blu ray player with component input/output for SD TV - AVS Forum | Home Theater Discussions And Reviews
Old 12-28-2012, 01:41 PM - Thread Starter
xtreme23's Avatar
hey guys i recently purchased a Samsung BD-E5900 blu ray player and have hooked it up to the tv in the living room which is SD TV. I did purchase a HDMI to Component Converter and some Premium RCA Cables but with the 28AWG cable the reception is not working(I ordered 24AWG to solve the issue as per guidance of Monoprice.com). One thing I was wondering if there any blu ray players out there that are component cable instead of HDMI and has APP access (Netflix, Pandora, Hulu Plus etc..) and also can play DIVX, XVID thru USB? I almost bought a Panasonic but decided on the Samsung instead (the Panasonic did have component so it might have been better) due it being able to play DIVX/XVID thru USB. So if anyone knows any good blu ray players that fit the above criteria I would really appreciate it. Thanks and Happy Holidays.
Sam
xtreme23 is offline
Old 12-28-2012, 02:01 PM
rboster's Avatar
Quoted: 886 Post(s)
Liked: 742
This topic has come up before...in fact earlier this week. If you go to advance search engine, use component as your search word and use title search only you'll find previous threads on the topic. If you are looking for recent players (there are less and less as time goes on) you'll want to bump an existing thread seeking an update.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
Samsung 3d Blu Ray Disc Player Bd E5900
