Official OPPO BDP-105 Owner's Thread - Page 391 - AVS Forum | Home Theater Discussions And Reviews
 504Likes
post #11701 of 14038 Old 10-23-2014, 04:08 PM
edfowler's Avatar
Quoted: 153 Post(s)
Liked: 83
Originally Posted by Smarty-pants View Post
The HA-1 has a better headphone amp, analog inputs and Bluetooth,
but the -105/105D offers a lot more features if the features above aren't your main attraction.
As a barebones 2ch pre-amp, both devices are virtually identical.
This makes me reconsider wanting the HA-1 for my listening room. If they really are virtually identical as a pre-amp I will probably go for a 105D for the multi-channel capability not to mention the bluray movie aspect. I use headphones but the headphone amp isn't my main priority.
edfowler is offline
post #11702 of 14038 Old 10-23-2014, 04:33 PM
Audiguy3's Avatar
Quoted: 123 Post(s)
Liked: 68
Time to take me out and shoot me. I have been ripping all my cds to FLAC on my pc. I have also been downloading DSD files (SACDS) and using the Oppo to connect to those files via my network convert them to analog and output them to the XLR outputs for my Marantz 8801. I had the owner of Audio Alternative over and he noticed that the information on the screen said DSD to PCM when I was playing DSD cuts. I checked my settings on the OPPO for audio. The settings for SACDs was set to "Auto" and I reset it to DSD. I could hear a immediate difference in the music.
I guess I need to do some more reading.
Audiguy3 is offline
post #11703 of 14038 Old 10-23-2014, 05:22 PM - Thread Starter
Neuromancer's Avatar
Quoted: 83 Post(s)
Liked: 314
Originally Posted by Eldecar View Post
Thanks Neuromancer. Turned my network to off and fixed the problem.
Good to know. So you have isolated it down to something on the network which is talking to the player too much which is causing the player to seize up. This was a very common issue with the HomeRun HD products, which was corrected in OPPO firmware, but it is possible that there are still other devices out there with a similar broadcasting scheme which causes havoc in the player.
Neuromancer is offline
post #11704 of 14038 Old 10-23-2014, 05:53 PM
woof07's Avatar
Originally Posted by Bob Pariseau View Post
Gapless from an attached USB drive or over the network from an SMB server works for WAV, FLAC, and APE files. Gapless is expected to extend to other formats at some point, but not yet.
--Bob
I wrote to Oppo today because files I've purchased from Hyperion Records download with flac in upper case (filename.FLAC). I cannot enable the gapless play option for these files. I play music over the network from an SMB server using the latest Media Controller app for iPad. If I change the files to (filename.flac), I can enable gapless playback. Oppo asked me to try it with the remote and UI interface. I cannot enable gapless play for ANYTHING this way (over the network). However, doing it from an attached USB drive it works including those "filename.FLAC" files.
I told this to Oppo and they replied with the following,
"Gapless Play will only work when you are trying to access the files on attached USB storage. It will not work over the network.
Best Regards,
Customer Service "
I think the person answering the emails needs to read our forum. I replied back that I've been enabling gapless play over the network with Media Controller since they released it. I have a feeling they won't address my filename.FLAC issue.
I also asked them about gapless playback for DSD files and they told me this,
"Unfortunately Gapless Playback for DSD will never be supported due to hardware limitations of the decoder and memory architecture of the player."
woof07 is offline
post #11705 of 14038 Old 10-23-2014, 06:09 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2353 Post(s)
Liked: 2957
Keep in mind that no audio processing is possible when using DSD-Direct-to-Analog Conversion. So, for example, if your setup expects Crossover processing or down-mixing or speaker distance adjusmtnes to happen that can't happen with SACD Output DSD. But it does happen when you let the player do the conversion to LPCM. That alone could make an audible difference, although the expectation then would be that the "DSD" choice would sound wrong.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #11706 of 14038 Old 10-23-2014, 07:05 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
A couple more things I did forget to mention... the HA-1 can also play some of the newer higher res DSD files via it's rear
asynchronous usb input, and you can also connect an iPod/iPhone/iPad and some android devices with an adapter to the front
usb input of the HA-1. However you can also do this with the front hdmi input of the 105/105D with a proper adapter as well.
Those features also may or may not appeal to you, but for the most part the HA-1 biggest attribute is the balanced headphone
output to equally capable headphones, and that really is it's main feature.
