Official OPPO BDP-105 Owner's Thread - Page 355 - AVS Forum | Home Theater Discussions And Reviews
 512Likes
post #10621 of 14111 Old 05-08-2014, 10:41 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3531 Post(s)
Liked: 4549
NAIM101,
No, both the Dolby and PCM output options on your cable box are DIGITAL audio. Again, audio on HDMI is always and only Digital. So no DAC is involved in either form of HDMI audio output from the cable box.
You should use the Dolby choice as that will let the box send 5.1 audio to the OPPO. Its PCM choice will only send Stereo (used when connecting it directly to a TV that only understands Stereo).
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #10622 of 14111 Old 05-08-2014, 10:48 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Got it. Thanks Bob!
NAIM101 is offline
post #10623 of 14111 Old 05-09-2014, 05:15 AM
music first's Avatar
Quoted: 57 Post(s)
Liked: 36
Originally Posted by DanF8500 View Post
So it wasn't your 105 after all. tongue.gif I know you are quick to blame the 105 for any audio playback problems because you had a mechanical issue with one before, but you've got to unbiasedly look at each of your components, especially your computer. It's loaded with software that can mess up network communications. Maybe one day you'll even move in a direction a lot of us have no regrets, where you won't have to rely on your home pc's to stream your audio to your media player. That will be one less problem you have to encounter in the future.
Dan - Yes I am eating crow. It was not the 105. I do apologize. It has been a little quirky at times, but I know that I would be hard pressed to find another component that streamed Netflix, Pandora, You tube, etc, and connected to my network, and put out really good sound and picture.. And oh yeah, play any kind of disc..
Main system | Sony 930D 65 inch | Yamaha RX-A3060 | Ascend Acoustics towers RAAL | Custom Ascend Horizon center | Rythmik F12 | Oppo BDP105 | Lenovo Windows 10 PC with Jriver media server streaming FLAC and WAV files | Surrounds - Def Tech Pro Monitor 1000s
Secondary system : Yamaha RX V2500 | Philharmonic AA bookshelf speakers.
music first is offline
post #10624 of 14111 Old 05-09-2014, 05:19 AM
Quoted: 57 Post(s)
Liked: 36
Originally Posted by Bob Pariseau View Post
--Bob
Yes- You gotta love Microsoft
post #10625 of 14111 Old 05-09-2014, 05:24 AM
Quoted: 57 Post(s)
Liked: 36
Originally Posted by Joe Appierto View Post
I now realize that after doing the same "critical update" was when the same thing happened to me. In my case the problem disappeared after I temporarily disabled my firewall. Once the connection was made between the Oppo SMB and my PC, the SMB re-appeared on the Network menu and even with the firewall now back in place, the SMB is still in place and working properly. You gotta love Microsoft. I also have Norton so you have to wonder...
yes, you have to wonder. I wish they would tell you what these "critical updates" do. Even though I am eating crow, i wanted to come back and post my solution in case anybody else experienced the same type of issue.
post #10626 of 14111 Old 05-09-2014, 05:25 AM
Quoted: 57 Post(s)
Liked: 36
This is an awesome forum by the way. So many knowledgeable folks here. Now I can get back to enjoying my new speakers biggrin.gif
scirica and DanF8500 like this.
post #10627 of 14111 Old 05-09-2014, 05:47 AM
James004's Avatar
For those that have upgraded to the new beta firmware. Have any of you experienced a shift in the surround and center channel outputs. Before the update my front channels where set to -7. That enabled me to set the center to 0 and the surrounds to -4 and I forget the other. Now I am forced to have the fronts at -10 and the center needs +1. The surrounds are also in the + 1.5 range. But my sub has gone from +3 in the Oppo and less than half on the sub volume control. To now  +5 and 3/4 on the subs volume control. This did not happen when I initially upgraded. But took affect after a factory reset was done when trying to resolve an issue with the Berliner Philharmonic (still does not work). Has anyone else has similar experience. Is there some other setting in the Oppo that may affect this?
I am using a 5.1 setup. With the Oppo as a preamp directly to one amp for fronts one amp for center and one amp for the surrounds. So the amps being at fault would not be possible and they are all independent. Not to mention the sub as independent as well.
James
James004 is offline
post #10628 of 14111 Old 05-09-2014, 06:40 AM
Mongo171's Avatar
Quoted: 963 Post(s)
Liked: 1388
James
The new Beta FW fixed a bug in the Speaker Configuration for speaker distances. You may need to remeasure distances and adjust trims accordingly.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #10629 of 14111 Old 05-09-2014, 07:04 AM
Read the FAQ!
Liked: 4549
^ The Speaker Distance Adjustments affect timing only. They don't alter speaker volumes.
--Bob
post #10630 of 14111 Old 05-09-2014, 07:22 AM
Mongo171's Avatar
Quoted: 963 Post(s)
Liked: 1388
^I understand that. But, if the distances aren't set accurately, it could possibly cause cancelation problems because of the phase differences. With that, the speakers won't be working as efficiently as possible.
