Official Sony BDP-S1100, BDP-S3100, BDP-S4100 and BDP-S5100 - Page 110 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #3271 of 3282 Old 04-18-2016, 07:48 AM
iron4044's Avatar
Quoted: 24 Post(s)
Amazon Prime BPD-S5100 GUI is terrible!
Ok, I'm sure this has been asked but I can't find the answer via Search.
I have both the S5100 and newer S3500. The GUI's are so different. The S5100 is bad, especially Amazon Primes GUI. It's old looking, slow, etc. Working with Prime makes me want to shoot myself!
The S3500 interface is awesome! (see below)
QUESTION: Can I update and/or get the newer GUI like the S3500 downloaded onto the S5100??
Help please!!
Name:	Sony BDP-S3500- GUI AWESOME!.jpg
ID:	1388810   Click image for larger version
Name:	Sony BDP-S510- GUI TERRIBLE.jpg
iron4044 is offline
post #3272 of 3282 Old 04-18-2016, 09:36 AM
jinj's Avatar
Quoted: 114 Post(s)
Liked: 43
Help please!!
I doubt it very much, the hardware on the s5100 is very slow.
Are you in the UK or USA? As I see the BBC/Ch5 channels.
I use a Roku to get the UK channels via SmartDNS, I wondered if I could do that with the s5100 too.
jinj is offline
post #3273 of 3282 Old 04-18-2016, 10:23 AM
iron4044's Avatar
Quoted: 24 Post(s)
I'm in the US and the screenshot was wrong country. I have looked around about this issue and couldn't find any solution so maybe there isn't any. And I don't know anything about SmartDNS.
iron4044 is offline
post #3274 of 3282 Old 04-18-2016, 11:56 AM
S_G7's Avatar
Quoted: 100 Post(s)
Liked: 37
For the main system GUI, no. Updates to the individual third party apps will depend on the provider.
S_G7 is offline
post #3275 of 3282 Old 04-18-2016, 01:24 PM
iron4044's Avatar
Quoted: 24 Post(s)
Thanks to you both.
iron4044 is offline
post #3276 of 3282 Old 04-18-2016, 04:55 PM
K5ING's Avatar
Help please!!
My 3100 is almost identical to your 5100, and the interface is identical, however if you use the SEN (Sony Entertainment Network) button on your remote, or get it by moving to the right on the main screen, the interface looks much like the one on your 3500, although not identical. All of the apps are there, just arranged differently to make it easier to browse through them. I can't speak for the Amazon app (I don't get have it), but I agree that the whole thing is pretty slow.
S_G7 likes this.
Far out in the uncharted backwaters of the unfashionable end of the south-western quadrant of the Greater Krum, TX  Metropolitan Area.
73, K5ING (Jeff)
K5ING is offline
post #3277 of 3282 Old 07-23-2016, 07:11 AM
steve1022's Avatar
Quoted: 81 Post(s)
Liked: 65
I have a s5100 that the Netflix app no longer works on. Netflix works fine on every other device so I assume that it's a firmware issue but my s5100 says it has the latest update. Is this the same for others or could it be something else?
steve1022 is offline
post #3278 of 3282 Old 07-25-2016, 09:17 AM
Briant73's Avatar
Quoted: 36 Post(s)
My S5100 lately is having an issue, twice now the system does the following after being powered on - no apps show up and when i go to shutoff the unit just keeps flashing the power down message on it's internal display but doesn't power off. I have to unplug the unit, wait a bit, plug back back in and do a full system reset.
Has anyone else had this issue and what have they done to resolve it?
Briant73 is offline
post #3279 of 3282 Old 08-06-2016, 07:28 AM
BluesSailor's Avatar
Quoted: 14 Post(s)
Briant - I'm having the same issue with my Sony 5100 as well. Drops settings regularly and have to start all over, freezes and locks up requiring a soft reset by unplugging. Getting pretty tired of futzing with it nearly every time I want to use it. When it works, picture and sound quality are great, when it doesn't the frustration factor makes me want to toss it to the curb for a better alternative.
Sony website and other related chat sites are of no help. Haven't seen a firmware update for nearly a year or more. Not impressed with Sony support AT ALL!
Came from a Samsung that also had it's share of problems. Right now waiting for the new standards to sort themselves out before moving on. The standards process is dragging out forever though. Looking like Oppo is the way to go from here. Oppo does have Apps for Netflix, Pandora, HULU, and Roku. Wish they had a larger selection that included Spotify, MLB, etc. Maybe that with Chromecast or similar.
Brad
BluesSailor is offline
post #3280 of 3282 Old 08-08-2016, 06:59 AM
Briant73's Avatar
Quoted: 36 Post(s)
Brad
Thanks for the response, it's sad because it's a decent player/streamer but if mine loses it's settings/apps again I'm going to replace it. I have an older s390 that still works fine (though it's slow) but is missing some of the newer apps.
Briant73 is offline
post #3281 of 3282 Old 04-19-2017, 12:57 AM
Liked: 0
Sony S5100 player anomaly with Star Trek TOS bluray box
Hi, I recently bought here in Rome, Italy, the bluray box set of the classic Star Trek series, with improved effects in computer graphics. I found an anomaly. In the start screen you can choose the title of episode and if you look at it with the digital effects or in the original version. The words on the menu reports that while watching, a symbol on the right appears on the sequence in which you can choose to see it with or without the digital effects or the original version. This symbol does not appear ever so it is impossible to know whether a particular scene or contains less improved effects. I have a Sony S-5100 bluray player and i check in options menu and there isn't any specifical setting for put on\of that symbol. I also tried with the Playstation 3 but the problem is always there. The DVD player is connected to the network and firmware is updated constantly, and now there is the latest version installed. On the remote control there is not the "angle" button to activate it and you have to go in the popup menu "options". However, if you choose this option here, the scene changes and you can see the sequence with or without digital effects. Maybe the problem is just the firmware, or Jawa software ? Has anyone encountered this problem? Thank you. Simone
The SpaceJockey is offline
post #3282 of 3282 Old 09-16-2017, 01:09 PM
a68oliver's Avatar
I currently own a Sony BDS-5100 and have recently installed a Dolby Atmos system. I have discovered that an Atmos enabled BD passes the Atmos track to my AV Receiver quite successfully. My question is, if I subscribe to a Netflix streaming plan with Atmos, will the Netflix app pass Atmos to my receiver?
Alan Oliver
Tivo user since May 2000
a68oliver is offline
Reply Blu-ray Players
bx510 , dolby , m2ts , Sony , Sony Bdp S1100 Blu Ray Disc Player , Sony Bdp S3100 Blu Ray Player , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , Sony Blu Ray Disc Player Bdp S790 , truehd
