Official OPPO BDP-105 Owner's Thread - Page 97 - AVS Forum
 15Likes
post #2881 of 11258 Old 01-17-2013, 08:11 AM
TrebleClef's Avatar
Originally Posted by Bob Pariseau View Post
Yes, the 105 can play 5.1 FLAC 96KHz 24-bit music files -- both from an attached hard drive and over your in-house network.
People have reported some issues with a type of meta-data sometimes found in them which rejoices in the name "ID.3 tags", which are not really SUPPOSED to be in there, I gather. (They are actually for a different file format.) There are evidently easy ways to strip those with utilities if needed.
Quite a few of the posters here are happily using multi-channel FLAC files, so I expect some will pop up with answers if you need more details. --Bob
So, if using the highly heralded OPPO DAC, we must add a Processor down the chain to get multichannel, correct? The OPPO DAC only delivers 2.0 audio.
I understood UPTHREAD (yes, I've read the entire thing), that this in some way would compromise or circumvent the high quality output from the onboard OPPO DAC.
Still learning....Thanks.
TrebleClef is offline
post #2882 of 11258 Old 01-17-2013, 08:22 AM
stevepow's Avatar
Liked: 27
You can play 5.1 straight from the Oppo - no processor required. What you cannot do is play 5.1 from the USB DAC input (directly from your computer using the Oppo as the "sound card") - that input is for stereo only. I have a bunch of 5.1 DVDA rips that I play from an attached USB directly to the Oppo analog outputs - sounds great.
Stephen Powell
stevepow is offline
post #2883 of 11258 Old 01-17-2013, 08:31 AM
TrebleClef's Avatar
Thanks stevepow.
So you are connecting your PC to one of the OTHER USB ports on the OPPO. Which one? Or does it even matter?
In your opinion then, you are not losing anything by bypassing the special USB DAC, which is one of the most heavily discussed difference makers and discriminating features on this unit?
Thanks for your reply. Much appreciated.
post #2884 of 11258 Old 01-17-2013, 08:38 AM
JazzGuyy's Avatar
Liked: 77
You aren't bypassing the DAC. The USB input is just another way of using the onboard DAC in the Oppo. Its input only allows stereo.
JazzGuyy is online now
post #2885 of 11258 Old 01-17-2013, 08:55 AM
TrebleClef's Avatar
Is there some sonic advantage then to having a SEPARATE USB DAC that does only stereo?
I guess I'm having a hard time understanding why all the hoopla over the special USB B connector DAC, when the other USB A DACs do just as much, or more (multichannel).
post #2886 of 11258 Old 01-17-2013, 09:05 AM
HowardV's Avatar
I don't believe you can connect a computer directly to the other USB "A" Dac's, you can only connect a computer to the USB "B" DAC as it acts as a sound card. You can still connect a computer to the SPDIF or coaxial digital inputs of the Oppo if your computer has this type of output. The benefit of the USB "B" DAC is that it's asynchronous provided that you have a Windows 7 computer or a Mac.
You still get excellent quality using the SPDIF or coaxial and you can make up for the asynchronous part if you run ASAPI for your music playback program on your computer (Foobar, Jriver, etc.).
The USB "A" inputs can be used if you connect an external harddrive directly to the Oppo, not a computer. At least that's the way I understand it.
McIntosh MX-119 Pre/Pro
Oppo BDP-105 Blu-Ray
Spectron Premiere MKII 7 Channel Class D Amp (500w x 7)
5 Anthony Gallo Reference 3.5 Speakers
Sunfire Super JR Subwoofer
Sony Z2 Series laptop as dedicated HTPC
HowardV is offline
post #2887 of 11258 Old 01-17-2013, 09:18 AM
stevepow's Avatar
Liked: 27
Originally Posted by drumgail View Post
Hi;
I purchased the Oppo -105 as soon as it became available, my set up is running the Oppo out of HDMI 1 into my Onkyo TX-VR 809 Receiver, then HDMI out of the audio receiver into the TV (Sharp LC-60LE632U) for my video, should I run the HDMI out of the OPPO straight into the TV? If I do this, what is done about the audio for the Receiver?
