Official OPPO BDP-105 Owner's Thread - Page 427 - AVS Forum | Home Theater Discussions And Reviews
 501Likes
post #12781 of 14026 Old 05-04-2015, 11:52 PM
linger63's Avatar
Quoted: 83 Post(s)
Liked: 46
Originally Posted by HowardV View Post
Just to add a note/question.....Isn't an amplifier with a gain control actually an amp which has a pre-amp built-in?
Unlike Patchesj, my amp needs more output from the Oppo. I can have the Oppo volume at 100% and still need more. I live in an apartment, so I won't get a pre-amp - this limitation is a blessing for my neighbors and a guide for me to not crank it up really loud when I've been drinking
But my speakers and amp are clearly saying to me "is this all you got? Give us more!". If I ever move into a house where neighbors aren't an issue, I would have to add a pre-amp. Sometimes I wish my amp had gain controls. But many amps don't.
Hi,
Here's something that might help you get a bit louder.
Try connecting a hybrid I/C from the XLR outs of your OPPO to the RCA ins on your Gallo's.
The XLR outputs on the OPPO are 4V whereas the RCA's are 2V.
You should still be able to achieve a higher volume level and get some of the benefits that OPPO claim to have added to the XLR outs.
Apologies if you are ALREADY doing this!!!
Cheers
linger63 is offline
post #12782 of 14026 Old 05-05-2015, 01:05 AM
patchesj's Avatar
Originally Posted by stehno View Post
Thanks for the correction.
Right... I have turned down the gains on the amps, turned up the Oppo volume and noticed increased detail. I've dug into the DAC specs and it appears they are expanding out the DSD signal to 32 bits and truncating for volume control, similar to the method with PCM but without converting DSD to PCM. The actual magic behind this is hush hush apparently... The claim is that this method does not impact sound quality or increase S/N ratios, but I have a repeatable test to say it does (at least in a non-blind subjective test ). I would love to have other people try this to make sure I'm not just hearing things. An interesting note is that PCM material does not seem to have the same increase in detail. So either the claim of their method being magic is not true and PCM is always losing detail, or the nature of DSD makes it more susceptible to bit truncation (even with a string of 0's) than PCM. This seems odd as PCM would only give an extra 8 bits of 0's for volume (24bit material for hi-res, expanded to 32bit) vs 26 bits of 0 (DSD @ 6 bits)
patchesj is offline
post #12783 of 14026 Old 05-05-2015, 06:43 AM
LairdWilliams's Avatar
Quoted: 199 Post(s)
Liked: 224
Actually, not necessarily. The gain control on a power amp is often really just an input level control - a variable attenuator that comes very shortly after the input circuit that controls the signal level entering the power amp circuit. Not always - some power amps definitely DO have preamps "hiding" at their inputs.
"Gain" controls are kind of misleadingly named. The actual amplifier part of an amplifier circuit, whether a voltage amp (preamp) stage or power amp stage, has its actual amplification level fixed to one level. It is the job of attenuator circuits to control signal levels entering or leaving that stage. When you turn up the gain control on an amp, you are really just turning DOWN the amount of attenuation being applied by an attenuator circuit. On a power amp, this is almost always placed before the first part of the amp circuit - often right after the input stage. There are exceptions, of course. I have built some designs for class A/B power amps where the volume control was between the phase inverter and the power amp section, called "post-PI volume" for obvious reasons.
The point I was trying to make is about matching. You buy a power amp, with or without a preamp circuit, and for the input on that amp, there is an optimal range of circuit characteristics in the source device that work best for that amp. This often has to do with signal levels, but it can also have lot to do with impedances and sometimes, at least with longer cable lengths, cable capacitance (this is not usually an issue in hi-fi though). If you purchase a piece of source gear, it may well be able to produce a signal that is pretty close to the middle of those characteristics. But that is a bit like winning the lottery. You just got lucky. MOST of the time, the source gear outputs are far from ideal for a given power amp input. Adapting the one to "play nicely" with the other is exactly what a preamp is for.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #12784 of 14026 Old 05-05-2015, 10:43 AM
HowardV's Avatar
Quoted: 65 Post(s)
Liked: 52
Originally Posted by LairdWilliams View Post
Actually, not necessarily. The gain control on a power amp is often really just an input level control.....
