Official Sony BDP-S1100, BDP-S3100, BDP-S4100 and BDP-S5100 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
Old 03-25-2013, 11:17 AM - Thread Starter
apw2607's Avatar
Quoted: 272 Post(s)
Liked: 332
Originally Posted by timmay77 View Post
I would like to hook a large external hard drive to the back USB port and store my backed up DVD files on to it so I can pull them up on the 5100. Could someone please answer a few questions?
1. What is the best format to use to retain the best video/audio quality?
2. What program do I use?
3. Can this be done with Blu Rays as well? 3D Blu Ray?
1. m2ts
2. two step process, Make MKV (create MKV). Tsmuxer (uses MKV to create m2ts). Since all DVD is in Mpeg2, you must put the Mpeg2 into a M2TS container.
3. Yes, however if the BD uses AVC/Mpeg4 codec you can leave it in the MKV. If the BD uses VC-1 or Mpeg2, then you must use TSMuxer to put the MKV into a M2TS.
3.a For 3D BD, you may get better results with DVDFab rather than MakeMKV ... I think you will only be able to play 3D SBS though.
The following table summaries support:
timmay77 likes this.
apw2607 is offline
Old 03-26-2013, 01:32 AM
timmay77's Avatar
Thank you apw2607, exactly what I was looking for......
I am EXTREMELY happy with the purchase of my S5100 so far. I have went through 4 Blu Ray players in the past month trying to find one that works for my system. As I stated before, I had an extreme audio delay issue with the S590 and even the S790. Now that I have the 5100, I have an audio ADVANCE issue, which isn't a big deal because the S5100, my Yamaha AVR, and my Sammy TV all have an audio delay feature. I just adjusted the audio delay to 45ms delay on the AVR and I have prefect sync. FINALLY. I have very satisfied with the start up time, audible level, and picture of the S5100 as well. Excellent purchase.
I also want to add that I love the fact that it has physical buttons. I can not stand the pressure sensitive buttons many units are offering now. I HATED them on the S790........
timmay77 is offline
Old 03-26-2013, 04:55 AM
dryasanne's Avatar
Quoted: 57 Post(s)
Liked: 25
I am EXTREMELY happy with the purchase of my S5100 so far. I HATED them on the S790........
Maybe you could compare in detail 5100 and 790 ?
I have the 790 ( european / norsk version). And I have just bought the 5100 from amazon.com/ US version.
I havent received the 5100 yet. But I m highly satisfied with 790, except the touch buttons, which is a way to sensitive. If 5100 have more like buttons, I will be glad!
I have a large SACD collection, I really hope 5100 plays these as perfect as 790.
Ps
Lincoln is now on rental on Vudu. Ooh that one I really look forward to, To be watched on my 790 tonight wink.gif
dryasanne is offline
Old 03-26-2013, 06:13 AM
UHD Addict
aaronwt's Avatar
Quoted: 5604 Post(s)
Liked: 3398
I tried out some SACDs on my S5100 this past weeked. The S5100 did a good job playing them and send DSD and PCM. I tried it both ways. My only isssue is that in my normal setup, I can't play the SACDs because I send audio only over HDMI from my iscan DUO to my receiver becasue my receiver can't handle 3D. So it fails HDCP for SACD playback So I had to connect my S5100 directly to my receiver to listen to the SACDs. If my Denon 3808 could handle 3D I wouldn't have an isue. But at this point, playing back 3D BD titles is more improtant to me than playing back my SACDs.
Although I wonder if I use the second HDMI video output(which does audio and video) instead of theHDMI audio only output to my receiver if that will solve the problem. I'll need to try it out sometime this week. Since i won't be looking at the video output of the receiver, it doen't matter to me that it can't handle 3D. But I guess it will probably send a signal t my S5100 then that it can't play back 3D. I'll have to try it to see what happens
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Old 03-26-2013, 12:40 PM
TomPiltoff's Avatar
Hey guys, I just picked up the S1100 and am having an audio issue.
I use an old Onkyo R330 receiver, has always worked perfectly fine. I have it hooked up to my 360 via an optical cable and it has always sounded great. Well now I have my S1100 hooked up via coaxial cable and movies sound extremely echoey.
I tried changing some of the default audio settings on the player, didn't notice a change. Does anybody have any clues as to what the issue could be?
TomPiltoff is offline
Old 03-26-2013, 01:01 PM
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
Anybody know if the 5100 can be hacked/modded for region-free Blu-ray playback?