You can do that using "HDMI Split" Mode: HDMI1 to the TV for the video, and HDMI2 to the receiver for the audio.
I was also trying to run HDMI 2 out of the Oppo into my receiver for audio for my DVD-Audio and SACD playback because I have several discs and love the DSD sound, doing this, I had no sound coming out of HDMI 1 using the HDMI AV Split setting, I got audio when I went to the Dual Display HDMI setting, I got 2 different responses from Oppo when I talked to them, one was that by using the Dual Display setting I am not getting the best audio possible, another was that it was ok to use the dual display setting, I want the best audio on HDMI 2 and the best Video/Audio on HDMI 1.
If you use split mode, it is by design that there is no audio from HDMI1 - this explains it well: http://watershade.net/wmcclain/BDP-103-faq#how-does-dual-hdmi-output-work. For most receivers that cannot "matrix" HDMI video to different sources (listen to one input while watching HDMI video from another), split mode will only be useful with HDMI1 connected directly to the TV. Then you need another input on your TV to use for the AVR menus.
I bought the Onkyo because of the DSD decoding capabilities. By using the HDMI 2 output instead of going analog out of the Oppo am I shortchanging the sound possibilities? Should I not be concerned about the DSD decoding in the Onkyo and just run analog cables? I believe the Onkyo does the DSD decoding over the HDMI, not sure if it will decode it over analog cables. Does the analog quality outweigh the HDMI DSD method?
The main reason for buying the BDP-105 versus the 103 is to take advantage of the analog outputs. For playing content over HDMI, both players are identical. So you spent about $600 for the analog outputs - and they do sound very good. There are 3 possibilities for SACD DSD playback:
1 - Set the Oppo SACD Playback mode to DSD and use the analog outputs. This avoids ALL processing in the Oppo (no speaker trim, no crossover/bass management, etc) - it is a very pure way to play SACD and you hear the mix as it was engineered. If your speakers are placed well and your room sounds good, this can be an awesome way to hear SACD.
2 - Set the Oppo SACD mode to PCM and use the Oppo analog ouputs. This will take advantage of the Oppo processing - speaker trim, crossover/bass management, etc.
3 - Send DSD or PCM over HDMI to your Onkyo to playback. If you send DSD to the Onkyo, you most likely lose all the processing the Onkyo can do (bass management, trim, Audyssey, etc). If you send PCM to Onkyo, then you take advantage of all the processing the Onkyo can do including Audyssey. But you are now using the Onkyo converters and analog section rather than the well-regarded Oppo analog section. Which sounds better? You have to do some listening and decide.
If I go strictly HDMI, I am trying to go best possible Video for HDMI 1 and best audio for HDMI 2 but to use the AV Split setting, it would force me to pull out the HDMI connection in the back of the Oppo out and move it when I want to play blu ray and when I wand to play SACD which is inconvenient, The Oppo Tech said just leave it in HDMI 2, that the video improvement would not warrant the inconvenience, saying that the only difference on HDMI 1 is Contrast Enhancement, Noise Reduction and 4K capabilities.
For split AV, you leave HDMI1 connected to the TV and HDMI2 to the receiver - there should be no need to shuffle the connections around.
I recently sold my home and moved into a new one, my basement man cave in the new home will not be finished until I get more funds, unfortunately I had to leave much of my home theater as well as my old PSB Stratus speakers as part of the selling price of my old house. I am currently using for my living room setup: Onkyo TX-NR 809, Wharfedale Diamond 8.4 for fronts, Wharfedale Diamond 10 CS for center, 2 JBL ES250 12" for Subs and my wife made me put speakers in the ceiling for aesthetics for surround, I think it is Dayton Audio Ultra Series, Acoustic Research AR-1 turnatable and now the Oppo-105.
What should my suggested setup and settings on the Oppo be? Not ready to run separate amps into Oppo, but should I go analog out for SACD/DVD-Audio playback? Since HDMI 1 will control the Video/Audio of the bluray, if I go analog, what do you use for the visual of the SACD menu and the DVD-Audio visual functions? The Oppo is capable of running HDMI 1 out and analog at the same time right?