One more thing... analog volume control.
The volume control for the 105/105D for it's analog output is digital based and thus not as robust as that of the HA-1.
The issues is when you have the volume below 70-75db, and when it is lower than that the fidelity can potentially sound
ever so slightly less resolute since the lower the volume goes, it becomes compressed.
Keep in mind that the issue is only a VERY slight difference in sound and can only be discerned on the highest quality of systems.
I consider my setup to be pretty good and when I tried comparing the HA-1 with the 105D in this specific manner,
I could not determine any difference with the volume of the 105 set at -50- and the HA-1 matched with SPL meter.
Since you are considering buying both of these items I thought I would offer this additional info. Hope it helps.
Smarty-pants is offline
post #11707 of 14038 Old 10-23-2014, 09:38 PM
Audiguy3's Avatar
Quoted: 123 Post(s)
Liked: 68
--Bob
Thanks Bob
I would not use the Oppo for anything that the Marantz is capable of except the D/A. I run the Marantz exactly as Sandy Gross recommends for his speakers with no correction or LFE.
Audiguy3 is offline
post #11708 of 14038 Old 10-24-2014, 01:31 AM
Garman's Avatar
Quoted: 1190 Post(s)
Liked: 509
Well all I can say is I fell in love with the BDP-105D once I hooked it up and I haven't even begun to look at video yet. Every format via Audio I have thrown at it, it plays!! WOW! I have tried equipment 3 times the price and other equipment around the same price and I get popping ticking and just won't play nice when playing audio files and this thing right off the bat plays everything. Just hooked up a 3tb hard drive and plays everything on it! I am tempted to get another one and just use it as my audio source for 2 channel, man they were really thinking of the customer when they put this unit together! Now I will just rip files in Flac or Apple Lossless or any format and buy a few hard drives and store my music, it reads my iTunes library with zero issues so far! The Pre/Amp section isn't bad either but even at the volume set at 1 it still plays pretty loud but sounds very good.
Dave: Thanks for the information you shared above! I found so far when I have the Oppo 105D set to 1 on volume it seems to be more than enough when listening during the evening hours when my kids are sleeping. It would really be cool, if they could make the HA-1 read right off of USB hard drives via the back panel as the 105D. I am so tempted just to use the 105D for my music and just buy the 103D for my video, that's how impressed I am so far on the music side and how this unit just reads everything!
Garman is offline
post #11709 of 14038 Old 10-24-2014, 04:51 PM - Thread Starter
Quoted: 83 Post(s)
Liked: 314
Release date: October 24, 2014
Category: Latest Official Release
Main Version: BDP10X-77-0827
Loader Version: 6U1000 or 7B1300 (BDP-103), 7B1300 (BDP-105, BDP-105D, BDP-103D)
Sub Version: MCU103-05-0916 (BDP-103), MCU105-04-1113 (BDP-105), MCU13D-01-0618 (BDP-103D), MCU15D-01-0930 (BDP-105D), DB10X 131030 (BDP-103D, 105D)
1. Resolved a Color Space issue for the HDMI 1 Out in BDP-103D/105D. Customers reported that if the Resolution was set to Source Direct and the Color Space was set to RGB Video Level, the actual color space sent out was RGB PC Level. This issue has been fixed in this firmware.
2. Resolved a Picture Adjustment issue found on 75-0515 firmware. Customers reported that after changing the Picture Adjustment parameters for HDMI 1, the value of Contrast Enhancement would automatically go back to 0. It has been fixed in this firmware.
3. Resolved a playback issue with regular DVD discs found on 75-0515 firmware. Customers reported that if the "DVD 24p Conversion" was set to "On", pressing the REV (rewind) button within the DVD playback could cause the player to immediately freeze up. This issue has been resolved in this firmware.
4. Resolved a HDMI Audio issue with some 2L Blu-ray Music discs. Customers reported that if the AV Sync was set to 90ms and above, there might be no audio signal from both HDMI outputs.
5. Modified the RS-232 serial control protocol: we eliminated the "#APP FFR" due to the removal of Film Fresh service, added the "#APP BER" to enable access to the Berlin Philharmoniker concert service, also fixed an issue with "#SZM" that could not change the Aspect Ratio.
6. Added support for the “Pandora Premiers” station in Pandora.
7. Improved the Gapless Playback feature, and resolved an issue where the gapless mode could not be enabled for some 96 kHz / 24-bit WAV files.
