Official OPPO BDP-105 Owner's Thread - Page 346 - AVS Forum | Home Theater Discussions And Reviews
 510Likes
post #10351 of 14091 Old 04-27-2014, 02:08 PM
Mongo171's Avatar
Quoted: 904 Post(s)
Liked: 1334
I run my 105 to my amp with RCA's out to my speakers with speaker wire. All analog.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is online now
post #10352 of 14091 Old 04-27-2014, 02:48 PM
Process53's Avatar
Liked: 24
Oppo BDP-105 Player
Musical Paradise MP-301 MK3 Tube Amp x 3
Paradigm Studio 60 v2 x 5 Speakers
Sony Bravia KDL-55W800C TV
Process53 is offline
post #10353 of 14091 Old 04-27-2014, 02:58 PM
OmarF's Avatar
Quoted: 32 Post(s)
Liked: 95
Originally Posted by Arwen View Post
Omar, nothing is clear.
I do not have a two channels set up. I have a 5.1 power amplifier.
I have 5.1 preamp.
My stereo has nothing to do with my surround apart of sharing the front speaker but not in the same time. I can listen to music or I could see a movie. Not in the same time.
You are saying like this: It I play blu-ray a DTS movie in Oppo and get out through Oppo's stereo everything is decoded. I connect to the preamp through Tape input. from there in my preamp it will get out as 5.1 Dolby? Or what?
Is that you are saying?
Ah, I've reread your posts. Okay, I have a better understanding now. Sorry I got a bit confused, I was rushing when I read your posts earlier, and I'd been working all night.
Your current preamp does not have HDMI input, nor does it have 5.1 analog input. It's only form of decoding is Dolby. It has optical and coaxial inputs. It has 5.1 output to your amp.
With your current setup, Optical and Coax will not do you a lot of good. If you go optical or coax out of the OPPO to your preamp by bitstream, your preamp will only be able to decode DD. If you go by LPCM out of the OPPO, everything will be downmixed to 2 channel before being sent to your preamp.
1) what is the input impedance of your amplifier? It should be in your manual's specifications, or available somewhere online.
2) IF your amp's input impedance is 47 K ohms or higher, you can try running the 105 directly to your amp as a preamp. Just BE AWARE, you may be happy with it (given the age of your equipment, I suspect you would be happier with it than with your current preamp), or you may not. If not happy, then you'd be in a position of buying a new preamp, anyway.
3) IF your amp's input impedance is BELOW 47 K ohms, you will not be able to use the 105 as a preamp. In this case, you would need to buy a new preamp and a 103, then run the 103 HDMI into the new preamp.
Omar
OmarF is offline
post #10354 of 14091 Old 04-27-2014, 03:05 PM
Process53's Avatar
Liked: 24
Originally Posted by OmarF View Post
IF your amp's input impedance is BELOW 47 K ohms, you will not be able to use the 105 as a preamp. In this case, you would need to buy a new preamp and a 103, then run the 103 HDMI into the new preamp.Omar
While I have seen it stated on Oppo documentation that 47K ohms is the recommended power amp input impedance I cannot agree that this is a hard-and-fast requirement. My amps (3 identical stereo) are 15K input impedance and work fine.
Oppo BDP-105 Player
post #10355 of 14091 Old 04-27-2014, 03:09 PM
OmarF's Avatar
Quoted: 32 Post(s)
Liked: 95
I hear you, but remember the fellow lives outside the US/Canada, and it might be very difficult for him to return the item if it doesn't work for him.
Omar
OmarF is offline
post #10356 of 14091 Old 04-27-2014, 04:20 PM
Process53's Avatar
Liked: 24
^Okay one of the experts weigh in here but isn't a power amp simply the piece that increases a line level signal so that it can run speaker cones? The 105 outputs a line level signal via the analog outputs, correct? So if you run this into a power amp there really shouldn't be a whole lot that can screw up, right? Regardless of the actual power amp specs it's still a power amp and it does what it does - run speakers.