You should at least try analog playback of SACD/DVD Audio - although you may like the processing from the Onkyo better - that depends on so many things, only you can decide that.
HDMI1 Video with simultaneous Analog out works fine - in Split AV or Dual mode.
In Split or Dual mode, the Oppo menu screens for playback control and setup appear on both HDMI 1 & 2. If you are using Split AV and connecting HDMI1 directly to the TV, you'll have to switch to another input on the TV that is connected to the Onkyo AVR to change any of the AVR settings. If this is inconvenient, you have to decide if Split AV is worth it for any perceived video quality improvements.
Lastly, the audio/video sync issue on the Oppo I have had from day one is very concerning to me, I would think that this would have been resolved prior to it's release.
Be easy on me, I am not that astute at Audio/Video, but I love it ! Thanks .....Mark
Stephen Powell
stevepow is offline
post #2888 of 11258 Old 01-17-2013, 09:32 AM
TrebleClef's Avatar
Ah, well that would definitely explain the difference.
Unfortunately that takes me back to Square One as all of my rather large collection of digital material is stored on my Home Server (WHS 2011). It makes little sense to export it to an external drive.
Yes, the vast majority of it is in Stereo format (FLAC), and I do understand that I can get 2.1 (subwoofer) out of the USB B DAC with some wiring tricks, but call me crazy, I have become fond of 7.1 multichannel reproduction via my Processor, of much of this stereo material . Yes, I know it is not true multichannel, but to my ears, the participation of all 8 speakers is often superior to plain stereo.
Thanks for that important clarification.
post #2889 of 11258 Old 01-17-2013, 09:38 AM
jfz
jfz's Avatar
Originally Posted by decooney View Post
SOUND CHECK!
With 94+ pages of ongoing hardware, software, firmware tech talk about the BDP-105 and not so much about sound quality,
I started a separate "sound only" only thread for audiophile types and anyone who might be interested in providing feedback.
Link Here: http://www.avsforum.com/t/1451764/oppo-bdp-105-sound-quality-check-thread-for-audiophiles
Thank you!
jfz is offline
post #2890 of 11258 Old 01-17-2013, 09:46 AM
stevepow's Avatar
Liked: 27
Originally Posted by james57 View Post
...audio RCA to a poweramp Celeste 4070 and BW804
Playing cd was a charm, it did lack a bit of bass extension but I am convinced that with a few hours of burn-in that the sound will improve, I am comparing to my trusted Audio GD DAC 3DV. I never beleived in burn-in before getting this DAC but I was forced to admit that the sound changed radically after 200 hrs. Volume control is really good with variable output and can confirm that this is a great setup, skipping a preamp stage all together. I will try the XLR out in a few days.
Playing BR, the sound level for some reason is really low compared to cd's. It is not as crips and lacks extension, less engaging. This is odd because I am using the exact same setup as cd's, any clues why the sound level is lower ?
Playing HDMI in from a external OTA tuner, the picture is again amazing, color deeper and less noise, this was a great surprise. The audio synch once the latest firmware applied is significantly better but not perfect, a little more work and this one will disappear from the punch list. Again tle audio has the same issue than with BR, its lower and less engaging.. any clues ??
Comparing the CD audio and Blu-ray could be tricky if it is not the exact some audio content. From above, it sounds like the entire setup is stereo only. If this is true, you are probably having to set the Blu-ray content playback as down-mixed to stereo. Down-mixing attenuates each channel so as not to overload the processing (stuffing 7.1 channels into 2). That down-mixing can make some playback seem low. That might be the issue - hard to say. There's a lot of variation in audio levels even from CD to CD - depending on the artist and style.
The only Blu-ray content I have evaluated so far is this sampler / calibration disc - AIX Records - Blu-Ray Audio Calibration Disc and HD Music Sampler - and it sounds wonderful. That and Stones Live at the MAX - pretty great sounding as well.
Stephen Powell
stevepow is offline
post #2891 of 11258 Old 01-17-2013, 09:47 AM
HaroldKumar's Avatar
My experience as well. The low end will start filling in for you after a few days.
