Official OPPO BDP-105 Owner's Thread - Page 361 - AVS Forum | Home Theater Discussions And Reviews
 520Likes
post #10801 of 14174 Old 05-21-2014, 09:03 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3798 Post(s)
Liked: 4937
^ Answered in the 105D thread.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #10802 of 14174 Old 05-21-2014, 09:21 PM
dbphd's Avatar
Quoted: 514 Post(s)
Liked: 187
The firmware download seems to be working fine, but I thought to do a reset to default, but couldn't find such a command. I've done it before with a download, but don't recall how I did it. If that's an option presented at the download, I don't recall seeing it.
db
dbphd is offline
post #10803 of 14174 Old 05-21-2014, 10:28 PM
OmarF's Avatar
Quoted: 32 Post(s)
Liked: 95
db
Reset to default is under Settings | Device Settings, I believe.
OmarF is offline
post #10804 of 14174 Old 05-22-2014, 12:25 AM
misko72's Avatar
Quoted: 13 Post(s)
Originally Posted by enricoclaudio View Post
After the new firmware update the Oppo Media Control app doesn't work. I need to power ON my 105D for the app to detect the player.
you can close the app in the phone too...it's much faster..
misko72 is offline
post #10805 of 14174 Old 05-22-2014, 01:59 AM
Smarty-pants's Avatar
Quoted: 751 Post(s)
Liked: 628
Update to the latest version.
Smarty-pants is offline
post #10806 of 14174 Old 05-22-2014, 05:29 AM
enricoclaudio's Avatar
Quoted: 1516 Post(s)
Liked: 1668
All is fine. After firmware update I did a full reset and then I forgot to set Quick Start. Thanks to Bob for the reminder smile.gif
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #10807 of 14174 Old 05-22-2014, 06:32 AM
Ramatam's Avatar
....I read about the "better sound" at the 720p setting and figured, well, I don't have to buy anything and it might take all of 5 minutes to try it, why not.
I too heard a significant improvement in the sound. I had originally written this post with a description of what I heard but felt that it might be off topic and should go to the "sound" thread for the 105.
I'm keeping the setting at 720p. For more critical viewing at 1080p, it takes all of 30 seconds to switch it back over; I use my 105 primarily for audio and Netflix.
Quick question: after the latest firmware upgrade, is the consensus to still turn HDMI off for HiRes and DSD listening?
Ramatam is offline
post #10808 of 14174 Old 05-22-2014, 07:32 AM
Read the FAQ!
Liked: 4937
Ramatam,
If you are hearing better audio using 720p that's of course a good trick for you to know. But if you really are hearing a significant or dramatic improvement, that suggests there is something wrong with your 1080p configuration. Even the folks who believe there is a technical reason why 720p *MIGHT* sound better wouldn't suggest the difference SHOULD BE significant or dramatic.
And of course that means it would be worthwhile figuring out what's wrong with your 1080p setup, since that affects audio for 1080p movie viewing.
This will be tricky to nail down as it likely involves details of your cabling, other settings and other HDMI gear.
For example, it could be a bandwidth issue with your cabling (marginal cabling). Setting 720p/60 is lower bandwidth than 1080p/60, and setting 720p may cause your other HDMI gear to reject Deep Color input if you have that enabled, which lowers the bandwidth even further.
My point is, if 720p sounds better to you, then of course you should use it. But it should leave a question in your mind as to WHAT'S WRONG in your setup at 1080p, more than what's right at 720p.
As to your other question, you can't turn off the HDMI outputs of the player, although you can deactivate them by uncabling them. Depending on your other HDMI gear, switching that gear to listen on a different HDMI input may or may not be the same thing as uncabling. (Some HDMI gear keeps its non-selected HDMI inputs "live" nonetheless.)
For the HDMI connections which are "live", you can turn off HDMI Audio.
You can also invoke Pure Mode (Pure button on the upper left of the remote) which blanks the video output to Black (there's still video output, but it is a Black frame) and also turns off the Front Panel Display. Press Pure button again to get those back. A trick: You can use the Light button lower right on the remote to briefly re-illuminate the Front Panel if you need to check it.
--Bob
post #10809 of 14174 Old 05-22-2014, 07:39 AM
kayhikski's Avatar
Quoted: 22 Post(s)
The 720p vs 1080p discussion so far has been about reduced jitter but what about bandwidth?
My understanding from the BDP-105 manual is that Split A/V is the path to highest audio and video quality and I interpret this to mean that video quality on HDMI2 to an AVR is reduced if needs be to ensure a full bandwidth audio signal whereas HDMI1 to the display carries video only. Is that interpretation correct though?
.. so are people who are not using Split AV losing audio quality because of their video bandwidth needs and when they drop the video quality to 720p the audio sounds better as a result?
James
kayhikski is offline
post #10810 of 14174 Old 05-22-2014, 08:02 AM
Read the FAQ!
Liked: 4937
James
When both outputs are "live", Split A/V mutes audio on HDMI 1. HDMI 2 gets a video resolution that's capable of carrying the full quality audio signal -- the best that device will accept -- even if the device on the other end of HDMI 2 can't handle the video resolution which works on HDMI 1.
