Denon DBT 3313 Owner's Thread - Page 11 - AVS | Home Theater Discussions And Reviews
post #301 of 326 Old 09-23-2014, 11:52 AM
newguy548's Avatar
Originally Posted by mmwwmm View Post
Just a few things to try. In the remote switch off "pure" option (the 3313 display shows the mode engaged) . If you use both 3313 hdmi outputs try to swap them to see if you have video. If not try all output resolutions pushing the "video resolution" button on the remote (the 3313 display shows the output resolution engaged).
Hope this helps
Thanks mmmwwmm. I tried your suggestions:
1. switch off pure
2. swapping cables and output ports
3. I could not locate "video resolution" button on remote. I tried changing the resolutions through the menu
I also tried swapping cables; swapping ports; updating firmware; hard reset (pushing up & down buttons on front panel and power on receiver until u see the display lights flash 4 times)
still no luck. Denon support wants me to ship the unit to them. Unfortunately, thats not an option now since I am out of the country (with my receiver) for another 6 weeks
newguy548 is offline
post #302 of 326 Old 09-23-2014, 11:59 AM
mmwwmm's Avatar
Quoted: 14 Post(s)
1. switch off pure
Video resolution button it's the left button in the lower row in the remote.
Just a last thing to try. Unplug ALL cables (HDMI, HDlink, RCAs power cord, etc) in the 3313, leave unplugged for 5mins and then plug again all the cables and try it. Denon receivers and blurays needs this kind of soft reset from time to time to avoid "strange" issues.
Good luck!
mmwwmm is offline
post #303 of 326 Old 09-23-2014, 12:04 PM
mmwwmm's Avatar
Quoted: 14 Post(s)
Good luck!
I forgot to say that if you have a Denon receiver too try this kind of soft reset in the receiver too. I.e. Unplug ALL cables (except passive speakers) I mean subwoofer, bluray, ethernet, triggers, HDMIs, AC wall, etc etc. And leave unplugged at least for 5min.
Good luck!
mmwwmm is offline
post #304 of 326 Old 10-23-2014, 06:51 AM
gadgtfreek's Avatar
Quoted: 232 Post(s)
Liked: 387
Any news on a 2014 model? I thought these came out every 2 years.
65" VT50 / Oppo 103D
Denon 4520CI / Emotiva XPA-3
Klipsch RF82 II and RC62 II / Hsu VTF-15H (2)
Directv HR44-200 / HR24-500
gadgtfreek is online now
post #305 of 326 Old 10-26-2014, 05:13 PM
Figarou's Avatar
Quoted: 117 Post(s)
Liked: 48
Nothing was mentioned at CEDIA about a new blu-ray player from Denon. Maybe their next model will be a 4K Blu-ray player in 2015.
Figarou is offline
post #306 of 326 Old 10-28-2014, 10:34 PM
Schwa's Avatar
Quoted: 334 Post(s)
Liked: 318
There was a new firmware update provided today...anyone have a link to the changelog?
Schwa is offline
post #307 of 326 Old 11-02-2014, 10:13 AM
ArTourter's Avatar
Well that's not cryptic at all!!!
The european changelog file says:
HQ 9304
The correction of the trouble of the video streaming service.
Hmmm, I am not sure what to say to that!
ArTourter is offline
post #308 of 326 Old 11-23-2014, 08:31 PM
j_sunne's Avatar
Safe firmware update foe DVD region free
Just a FYI for anyone DVD region free (I've not bothered with BR-region free), I let the unit upgrade the firmware and it didn't break the region free. Unfortunately, I only let it upgrade because bitstream over DLINK for Netflix and Vudu recently stopped working and we'd just rented a Vudu movie for impatient kids. I later tried the 5min unplug reset and it's still only passing audio from the streaming services as PCM. Next step, the hard reset.
j_sunne is offline
post #309 of 326 Old 11-23-2014, 08:47 PM
j_sunne's Avatar
I just realised the instructions above were for the AVR. No idea how to hard reset the BDP-3313, maybe just unplugging is the only option. The bitstream issue might be an issue with my X4000 AVR as I recently had an issue where the "Network" functions all stopped working. I really dont want to reset the AVR and set everything up again.
j_sunne is offline
post #310 of 326 Old 12-21-2014, 04:01 AM
fordiebianco's Avatar
Hi All,
my very lovely DBT-3313UD started playing up last night: this started after inserting the new 'Guardians of the Galaxy 3D' bluray: the player refused to play the content (no pic/sound was sent to the amp) and got stuck. Never happened before with any blu-ray / 3D content. From then on trying different sources (cd/sacd/DVD/BluRay) all didn't work. When the player boots up, it immediately goes into 'pure direct 1' and from then on refuses to respond to remote control. There is no time to do a reset via the remote in the menu.