8. Improved support for CUE files, specifically for CUE files that point to multiple WAV files.
post #11710 of 14038 Old 10-24-2014, 07:46 PM
ultra 150 pilot's Avatar
Quoted: 84 Post(s)
Liked: 43
Sorry if this question has been asked before but is the 105 capable of supporting atmos or aura 3d?
ultra 150 pilot is offline
post #11711 of 14038 Old 10-24-2014, 08:13 PM
Quoted: 747 Post(s)
Liked: 623
Depends on what you mean by "supporting".
Any BD player that can bitstream audio can also bitstream Atmos audio to a processor that decodes Atmos.
However the BDP-10x players from Oppo are not capable of decoding Atmos internally.
post #11712 of 14038 Old 10-25-2014, 02:09 AM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
How come not DSD?
NAIM101 is offline
post #11713 of 14038 Old 10-25-2014, 02:18 AM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Hello, so I bought an oppo 105d months ago, sold it because I didn't have 4K tv at the time plus no preamp, and found oppo to sound harsh and edgy. But since then I now have a tube integrated that is balanced and a 4K T.V, so I am go a buy the oppo 105d again to give it another shot. Was trying to decide between this and cambridge, but because of xlr connection plus a cleaner dynamic sound, I am going with Oppo again . Camnridge would be smoother I assume but my tube integrated is mellow as it is.
Just 2 questions.
1. What processer is doing the 4K upscaling? Is it Darbee? If I put a 4K upscaling on the menu (I assume this is how upscale option would work) on a 4K capable t.v, will all video feed through HDMI on oppo upscale content to 4K?
2. Anyone have 4K t.v who tried this option and how well did oppo upscale?
Edit: just wanted to mention the first time I purchased the oppo105D, I didn't use a seperate preamp and was running the amp straight from Oppo 105D using single ended connection. Perhaps this was the reason why I was getting harsh sound. Even oppo does not recommend using the player as a preamp.
NAIM101 is offline
post #11714 of 14038 Old 10-25-2014, 06:45 AM
Quoted: 84 Post(s)
Liked: 43
Thx, that's what I wanted to know.
Bob
post #11715 of 14038 Old 10-25-2014, 08:55 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1071 Post(s)
Liked: 1034
On the standard 105, the Marvell QDEO handles upscaling to 4K. On the 105D, the VRS video processing chip handles upscaling to 4K. In both cases, 4K output is only available on the HDMI1 output.
gsr is offline
post #11716 of 14038 Old 10-25-2014, 09:53 AM
BillP's Avatar
Quoted: 260 Post(s)
Liked: 201
Many have reported the 105 sounding harsh until it was broken in with 100-200 hours of use.
linger63 likes this.
BillP is offline
post #11717 of 14038 Old 10-25-2014, 11:50 AM
Garman's Avatar
Liked: 509
How come not DSD?
Unit has no problem with DSD files, and Oppo never said anything about not using it as a pre/amp, it's not my main pre/amp but in a second system I tried it out and it sounded perfectly acceptable.
Garman is offline
post #11718 of 14038 Old 10-25-2014, 11:57 AM
linger63's Avatar
Quoted: 83 Post(s)
Liked: 46
Edit: just wanted to mention the first time I purchased the oppo105D, I didn't use a seperate preamp and was running the amp straight from Oppo 105D using single ended connection. Perhaps this was the reason why I was getting harsh sound. Even oppo does not recommend using the player as a preamp.[/QUOTE]
Hi Naim101,
My OPPO 105 DIRECT to my active speakers easily beats my high end stereo preamp
so whilst OPPO may or may not recommend it......... I CERTAINLY DO!!!!!
Cheers,
JohnL
linger63 is offline
post #11719 of 14038 Old 10-25-2014, 01:19 PM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 224
Hi Naim101,
Cheers,
JohnL[/QUOTE]It will depend in great part on the electrical characteristics of the power amplifier into which the Oppo is plugged. If the amp loads the Oppo too much, then it can sound like crap. If the amp does not load the Oppo, then it should sound great.
Some power amps "hide" a small preamp circuit at their inputs anyway, which effectively buffers the input and prevents loading the source device. This is especially common for powered speakers.