Oppo BDP-105 Player
post #10357 of 14091 Old 04-27-2014, 05:34 PM
Mongo171's Avatar
Quoted: 904 Post(s)
Liked: 1334
post #10358 of 14091 Old 04-27-2014, 05:56 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 284
Hi, I have two Rotel amps and one is dedicated to the rear-surround speakers in my 5.1 system. It works okay - at low levels. At reference level, I've noticed clipping in both speakers and thought that maybe the amp is underpowered (7x 100 Watts). Now I see that the input impedance is 8.3K ohms and may not match up well with the 105's analog outputs. Before I pull my old Onkyo 818 AVR from the storage closet, is there any reason to believe the Onkyo's outputs will be any better? Thanks.
Pres2play is online now
post #10359 of 14091 Old 04-27-2014, 05:58 PM
Mongo171's Avatar
Quoted: 904 Post(s)
Liked: 1334
He lost me at "it sounds better with a preamp because it sounds more natural" or something like that.
A power amplifier's main job is to increase the amplitude of the input signal by a set amount by the output stage.
My amp runs fine at 28K input resistance.
post #10360 of 14091 Old 04-27-2014, 06:03 PM
Mongo171's Avatar
Quoted: 904 Post(s)
Liked: 1334
It's either amps clipping or the speakers are under-powered.
The amps' input impedance is 8.3K?
What are those speakers' wattage rating?
post #10361 of 14091 Old 04-27-2014, 06:29 PM
OmarF's Avatar
Quoted: 32 Post(s)
Liked: 95
Mongo, I get your skepticism, but If you heard it you'd understand. On its own the 105 sounds muffled compared to when I use my preamp. Don't know how else to spell it out, the OPPO doesn't produce nearly as dynamic a sound on its own. This was confirmed by two other ppl who I blind tested on comparing the two, on separate occasions from each other. One of them was a sound engineer.
Omar
OmarF is offline
post #10362 of 14091 Old 04-27-2014, 07:21 PM
wse
wse's Avatar
Quoted: 2189 Post(s)
Liked: 797
Here is a question for Bob or other OPPO experts.
When I ran my OPPO BDP-105 straight to the amps ( Classe CA-M600 and Classe CA-5200) I never had to raise the volume higher than 35 out of 100 to reach 95 db.
Now that my Classe SSP-800 is in front of the OPPO the volume needs to be raised to -20 db (the volume on the Classe is absolute). It seems that I have to raise the volume much higher to get the same db. Any reasons why you think that is?
wse is offline
post #10363 of 14091 Old 04-27-2014, 07:28 PM
Roger Dressler's Avatar
Quoted: 1547 Post(s)
Liked: 734
If the Oppo is passing through the analog bypass path of the SSP-800, that path is not unity gain until the Volume is 0 dB (assuming trims = 0).
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #10364 of 14091 Old 04-27-2014, 07:36 PM
Process53's Avatar
Liked: 24
Originally Posted by Mongo171 View Post
You're testing me right? Okay I'll bite. The 105 doesn't do analog sources.
Oppo BDP-105 Player
post #10365 of 14091 Old 04-27-2014, 07:49 PM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 226
Not the case. "Line level" refers to voltage. And voltage is attenuated by a voltage divider. And the combination off the output impedance with the input impedance creates a voltage divider, which WILL attenuate the signal. By how much is a function of the values of the two impedances. If, for example, the two impedances are equal, then you will lose 50% of the signal. If the input impedance is lower than the output impedance, then you will lose MORE than 50%. If the output impedance is lower than the input impedance then you will lose less than 50%. If you get the output impedance to the point where it is 20-50 TIMES lower than the input impedance to which it is connected, then the attenuation is negligible. Hence, this is always the goal for audio interconnect....low output impedance feeds very high input impedance.
Because these are impedances (AC) instead of resistances (DC) that we are talking about, the impact is frequency-dependent. This means that not only will you lose signal. but you will also lost fidelity with a poorly spec'd bridging connection.