Mongo171 is offline
post #10631 of 14111 Old 05-09-2014, 07:36 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1209 Post(s)
Liked: 1249
By all means, the distance settings should be set to the correct values, but as Bob said, the distance settings have absolutely no affect on the trim settings. The 2nd half of your statement that I've bolded:
"You may need to remeasure distances and adjust trims accordingly"
is incorrect. You can change the distances to whatever you want without having to adjust trim levels at all.
If the trim levels needed to be changed that dramatically after a reset to factory defaults, something other than distances is at play here.
gsr is online now
post #10632 of 14111 Old 05-09-2014, 07:38 AM
Read the FAQ!
Liked: 4549
James
How old was your PRIOR firmware? Do you remember the version number for it?
How are you checking your levels? Are you using a calibration disc such as AIX Audio Calibration, Blu-ray, or using the 105's built-in test tones?
If you were on the current, Official 0218 firmware prior to this, then try rolling back to it:
1) Download it from the OPPO Support page for install via USB stick
2) After the re-install of 0218, do a Reset of settings
3) Check your speaker levels.
If that fixes the problem, then try a re-install of 0430B -- again, via USB stick, and with a Reset of the player afterwards, and see if the problem returns.
If it does, email your info to OPPO Tech Support and see what they suggest. I've not heard any other reports like this.
Of course the first thing to check is that your speaker configuration is the same under the new firmware, including whether you are using the Dedicated L/R outputs in place of the normal LF/RF outputs of the multi-channel set. (If your prior firmware was old enough, your prior level settings may have been screwed up by the Stereo Signal setting bug, fixed some time back.)
--Bob
post #10633 of 14111 Old 05-09-2014, 09:25 AM
Mongo171's Avatar
Quoted: 963 Post(s)
Liked: 1388
I don't come across very well at times. For that, I am sorry. I'll try again.
I'm going to use an exaggerated example. Let's say I am putting a 2.0 system together against a wall. I measure the distance of each speaker and input the data. That distance won't change. The only variable now, in the BDP, is trim. Theoretically, the distances should be the same as the trim level for both speakers, assuming equidistant placement.
I know there are some people out there who have different trim levels for equidistant speakers. But, you can have phase issues that one will try to compensate for with trim levels.
Mongo171 is offline
post #10634 of 14111 Old 05-09-2014, 10:05 AM
wse
wse's Avatar
Quoted: 2200 Post(s)
Liked: 805
wse is online now
post #10635 of 14111 Old 05-09-2014, 10:08 AM
Process53's Avatar
Liked: 24
^ Has What been released?
Oppo BDP-105 Player
Musical Paradise MP-301 MK3 Tube Amp x 3
Paradigm Studio 60 v2 x 5 Speakers
Sony Bravia KDL-55W800C TV
Process53 is offline
post #10636 of 14111 Old 05-09-2014, 10:26 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1249
If the room is perfectly symmetrical, the trim levels for both speakers would probably be the same, but they certainly wouldn't have the same values as the distances. For example, if the speakers are 10 feet away from the listening position, that most definitely doesn't mean that the trim levels would be set to 10.
Of course in the real world most rooms are not perfectly symmetrical. So even though the distances from both speakers to the listening position might be the same, it doesn't follow that the trim levels will be the same for both speakers. One of the side walls might open up to another room, while the other side wall might just be a solid wall - that will likely result in different trim levels despite the distances being the same.
The distance settings are all about delaying sounds from the closer speakers so that sound will arrive at the listening location at the same time from all speakers. The trim levels are to ensure that the volume level will be the same from all speakers at the listening position. The 2 settings really don't interact with each other as you are suggesting.
gsr is online now
post #10637 of 14111 Old 05-09-2014, 10:38 AM
Read the FAQ!
Liked: 4549
Originally Posted by wse View Post
So has it been released
The Kraken?
--Bob
post #10638 of 14111 Old 05-09-2014, 10:53 AM
wse
wse's Avatar
Liked: 805
Originally Posted by Bob Pariseau View PostThe Kraken? --Bob
LOL the updated software?
wse is online now
post #10639 of 14111 Old 05-09-2014, 10:56 AM
Process53's Avatar
Liked: 24
I agree that the Speaker Distance Settings don't interact with the Trim settings. However, the current situation is special in that a flaw (speaker distance settings) is being corrected. Anything affecting the sound from the analog outputs needs to be considered for re-evaluation.