Is there a way to perform a hardware or microprocessor reset?
I tried the 'remove all cables and leave it off electricity over night' but no avail.
Ideas appreciated.
FB
fordiebianco is offline
post #311 of 326 Old 12-21-2014, 06:55 PM
wadec22's Avatar
Quoted: 105 Post(s)
Liked: 45
Originally Posted by fordiebianco View Post
Hi All,
Ideas appreciated.
FB
the only two reset methods are unplugging it or reset via remote.... sadly I think you are going to have to have it worked on.
Denon 4520CI
Emotiva LPA-1
Epson 5020ub::::100" ES Cinewhite
PS4::::Toshiba HD-A35:::::::::Denon DBT 3313UDCI::::Darbee 5000::::Marantz UD5007
Martin Logan Stage(c)::::ML Aerius I(l/r)::::ML Motion FX(fw/s)::::ML Scripts(sb)
PSA XV15:::::PSA XV15se
wadec22 is online now
post #312 of 326 Old 12-22-2014, 12:09 PM
That's what I feared.
Thank you for the response, see what Denon will come up with.
That's the second Denon piece of kit breaking down in 3 months....
FB
post #313 of 326 Old 12-22-2014, 05:26 PM
wadec22's Avatar
Quoted: 105 Post(s)
Liked: 45
FB
major bummer. I've had the oppo 103, Marantz ud5007 (still own) and the denon dbt3313. I much prefer the soft image of denon's custom mediatek solution.
Denon 4520CI
Emotiva LPA-1
post #314 of 326 Old 12-24-2014, 08:50 AM
Hi, there's good and bad news:
Good news: you can hardware reset the player (see picture).
Bad news: it didn't work on mine.
FB
post #315 of 326 Old 12-29-2014, 05:08 PM
Liked: 0
J_sunne, I just tried to reset the region code to "0" but am unable to navigate once I access the Factory Page. Can you please provide additional instruction on changing the code once in the Factory Page. Thanks in advance.
Dthomps0 is offline
post #316 of 326 Old 12-31-2014, 02:04 AM
Liked: 0
Originally Posted by j_sunne View Post
<div class="quote-container" data-huddler-embed="/t/1448111/denon-dbt-3313-owners-thread/240#post_24633504" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>MarkGriffin</strong> <a href="/t/1448111/denon-dbt-3313-owners-thread/240#post_24633504"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Hi, Just tried a region 1 DVD in my 3313UD and it won't play. So tried a region 1 BD and wouldn't play. Tried the files posted in this thread and they work for BD which is great. And pressing setup 3265 shows the region change for BD.<br>
Is there a set of files to change the DVD region? I can't seem to find any<br>
Thanks in advance for any help</div>
</div>
<br>
I've been looking for some time but no luck. I've not seen any confirmation of a unit where the end user could switch DVD region without having purchased it supplied already multi region. A dealer in the UK supplied the bulk of the region free models you'll see in various forums. I only had a handful of Region 2 DVDs and used AnyDVD Cloner (lots of other software can do the same) to directly re-author without a region. The DBT-3313 is outputting PAL DVDs as 1080/50p which I was pleasantly surprised to find my Samsung display (UN55F7100) handles fine.<br><br>
EDIT: I stand corrected courtesy of some great members. Both Blu Ray and DVD region can be changed by the end user with this unit.
Dthomps0 is offline
post #317 of 326 Old 01-11-2015, 01:00 PM
mcd4959's Avatar
FB
I had the exact same issue with Guardians of the Galaxy 3-D last night. Player simply would not play it. I have an Oppo in another room in my house and it played fine on that.
Similarly I've had multiple issues with the Denons lately - the Oppo was purchased to replace a DBT-1713 that had real trouble playing old DVDs and some Blu-rays. I always make sure I have the latest firmware so that wasn't the issue. I just got fed up - and have had no problems with the Oppo.
So after the Guardians problem on the 3313 last night I tried those problematic DVDs in it - and sure enough, they had the same problem as I experienced with the 1713. They just would not play. Front display just reads "ROOT".
This is troubling on many levels - both Denon players are at the slightly over 2 years old mark and both broke down the exact same way. Very frustrating. I am a Denon lover, have the AVR-4520 in my theater and the AVR-4311 in my living room system. Both of these are upgrades over several other Denons I've owned over the years so I am a longtime fan.
What has happened? Players at this cost level shouldn't break down after 2 years. Very disappointing, not to mention the $$$$ I've had to lay out.
Exxodus and fordiebianco like this.