Independent of the voltage divider problem, there is also the problem of loading on the output amplifiers of the sending device. EVEN IF the attenuation due to the voltage divider is negligible, it is possible that the receiving device will "load" the outputs of the sending device so heavily that it will reduce the gain of the output amps. This can be especially true if the output of the sending device is not buffered. A high input impedance ALSO reduces the load on the output of the sending device, thus permitting the output amplifiers to operate at their optimal (and highest fidelity) levels.
Thus, when a manufacturer recommends at least a 47k load (input) impedance on the amp, it is a good idea to take the recommendation. It is all about risk - and while it is possible that things will be fine with the input impedance of the receiving device at a lower value, it is MUCH lower risk to comply with the advice as-given.
RichB likes this.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #10366 of 14091 Old 04-27-2014, 08:17 PM
Process53's Avatar
Liked: 24
^Thank you very much. That is a great explanation of output/input impedances.
Oppo BDP-105 Player
post #10367 of 14091 Old 04-27-2014, 08:25 PM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 284
The amp is a Rotel RMB-1077. It's input Sensitivity/Impedance: 1.2 V / 8.3 k ohms
The speakers are 4-ohm M&K S-85s (25 Watts min, 200 max)
I've experienced the clipping with certain movies, most recently while watching Amercan Hustle. It's pretty loud, but happens only once or twice during the movie.
post #10368 of 14091 Old 04-27-2014, 09:29 PM
OmarF's Avatar
Quoted: 32 Post(s)
Liked: 95
Could these factors have anything to do with why my system sounds better running my 105 through my preamp, than straight to the amp? Amp is Ayre V-5xe, input imp of 100k. Preamp is Ayre K-5xe-mp.
Omar
OmarF is offline
post #10369 of 14091 Old 04-27-2014, 09:47 PM
Sam1000's Avatar
Quoted: 60 Post(s)
I assure you, there's no apparent coloring going on from my preamp. When I run my OPPO straight into my amp, it sounds pretty good. But via the preamp, I have much more dynamic, crisp, clear sound.
Omar
+1. I use Bel Canto pre6 with Oppo105 and prefer to have it in the chain.
Pioneer/TAD S-1EX, S-7EX, Ascend HTM200
Marantz 8802A, Devialet D400 L/R, NAD M27, Squeezebox
Sam1000 is offline
post #10370 of 14091 Old 04-28-2014, 05:16 AM
Pres2play's Avatar
Quoted: 528 Post(s)
Liked: 284
Well, I dragged the Onkyo back into service and removed the Rotels. Now I have to reinstall the Lumagen processor between the AVR and the display and recalibrate the video. Can't wait for Oppo to fix the speaker distance bug thing. Then I'll return to Oppo analog and reevaluate the amp.
post #10371 of 14091 Old 04-28-2014, 06:43 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Bob has provided all of us with a temporary workaround for the speaker distance bug. It's as effective as the real fix will be. Did you read his workaround post? Also, with regards to speaker clipping, did you raise any of the 105's trim settings in your Oppo player?
DanF8500 is offline
post #10372 of 14091 Old 04-28-2014, 07:08 AM
runninkyle17's Avatar
Quoted: 20 Post(s)
Liked: 36
Got the idea from the forum to upgrade my current bluray player in lieu of changing my pre-pro. Currently I am using an Anthem D2v as the pre-pro and have J. River along with EMU 0404 DAC outputed to the D2v. Mainly looking to upgrade to have some of the network music streaming features for my family. I guess my question is how to hook all this up.
From looking at the Oppo it appears as though I would just connect the Oppo RCA outputs to the D2v inputs and basically run everything through the Oppo. For the DAC, just connect the USB from my HTPC and change the video output settings on the D2v to match the HTPC output, while setting the audio in on the D2v to the balanced XLR output from the Oppo.
Does that all sound right or am I missing something?
runninkyle17 is offline
post #10373 of 14091 Old 04-28-2014, 07:15 AM
Arwen's Avatar
my surround amp
Input Sensitivity/Impendance
Surround: All channels 1.1V/30 k-ohm
Arwen is offline
post #10374 of 14091 Old 04-28-2014, 07:34 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
All your digital audio sources will begin at the 105, get converted to analog by the 105's DAC's, and then outputted to your D2v via rca/xlr. There are many options to play digital music from your 105, such as using J River with one of the 105's digital inputs or DLNA via the ethernet connector, via a usb attached hard/flash drive, or from the 105's onscreen browser ( via SMB protocol or as a DLNA media player). Your 105 will be your DAC. It is audiophile quality. Why would you need another DAC?
