Denon DBT 3313 Owner's Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #361 of 377 Old 11-09-2016, 07:40 AM
Salamigurke's Avatar
Liked: 4
maybe some Java-Update
Btw im using universal media server to stream content over the network.
But unfortunately there is no conf-file for Denon devices.
UMS is recognizing the DBT-3313 as Vizio Smart TV, but all is working fine.
By inspecting the conf file for the Vizio i see things that, probably, some are not the right parameters for the denon.
Unless these parameters have no effect when playing "no transcode" (otherwise the content get degraded).
Well long in short: does anybody use UMS and have a custom conf file for the denon?
Salamigurke is offline
post #362 of 377 Old 11-10-2016, 11:43 AM
ArTourter's Avatar
Unhappy
Well one thing definitely changed: the youtube application. They broke it.
All settings (account login and paired devices such as mobile phone apps) are lost after the update and they don't persist after power off. Also it crashes/freezes frequently...
hmm not good.
ArTourter is offline
post #363 of 377 Old 12-23-2016, 03:59 AM
wbree's Avatar
Quoted: 16 Post(s)
I have recently bought the DBT-3313. I use it in combination with my DENON AVR-X6200 .
I connect the HDMI (Amp) to the receiver and also connected the HD link to the receiver.
But how do I know that the receiver is using the HD link for producing the audio sound?
I don't see anything on the receiver display that the audioinput is coming from the HD-link.
The blue led on the player is on.
Wilco
SAMSUNG UE55HU7500 - DENON AVR-X6200W - Monitor Audio Gold speakers- REL205 sub - PCH-400/VTEN Mediaplayer - DENON DVD 3910 - DENON DBT-3313UD
wbree is offline
post #364 of 377 Old 12-23-2016, 07:46 AM
Schwa's Avatar
Quoted: 1107 Post(s)
Liked: 1154
That's how you know. If you switch inputs on your receiver you'll notice that the light will go out.
Schwa is offline
post #365 of 377 Old 12-24-2016, 05:27 AM
wbree's Avatar
Quoted: 16 Post(s)
That's all there is? Thanks Schwa.
Wilco
wbree is offline
post #366 of 377 Old 12-24-2016, 09:24 AM
Schwa's Avatar
Liked: 1154
Wilco
Yep, that's it. Well, that and the drastically improved sound.
Gerhard_Bader likes this.
Schwa is offline
post #367 of 377 Old 01-03-2017, 08:59 AM
avgorder's Avatar
Netflix Audio Issue
When I stream from Netflix 5.1 audio there is no sound.
I switched to stereo on Netflix it works.
While 5.1 sound works with Bluray.
Upgraded the firmware but still no luck.
Anyone experienced this issue.
Denon 4520 CI
JTR 228 x 3
JTR Slanted 8 x 2
PSA XS30 x 2
avgorder is offline
post #368 of 377 Old 01-14-2017, 08:34 AM
ArTourter's Avatar
Originally Posted by avgorder View Post
Netflix Audio Issue
I am afraid, I have never had that problem, 5.1 netflix sound has been working flawlessly for me on the unit attached to the X4000. The codec should be DD+ but your 4520 should have no problem with that anyway.
Does the AVR see an audio stream at all?
post #369 of 377 Old 01-16-2017, 06:15 PM
whotony's Avatar
Recently my Denon 3313 has started to display audio as multi channel in 5.1/7.1 when watching a bluray.
Hasn't done that up until recently and I'm not sure if I accidentlally pressed a setting or what.
Watching tv doesn't display this way.
Checked all the settings on the player and the Denon but can't change it back to previous display settings.
I'm sure it's a setting on the sony player but nothing.
Any one have an idea?
whotony is offline
post #370 of 377 Old 01-16-2017, 07:04 PM
Schwa's Avatar
Liked: 1154
One thing, you're in the DBT-3313UDCI Blu-ray player thread. You'd be better served posting in the AVR-3313CI receiver thread. Nevertheless, the reason you're seeing "MULTI CH IN" on your receiver's display is because your BD player is outputting PCM. Change its audio output to bitstream and you should be good to go.
Schwa is offline
post #371 of 377 Old 01-16-2017, 07:25 PM
whotony's Avatar
Thanks Schwa.
That worked sort of.
There's no setting for bitstream on this but there is one similar.
I had to tun this setting off to get back to normal audio.
BD Audio MIX Setting
On: Outputs the audio obtained by mixing the
interactive and secondary audio to the
primary audio.
Off: Outputs the primary audio only. Select
this to output HD audio signals to an AV
amplifier (receiver)
Sorry for posting in the wrong area, did a search and got here witout noticing the DBT part of it.
whotony is offline
post #372 of 377 Old 01-19-2017, 03:56 PM
ArTourter's Avatar
Netflix Audio Issue
Well actually, that behaviour just started happening for me today. Restarting the player doesn't solve it.
The avr doesn't seem to see anything audio stream apart for basically pcm stereo but no sound comes out.
Not sure where the problem comes from but it seems unlikely the player is at fault.
post #373 of 377 Old 03-30-2017, 10:38 AM
Liked: 4
Netflix Audio Issue
i guess i have this too, but in similar way:
when i switch on my receivre too late (or too early), and im in netflix already the movie is playing, can be i receive stereo to my receiver or no sound at all.
Rewind in netflix some seconds and play the movie solves my issues, its 5.1 again without changing something.
Or its when im in netflix for half day without watching something (powersave mode is off, so the player never goes to sleep), then playing something only stereo comes first.
Also here rewind and pla again helped.
(im in AV pure mode with sound out only on hdmi2, and video to hdmi1 directly to the TV)
post #374 of 377 Old 05-18-2017, 02:36 PM
ArTourter's Avatar
HMMM, just got a message while loading the youtube application from the player, that youtube will stopped being supported from 30 June! I wonder how it will be before netflix and the other providers (although netflix and youtube are the only ones I can get from the UK) follow suit.
I guess I really have to get myself another device dedicated to streaming...
post #375 of 377 Old 05-19-2017, 09:27 AM
Quoted: 12 Post(s)
Liked: 1
Is this customer unfriendlyness by DENON or by Google?
I had thought YouTube was a defined attribute of this product, they even provided a button for it on the remote control, and the BDT is still in their products actively sold.
I would open a ticket at DENON.
Sent from my E6653 using Tapatalk
Gerhard_Bader is offline
post #376 of 377 Old 05-19-2017, 09:50 AM
Super Moderator
teachsac's Avatar
Quoted: 788 Post(s)
Liked: 1287
This is YouTube. US support was dropped a couple years ago on all older players for SOny, Panasonic, etc.
ArTourter and Gerhard_Bader like this.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #377 of 377 Old 05-19-2017, 10:20 AM
Quoted: 12 Post(s)
Liked: 1
Thank you @teachsac
Just found this on Denon support site for Europe. It's official and they cannot fix it by firmware update.
http://denon-eu.custhelp.com/app/ans...810/kw/Youtube
Time to connect PS4 or Xbox...
And for Denon to finally build a successor!!!
ArTourter likes this.
Reply Blu-ray Players
Denon Blu Ray Disc Player Dbt 3313udci , Blu Ray Players , Denon Avr 3313ci Receiver
