Official Sony BDP-S1100, BDP-S3100, BDP-S4100 and BDP-S5100 - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #1261 of 3280 Old 08-21-2013, 02:42 AM
marctronixx's Avatar
Quoted: 24 Post(s)
Liked: 35
thats why I said I usually do this under 24 hours. thank you for confirming...
Originally Posted by Foxbat121 View Post
Netflix button won't bypass that either. If you didn't use Netflix for a day or two, you will see this annoying screen.
marctronixx is offline
post #1262 of 3280 Old 08-21-2013, 06:59 AM
goldmine848's Avatar
Are these models the same. Amazon has the S5100 and Costco has the Bx 510. From what I can tell they are the same.
goldmine848 is offline
post #1263 of 3280 Old 08-21-2013, 07:15 AM
jtrippe's Avatar
My 5100 won't remember the network settings and makes me rerun network settings about once a day. Is there a fix for this?
jtrippe is online now
post #1264 of 3280 Old 08-21-2013, 07:53 AM
Super Moderator
teachsac's Avatar
Quoted: 651 Post(s)
Liked: 958
The Costco version comes with an HDMI cable. Otherwise they are the same.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #1265 of 3280 Old 08-21-2013, 08:18 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3021
Someone just posted this in the Amazon DD 5.1 issues thread, but its from 4/13, dont understand.
" Unable to play Amazon On Demand content in high definition (HD).
Article ID: 37566 | Last Updated: 04/19/2013
Amazon® On Demand high definition (HD) playback is not currently supported by Sony® Internet video devices. Internet video devices will only playback movies and programs available on Amazon On Demand in standard definition (SD)."
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is online now
post #1266 of 3280 Old 08-21-2013, 08:23 AM
MacinMan's Avatar
Quoted: 79 Post(s)
Liked: 30
When did this start? I own HD content (the BBC Yellowstone documentary) and it plays in HD just fine. I has since the 570 was current.
MacinMan is offline
post #1267 of 3280 Old 08-21-2013, 08:32 AM
Super Moderator
teachsac's Avatar
Quoted: 651 Post(s)
Liked: 958
Sounds like someone doesn't know what they are talking about. I have no problem with HD video on my S790, DD 5.1 is broken and they know about it, yet it's still not fixed.
S~
teachsac is offline
post #1268 of 3280 Old 08-21-2013, 08:33 AM
eah9's Avatar
Liked: 29
I don't think that is accurate about only SD. I am getting HD on Amazon Prime - as of 2 days ago. I have a the 3100 and the strn-dn1030 (both sony). biggrin.gif
The issue with 5.1 is still there. Hopefully it will be fixed soon!!
Energy RC70 L/R | RC-LCR Center | C-R3 Surrounds | VMINI Bookshelves Surrounds | S12.3 and Dual S10.3 Subs | KRK 10s Sub | Benq w1070 pj | Elite 100" Sable Screen | SONY STR-DN1030| Sony S5100 and S3100 BDPs
eah9 is offline
post #1269 of 3280 Old 08-21-2013, 08:51 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3021
I think that is meant to reflect 5.1. A lot of people are saying they lost 5.1 in April and never got it back. regardless, there are definitely issues with 5.1.
post #1270 of 3280 Old 08-21-2013, 12:40 PM
MacinMan's Avatar
Quoted: 79 Post(s)
Liked: 30
I can't test 5.1 on amazon I am using TV speakers for now. I do know when using netflix or VUDU, the information will say what audio is streaming even though i'm only getting stereo via the TV.
Does amazon tell you on screen what the stream coming in contains? I could test that way only.
P.S.
I would say netflix is main for me then VUDU, then Amazon VOD. Also I have amazon instant video on my iphone, would i be able to test for 5.1 based on what the iphone is receiving ?
MacinMan is offline
post #1271 of 3280 Old 08-21-2013, 03:40 PM
tuffluck's Avatar
Been trying to watch the pixel flipper on Disney's WoW disc today...the S5100 keeps shutting off after that thing runs for 15 minutes or so, also turning the TV off as well. Any idea why it's doing that?
tuffluck is offline
post #1272 of 3280 Old 08-21-2013, 04:01 PM
kamgol's Avatar
Have any of you had a problem with the S5100 responding to RF/IR signals? I have a setup with the Logitech Harmony 900 which has the RF hub and IR burst connectors. All my other devices work perfectly fine, but the Sony BDP seems to have a weak response. I've tried all kinds of things like moving the IR hub, clearing the BDP path, etc. but the result is the same.
Any ideas?
kamgol is offline
post #1273 of 3280 Old 08-21-2013, 07:04 PM
tuffluck's Avatar
Originally Posted by sawfish View Post
I've posted this a couple of times in a couple of threads, but this time I linked to the clearly described software. If you can hook up a PC, this will give you a free Pixel Flipper equivalent that will run as long as you want it to.
The problem with the Disney Pixel Flipper is the players. The newer ones like to turn off after a period of inactivity, which includes playing that Java app. For example, the Sony S5100 shuts off after 30 minutes or so. If you can connect a PC, there is Jscreenfix, but the normal version likes to blink 0:00 after 20 minutes in the bottom right corner, and I see no way to disable that behavior. OTOH, the screensaver version doesn't do that, and it's free to boot. But can you believe it, neither one of them hides the mouse while running! Fortunately, that can be fixed in various ways. The simplest is to move the cursor to the bottom left corner, but that still leaves the tip visible. To actually hide it, I use Autohotkey. If you have that program, search its Help file for "SystemCursor". You will find some sample script that binds a mouse visibility toggle to Win+C. It works perfectly. So, after installing Jscreenfix screensaver version, adding the mouse toggler to my main Autohotkey startup script, setting the screensaver timer to 1 minute when I want flip pixels, and using Win+C to hide the mouse, I have a free Pixel Flipper equivalent I can leave running overnight. When I don't want to use it, I use Win+C again to show the mouse, and I turn the screensaver back off.
