Official Sony BDP-S1100, BDP-S3100, BDP-S4100 and BDP-S5100 - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #451 of 3280 Old 04-20-2013, 08:42 PM
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
Originally Posted by apw2607 View Post
I have some experience with the 103, the s3100, s590 and s790.
If its BDs then for the most part I can't see any difference. For DVDs I actually prefer the s790 over the s3100 and s590. Didn't look at DVD with the 103.
Thanks man. I think I'm going to order one.
purbeast is offline
post #452 of 3280 Old 04-20-2013, 09:40 PM - Thread Starter
apw2607's Avatar
Quoted: 115 Post(s)
Liked: 220
Originally Posted by markusn82 View Post
Do these devices support YouTube pairing? If not, does the SideView app support remote YouTube search / playback?
How would you rate the YouTube experience overall?
Yes it supports device pairing and supports the very latest lean back YT interface found on lots of devices, e.g tivo. Sideview also supports search.
Overall the YT experience is greatly improved over previous versions.
Note the s790 still has the old style interface. The Sony hx750 tv just got a firmware update where they added the new YT interface so its possible they add it to the s790 as its still current .... But who knows. Sony works in strange ways.
apw2607 is offline
post #453 of 3280 Old 04-20-2013, 11:59 PM
dryasanne's Avatar
Quoted: 28 Post(s)
Originally Posted by 1ceTr0n View Post
No, you need to install another USB drive to run local BD Live content as the 5100 and set it up in the menu for BD live usage as the 5100 and other models no longer let you install SD cards to download BD live content like you could with the older Sony models. No idea why other then just more cost cutting
Sorry - I dont understand what you are saying.
I have aleeady a usb 2.0 Seagate 500 GB external harddisk drive to my Sony bdp s5100.
So - you mean I have to buy me another external harddisc drive ??
I need TWO - 2 - USB drives to be able to run BD live -
one in front usb in addition to my Seagate 500 gig in the back usb port??
dryasanne is offline
post #454 of 3280 Old 04-21-2013, 01:56 AM
dryasanne's Avatar
Quoted: 28 Post(s)
Fixed.
The usb has to be in the REARS !!!
Why this ?
post #455 of 3280 Old 04-21-2013, 02:22 AM
1ceTr0n's Avatar
Liked: 33
Originally Posted by dryasanne View Post
Fixed.
Why this ?
My guess would be so its:
A: Out of sight cause your gonna leave it in there for moving watching so you don't want it sticking out of the front panel USB port like an eyesore
B: Leave the front USB port open for temporary USB use like pics or songs
1ceTr0n is offline
post #456 of 3280 Old 04-21-2013, 07:51 AM
UHD Addict
aaronwt's Avatar
Quoted: 5216 Post(s)
Liked: 3121
Fixed.
Why this ?
I got these Cruzer Fit USB flash drives to use with my S5100 players in the rear USB port. BD-Live works great with them in the rear port. BD Live won't work with them in the front USB port.
http://www.amazon.com/SanDisk-Cruzer-SDCZ33-008G-B35-Flash-Drive/dp/B005FYNSUA/ref=sr_1_3?ie=UTF8&qid=1366552131&sr=8-3&keywords=cruzer+fit
They are extremely small. They were only around $8 for the 8GB ones.
This is another reason I like the S5100 over the PAnny BDT220. You can't use the rear USB port for anything except a camera in the Panny.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #457 of 3280 Old 04-21-2013, 09:06 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3037
Just ordered a 5100, will have Tuesday. I'm looking at selling the OPPO, not leaving discs but want something with great streaming AQ and PQ.
My main plan is to use Netflix, Amazon Prime and Vudu HDX. The Samsung 7500 is on my list but I'm going to try the cheaper model first. If its anything like the 790 (I had for a short period) was at streaming, I should be quite happy.
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
post #458 of 3280 Old 04-21-2013, 09:25 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3037
Two questions:
Will a sandisk cruzer fit 4 GB USB drive be a good choice for the back memory expansion?