HaroldKumar is offline
post #2892 of 11258 Old 01-17-2013, 09:49 AM
stevepow's Avatar
Liked: 27
Try the DTS Neo:6 processing in the Oppo for stereo sources. It can sound pretty cool if you like to get all your speakers involved while still enjoying the Oppo's analog output - should work on FLAC audio coming from your server over Ethernet.
Stephen Powell
stevepow is offline
post #2893 of 11258 Old 01-17-2013, 09:57 AM
TrebleClef's Avatar
Try the DTS:Neo processing in the Oppo for stereo sources. It can sound pretty cool if you like to get all your speakers involved while still enjoying the Oppo's analog output - should work on FLAC audio coming from your server over Ethernet.
Someone suggested that (or something similar) early on.
I don't believe that works with the USB B DAC.
However, I will try it again tonight. Isn't that a configuration setting off the Main Menu in "Audio Setup", or something like that?
post #2894 of 11258 Old 01-17-2013, 10:06 AM
stevepow's Avatar
Liked: 27
No, DTS Neo is only for the other stereo inputs; however, using the USB Async DAC is a very purist way to play stereo audio - taking that and then turning it into faux surround would be sort of audio heresy - likely with punishments up to and including having your Oppo confiscated. eek.gif
Stephen Powell
stevepow is offline
post #2895 of 11258 Old 01-17-2013, 10:07 AM
james57's Avatar
Hi Steve & HK thanks, Yes my setup is purely 2ch stereo using the rca-xlr analogue out. As for the downmix I was under the impression that this would only affect the multi-channel DAC. I am always using the other pure audiophile one ? The difference in level is quite significant almost double ie 3db
james57 is offline
post #2896 of 11258 Old 01-17-2013, 10:15 AM
TrebleClef's Avatar
Well, the "multichannel" thing is probably out the window.
The bottom line: It looks like I MUST use the USB Async DAC if I want to stream DIRECTLY from my Server. With that constraint, and in lieu of a Processor (which I suppose is also considered a heresy), I am limited to 2.0 or 2.1.
I'll just have to get used to good old STEREO again.
post #2897 of 11258 Old 01-17-2013, 10:36 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 143 Post(s)
Liked: 311
What about network access? Via DLNA or SMB.
-Bill
wmcclain is online now
post #2898 of 11258 Old 01-17-2013, 11:02 AM
JazzGuyy's Avatar
Liked: 77
You don't need the USB DAC to connect your home server to the Oppo. You can use either the SMB shares or DLNA (depending on your hardware/software on the server) and link your server directly to the Oppo.
post #2899 of 11258 Old 01-17-2013, 11:03 AM
TrebleClef's Avatar
-Bill
I'm not sure what you are getting at.
Are you referring to alternative network protocols which would allow DIRECT playing of media from my server, WIHOUT using the STEREO ONLY USB B DAC (async) port/connection?
post #2900 of 11258 Old 01-17-2013, 11:06 AM
wmcclain's Avatar
Quoted: 143 Post(s)
Liked: 311
-Bill
Yes. This is standard on many Blu-ray players and media servers. See the DLNA sections in the FAQs linked in my signature.
-Bill
post #2901 of 11258 Old 01-17-2013, 11:08 AM
TrebleClef's Avatar
I'll have to explore that, as I'm not sure of the implementation of that scheme. I MUCH prefer to use the WIN7 PC interface to the primitive GUI on the OPPO.
Doesn't DLNA require the use of Windows Media Center?
I've been using the richly featured Media Monkey as my player.
post #2902 of 11258 Old 01-17-2013, 11:09 AM
wmcclain's Avatar
Quoted: 143 Post(s)
Liked: 311
There are many different DLNA servers available. Microsoft's are not the best loved.
-Bill
post #2903 of 11258 Old 01-17-2013, 11:09 AM
TrebleClef's Avatar
-Bill
OK, thank you very much for the information.
Looks like I have STILL more reading/learning to do.
As if this ENTIRE thread wasn't enough. LOL.
post #2904 of 11258 Old 01-17-2013, 11:30 AM
TrebleClef's Avatar
-Bill
The term "DLNA Server":
Is that referencing a software media player such as Media Monkey, J River or MS Media Center/Media Player? Maybe even VLC?
