing about.
People also seem to think our internet infrastructure works as well as it does on TV and in the movies. Those are fiction, but we have to deal with reality.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #8747 of 14161 Old 01-17-2014, 05:22 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 354
-Bill
It would be so nice if somebody that I knew could come to my house and help me out with all this. I know of only one person in my area. And unfortunately he is my ex wifes new husband. That would just be to weird. Lol
post #8748 of 14161 Old 01-17-2014, 06:02 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 354
Ok there is all this talk about if you have good dacs or as in my case the Krell Foundation, which has the same dacs. It would be of no benefit to have the 105 over the 103 when passing pure digital signals. I however couldn't part with the 105. I am old school snd kept wondering if the better tranformer in the 105 wouldn't somehow play a slight part in it sounding better than the 103 even when passing thpse digital signals.
My question is this has it been proven that there is definitely no, none, natta difference? Or is this just what everyone has always excepted as fact?
post #8749 of 14161 Old 01-17-2014, 06:20 AM
Bill Mac's Avatar
Quoted: 1569 Post(s)
Liked: 1817
Have no fear as I'm in the same "boat" as you. The only acronym I understand is "dope" which would be me as far as all this stuff is concerned biggrin.gif.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #8750 of 14161 Old 01-17-2014, 06:29 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 354
Bill
You got that right. I am laughing so hard right now. Or I may have smoked way to much of that stuff when I was a kid. Thats why I don't understand this stuff.
Bill Mac likes this.
post #8751 of 14161 Old 01-17-2014, 06:37 AM
Bill Mac's Avatar
Liked: 1817
I think you are on to something here. I was also known to par take in that controlled substance when I was younger eek.gif. I'll leave it at that as I don't want to derail a great thread with war stories wink.gif.
Bill
Bill Mac is offline
post #8752 of 14161 Old 01-17-2014, 07:04 AM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 226
-Bill
It is like that in a lot of places these days. Try being an electric guitar player.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #8753 of 14161 Old 01-17-2014, 08:16 AM
Holzohr's Avatar
@Dan & Neuromancer, do you know any other source where I can read more about the specs of the new USB DAC? I still couldn' t find anything about if it is DoP-ready. All I read it accepts DSD64 and DSD128. Does it mean native DSD? This external clock thingy still sounds strange to me. Maybe it is not about clock but about lock? smile.gif The stream must be bit perfect. If not, the DAC can not lock and can not recognize the DSD format within the PCM container.
Holzohr is offline
post #8754 of 14161 Old 01-17-2014, 08:39 AM
jima4a's Avatar
Quoted: 289 Post(s)
Liked: 155
Please help me understand but I thought DoP was basically DSD converted to PCM, do I understand this correct?
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #8755 of 14161 Old 01-17-2014, 08:50 AM
Holzohr's Avatar
^ Nope. DoP means DSD over PCM. You put the DSD file (.dff or .dsf) into a PCM container. Usually FLAC. The DoP-ready DAC can "unpack" the DSD file then.
http://www.audiocircle.com/index.php?topic=119364.0
(3. Use Foobar As A DSF to DoP File Converter)
For DSD128 you must change the PCM sample rate to 352.8kHz
Holzohr is offline
post #8756 of 14161 Old 01-17-2014, 08:55 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1270 Post(s)
Liked: 860
DSD over PCM is a way of transmitting the DSD unchanged within PCM frames. It is still DSD.
There is a history as to why this was chosen, but it basically, it was easier to encode the DSD in PCM than to try to invent a new streaming format.
Here is an article that explains it pretty well (IMO):
http://dsd-guide.com/dop-open-standard
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is online now
post #8757 of 14161 Old 01-17-2014, 09:01 AM
jd_alpha's Avatar
Bill
Friends - you are definitely not alone here. For video I am quite content to stick with the shiny disks as I only have the 1 big TV in the house where I really want to watch high quality video. For me, it would be nice to be able to easily and robustly back-up the video shiny disks on my computer/home network though (and if I could ultimately "stream" this content hassle-free at high quality, well, that would be a nice bonus).
For audio, I'm much more interested in having a single, high quality digital copy on the network to "stream", but I'd want it in a format that could be easily utilized on legacy devices like portable players or car stereos. I've been trying just to do the very basics with WAVs ripped from my CDs, but I've been having issues. I'm reluctant to go through the hassle of ripping all my shiny disks until I know I have something in place that's bulletproof. I can't even imagine getting into the real nitty-gritty of alternative hi-rez formats, etc., being discussed here.
Cheers,
JD
jd_alpha is offline
post #8758 of 14161 Old 01-17-2014, 09:10 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
I have no detailed info on the new specs/programming with regards to this.....I only know what Neuro told me....I did see on the JRiver wiki site about Oppo providing dsd over usb on their next player, and they mention DoP. Scroll down to the manufacturer list.
http://wiki.jriver.com/index.php/DSD_Format
DanF8500 is offline
post #8759 of 14161 Old 01-17-2014, 09:16 AM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
Opinion, not fact (I haven't done a head-to-head comparison): you will be very hard pressed to hear any difference between the 103 and 105 if you output audio digitally. It's all 0's and 1's. Analog audio, of course, is a different story. I went with the 105 over the 103 for analog audio.
BillP is offline
post #8760 of 14161 Old 01-17-2014, 09:25 AM
Holzohr's Avatar
Thank you! I guess we will have to wait till Oppo gives out more informations or till a "DSD-aholic" was playing with the USB DAC of the 105D.
Holzohr is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
