Blu-ray worth it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-25-2012, 02:52 PM - Thread Starter
igolf's Avatar
I have an older Mitsubishi HDTV 1080 (probably 1080i). It does not have an HDMI connection. I am currently running a DVD player with component video. Would I notice a considerable improvement if I upgraded to a Blu-ray player with component video?
igolf is offline
post #2 of 6 Old 12-25-2012, 03:49 PM
JazzGuyy's Avatar
Quoted: 287 Post(s)
Liked: 268
Yes. But unless you can find an older model or buy a used player, you will not be able to. Blu-ray players with component video are no longer being made. Blame the content owners who succeeded in having them banned.
JazzGuyy is online now
post #3 of 6 Old 12-25-2012, 03:57 PM
Super Moderator
teachsac's Avatar
Quoted: 651 Post(s)
Liked: 958
Welcome to AVS. There are several dedicated threads for your situation.
Analog Sunset:
http://www.avsforum.com/t/1305969/analog-sunset-begins
Component Output:
http://www.avsforum.com/t/1316836/2011-model-with-component-outputs-and-1080i
Another option is to search the Help Me Choose thread with component.
Good luck.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #4 of 6 Old 12-25-2012, 04:08 PM - Thread Starter
igolf's Avatar
What about this one sold at Wal Mart?
http://www.walmart.com/ip/LG-BD550-Blu-ray-Player/13912185
It's my understanding that BD can be played over component up to 1080, you just can't upconvert DVD's to 1080 over component correct?
igolf is offline
post #5 of 6 Old 12-25-2012, 04:52 PM
Super Moderator
teachsac's Avatar
Quoted: 651 Post(s)
Liked: 958
Incorrect. Please refer to the Analog sunset thread posted above. Questions regarding specific players should be addressed in the appropriate player thread. I believe LG has disabled HD over component.
S~
teachsac is offline
post #6 of 6 Old 12-25-2012, 04:56 PM
rboster's Avatar
Quoted: 894 Post(s)
Liked: 747
Analog Sunset:
Component Output:
Good luck.
S~
Thanks for the links. OP please use the above links to do your research and ask follow up questions about component output from blu ray players. If you need suggestions for br players, please post in the "help me chose a BR player" sticky thread
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
Closed Thread Blu-ray Players
