Official OPPO BDP-105 Owner's Thread - Page 430 - AVS Forum | Home Theater Discussions And Reviews
 504Likes
Old 05-25-2015, 01:14 PM
Bill Mac's Avatar
Quoted: 1289 Post(s)
Liked: 1486
Originally Posted by JohnAV View Post
You mean 105 owners, doesn't have to be multiple models discussion.
Sure that will work best .
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
Old 05-25-2015, 01:56 PM
markus767's Avatar
Quoted: 3737 Post(s)
Liked: 1338
Originally Posted by Bill Mac View Post
With the current discussion of bass management and the possibility of signal distortion is it audible?
Pretty easy to hear IF you also happen to know what the undistorted version sounds like. Put on headphones and listen to the following two files on your computer.
80Hz sine at 0dBFS:
https://dl.dropboxusercontent.com/u/...80Hz-0dBFS.wav
80Hz sine driven into distortion by only 1dB:
https://dl.dropboxusercontent.com/u/...z-%2B1dBFS.wav
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old 05-25-2015, 02:03 PM
markus767's Avatar
Liked: 1338
Originally Posted by Bob Pariseau View Post
OPPO used to do that in the older players -- -15dB down regardless of whether Crossover was engaged.
They got enough push back, that they improved it for these players. Of course no additional attenuation is required if the Crossover is disabled.
--Bob
Don't follow. What kind of signal flow do you have in mind?
Markus
Old 05-25-2015, 02:07 PM
Mongo171's Avatar
Quoted: 839 Post(s)
Liked: 1282
Distortion is audible in "Interstellar."
Mongo171 is online now
Old 05-25-2015, 02:09 PM
Bill Mac's Avatar
Liked: 1486
80Hz sine at 0dBFS:
Did you find this with your 105? I'll pass on playing the files. I don't listen to surround movies or music with headphones on. Do you have any music or movie titles that would exhibit this distortion.
Thanks ! I'll check this when I rent it from Redbox. Any specific areas of the movie to listen for the distortion?
Bill
Old 05-25-2015, 02:10 PM
splotten's Avatar
Quoted: 269 Post(s)
Liked: 110
Well that can't be it because if you play the 5.1 LPCM test track from AIX Audio Calibration Blu-ray using the multi-channel Analog outs, the LFE test is down -15dB with Crossover enabled (compared to the other speaker tests) and down -10dB without Crossover enabled. I.e., you need +5dB more Sub boost, as expected, with Crossover enabled. This is on the 10x players.
--Bob
OK. I really dont know what to make of it then, except to say that it sounds like there is room for improvement. Wonder if this is this a common short coming. Just ordered a RX-A2040 that was on sale. It shall be interesting to see if that does the same thing. Fingers crossed :-)
splotten is offline
Old 05-25-2015, 02:15 PM
markus767's Avatar
Liked: 1338
Bill
You don't need to "listen to surround movies or music with headphones on" You just need to listen to the two files I've posted. You're already sitting in front of a computer, no? Plug in headphones and play the two files.
Markus
Old 05-25-2015, 02:16 PM
smurraybhm's Avatar
Quoted: 1504 Post(s)
Liked: 1811
80Hz sine at 0dBFS:
Marcus - respect your knowledge and propensity to dig, but how about something we would normally listen to, I don't listen to test files. Igor managed to suggest a few disks on the issue with the XMC-1 that demonstrated the bug he found. It would be nice to have a few here, it's not difficult to design a test signal that a/v devices will not handle correctly.
I don't see owners posting about this issue when playing actual content, I use analog outs for 2-channel and haven't heard it on anything I've played since buying one via early invite from Oppo. My collection of hi-res music isn't comparable to Bill's, but not too shabby either. Thanks. Steve
Bill Mac likes this.
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is offline
Old 05-25-2015, 02:19 PM
markus767's Avatar
Liked: 1338
Bill
Such a "test" is nonsense because you have nothing to compare to. You would need to have access to the undistorted version of the movie and listen to it A/B.
Markus
Old 05-25-2015, 02:23 PM
markus767's Avatar
Liked: 1338
Actually it is IMPOSSIBLE to design a test signal that would drive the output of bass management into clipping IF summing is properly implemented.
Markus
Old 05-25-2015, 02:25 PM
wse
wse's Avatar
Quoted: 2070 Post(s)
Liked: 756
Exclamation
OPPO is probably waiting to see what the next format will be before making the next new models.....
Yes they told me December 2016 or January 21017
wse is offline
Old 05-25-2015, 02:28 PM
Bill Mac's Avatar
Liked: 1486
No offense but you just don't seem to get it do you . I have no interest in listening to "files" on my computer with headphones. I would like to hear the issue with my 105 using material I listen to in the way I listen to it. Is that so hard to grasp? I'm not the only AVS member that has told you they don't listen to "files" either.
It is quite apparent that you don't own the 105 by your refusal to answer my question if you in fact own one. So why do you care if the 105 has this issue if you don't own one? It seems your issue is with Oppo so why don't you contact them instead of bogging down multiple Oppo threads. But I guess that could be an problem as Oppo will ask you what the issue is with your 105 and you'll have to say "well I really don't own the 105.......... That would be a bit awkward for you .
Bill
Old 05-25-2015, 02:30 PM
Mongo171's Avatar
Quoted: 839 Post(s)
Liked: 1282
80Hz sine at 0dBFS:
Bill
At anytime the LFE channel gets loud. Like the rocket launching. The bass sounds very bad through the sub.
Old 05-25-2015, 02:31 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3548
Arrow 'Interstellar' on Blu-ray
Bill
If you want to hear from real life movie watching/listening on Blu-ray:
The first "dream" sequence @ the beginning, and also the rocket launch sequence, and also the going through the wormhole sequence, and going through Gargantua, and the big wave....
