Official OPPO BDP-105 Owner's Thread - Page 459 - AVS Forum | Home Theater Discussions And Reviews
 481Likes
post #13741 of 13746 Old 07-27-2016, 12:15 PM
BassThatHz's Avatar
Quoted: 1793 Post(s)
Liked: 1357
Originally Posted by miike88 View Post
does anybody know if the crossover slope is 24db on the OPPO?
It is 12db.
BassThatHz is offline
post #13742 of 13746 Old 07-27-2016, 11:09 PM
Liked: 0
Question re speaker distance settings
I assume the speaker distance settings apply whenever the Oppo is playing digital, i.e. Blu-ray or HDMI content, but a) do they apply to a digital stream feeding the rear USB input? or b) do they apply when using the balanced analog outputs?
sdolezalek is offline
post #13743 of 13746 Old Yesterday, 05:36 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 1323 Post(s)
Liked: 1335
Speaker distance adjustments DO apply to media files read from a hard drive attached to one of the rear, USB, peripheral ports (thin rectangular socket), but do NOT apply to stereo audio sent into the USB DAC port (square socket).
EXCEPTION: When playing media file content from a hard drive attached to a USB peripheral port in DSD digital audio format (the format used on SACD discs), whether or not audio processing happens depends on the SACD Output setting. If you have DSD-Direct-to-Analog conversion engaged, the DSD goes directly to the DACs -- so audio processing, including speaker distance adjustment, is bypassed.
Audio sent into the USB DAC port always goes DIRECTLY to the DACs, thus always bypassing all audio processing, regardless of other settings. Meaning you get just Volume control.
The Dedicated Stereo Analog outputs (both the RCA pair and the XLR pair) are controlled by the Stereo Signal setting. When that is set to DOWN-MIXED STEREO, the Dedicated L/R outs operate independently of the Speaker Configuration settings for the multi-channel outs. You get a "Stereo" down-mix, with no per-speaker volume trim, no distance adjustment, and no crossover processing -- i.e., they are treated as LARGE. (Main Volume and Mute still apply.)
When set to FRONT LEFT/RIGHT, the Dedicated L/R outs respond to all the settings that would normally affect the Left Front and Right Front outs of the multichannel Analog set -- including speaker distance adjustment. The intent is that you will wire a Dedicated L/R pair INSTEAD of wiring LF/RF from the multichannel Analog set.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #13744 of 13746 Old Yesterday, 08:18 AM
Liked: 0
--Bob
Terrifically clear answer. Thank you. I'm using HQPlayer to upsample files sent to the USB DAC port to DSD128 and HQPlayer has very granular (down to the centimeter) distance adjustments, so I wanted to make sure I wasn't doubling up by also having the speaker distance active in the Oppo when playing hi-res music files this way.
post #13745 of 13746 Old Yesterday, 04:41 PM
kmmcdonald's Avatar
I have had our new BDP-105D for a few weeks. Where is the best place to buy high resolution "studio" quality .flac and DSD files of classical music? My investigations online so far indicate that it is the wild west, and that some sources provide files are true high resolution, and some are just upconverted from CD format.
thanks
Keith
kmmcdonald is offline
post #13746 of 13746 Old Today, 04:50 AM
jamesg11's Avatar
jamesg11 is online now
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