I assume the proper preset picture mode is called normal or standard?
post #459 of 3280 Old 04-21-2013, 10:54 AM
1ceTr0n's Avatar
Liked: 33
Dear sweet Christ, I rented Avengers tonight using my new sony BDP-BX510 blu ray player through my Yamaha HTR-5930 5.1 DTS system I've had for years and the movie when it got to an action damn near blew out my surround system sub woofer because of the insane amount of bass that came out of nowhere because I had to raise the volume to be able to hear people speak.
Either the movie on the disc has some REALLY weird balance issues that required me to basically disable my subwoofer or the fact that blue ray has some type of audio code that raises the volume level, I had to crank my system way down and put the speakers in straight more less I piss off every single neighbor in my apt complex by keeping it in surround sound mode.
What the hell gives with Blue Ray discs that would throw my normally balanced 5.1 system for Xbox 360 optical sound usage completely out of whack like this that damn near turned my apt to an earthquake?
1ceTr0n is offline
post #460 of 3280 Old 04-21-2013, 11:07 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3037
Did you bitstream the Master HD 7.1 track? This disc sounded great in my home, but I have a denon and that was on an oppo. I have noticed 7.1 lossless tracks tend to require more volume on a non 7.1 system.
post #461 of 3280 Old 04-21-2013, 01:57 PM
1ceTr0n's Avatar
Liked: 33
Did I what?
1ceTr0n is offline
post #462 of 3280 Old 04-21-2013, 02:03 PM
Ph8te's Avatar
Quoted: 4545 Post(s)
Liked: 3978
Ok so it looks like you hook up through optical no? I looked up your AVR and its an older model that doesnt do the HD audio codecs.......As far as audio mixes go every mix will be different and you may need to re adjust your settings of your audio equpment. I would suggest boosting teh center channel rather than turning teh volume all the way up, this way you are less likely to experience what you did....
Ph8te is online now
post #463 of 3280 Old 04-21-2013, 03:29 PM
1ceTr0n's Avatar
Liked: 33
The BX510 doesn't have optical output, Digital coaxial only. What is this downmixing I keep hearing about also if you don' t have an HD reciever
1ceTr0n is offline
post #464 of 3280 Old 04-21-2013, 04:05 PM
Ph8te's Avatar
Liked: 3978
You are correct I apologize, downmixing means that the 5011 is taking the lossless track that is on the Blu-ray and down mixing to DD 5.1 or DTS 5.1 so that your AVR can decode and play the audo
Ph8te is online now
post #465 of 3280 Old 04-21-2013, 04:20 PM
1ceTr0n's Avatar
Liked: 33
I'll have to figure it out via manual cause it was total mess last night audio wise, but the movie was farking fantastic
1ceTr0n is offline
post #466 of 3280 Old 04-21-2013, 05:22 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi 1ceTr0n, see if it helps by enabling Dynamic Volume or Night Mode (if the receiver have this setting).
JChin is offline
post #467 of 3280 Old 04-21-2013, 08:15 PM
1ceTr0n's Avatar
Liked: 33
It does have Night mode, dunno about dynamic
1ceTr0n is offline
post #468 of 3280 Old 04-21-2013, 08:32 PM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
Dynamic is set on the player. Might be called DRC.
mdavej is offline
post #469 of 3280 Old 04-23-2013, 04:34 PM
dryasanne's Avatar
Quoted: 28 Post(s)
Do you have dog?
There is a most very irritating "feature" of 5100
- some kind of Power saving that turns it OFF after some 30 mins.
When Im walking the dog, it takes approx 24 mins, that shorter walk in the nights.
And when I get back, the 5100 is off, and I have to crank up again the film. On The Hobbit, no problem, because 5100 remembers where it left / turn. On others, like Prometheus, it dont, I have to wade through a lot of scenes frown.gif
My 790 doesnt have this power off , it stays on.
How do I disable this power off feature ??
post #470 of 3280 Old 04-23-2013, 05:54 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
You must have the ONLY 790 in the world that stays on
drhankz is offline
post #471 of 3280 Old 04-23-2013, 08:12 PM - Thread Starter
apw2607's Avatar
Quoted: 115 Post(s)
Liked: 220
Hahaha. So true.
apw2607 is offline
post #472 of 3280 Old 04-23-2013, 09:01 PM
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
Just another curious quick question, as I did not purchase my S51000 yet due to $$ reasons.