Thanks for the explanation, although it goes above the level of my understanding. But I completely agree that it's a crap shoot in hoping that the Oppo's output will match an amplifier's input perfectly.
Originally Posted by linger63 View Post
Hi,
I appreciate the advice. But most of my music listening is multichannel. Unfortunately, Oppo only has RCA outputs for multichannel. I could still use the XLR output for front left/right, but I'd have to turn down the levels to match the center/rear RCA outputs...which would defeat the purpose of using XLR for the higher output.
My main amp is the Spectron (which has both RCA and XLR inputs). The Gallo amps just power the 2nd voice coil of the speakers. I wish the Oppo had all XLR outputs as well.
Oppo BDP-105 Blu-Ray
Spectron Premiere MKII 7 Channel Class D Amp (500w x 7)
2 Anthony Gallo Reference SA Amps
5 Anthony Gallo Reference 3.5 Speakers
Sunfire Super JR Subwoofer
Sony Z2 Series laptop as dedicated HTPC
HowardV is offline
post #12785 of 14026 Old 05-05-2015, 11:13 AM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
^^^MCH is also Output on HDMI.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #12786 of 14026 Old 05-05-2015, 06:30 PM
jilgiljongiljing's Avatar
I'm a bit unclear on this Multi-channel analog out put vs HDMI.
Right now I have the BDP-105 connected to my Pioneer elite receiver via both HDMI and Multi channel analog 7.1 RCA cables. Problem as has been mentioned by many before is that I dont get any of the EQ and management capabilities on the Analog input selection. I have two inputs set on the Pioneer, one with HDMI so I can do NEO:6 conversion on online videos and home videos that are lo-res, and another one for the multi-channel inputs to utilize the Oppo DAC.
When I watch hi-res material I want to be able to use the Oppo's DACs for doing D-A duties and use the Pioneer to do just the amplification, but also give me some ability with the EQ so I can trim my fronts a bit on the bass.
I am not quite able to figure this out. How do I connect the Oppo to my Receiver, with the Oppo doing the D/A duties and the Amp doing the EQ. It appears this may not be possible. If I set it to output LPCM via HDMI, then its just decoding the format but still letting the Pioneer do the D/A conversion after processing, if I let the Oppo send it out of the analog RCA, I dont get to change anything. Is there any other way around?
If this is the case, are all the folks using the Multi channel analog outputs from the Oppo simply running it straight to their speakers without any EQ?
Right now I'm thinking either Bass traps, or a processor with EQ on the analog inputs (does something like that even exist?)
jilgiljongiljing is offline
post #12787 of 14026 Old 05-05-2015, 07:00 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2253 Post(s)
Liked: 2819
To use the OPPO DACs you have to use the Analog audio outputs.
It is actually pretty typical that AVRs won't "process" multi-channel Analog audio input. That's a feature typically resolved for the high-end AVRs and prepros. Note that to DO that sort of processing, the Analog input first has to be re-digitized. Then after processing (Room EQ and/or whatever -- all of which is done digitally) it gets converted BACK to Analog for transmission to the power amps and speakers. That conversion back to Analog would be done by the DACs in the high-end AVR or prepro.
If the AVRs redigitizing and DACs are good enough this can all work well. On the other hand, if you send HDMI LPCM or Bitstream to the AVR the redigitizing step is eliminated.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #12788 of 14026 Old 05-05-2015, 07:05 PM
Quoted: 199 Post(s)
Liked: 224
Which Pioneer Elite model? You may have promoted yourself to the department of redundancy department - a situation where you payed handsomely for TWO very high-end DACs when only one can be in the signal path at a time...
...at which point I would shoot for convenience and room correction and just use HDMI.
linger63 likes this.
post #12789 of 14026 Old 05-06-2015, 12:41 AM
Frank Derks's Avatar
Quoted: 311 Post(s)
Liked: 260
Some out of the box thinking:
Buy a nanoAVR (HD or Dirac version) from miniDSP for the room correction and add an Oppo 103D.
Oppo 103D -> nanoAVR -> hdmi input Oppo 105.