When both outputs are "live", Dual Display, uses a compromise audio format that will work on both outputs. Since many displays can only accept stereo LPCM, that means HDMI 2 may also get only stereo LPCM.
Note that when only ONE of the two HDMI outputs is "live" -- either one -- the Split A/V vs. Dual Display setting choice is ignored. The one connection in use gets the best audio and video the device at the other end will accept.
When listening to Bitstream content as HDMI Bitstream audio it is also important to leave Secondary Audio OFF to avoid having to re-encode the Bitstream for output (as a lossy Bitstream).
And when listening to stereo content on any output, it is important to leave DTS Neo:6 Mode OFF unless you really want to take advantage of it on the multi-channel Analog outputs. DTS Neo:6 Mode will only engage for stereo content, but when engaged it limits the digital audio processing in the player to a max of 44.1 or 48KHz.
HDMI audio is embedded in the "blanking intervals" of HDMI video. (There's ALWAYS a video signal, even if it is just a Black screen.) That means audio has to fit into a portion of the video data for each frame. The way HDMI is designed, any resolution of 720p or higher has enough space to hold ANY of the audio formats HDMI supports.
So using 1080p video does not limit the ability to carry audio. I.e., there's not a tradeoff of video bandwidth for audio bandwidth.
However, higher total output bandwidth CAN mean you start noticing problems due to marginal cabling.
--Bob
kayhikski and scirica like this.
post #10811 of 14174 Old 05-22-2014, 08:12 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
I'm sure over 95% of the 105 owners on this forum have no idea what this whole discussion of 720P video and "better" audio have anything in common. Most of the 105 owners use its DACs and analog outputs for audio....not its digital outputs. I can understand this discussion pertaining more to the 103 owners, but not the 105 owners.
eljr and mtn-tech like this.
DanF8500 is offline
post #10812 of 14174 Old 05-22-2014, 08:41 AM
kayhikski's Avatar
Quoted: 22 Post(s)
--Bob
Bob,
Thanks for clarifying. I evidently had a misconception about this.
Best,
James
post #10813 of 14174 Old 05-22-2014, 10:33 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Just want to personally thank Bob for the guidance in post #10810. I have pieced together this information from various posts of his and of others, but it's nice to have it in one concise post. I've saved this off in a Word document and will be double-checking my settings when I get home from the office. I currently am using HDMI 1 direct to Panasonic VT50 and HDMI 2 to McIntosh MX121. I have the Oppo to Split A/V, so I've got the basics right. Now off to check the rest.
Like some other 105/105D owners, when it comes to music I'm generally using the 2-channel balanced outputs to my balanced stage in the A/V processor so I can go "pure/bypass" all the way through. I'm still using HDMI for movies until I can afford 6 high-quality interconnects for the 7.1 outputs.
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #10814 of 14174 Old 05-22-2014, 12:20 PM
Ramatam's Avatar
Hi Bob,
For the life of me, I'm not sure why I hear a difference but I hear one......I was skeptical about it but was surprised to hear something.
Perhaps my ears are playing tricks on me......I don't think so. I might not have golden ears but I'd say that they are perhaps above average and being a musician, I know what to listen for.
I don't wish to question those vastly more knowledgeable here, I am just reporting something. Take it was as many grains of salt as you would like...
I think that there's one or two others who are reporting the same thing.
Anyway, there ya go
Ramatam is offline
post #10815 of 14174 Old 05-22-2014, 12:23 PM
Read the FAQ!
Liked: 4937
^ Sure, I'm not suggesting your ears are playing tricks on you. What I'm suggesting is that it may mean there's a problem which can be FIXED in your 1080p configuration.
--Bob
post #10816 of 14174 Old 05-22-2014, 12:31 PM
Lonely Raven's Avatar
Quoted: 34 Post(s)
Liked: 42
--Bob
Bob has a very positive way of looking at technology!
Lonely Raven is offline
post #10817 of 14174 Old 05-22-2014, 12:37 PM
Ramatam's Avatar
I should have worded my post a bit better. I understand what you have suggested and will try to address that. I appreciate the input. You make an interesting point, if there is something wrong with the 1080p setting then I haven't heard this player's best until stepping down to 720p...and yes it would be difficult to diagnose the problem. I think since it sounds very good now, I'd not go the cabling route as it would sound the same with both settings if cabling was at fault
On another note, using Pure Audio does absolutely nothing to my sound quality, accept allow me to focus more on the audio psychologically as when listening in a darkened room.
I'l do more listening between the two settings and perhaps ask for your assistance.
Ramatam is offline
post #10818 of 14174 Old 05-22-2014, 02:14 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
I think you missed the point of Bob's post based on this statement. If there is cabling/bandwidth issues, it WON'T sound the same on both. Am I wrong?
scirica is offline
post #10819 of 14174 Old 05-22-2014, 02:26 PM
Read the FAQ!
Liked: 4937
^ If the problem is bit drops due to marginal cabling, that will be more likely to happen when sending higher bandwidth video on the cable. 1080p/60 is higher bandwidth than 720p/60. Enabling Deep Color also uses more bandwidth.