Oppo BDP-105 Player
post #10640 of 14111 Old 05-09-2014, 11:05 AM
dbphd's Avatar
Quoted: 480 Post(s)
Liked: 174
I plan to wait for the official firmware release, so last night I set my speakers using the workaround. My mains are at 9', surrounds at 6', and a pair of subs at 10.5'. I hadn't noticed a problem with the distance settings. I no longer use a center channel. The effect of the workaround settings wasn't subtle. A DirecTV HD-DVR via HDMI to the 105 was the source while I made the correction. The soundstage seemed to move back and get broader and deeper. I played a 5.1 DTS HD MA Blu-ray of the second movement of Beethoven's 7th and the sense of the ambience of the Vienna concert hall was considerably enhanced. I then played an SACD of Corelli violin sonatas that I knew incorporated a great sense of hall ambience. Wow! I was transported to the audience. By then it was 3 AM and I went to bed. The sense of enhanced ambience remains this morning so it wasn't just late night haze. Thanks, Bob.
db
dbphd is offline
post #10641 of 14111 Old 05-09-2014, 11:05 AM
Process53's Avatar
Liked: 24
I'm still not sure what you are talking about. The only thing I can think of is the latest Oppo firmware update.
Oppo BDP-105 Player
post #10642 of 14111 Old 05-09-2014, 11:07 AM
Process53's Avatar
Liked: 24
db
You got it man! That's the kind of experience I'm getting too. It is significant.
Edit: You can thank DanF8500 too - he discovered the bug. smile.gif
Oppo BDP-105 Player
post #10643 of 14111 Old 05-09-2014, 11:09 AM
wse
wse's Avatar
Liked: 805
When was it release have not fired up my system for a week too much work wink.gif
wse is online now
post #10644 of 14111 Old 05-09-2014, 11:12 AM
Process53's Avatar
Liked: 24
The Beta is out - since Apr 30. You just need to check the Oppo site. They list all this information under Customer Support.
Oppo BDP-105 Player
post #10645 of 14111 Old 05-09-2014, 11:13 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3179 Post(s)
Liked: 2462
Reading post #1 in this thread saves time for all of us.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #10646 of 14111 Old 05-09-2014, 11:45 AM
enricoclaudio's Avatar
Quoted: 1419 Post(s)
Liked: 1530
Just got my 105D. Everything is working fine but I have a question. It asked me about the firmware update, do I wait until the new beta get public or is better to update to BDP10X-70-0218?
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #10647 of 14111 Old 05-09-2014, 12:10 PM
Read the FAQ!
Liked: 4549
You should definitely, at least update to Official 0218. You could do the update to Public Beta 0430B instead -- or later -- you can roll back to 0218 from that if you find a need. To install 0430B, download it from the OPPO Support page for install via USB stick. You can do that whether or not you install Official 0218 first.
There are links at the top of the first page of this thread which will take you to release notes for the firmware releases.
--Bob
post #10648 of 14111 Old 05-09-2014, 12:12 PM
James004's Avatar
Hi Bob,
I am using the dedicated L/R outputs for the fronts. I was on the current 0218 FW version. I use a RS sound meter and a calibrated Dayton usb mic for setting levels at the MLP. I am using both the AIX calibration disc and the internal test tones. The results are very close if not the same. So I tend to use the internal test tones more often (sub excepted). But I did verify with the AIX disk for this issue. I will do the revert to see if the problem clears. Can I do a save and revert to my settings? Or can that reintroduce the issue?
By the way does saving your settings to USB always produce an error file. Or is that indicative of a problem?
James
--Bob
James
James004 is offline
post #10649 of 14111 Old 05-09-2014, 12:18 PM
Read the FAQ!
Liked: 4549
^ Saving settings to an attached USB drive or stick should not produce an error, presuming the drive is formatted in a way that lets the player write to it, such as FAT32.
And yes, you can save and restore settings via the USB stick (assuming you can get it to do it without an error) to simplify the Resets.
--Bob
post #10650 of 14111 Old 05-09-2014, 12:25 PM
James004's Avatar
Bob,
I am talking about a text file named "error" being written to the usb drive. It contains a huge amount of text. For example.
--- 02 May 2014 15:36:18 ---
http://static.tv.digitalconcerthall.com/dchtv/css/720/all2479.css
Linked-in stylesheet
Selector syntax error
Line 234:
  Title,.ja .specialsConcertListHeadline,.ja .specialsDetailTitle,{font-size:20px}
--- 02 May 2014 15:36:19 ---
http://tv.digitalconcerthall.com/dchtv/720.html5
DOM style property
Invalid value for property: zoom
Line 1:
  1
+++ 02 May 2014 15:36:28 +++
http://static.tv.digitalconcerthall.com/dchtv/pong.ping
Cross-origin resource sharing check [response verification]
Access denied, Access-Control-Allow-Origin not included in response.
--- 02 May 2014 15:37:12 ---
Line 234:
--- 02 May 2014 15:37:13 ---
DOM style property
Line 1:
  1
+++ 02 May 2014 15:39:19 +++
+++ 02 May 2014 15:39:35 +++
+++ 02 May 2014 15:39:51 +++
+++ 02 May 2014 15:40:03 +++
+++ 02 May 2014 15:40:22 +++
+++ 02 May 2014 15:40:31 +++
+++ 02 May 2014 15:40:37 +++
+++ 02 May 2014 15:41:36 +++
--- 02 May 2014 22:10:58 ---
Line 234:
James004 is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