Is the 3D picture on this going to look any different than the 3D picture on a PS3, or will it be virtually the same?
purbeast is offline
post #473 of 3280 Old 04-23-2013, 11:15 PM
dryasanne's Avatar
Quoted: 28 Post(s)
Aaaah !
Sorry, I was thinking about my dogwalking !
My Sony 790 has this setting:
Auto standby on / off
Turn off after 30 min of inactivity.
The very first I did when I bought the player, was setting this to off ( due to my dog)
The Sony 5100 has no such setting
It simply turns off after 30 mins, no questions asked ;(
Another somewhat big difference between these players!
post #474 of 3280 Old 04-23-2013, 11:42 PM
Christian Busch's Avatar
Hi,
How do I tell the bdp5100 to output dvd audio and blu ray audio via the coax out ?
right now my receiver tells me its getting audio via hdmi.
best
Parasound zPhono, Pro-Ject Carbon
Marantz UD8004
Anthem D2V
Outlaw 7700
Monitor Audio 2 x GS60, GSLCR, 4 x GSFX, GSW12
Christian Busch is offline
post #475 of 3280 Old 04-24-2013, 07:38 AM
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
I had another question I was wondering about as well...
Has anyone played a regular DVD on the S5100 on a large screen before? I am curious how the HD upscaling on a DVD actually looks compared to a blu-ray.
I've recently realized there are quite a few older movies that are DVD only that I would like to own, and I doubt they are going to come out on blu-ray any time soon. I'm just wondering though how the quality will look on my 120" screen even when they are upscaled, as I have no experience with upscaling dvds at all.
purbeast is offline
post #476 of 3280 Old 04-24-2013, 08:15 AM
mdavej's Avatar
Liked: 940
Originally Posted by Christian Busch View Post
Hi,
best
If your receiver can do HDMI audio, why on earth would you use coax?
mdavej is offline
post #477 of 3280 Old 04-25-2013, 03:44 PM
am_dew's Avatar
Quoted: 27 Post(s)
Well 3rd time is a charm I guess. Picked up 3rd BX510 from Costco on way home from work trip
Is the BX510 just like the S5100? How much was it at Costco?
I ordered a BDP-S590 from Amazon over a month ago when it was supposedly in stock but it has not shipped yet so I have been thinking about getting something else instead.
am_dew is offline
post #478 of 3280 Old 04-25-2013, 06:55 PM
TheLight's Avatar
It gets the most out of DVD's and Blu in my experience compared to a few diff players and PS3 I've owned. Outside of the Dolby decoding it seems solid and capable for sure.
TheLight is offline
post #479 of 3280 Old 04-26-2013, 12:49 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
It is identical, except the BX510 comes with an HDMI cable. It was $119.99 at my Costco, if memory serves.
Mark
giomania is offline
post #480 of 3280 Old 04-27-2013, 07:04 AM
mhobart's Avatar
Quoted: 59 Post(s)
Liked: 47
I'm probably doing something stupid, but I'm having problems in using the TV Sideview app on my iPad (running IOS 6.1.3). I have no problems in getting the Ipad to showing as a Registered Remote Device for the BDP-S5100, but when further configuring the app, it gets to the TV service provider screen [even though it is only BD player!], I enter the Zip code and it then goes to "Please Select Your TV service provider" and cannot find anything...
It displays a message that it cannot retrieve the information, and I'm stuck... Obviously since it's just a BD player and not a Sony TV, the questions on TV service provider are not particularly relevant, but I would like to use it as a remote control, as advertised.
Thanks in advance, Mike
Vizio M501D-A2r hdtv, Sony STR-DN1050 AVR, Oppo BDP-93 blu-ray, Samsung BD-UP5000 HD-DVD/Blu-ray combo, Roku 3, Apple TV
other older items of various types and vintages
mhobart is offline
Reply Blu-ray Players
bx510 , dolby , m2ts , Sony , Sony Bdp S1100 Blu Ray Disc Player , Sony Bdp S3100 Blu Ray Player , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , Sony Blu Ray Disc Player Bdp S790 , truehd