Bit drops will USUALLY be noticeable in video before you hear issues in audio. The classic symptom is "sparklies": Randomly distributed, usually widely spaced, pixels turning on and off -- typically most easily seen in black or near black portions of video, particularly if you get up close to the screen.
Sparklies will typically sparkle even when the video is Paused.
HDMI cabling carries both high and low bandwidth signals, and each can fail separately if the cabling is marginal. Failures of the lower bandwidth signals typically show up as "handshake" failures or retries. Failures of the higher bandwidth signals typically show as the sparklies. BOTH are more likely to fail when sending higher bandwidth video.
Of course cabling is just one of many possibilities here. It's also possible the AVR simply isn't handling the 1080p input properly.
--Bob
post #10820 of 14174 Old 05-22-2014, 05:11 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ Ramatam said on the Sound Quality thread that the difference he heard was with the 105's analog outputs....I still say "impossible". Changing the 105's video output resolution should have nothing to do with direct 105 Digital to analog conversion.
Mongo171 likes this.
DanF8500 is offline
post #10821 of 14174 Old 05-22-2014, 09:09 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
A new version of Oppo's Media Control HD app was just made available for tablets (iPads) running iOS 6.0 and later. There's another Oppo Media Control app optimized for the iPhone 5 released yesterday also. I just ran the iPad version of the app and it's a remarkably improved version from all the previous versions. This app is actually very useable! Very robust so far, and digital audio within a media directory is played back in alphanumeric order perfectly! Kudos to Oppo for finally fixing all the bugs which plagued this app since its creation!
DanF8500 is offline
post #10822 of 14174 Old 05-22-2014, 09:18 PM
Liked: 1668
I did the update in my iPad but I love the look of the new iPhone version better. Love the black background on the iPhone version better than the grey on the iPad.
post #10823 of 14174 Old 05-22-2014, 09:43 PM
kellybob's Avatar
"If you are hearing better audio using 720p that's of course a good trick for you to know. But if you really are hearing a significant or dramatic improvement, that suggests there is something wrong with your 1080p configuration. Even the folks who believe there is a technical reason why 720p *MIGHT* sound better wouldn't suggest the difference SHOULD BE significant or dramatic."
I find the difference significant and dramatic, that is why I started talking about this. I am aware that the differences may not be significant or dramatic to others. Point here is that I can see others saying this is a major change and others might not be able to hear it. To me, it is significant and dramatic. It will not be to everyone.
Charles Hansen seems to think it is significant as the dedicated audio ouput on his player runs only at 720P. The explanation for 720P sounding better over HDMI is already there. Some people are hearing the actual proof. Some people aren't.
Hearing this difference does not mean anything is wrong with the 1080P setup, it simply means one can hear the reduced jitter due to using 720P.
I can hear an improvement over all the outputs not just HDMI (well, I did not test optical, but the optical is fed from the coax, so it should also improve). I cannot explain this specifically, but it does not suprise me, and I have theories.
kellybob is offline
post #10824 of 14174 Old 05-23-2014, 12:57 AM
Joe Appierto's Avatar
kellybob,
Should or would this difference in sound at 720P be evident even with HDMI audio turned off and/or in Pure Audio mode?
Joe Appierto is offline
post #10825 of 14174 Old 05-23-2014, 07:18 AM
zoomin's Avatar
Originally Posted by Smarty-pants View Post
Try deactivating NF in the setup menu erasing all you NF info, then reactivate it.
This did not fix the problem for me.
This is from Oppo regarding the 0515 firmware update:
Due to the extensive changes in this major firmware update, it is recommended that the user performs a "Reset Factory Defaults" operation after the firmware is installed. Please write down your special settings before doing this, and remember to re-apply your settings and adjust the proper volume level (if applicable) before you play any content. You may experience stability issues if this step is not performed.
Did you do the "Reset Factory Default" after update? I did it and NF is working fine.
This fixed the problem for me. Thanks.
zoomin is offline
post #10826 of 14174 Old 05-23-2014, 09:47 AM
kellybob's Avatar
Originally Posted by Joe Appierto View Post
kellybob,
Yes, evident with HDMI audio turned off. Yes, evident in Pure Audio mode. Yes, evident with HDMI audio turned off and in Pure Audio mode.
kellybob is offline
post #10827 of 14174 Old 05-23-2014, 09:50 AM
Thank you. Something new to test.
post #10828 of 14174 Old 05-23-2014, 10:20 AM
kellybob's Avatar
kellybob is offline
post #10829 of 14174 Old 05-23-2014, 11:00 AM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is online now
post #10830 of 14174 Old 05-23-2014, 02:19 PM
Sebring5's Avatar
Quoted: 269 Post(s)
Liked: 195
I have downloaded and installed the new firmware six times. No matter what I do the factory settings reset is greyed out and cannot be selected. I'm using a USB thumb drive. The only issue I have is that on some Blu Ray discs I cannot go back using the reverse button on the remote. Any suggestions?
Oppo 203 4k UHD, Meridian Audio Core 200 & M6 Active Speakers, Sony A1E 65" OLED 4k UHD, U-verse
Sebring5 is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
