Official OPPO BDP-105 Owner's Thread - Page 412 - AVS Forum | Home Theater Discussions And Reviews
 520Likes
post #12331 of 14174 Old 01-26-2015, 03:23 PM
Mongo171's Avatar
Quoted: 994 Post(s)
Liked: 1425
Originally Posted by misko72 View Post
I dont think there is any clipping.
Its just the way it sounds.
I think it has something to do with low pass filter and its rolloff,bryston has 24db octave filter,where oppo must have something like 12db,which would be very unusual for low freq.
Probably it has 18db and that is the culprit!
From my experience,difference between 18db and 24db can be huge.
It can take up to 4vrms in bypass mode.
Never heard of an 18dB slope. The OPPO is 12dB.
Mongo171 is offline
post #12332 of 14174 Old 01-26-2015, 05:05 PM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 226
I had some old "Infinite Slope" brand speakers years ago that had 100+dB-per-octave crossovers. Loved the sound of the speakers - but really can't say whether the crossover slope did anything for them. I suspect that it did, since the phase distortion problem that is inherent in crossovers was mitigated to a great degree. But now we have DSPs that can compensate for that to some degree, and there are both advantages and disadvantages to both conventional and "hard-wall" crossovers. The Audio Theory forum ought to have a good discussion about this.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #12333 of 14174 Old 01-26-2015, 09:44 PM
misko72's Avatar
Quoted: 13 Post(s)
I couldnt find what slope is on oppo,but when its true that it has 12db,i am sure this is the problem i am experiencing.
Why would they use 12db slope,is beyond me.In low pass slope should be steeper,am i right?
In car audio nobody ever would use
12db for low fq.I had amps and preamps in my car,where i was able to set low pass slope,always ended up with 24db and the difference was exactly i am experiencing right now,with oppo player.
Maybe it can be 'fixed' in future with software update?Probably more people must demand it,which i really doubt.
Mike
misko72 is offline
post #12334 of 14174 Old 01-27-2015, 06:08 AM
Mongo171's Avatar
Quoted: 994 Post(s)
Liked: 1425
Mike
My sub has the option of a 12dB or 24dB slope. I use 12dB, but not in a normal way. Sounds good in MY room. You just have to play with it to see what sounds good in YOUR room.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #12335 of 14174 Old 01-27-2015, 06:16 AM
misko72's Avatar
Quoted: 13 Post(s)
I can not play with it,because oppo is not giving me any option
misko72 is offline
post #12336 of 14174 Old 01-27-2015, 07:41 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3789 Post(s)
Liked: 4927
Mike
You are talking about the slope of the Crossover, right? 12dB per octave is perfectly normal. You definitely do *NOT* want a brick wall filter -- i.e., a much higher slope -- as that leads to artifacts.
If you find you prefer a higher slope (as set in your other gear), that suggests either your main speakers are not really good down that low -- i.e., you should really be using a higher value for your Crossover frequency -- or you have room response problems with the bass output of your main speakers when they are allowed to output bass that low -- i.e., the physical location of the Sub is better for coupling those bass frequencies to the room than the physical location of the main speakers.
The only place where high slope filters are appropriate is for very low frequency bass protection. I.e., keeping your Sub from trying to reproduce bass, say, *BELOW* 16Hz. There 24dB/octave is not uncommon.
Are you still trying to use a 50Hz Crossover setting in the OPPO? I really don't recommend that.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #12337 of 14174 Old 01-27-2015, 08:13 AM
misko72's Avatar
Quoted: 13 Post(s)
--Bob
Bob,i really appreciate your input..
No,iam not using 50hz anymore,altough it was as close as could get to prepro.
I wouldnt call 24db slope 'brick wall filter'its not like 48 or higher,..
With 24db slope,there is still some leakage of higher fq,so it should provide smooth blend with main speakers.
Is it very hard to include that option in software update,or is it hardware related?
Mike
misko72 is offline
post #12338 of 14174 Old 01-27-2015, 08:40 AM
Read the FAQ!
Liked: 4927
Mike
I'm' not privy to the implementation details, but it is likely it's adjustable, as it is done in the digital audio processing.
You can email OPPO Tech Support with your suggestion. They do take such stuff seriously.
--Bob
post #12339 of 14174 Old 01-27-2015, 08:57 AM
misko72's Avatar
Quoted: 13 Post(s)
--Bob
That would be great,if they included such feature..
But i am afraid,i am alone with such
an idea.
I will definitely contact them...
Your help is really appreciated,Bob..
Mike
misko72 is offline
post #12340 of 14174 Old 01-27-2015, 09:01 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1286 Post(s)
Liked: 1350
an idea.