Boston Acoustics Classic series L/C/R + front presence; Fluance XLBP Bipole surrounds; 2 x PSA XS15se
Yamaha RX-A3040; 3 x Emotiva XPA-100; Emotiva BAS-X A500
Oppo BDP-103D
AC2011 is offline
Old 03-26-2013, 02:39 PM - Thread Starter
apw2607's Avatar
Quoted: 272 Post(s)
Liked: 332
Sure, if its anything like the 390, 590 and 790. However the region mods are normally hardware and only offered by the World import stores ... and command a high price. Normally twice the price ! There is no software mod that I know ... at least not for North American players.
You'll find region free version of the new 2013 players on Ebay, or a simple search on google.
I once purchased a Denon DVD player that was multi-region / NTSC to PAL Conversion, etc ... from such stores .. and it worked perfectly.
One thing you should be aware of. If you make a MKV/M2TS backup of such disks, the Sony BDPs will playback the contents fine.
So if you had PAL DVD material or BD 1080i/50Hz material .. these all play fine on USA Sony players over DLNA and MKV/M2TS.
apw2607 is offline
Old 03-26-2013, 02:41 PM - Thread Starter
apw2607's Avatar
Quoted: 272 Post(s)
Liked: 332
Sounds like you need to change a setting on your receiver, not the player. Check that the player is outputing bit-stream audio, if it is .. then everything else is on the receiver/processor/amplifier side.
apw2607 is offline
Old 03-26-2013, 02:47 PM
TomPiltoff's Avatar
Actually it was a even simpler - I'm an imbecile and had my TV speakers on as well as the 5.1. But thank you!
Old 03-26-2013, 03:09 PM
mdavej's Avatar
Quoted: 2167 Post(s)
Liked: 953
I think there's a setting to turn off HDMI audio in the player so you won't have to mess with the TV volume or speaker settings.
mdavej is offline
Old 03-26-2013, 11:11 PM
dryasanne's Avatar
Quoted: 57 Post(s)
Liked: 25
Sony is known to be on of the hardest to hack = impossible.
I have chosen a new approach, By having two, on for region A and one for Europe (my 790).
The total price is way below the only other option - Oppo 103.
And amazon.it will gladly sell you a s590 for 130 euro, a perfect match for a brand new usa s5100. Remember, as a foreign buyer they deduct 20% vat, giving a nice total price wink.gif
Old 03-27-2013, 04:26 PM - Thread Starter
apw2607's Avatar
Quoted: 272 Post(s)
Liked: 332
Are the Euro versions of the players 110v-240v at either 50 or 60Hz, or just 200-240v @ 50Hz?
apw2607 is offline
Old 03-27-2013, 04:43 PM
dryasanne's Avatar
Quoted: 57 Post(s)
Liked: 25
Just 220v @ 50 hz. Every country, including uk
I dont know any region that use 110v other than usa.
You need a power converter of some kind I guess
Old 03-27-2013, 05:46 PM
leoniki's Avatar
Originally Posted by PioManiac View Post
The S5100 is the only 3D capable component in my system,
Yamaha RX-V3900 AVR with two HDMI outs to a Pioneer Kuro plasma and Epson 1080UB projector.
Both work perfectly in 2D, 1080p/24 and up to 7.1 Bitstreamed HD audio.
Did you update the firmware right away?
Switching the mix setting to off was all I needed to get DTS-HD and TrueHD lit up on my AVR.
Got the BDP-S5100 today, updated the firmware right away and connected to my Onkyo TX-NR717 via HDMI.
It only showed multi channel for DTS, however Dolby True HD already worked.
Thanks to your post I switched off the 'BD Audio Mix' and that solved it for me, now DTS HD MA is displayed on the Onkyo as well.
leoniki is offline
Old 03-28-2013, 03:16 AM
bdahms2's Avatar
Already had a freeze up while watching YouTube. Wasn't good for Sony as I was showing a friend how good it was. Oh well guess I will see how often it happens and get a replacement if needed.
bdahms2 is offline
Old 03-28-2013, 06:07 AM
Mercfh's Avatar
Got a 5100 yesterday. Youtube app is really fun! a little slow but not like "terribly" so. I have it wired and I have zero delay as far as loading/buffering and such goes.