The 105 is used as a multichannel dac while the 103 is doing the player/streaming duties.
Frank Derks is offline
post #12790 of 14026 Old 05-06-2015, 08:41 AM
I have an older model the SC-27, I for one an quite certain the Oppo DACs are better, maybe it wont make all that much of a difference for majority of the material, but with lots of good music coming out in the hi-res formats on Bluray, I'd like to use the BEST DAC in my chain.
I just wish the Oppo would have had this as an option, a 10 band parametric you can mess with. You measure the room, you figure it out and then set it manually on the Oppo (Kinda like the Outlaw Processor)
post #12791 of 14026 Old 05-06-2015, 08:43 AM
This is quite the chain and will indeed solve it, but maybe a bit overkill
post #12792 of 14026 Old 05-06-2015, 08:50 AM
--Bob
Exactly, I've been thinking about swapping out the SC-27, I could in theory get a new Pre and run the SC-27 as a power amp for now and invest in a power amp later, but then it looks like all of them would work in the digital domain to do any corrections and hence defeat the purpose.
This does bring me back to my original question, is the Oppo 105 really designed for people who have perfect rooms and speakers and an AVR that wont touch the Audio AND Video? for if its not, then why do we need all the bells and whistles on the 105?
post #12793 of 14026 Old 05-06-2015, 09:19 AM
Read the FAQ!
Liked: 2819
^ The 105 and 105D are intended for people who want to use a pure Analog signal path for Audio external to the player. Some folks who do that for music still use HDMI audio for movies, typically to get access to value-added audio processing in their HDMI-capable AVR. For Analog, they set the AVR to pass-through the Analog signal unprocessed except for volume control.
Some other folks use the 105 and 105D as a simple pre-amp. I.e., they have its Analog outputs connected directly to their power amps. Of course they still use HDMI for video.
--Bob
post #12794 of 14026 Old 05-06-2015, 12:54 PM
dbphd's Avatar
Quoted: 388 Post(s)
Liked: 143
^ The 105 and 105D are intended for people who want to use a pure Analog signal path for Audio external to the player. Some folks who do that for music still use HDMI audio for movies, typically to get access to value-added audio processing in their HDMI-capable AVR. For Analog, they set the AVR to pass-through the Analog signal unprocessed except for volume control. Of course they still use HDMI for video.
--Bob
Bob,
For audio, my 105 is connected to a Cary Cinema 12 via HDM2; HDMI-1 goes directly to a projector. I have cables for analog connection between the two units, but have yet to install them. Do you have any opinion about how the DACs of the Cary and Oppo might compare sonically?
My impression is that surround sound and bass management are better with the Cary in the loop compared to connecting the 105 directly to amps. The Cary does not digitize an analog signal in by-pass mode, and it is trivial to switch between Cary HDMI and 7.1 inputs. I suppose the only downside is cable clutter.
db
dbphd is offline
post #12795 of 14026 Old 05-06-2015, 12:58 PM
Read the FAQ!
Liked: 2819
^ I don't know enough about the Cary to help with this, except for the obvious advice to trust your own ears.
--Bob
post #12796 of 14026 Old 05-08-2015, 09:31 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
--Bob
I'm definitely one of those people. Analog out to my MX121 and from there via Pure Direct mode to my amp. Analog sources are the Oppo 105D and my Bryston BDA-2 DAC.
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #12797 of 14026 Old 05-08-2015, 10:42 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
+1.
Everyone who has a 105/105D should be using its analog outputs. It is a great disservice to these players to not be utilizing their dacs/analog outs....an analogy would be buying a Ferrari and never driving it faster than 50 mph..
DanF8500 is offline
post #12798 of 14026 Old 05-08-2015, 10:53 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
Originally Posted by DanF8500 View Post
+1.
I agree and disagree. I believe a Ferrari would be something like an Esoteric K01X. The Oppo 105 is a great universal player, but there are better DAC chips than the Sabre used in the Oppo. My Bryston BDA-2 for example is a much better DAC for 2-channel than the Oppo.
Having said that, I will always have the Oppo 105D in my rack because it can do everything and do it well. You have to pay thousands more to see improvement over the Oppo.
scirica is offline
post #12799 of 14026 Old 05-08-2015, 11:01 AM
eljr's Avatar
Quoted: 1050 Post(s)
Liked: 8025
I doubt it.