They've been known to implement ideas that the think have merit rather than relying on hundreds of people to make the same request.
gsr is offline
post #12341 of 14174 Old 01-27-2015, 09:54 AM
misko72's Avatar
Quoted: 13 Post(s)
Ok guys...
Here is the reply from tech support
Michael,
The DSP in the player was to be used at a single crossover point and at an optimal 12dB octave/slope. The ability to increase this to 24dB, as well as allow for multiple crossovers to compensate for different speaker sizes, is something that has been requested but not something that the player currently supports. This is likely not something that we can add through firmware.
Best Regards,
Customer Service
OPPO Digital, Inc.
misko72 is offline
post #12342 of 14174 Old 01-27-2015, 03:16 PM
classicrecording's Avatar
Quoted: 46 Post(s)
Liked: 94
Well, at least you got it right from Oppo, and now you know.
Mongo171 likes this.
classicrecording is offline
post #12343 of 14174 Old 01-27-2015, 08:15 PM
Bill Mac's Avatar
Quoted: 1591 Post(s)
Liked: 1859
I noticed the 105 hasn't been available for sale on the Oppo site this past week. I contacted Oppo and they replied "We will unfortunately not be looking to carry this model anymore, as we will only be selling the BDP-105D going forward as this model was outselling the BDP-105 to the extent that it no longer makes sense to continue to manufacture the BDP-105." Typical of Oppo they replied very quickly to my email. So it looks like the 105D might be my choice for my next player . I had thought about the Sony 5400ES but the prices are steep and with that no warranty. For me the 105D will be the best choice .
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #12344 of 14174 Old 01-27-2015, 10:21 PM
dbphd's Avatar
Quoted: 511 Post(s)
Liked: 186
Bill,
I have both an Oppo BDP-105 and Sony 5400ES in my setup. They really aren't equivalent. The Sony does analog stereo and digital stereo or surround; it does no speaker management nor video processing or even video pass through, IIRC. The Sony is superb for DSD, and I used it mostly as an analog stereo source until I got the wild hair that I wanted DSD surround so added HDMI and coax to its output and a Cary Cinema 11a to accommodate the digital output. Before the Cary, the Oppo served as processor with stereo bypassed through a Parasound JC-2 BP preamp.
db
dbphd is offline
post #12345 of 14174 Old 01-27-2015, 10:22 PM
audiofan1's Avatar
Quoted: 1879 Post(s)
Liked: 1955
Ok guys...
Michael,
Best Regards,
Customer Service
OPPO Digital, Inc.
I got the same response when I wanted this feature in the 95, would've been nice
audiofan1 is online now
post #12346 of 14174 Old 01-28-2015, 05:19 AM
misko72's Avatar
Quoted: 13 Post(s)
Audiofan-why did you wanted?
Did you have the same experience as i have now,or you wanted multiple crossover fq?
Mike
misko72 is offline
post #12347 of 14174 Old 01-28-2015, 05:50 AM
tomdac's Avatar
Quoted: 18 Post(s)
Got my 105D last night and replaced my BDP-83 with it in my system. Connected the wi-fi dongle and updated the firmware. Was pleasantly surprised when it saw my SqueezeServer on my Mac Mini and allowed me to access it. So far, I'm impressed... I mainly bought this to act as a music server and move me into the hi-res music files arena and have the intention of connecting a USB hard drive to it to play my 50K track music collection... I only spent about an hour or so messing around with it, but so far, I like it. :-)
I played around with the iPhone app too and that seemed like an easier method to find the music I wanted to play... I'm sure I'll have more questions down the road... I'm planning on using the XLR outputs to feed into my Anthem Statement D2 for 2 channel music listening and HDMI for everything else.
Tom
Hayward, CA
tomdac is offline
post #12348 of 14174 Old 01-28-2015, 10:49 AM
audiofan1's Avatar
Liked: 1955
Mike
Yes ! I was after multiple crossovers as I was wanting to hear the Sabre dac's without the need for additional processing. At the time I was using an Anthem AVM 20.v2 which couldn't process the newer codecs . I found that the Anthem with its ability to allow just about any crossover point under the sun to be better sounding than the benefits of the better dac's in the 95 with global crossovers and therefore used its Analog/DSP feature along with the 5.1 inputs. It wasn't such a big deal but its why I don't use the Oppo as a dedicated pre/pro but use my 105 for 2/ch and an Marantz 8801 for all my multi/ch. Should Oppo allow one day in a universal player or pre/pro ( wishing for this big time) I'm the first in line
post #12349 of 14174 Old 01-29-2015, 08:54 AM
groove006's Avatar
Hello I have a 105d and a Cary 11a with 1.4 upgrade. I just bought A Sony xbr 65 950b tv I'm having a tough time setting this combo up properly. Right now I'm using hdmi from Sony to Oppo set on arc and use that for Netflix 4k etc and analog for most else. Martin Logan 5.1 surround. However this configuration is overly complicated. Please help. This Sony 4k has me dizzy. My Samsung plasma was a much easier set up.
