Help me diagnose the issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-26-2012, 09:53 AM - Thread Starter
JX71's Avatar
I have an Hitachi TV and a Toshiba Blu-Ray Player. When I connect them with an HDMI cable, into either HDMI port (HDMI1 or HDMI2), a pop-up reading "Not Supported" emerges for a millisecond before the Blu-ray screen comes up and vanishes within about five seconds. Then you can here the blu-ray player running, but nothing happens.
What could the problem be? Perhaps they aren't compatible? How can I fix this problem?
JX71 is offline
post #2 of 6 Old 12-26-2012, 11:44 AM
rboster's Avatar
Quoted: 904 Post(s)
Liked: 752
Please post the model numbers of your TV and blu ray player.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
post #3 of 6 Old 12-26-2012, 03:36 PM - Thread Starter
JX71's Avatar
Sure thing.
The Hitachi TV is an HDTV Model: LE29H306 and the Toshiba Blu-ray Disc/DVD Player is a BDX3300.
JX71 is offline
post #4 of 6 Old 12-26-2012, 03:40 PM
rboster's Avatar
Quoted: 904 Post(s)
Liked: 752
I assume you have tried other source components (cable box etc) that can output an HD signal? If so, does the TV have any issues showing 720p or 1080i (or p) signals on your TV?
First, try a different video cable.
Another option I would try is to set the player's resolution output to match your TV's native resolution of 720p. Try that and report back.
Lastly, do you have another TV you can test the player on the second set? If not, I would suggest taking the player over to a friend or neighbor's house and test it on their HD set.
As you can see I am trying to elimate which unit is causing the issues.
Retired Moderator
rboster is offline
post #5 of 6 Old 12-26-2012, 05:53 PM - Thread Starter
JX71's Avatar
The other TV works fine, watching 2010: The Year We Make Contact as I write this. Weird.
JX71 is offline
post #6 of 6 Old 12-26-2012, 07:53 PM
rboster's Avatar
Quoted: 904 Post(s)
Liked: 752
It appears it's a TV issue. I can move this thread to LCD forum if you would like?
Retired Moderator
rboster is offline
Reply Blu-ray Players