Speaking of the youtube app, what quality does it play them in? and is there any way to change it? (I have a 46inch 1080p TV for reference)
Mercfh is offline
Old 03-28-2013, 03:46 PM
johncourt's Avatar
New owners: please tell us if the 5100 or 1100 is a quiet player or not, especially in comparison with the 590 or 790. This is a key point for me.
johncourt is offline
Old 03-28-2013, 06:19 PM - Thread Starter
apw2607's Avatar
Quoted: 272 Post(s)
Liked: 332
Can the owners here take the Sony BD survey. There are questions on where sony can improve including apps, user interface and DLNA file support. Only takes 30 seconds.
You'll find it under recommendations on the XMB on your Sony BD player !!
apw2607 is offline
Old 03-29-2013, 09:38 AM
Mr. Cinema's Avatar
I have the 5100. I know from past experience, some Sony players can be a little noisy during disc loading. But when I played The Hobbit, I didn't hear a single thing during the load time. It was quiet all the way through.
Mr. Cinema is offline
Old 03-29-2013, 02:39 PM
johncourt's Avatar
Old 03-29-2013, 05:22 PM
UHD Addict
aaronwt's Avatar
Liked: 3398
Every BD I've loaded into my S5100 has initially been noisy. But once it started playing it was much quieter. But still, like any DVD or BD player, I can always hear the player in a quiet room. I think the S5100 is little louder than other BD players I've had while playing a title. But I also wouldn't typically be playing a disc in a quiet room anyway. I would be listening to the audio track along with watching the video.
I am still planning on picking up a second S5100 to put in my secondary 3D viewing location. Overall I like the S5100 better than my Panny BDT220 player.
aaronwt is offline
Old 03-29-2013, 06:32 PM
tremor13's Avatar
3100 bricked on me tonight.
Has been working fine for a few weeks. Turned it on this evening, got the standard Sony/Blu Ray splash screen... then TV goes to "No Signal." Tried repeatedly, dumped power, same thing, unplugged everything (hdmi/ethernet/power), same thing. Waited a half an hour, back to the home screen... yay! Until it hung loading Netflix. On reboot, back to splash screen then "No Signal."
Disappointing, this thing seemed solid.
tremor13 is offline
Old 03-29-2013, 08:34 PM - Thread Starter
apw2607's Avatar
Quoted: 272 Post(s)
Liked: 332
After the player has booted keep you finger on the stop button (on the player) for over 10s. It will reset to the lowest HDMI output resolution (480p).
Go back into the screen settings and turn off deep color and then turn the HDMI resolution to 1080p or whatever your display supports.
apw2607 is offline
Old 03-29-2013, 10:51 PM
dryasanne's Avatar
Quoted: 57 Post(s)
Liked: 25
Regarding noisy players.
Maybe the same feedback problem as turntables?
Mine s790 seems to be more quiet when sitting on a rock surface.
On a chipboard shelf, it tends to make some noise, at least at startup.
Old 03-30-2013, 04:34 AM
tremor13's Avatar
I'll try that, thanks!
Edit: Brought it back, thanks! But why did that happen in the first place? It's been fine for weeks, then all of a sudden a problem? Deep Color was at its "Auto" default. I reset the output resolution to Auto and it went right back to 1080p, where it was before.
tremor13 is offline
Old 03-30-2013, 08:47 AM
makorip's Avatar
According to Sony the S5100 upscale DVDs, TV shows and sports to 3D and easily turns 2D films and TV into virtual 3D viewing
at the press of a button. A really good and technically applicable reason for buying!
makorip is offline
Old 03-30-2013, 09:01 AM
UHD Addict
aaronwt's Avatar
Liked: 3398
Don't the 3D TVs already do this?
aaronwt is offline
Old 03-30-2013, 12:03 PM
Vishwa Somayaji's Avatar
Not all of them do.
Vishwa Somayaji is offline
Old 03-30-2013, 02:56 PM
n8dgr84's Avatar
Why would I buy this instead of using a ps3? I dont care about sacd...is pq or aq better?
n8dgr84 is offline
Old 03-30-2013, 03:03 PM
Ph8te's Avatar
Quoted: 4626 Post(s)
Liked: 4112
1, Its cheaper
2. Not everyone plays games, so a dedicated player fits well
3. Its smaller
Those are just the quick 3....
Ph8te is offline
bx510 , dolby , m2ts , Sony , Sony Bdp S1100 Blu Ray Disc Player , Sony Bdp S3100 Blu Ray Player , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , Sony Blu Ray Disc Player Bdp S790 , truehd