It does not refer to a separate Server OS, I assume?
As mentioned, my Server is WHS 2011 , but I pull media from it via a number of Win 7 machines, running various media player softwares.
post #2905 of 11258 Old 01-17-2013, 11:34 AM
wmcclain's Avatar
Quoted: 143 Post(s)
Liked: 311
-Bill
Yes, it's a program running on a computer. You can run it along with all your other stuff. See the FAQs, there is a list of what people have reported using with the OPPO. We have a separate thread here on DLNA for OPPO.
-Bill
lanping09 likes this.
post #2906 of 11258 Old 01-17-2013, 12:28 PM
stevepow's Avatar
Liked: 27
The Stereo XLR outputs have two possible settings: Stereo Downmix or Front L/R (see page 74 in the manual). If you have them set as Front L/R, then the other 5.1 analog outputs must be used to get all channels of a multi-channel source- otherwise the other channels are sent off into nowhere. If you have the XLR outputs set as Stereo Downmix, then all multi-channel sources (other than SACD DSD) are mixed down to stereo - probably what you want.
I just did a quick test - the Stones MAX Blu-ray has both a DTS Master and a Stereo LPCM version of the audio - I have a meter on the stereo outputs of my system and the down-mixed DTS Master track indeed measures roughly 6dB lower on peaks than the same track played back from the Stereo LPCM version. I also tossed in a regular CD (not the Stones live though) and that track was also about 6dB hotter on peaks than the down-mixed DTS Master.
Now, back to the Stones...using an SPL meter in the room with the DTS Master playing back in 5.1 compared the same track played back from the LPCM version, the SPL was almost identical. This is exactly what I would expect since there are simply more amplifiers and speakers playing back the individual channels versus when they are down-mixed.
Stephen Powell
stevepow is offline
post #2907 of 11258 Old 01-17-2013, 12:52 PM
tme110's Avatar
Thanks stevepow.
There's only one USB connection you can connect a PC to.
If you have have a digital input and an analog output there is no way you can ever bypass any DAC.
You don't have to use the USB DAC, it's only an option for people who need it. IF you don't need it there's no point in trying to find a use for it. Many people have seperate external USB (or other) DACs connected to their computers already. If you already have the 105 then you can get rid of your other DAC. Since my DACs cost as much as the 105 did, the 105 saved me a lot of money. And the 105 DAC still provided much more capabilities than any external DAC.
tme110 is offline
post #2908 of 11258 Old 01-17-2013, 02:13 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 122 Post(s)
Liked: 771
New User Manual Available for BDP-105
http://www.oppodigital.com/blu-ray-bdp-105/blu-ray-BDP-105-Support.aspx
In the US, OPPO Digital has now posted V1.6 of the User Manual for the BDP-105. Changes appear to be mainly additional clean-up and editorial corrections.
--Bob
stevepow and lanping09 like this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #2909 of 11258 Old 01-17-2013, 03:20 PM
JRDiAndrea's Avatar
Well, my most recent issue is with DVD-Audio & SACD Multichannel playback. It seems that each time I first put in either of these disc formats that are multichannel I initially only get stereo output. I have to turn the player off, then turn back on. Then I get the multichannel output. No other adjustments are made prior or after. Anyone else experience this?
JRDiAndrea is offline
post #2910 of 11258 Old 01-17-2013, 03:40 PM
Read the FAQ!
Quoted: 122 Post(s)
Liked: 771
Are you running the latest firmware? Check Setup > Device Setup > Firmware Information. Your "Main" firmware version should end 1220.
How are you connected for audio output when the problem happens? Are you using the multi-chanel Analog outputs? Are you also using Dedicated Stereo Analog outputs in place of the normal LR/RF output pair of the multi-channel Analog outputs (i.e., Stereo Signal = FRONT LEFT/RIGHT)?
What does the on-screen music playback graphic say is happening when the problem happens? For example, for SACD it will display whether it is playing the 5.1 or the 2.0 layer.
--Bob
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
User Tag List