Thank you
David
keikihula likes this.
groove006 is offline
post #12350 of 14174 Old 01-29-2015, 08:55 AM
groove006's Avatar
Thank you
David
post #12351 of 14174 Old 01-29-2015, 12:44 PM
elphillips's Avatar
Quoted: 273 Post(s)
Liked: 191
Thank you
David
You might be better off using the OPPO to source streaming content such as Netflix, Vudu etc. The ARC on TVs are notoriously unreliable. Many of us use an optical connection from TV to the avr for apps sourced from the TV.
scirica likes this.
elphillips is offline
post #12352 of 14174 Old 01-29-2015, 04:52 PM
groove006's Avatar
Thank you. I used to do that but Oppo Netflix is not 4k capable and the Sony is. As well as Amazon prime
post #12353 of 14174 Old 01-29-2015, 05:20 PM
JimSatala777's Avatar
Quoted: 149 Post(s)
Liked: 35
If you want to I use the digital output from my tv to my oppo for Netflix because I was having issues with the arc I would get like a warble and what almost sounded like feedback ...only downside is for vudu 7.1 I'm not sure if you are getting all the channels over optical or coax
JimSatala777 is offline
post #12354 of 14174 Old 01-29-2015, 07:58 PM
Quoted: 149 Post(s)
Liked: 35
Ok so if I use the Netflix app or vudu or CinemaNow on my 105D I can't get surround sound to work...vudu has 7.1 dolby and CinemaNow has Dts Netflix has 5.1 dolby but I only get 2 channels out of the multichannel outputs .
it kinda makes the apps useless
post #12355 of 14174 Old 01-29-2015, 08:25 PM
Read the FAQ!
Liked: 4927
^ Check your configuration again. Multi-channel Analog works with all of those apps on the 105D.
Check that you have the speakers enabled and that you don't have a stereo down mix set. For Netflix for example you also need to select the 5.1 track. Use Down Arrow while the program is playing to check what you have selected.
Make sure your AVR or preamp has the multi-channel Analog input selected.
--Bob
post #12356 of 14174 Old 01-30-2015, 07:45 AM
eljr's Avatar
Quoted: 1192 Post(s)
Liked: 9008
i ran an optical cable from my cable box to the 105 and got a 2 second delay in the picture.
Had to forget about it.
ELJR's "listening" blog.
eljr is offline
post #12357 of 14174 Old 01-31-2015, 07:01 AM
groove006's Avatar
Hi Bob the problems are the way way the Sony 4k interacts with the 105d. Even I had my Samsung plasma I could use hdmi on my Cary 11a or analog 7.1 or optical and or straight input 1 for music. Now this Sony overpriced thing hdd crippled the Oppo do you thing the new hdmi on the tv is not playing nice with the Oppo. I can only get stereo now with optical or hdmi or analog. Any suggestions. I'm at on 5.1 down mix to stereo out. Oppo tech suggested not to use front l/r. On my old 95 that was the proper setup but not on the 105d. Or the Sony is defective!
Angry and confused, David
post #12358 of 14174 Old 01-31-2015, 11:49 AM
tranle's Avatar
Quoted: 68 Post(s)
I think that if you are using HDMI ARC, this is how it work, because the TV has only 2 speakers, it will only send back through ARC 2 channel.
My older Sony XBR8 was already doing this with SPDIF out, and I don't if with the newer tv there is an option to tell it to decode all the channels and send it back through ARC or SPDIF.
tranle is offline
post #12359 of 14174 Old 01-31-2015, 12:44 PM
Read the FAQ!
Liked: 4927
I can't figure out what you are talking about. Try again.
ARC audio from the TV into the OPPO can be stereo LPCM or DD 2.0 or DD 5.1. It's up to the TV to decide what it wants to send back down that HDMI connection to the OPPO.
It sounds like you are saying your HDMI to the new TV is also screwing up audio when playing other content sources. If so, there is something screwed up in your configuration, but I've got no clue how you are trying to set things up.
--Bob
post #12360 of 14174 Old 01-31-2015, 12:46 PM
Quoted: 149 Post(s)
Liked: 35
You have to go into the settings on the TV and change the sound to dolby digital or Dts ....you should see its set on either PCM or stereo....it's where you can apply Dts neo 2:5 ....you have to look into your sound settings on your tv...it should give you choices for what you want to send out
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