I hate to steal the thunder from folks like FMW but I'd be shocked if a consistent preferable difference was attributed to the Bryston over the Oppo in a DBT.
just sayin.
eljr is online now
post #12800 of 14026 Old 05-08-2015, 11:33 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1059 Post(s)
Liked: 987
I think Dan's point was that if you're not going to use the analog outputs it would make a lot more sense to save a bunch of money and get a 103 or 103D.
gsr is offline
post #12801 of 14026 Old 05-08-2015, 11:56 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Yes, this is correct. .....but we all know that doing what's more sensical is not always synonymous with audio aficionados.
DanF8500 is offline
post #12802 of 14026 Old 05-08-2015, 12:39 PM
BillP's Avatar
Quoted: 258 Post(s)
Liked: 199
I don't think most on this thread would agree with FMW or spkr that all CD players and all DACs sound the same. Just sayin.
BillP is offline
post #12803 of 14026 Old 05-08-2015, 12:42 PM
BillP's Avatar
Quoted: 258 Post(s)
Liked: 199
The Bryston is also $2400. For the money, the 105 is hard to beat.
BillP is offline
post #12804 of 14026 Old 05-08-2015, 01:25 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
I doubt it.
just sayin.
Whatever. You are wrong but that of course is one man's opinion. Doesn't mean the OPPO isn't a great machine.
Sent from my iPad using Tapatalk HD
scirica is offline
post #12805 of 14026 Old 05-08-2015, 01:26 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
I don't think I ever said it wasn't. But when someone compares the Oppo to a Ferrari, I think that is a bit overstated. I do like the enthusiasm however.
scirica is offline
post #12806 of 14026 Old 05-08-2015, 02:17 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
You misunderstood....I wasn't comparing an Oppo to a Ferrari. I was comparing not using the dacs of a 105/105D as analogous to limiting a high horse powered car to only 50 mph. Car/Oppo price was not a factor in my comparison. Sorry for the confusion.
DanF8500 is offline
post #12807 of 14026 Old 05-08-2015, 04:26 PM
eljr's Avatar
Liked: 8025
I've got 5 cd players priced from $500 to $4000 and a DAC.
I can hear no difference between any of them no matter what system I use.
I don't think many would question the quality of the speakers or amps I use as a reason to not hear any differences.
You may be right that people will disagree with FMW and the gang but in many ways FMW is correct. He's a little to all encompassing and a zealot but he has a point.
eljr is online now
post #12808 of 14026 Old 05-08-2015, 07:48 PM
BillP's Avatar
Quoted: 258 Post(s)
Liked: 199
If I may ask, then why did you buy a $4000 player?
scirica likes this.
BillP is offline
post #12809 of 14026 Old 05-08-2015, 09:11 PM
JimSatala77's Avatar
Quoted: 396 Post(s)
Liked: 139
oppos dacs are very good and their setup is pretty clean...but I definitely hear a difference going from using the oppos dacs to my foundations dacs or my directstream and as far as cd playback the PSAudio PWT blows the 105d out of the water only issue is the PWT wont play SACD DSD LAYER...Now where OPPO Really Stands out is as a Media Streamer...it can play anything up to dsd64 over dnla and it can do 128 from an extr hdd and its control apps are better than anything else for seamless playback IMO
JimSatala77 is offline
post #12810 of 14026 Old 05-08-2015, 09:13 PM
Quoted: 27 Post(s)
I don't know much about audio, but I know plenty about cars.
I got the Ferrari analogy immediately.
But my take is this:
Oppo = Porsche. Great on the road, great on the track, and *relatively* easy on the wallet. Nice and analog if you can get into one that's still got a stick.
Ferrari = What piece of gear sounds *incredible* when you first get it, but costs as much as the purchase price to service over a decade, occasionally breaks down for no reason, will lock you out of its computer and disable you from overriding anything manually, and has a parent company that will tell you to like it no matter what?
You guys will have to find that piece of equipment for an appropriate analogy.
scirica and JimSatala77 like this.
eephusman is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