* Set your Oppo 105's bass management so that all your speakers are selected as SMALL. ...Turn the master volume just below reference level; @ reference level you might damage your subwoofer(s). ...And yes, it's the multichannel analog connections that you are using here; that's what the internal bass management in the Oppo 105 is for. ...Not from the digital HDMI connection (or Coax or Opt.).
Strap yourself real good, and listen to your sub(s).
♦ But as Markus just mentioned above you can also verify much easily; his suggestion is the best...most efficient and simple...for confirmation.
P.S. I am not taking responsibility if you damage your sub(s). ...You asked a question, I just gave you an answer; so proceed @ your own risk.
And by the way, 'Interstellar' is not the only Blu-ray title that you will get sub channel clipping issue from; there are many many more titles...movies and music too. ...Any BR movie titles and music recordings (SACD multichannel, etc.) with prominent bass would do.
Best of luck.
NorthSky is offline
Old 05-25-2015, 02:35 PM
markus767's Avatar
Liked: 1338
You obvisouly don't know what it sounds like when a digital signal is driven to levels above 0dBFS. I just offered you an easy way to find out for yourself. "You can lead a horse to water ..."
I understand that very well but you don't seem to understand the simple notion that you can't compare A to B if B is missing. Such a test is nonsensical.
I'm well aware of the annoying logical fallacy behind such statements.
Markus
Old 05-25-2015, 02:37 PM
Mongo171's Avatar
Quoted: 839 Post(s)
Liked: 1282
Bill
Distorted sound isn't clean and precise. Don't need an o'scope to realize it. A good ear, maybe.
Old 05-25-2015, 02:38 PM
NorthSky's Avatar
Liked: 3548
That ^
NorthSky is offline
Old 05-25-2015, 02:39 PM
Mongo171's Avatar
Quoted: 839 Post(s)
Liked: 1282
I agree with markus. If you have poor equipment, distortion won't be audible.
Old 05-25-2015, 02:48 PM
markus767's Avatar
Liked: 1338
Without knowledge of the undistorted original there's just no way to make such an assessment. Listen to a recording with an electric guitar. Is it the distortion of the electric guitar you like or the distortion of your equipment on top of the already distorted guitar sound?
Using measurements and test signals is just so much easier and precise. For others it's obviously more like a red rag to a bull.
Markus
Old 05-25-2015, 02:58 PM
JazzGuyy's Avatar
Quoted: 292 Post(s)
Liked: 286
Are any multi-channel SACD, DVD-Audio or downloadable .flac or .dsd files affected by this? Most multi-channel music I own doesn't have an LFE channel so I suspect there may be few, if any, music cases but maybe someone knows of some specific examples. I would only use analog audio with subs for music, otherwise I use my AVR for movies.
JazzGuyy is online now
Old 05-25-2015, 02:59 PM
Bill Mac's Avatar
Liked: 1486
Is the above post related to the Oppo 105 in any way? I would suggest you start a specific thread for this issue as the Mods have already requested. It really is bogging down this thread IMO. "Red rag to a bull"? More like beating a dead horse.
Bill
scirica likes this.
Old 05-25-2015, 03:01 PM
Mongo171's Avatar
Quoted: 839 Post(s)
Liked: 1282
Does one have to see and hear a rocket launch in person for that person to hear a distorted playback of a rocket launch on a HT? I think not. And to respect dead horses everywhere, if you don't get it by now, you won't. Out.
Old 05-25-2015, 03:13 PM
smurraybhm's Avatar
Liked: 1811
Thanks for the typical Marcus response - is respect just a one way thing for you? I could understand without the caps and have no trouble with Bill regarding his headphone use. Personally within the last year I just started down the headphone path as well as buying an HA-2, should have never started, expensive path. HA-1 may be coming unless I quit reading this forum.
So who normally uses analog outs for movies? Still interested in a music file that would create the issue though.
Old 05-25-2015, 03:26 PM
Super Moderator
markrubin's Avatar
Quoted: 1064 Post(s)
Liked: 2334
may I suggest a separate thread for bass management discussions? in the Audio Theory Forum...http://www.avsforum.com/forum/91-aud...ry-setup-chat/
and that we move on please
thanks
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
Old 05-25-2015, 04:21 PM
beatmachine's Avatar
Tivo Romao OTA and 105
Hoping this issue hasn't been posted:
Picked up an OTA Tivo and cannot receive picture and sound simultaneously. Tivo HDMI to both 105's front and back inputs does not have sound. When I try Digital audio, there is sound but no picture. I troubleshot with an HDMI direct to LG display and it worked fine.
Frustrating as I have a DTV that works fine through the 105 via HDMI.
Suggestions?
thanks
Mike
beatmachine is offline
Old 05-25-2015, 04:28 PM
Mongo171's Avatar
Quoted: 839 Post(s)
Liked: 1282
Suggestions?
thanks
Mike
How do you have the OPPO setup, Split A/V or Dual Monitor? With only one TV, it should be set on Split A/V.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Old 05-25-2015, 04:31 PM
NorthSky's Avatar
Liked: 3548
Did you select the appropriate HDMI input (source) in your Oppo 105 Blu-ray player?
NorthSky is offline
Old 05-25-2015, 04:34 PM
Mongo171's Avatar
Quoted: 839 Post(s)
Liked: 1282
That, too!
Old 05-25-2015, 04:41 PM
Thanks for responding Mongo and Northsky
Yes to both: Selected HDMI front and HDMI setting : Split/AV
No sound. Its a mystery because my DirecTV works fine through HDMI.
Old 05-25-2015, 04:42 PM
oops-- let me clarify : Selected HDMI BACK ..and Split AV
Oppo Bdp 105 Blu Ray Player