DanF8500 is offline
post #10375 of 14091 Old 04-28-2014, 08:18 AM
mikepos's Avatar
Quoted: 24 Post(s)
Since using the 105 as a preamp involves using the analog outputs this isn't really the best time to see if you like it. Wait until the next firmware update fixes the speaker distance bug.
I don't find the distance bug too big of an issue. People sit in different places anyway which throws things off, and distances are usually very similar for the front three channels, where the huge majority of sound comes from. I'm looking forward to the fix but you can already hear the detail, frequency response, and bass quality using current firmware. Especially considering the simple work around I wouldn;t consider the firmware bug to be even a small factor on when to buy.
Oppo BDP-105
Bryston 3B-ST 2ch on mains, Lexicon 512 5ch
PSB Stratus Gold mains, C6i center
Rythmik FV15HP
Paradigm ADP-370 surrounds
cheap energy rear speakers
mikepos is offline
post #10376 of 14091 Old 04-28-2014, 10:31 AM
RickyDeg's Avatar
Quoted: 139 Post(s)
Liked: 150
^ Here's what I do...see if this helps:
Oppo 105 Analog 5 rca outputs ==> to power amps ==> Speakers
Oppo 105 Analog .1 rca output ==> to subwoofer
I have 3 stereo power amps which is the same as you having a single 5.1 power amp.
You seem to be pleased just using the 105 direct to your amps. May I ask what preamp/processor you used before it and what the sonic benefits are that you have personally experienced getting it out of the chain and letting the Oppo do the job?
| NAD M17 (a/v processor & DAC)
| NAD M27 (multichannel poweramp)
MONITOR AUDIO APEX (5.2 speaker system)
OPPO BDP-103D (blu-ray player)
LG OLED55B6V (television screen)
Check out my AVSForum review of the NAD M17 & M27 Master Series
RickyDeg is online now
post #10377 of 14091 Old 04-28-2014, 10:39 AM
dbphd's Avatar
Quoted: 451 Post(s)
Liked: 166
I
I assume one of the reasons you had for buying a D2v was its ARC. To use that with RCA inputs from the Oppo would require the D2V to digitize an analog signal. It would seem better to use HDMI output from the Oppo to the D2v, and let the D2v do the analog processing including ARC.
Nothing in my response was rude.
It seemed so to me.
db
dbphd is offline
post #10378 of 14091 Old 04-28-2014, 11:30 AM
Quoted: 20 Post(s)
Liked: 36
Originally Posted by dbphd View Post
I
That is a good point. That is partly why I asked the question about how exactly to hook things up. For the DAC setup I can just use the balanced 2ch output from the Oppo and send it to the D2v balanced inputs. I would just passthrough the 2ch audio through the D2v, that way the DAC in the Oppo is doing all the work.
audiofan1 likes this.
post #10379 of 14091 Old 04-28-2014, 11:42 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1159 Post(s)
Liked: 1152
The D2V is already an excellent DAC - why do you want to use the analog outputs from the Oppo? IMO, you should save yourself some money and get a BDP-103 or BDP-103D instead and send audio to your D2V digitally and let the D2V work its magic - there's presumably a reason why you spent the money for the D2V to begin with... If you had an otherwise all analog system or a lower quality surround sound processor, it would make sense to use the analog outputs, but not in this case.
gsr is offline
post #10380 of 14091 Old 04-28-2014, 11:44 AM
Process53's Avatar
Liked: 24
Right, it depends on how you use it. I'm the only listener and I always sit in the sweet spot. My rears are about half as close to me as my front 3. This bug is a major deal for me. Applying the workaround opened my eyes as to how much of the proper surround experience I was missing.
Oppo BDP-105 Player
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