I love this site!
mcd4959 is offline
post #318 of 326 Old 01-13-2015, 02:19 AM
I know what you mean. I have a Denon AVR-5200 and am eyeing it suspiciously. I actually shelled out the extra cash for the 5200 because it was built in Japan and the built quality apparently is better than the chinese factory Denon/Marantz contract.
If you pay >1000 bucks for your AV gear, you really shouldn't have to worry about built quality.
FB
post #319 of 326 Old 01-18-2015, 12:07 AM
wadec22's Avatar
Quoted: 105 Post(s)
Liked: 45
really odd... had no issues with GOTG in 3d on my unit, or any other new releases... might want to try a newer hdmi cable. I doubt it's the issue, but on a 2yr+ old unit, it may be worth a shot.
Denon 4520CI
Emotiva LPA-1
post #320 of 326 Old 01-23-2015, 03:23 AM
Shad0wDK's Avatar
Hi,
I just bought an AVR 4520 second hand, and I'd like a new blu ray player as well (got one of the very first sony blu ray players). I considered the Denon DBT 3313 UD, but as it is getting kinda "old" now, do you think it would be a bad idea to purchase this model? Would I be better off waiting for a refresh, or getting another brand?
Shad0wDK is offline
post #321 of 326 Old 01-23-2015, 06:42 AM
wadec22's Avatar
Quoted: 105 Post(s)
Liked: 45
Originally Posted by Shad0wDK View Post
Hi,
IMHO it's still the best player available. The custom Mediatek solution is an awesome picture. I found it to be superior to both the Oppo 103 and the Marantz UD5007. If you have a large collection of DVDs, it has an even larger advantage since it does such a killer job with standard DVD picture.
Having said that - know what you are buying. If you get a new in box unit, I think you have nothing to worry about, but will probably over pay. If you buy a used unit, I think you are missing out on some hardware revisions.
I've owned two units - one purchased new, that had absolutely no issues whatsoever, but was also manufactured in '14. The used unit I bought was manufactured in '12. While I've had no major issues with it (and I use the latest firmware), it does act a little goofy sometimes. It can sometimes take two power cycles to wake up if I shut it off with a disc in it... I can't think of another example, but they are there. Just little bugs you can tell they could not eliminate with a firmware update, but obviously did eliminate with hardware revisions on the line.
The Denon HD Link is a nice touch with your 4520. Knowing all that, both the players I mentioned are a very close second. Hope that helps.
Denon 4520CI
Emotiva LPA-1
post #322 of 326 Old 01-23-2015, 07:21 AM
Shad0wDK's Avatar
Many thanks for your reply If I decide to buy it, it will most likely be purchased as new (no used units available at the moment where I live). Have you tried Denon HD Link?
My main concern is actually if 4k projectors and 4k blu ray is going to get accessible in 1-2 years - by accessible (for me), I mean a projector at around half the price of a Sony VPL-HW300. However, I'm not sure if that is going to happen or if it will be more like 3-4 years from now..
Shad0wDK is offline
post #323 of 326 Old 01-30-2015, 10:21 PM
Kevin. W's Avatar
Quoted: 46 Post(s)
I had an older DBP 4010 that I had hooked up to my A100 via Denon Link. At first it worked then it exhibited issues playing discs. At first I go an exchange from my dealer, then that one acted up. So of it went to Denon for repair. 2mths later it comes back to me, with the same issues. Luckily since I bought most of my gear from my dealer he gave me a full refund of the unit, even though I had it for 8mths(minus 2 for repair). Is this a common issue with Denon's not playing some discs? I've never had an issue with any other player I had.
Kevin. W is offline
post #324 of 326 Old 02-14-2015, 03:05 PM
Liked: 0
Hi all,
I'm very interested in the DVD region free hack for the Denon DBT-3313. Could anyone please provide me with some information?
Thanks a lot!
mucdude
mucdude is offline
post #325 of 326 Old 02-17-2015, 06:16 PM
wadec22's Avatar
Quoted: 105 Post(s)
Liked: 45
Originally Posted by mucdude View Post
Hi all,
Thanks a lot!
mucdude
Didn't know there was one. Interesting. . .
Denon 4520CI
Emotiva LPA-1
post #326 of 326 Old Today, 05:49 PM
cgperry's Avatar
Anyone Have a Crestron Module For DBT3313?
Just wondering if any of you have a working module that has full control of the DBT-3313? I have partial control using a module written for the DVD-2500BT/3800BDCi. Was hoping to avoid having to write my own. Thanks!
cgperry is online now
Reply Blu-ray Players
Denon Blu Ray Disc Player Dbt 3313udci , Blu Ray Players , Denon Avr 3313ci Receiver