RichB and linger63 like this.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #11720 of 14038 Old 10-25-2014, 09:27 PM
linger63's Avatar
Quoted: 83 Post(s)
Liked: 46
Some power amps "hide" a small preamp circuit at their inputs anyway, which effectively buffers the input and prevents loading the source device. This is especially common for powered speakers.[/QUOTE]
Hi,
Thanks for informative reply!!!
Active speakers are ATC SCM 70 with 10 Kohm impedance.
Cheers,
JohnL
linger63 is offline
post #11721 of 14038 Old 10-25-2014, 09:39 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Hello, sorry not very familiar with video in general. So i looked up Hdmi 1 on oppo and it's only output. Would this mean I won't get 4k upscaling from other sources like direct TV through oppo inputs out to my 4k tv? Or would this mean I would get it, but only using hdmi 1 and not hdmi 2 output? Thanks in advance.
NAIM101 is offline
post #11722 of 14038 Old 10-25-2014, 10:17 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1034
Only when using the HDMI1 output. Anything you play through the Oppo (so that includes shiny discs, HDMI inputs, streaming content, etc.), can be upconverted to 4K on the HDMI1 output.
gsr is offline
post #11723 of 14038 Old 10-25-2014, 10:31 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ That's 4K/24 or 4K/30Hz refresh rates for the 103/105, and 4K/60Hz for the 103D/105D, right?
DanF8500 is offline
post #11724 of 14038 Old 10-25-2014, 11:04 PM
Read the FAQ!
Liked: 2957
^ Yes, with the 4K/60 on the 103D/105D restricted to YCbCr 4:2:0 output format.
--Bob
post #11725 of 14038 Old 10-26-2014, 11:58 AM
frank_t's Avatar
For those interested in such things, I asked Oppo whether or not Cinavia has been enforced for MKV files over DLNA or SMB with this firmware. They answered NO and further indicated that it would be *likely* (but not definite) that if they ever are required to do such a thing it would be in the release notes.
Now if they could only fix Chapter Skip+ when using the Oppo as a DMR and also PGS subs for anything over than SMB/local attached storage
frank_t is offline
post #11726 of 14038 Old 10-27-2014, 11:13 AM
Paul Renaud's Avatar
Question Cover art missing with Media Control
I am using my OPPO 105 with a QNAP and the ASSET DLNA software for music play back. I have been controlling the pplayer via the onscreen menu and remote/iphone as remote. When playing an album the cover art is nicely rendered. I started using mediacontrol 3.0 via my iPhone. Everything works fine except the cover art is missing both on the iphone screen as well as the big screen. Is there a setting I have to change or is this a bug in MediaControl or a missing feature. I would love to have mediacontrol having the same graphical interface as JRemote.
Paul Renaud is offline
post #11727 of 14038 Old 10-27-2014, 12:01 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
I had success with displaying cover art with the media control app for usb attached drives, and for the SMB network protocol from my NAS drive. I haven't been able to get cover art to display on the media control app when the 105 is a renderer using DLNA. I can't comment on the Oppo as a DLNA media player, since I don't use the Oppo's onscreen browser anymore.
DanF8500 is offline
post #11728 of 14038 Old 10-27-2014, 03:25 PM
Garman's Avatar
Liked: 509
Thanks for bringing this up, I noticed that last night and I was listening to some DSD files it said DSD>>>PCM , this was on files and Not SACDs but I take it applies in the same way.
Garman is offline
post #11729 of 14038 Old 10-27-2014, 06:29 PM
Audiguy3's Avatar
Quoted: 123 Post(s)
Liked: 68
Garman
The technology today is easy to get lost in. SACD = DSD
I expect (hope) SACD will become the go to format now that there is finally a way to edit DSD files with out converting them first and then back to SACD (DSD)
Audiguy3 is offline
post #11730 of 14038 Old 10-27-2014, 09:07 PM
Garman's Avatar
Liked: 509
Garman
One can only hope, as they abandoned quality music for the cheap and easy MP3 format, with Sony now owning a crapload of music studios one can only hope quality goes forward. I was debating getting a 103D just to do my video capabilities as the 105D and 103D are the same there but I think I am just going to get some longer RCA and run the output to my Int. Amp when I decided to do 2 channel only. My HT system is in a large rack built into the wall, but I wheel out my higher end gear when doing critical listening, since the 105D is like a swiss army knife in audio, I think I am going to go this route.
Garman is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