Is there any way to keep the s5100 from stopping due to this inactivity?
tuffluck is offline
post #1274 of 3280 Old 08-21-2013, 09:18 PM - Thread Starter
apw2607's Avatar
Quoted: 114 Post(s)
Liked: 220
I had reconfigured it to use my current setup, so I think it may have been a player glitch. Speaking of that though, in OS X is there a way to upgrade Serviio to keep settings? I usually just replace the console and sever app in /Applications.. Most apples store their settings in the perferences folder or in another Apple specific format, which cary over. Serviio seems to store the settings in the app bundle so replacing the old version with the new seems to reset like installing a fully new copy. Is there a way around this?
Before you replace Serviio (not Serviio console) right click, show package contents
Then goto ./contents/resources/java
And copy thr library folder. There are all your settings and share info
Simply replace the new one with your copy when you reinstall the new version
apw2607 is online now
post #1275 of 3280 Old 08-22-2013, 10:20 PM
73ChargerFan's Avatar
I know this isn't a Serviio thread, but I nuked my install because it kept at >90% cpu and filling up my C hard drive, even when my Sony 5100 was turned off and I had transcoding disabled.
Can anyone recommend a better DLNA server?
73ChargerFan is offline
post #1276 of 3280 Old 08-22-2013, 10:28 PM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
Serviio is no problem if you simply turn off metadata and thumbnails. There is no better server IMO.
mdavej is offline
post #1277 of 3280 Old 08-22-2013, 11:22 PM
dryasanne's Avatar
Quoted: 28 Post(s)
Any ideas?
I have similar issues in my Roomie setup.
In my case, Its all about getting the player to respond to WOL. Which 790 will not, but 5100 will do.
I have still not fixed this issue, so I am at present having a workaround. Issue a PLAY infrared command, that will wake both my players.
But NOT any power on command, that will only mess up things..
Just my idea :-)
dryasanne is offline
post #1278 of 3280 Old 08-23-2013, 05:14 AM
MacinMan's Avatar
Quoted: 79 Post(s)
Liked: 30
I thought I'd bring up a question i've been asking on and off through the years to see if anyt new feedback to new information can be given.
Is a 3D tv worth investing in for someone who has had seizures in the past or someone who has a visual impairment that could easily get eye strain from having to sit in a certain position for the glasses able to work correctly ? Thinking about some home upgrades just getting some ideas.
MacinMan is offline
post #1279 of 3280 Old 08-23-2013, 05:35 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
3D TV is dead. That being said, you typically don't pay much extra for a TV with 3D features then not (typically they are mid to high end TVs with features not available in low end 2D only TVs). So, pick which ever TV you like. You might just get 3D for free.
Foxbat121 is online now
post #1280 of 3280 Old 08-23-2013, 05:43 AM
MacinMan's Avatar
Quoted: 79 Post(s)
Liked: 30
Thanks for the feedback, If that's the case, i might as well just keep the TVs I have as they work well and have no need to be replaced. Like i said this was mainly informational questions. I'll look around at current tvs to see if they offer anything i'd used on a daily basis maytbe like smart features.
MacinMan is offline
post #1281 of 3280 Old 08-23-2013, 06:17 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Sometimes I wish it was, I could save a lot of money by not buying all of the new releases of 3D movies. Seems like every week another one hits the theaters.
joed32 is offline
post #1282 of 3280 Old 08-23-2013, 06:37 AM
MacinMan's Avatar
Quoted: 79 Post(s)
Liked: 30
it seems sony bd players are the most reliable. I haven't tried toshiba, LG, or samsung players but between the ones I have tired they seem to be.
I had tried a panasonic DMP-BD71p-k i found at walmart last night, got it home and it was crap didn't connect to the network and i would turn it off and had to unplug and replug to get it to turn on. So, I returned it. Seemingly, the sony players just work it seems kind of like Apple vs windows.
MacinMan is offline
post #1283 of 3280 Old 08-23-2013, 04:07 PM
WilliamG's Avatar
Quoted: 303 Post(s)
Liked: 172
So I already had one BDP-S5100 from Amazon, and bought another for the other room. The difference between them is STAGGERING. The first one I got a few months ago, and is nigh-on silent. The tray eject mechanism is quiet, playback noise is extremely low (and becomes "silent" the further you get into the movie, because of slower disc rotation).
The second BDP-S5100 I received just yesterday from Amazon is a whole other kettle of fish. The eject mechanism sounds very... cog-y. It's not smooth like the first one. You can tell it's running on cogs (which of course, it is). And then the noise it makes during playback is appalling. It does get quieter (though never actually quiet) as you skip through chapters of movies, but MAN is it loud.
So, for those who get a noisy BDP-S5100 (I know this is subjective, like... *sigh...* everything...), get another one. You might be surprised.
WilliamG is offline
post #1284 of 3280 Old 08-23-2013, 05:35 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
I went through four over two months, two from Amazon and two from Sam's. They all produced a terrible whine when playing BDs and DVDs and vibrated badly. Cheap plastic construction, cheap drives. The whine does subside the further into a disc you get, but it never gets less than annoyingly loud. It's funny, I used to avoid my S350 because it was so glacially slow. The S5100 improves greatly on the speed, but I avoid using it due to the appalling whining it makes. The Samsung F5900 wasn't any better.
sawfish is online now
post #1285 of 3280 Old 08-23-2013, 06:35 PM
WilliamG's Avatar
Quoted: 303 Post(s)
Liked: 172
I'd tell you to try another BDP-S5100, but - honestly, given your experience - don't bother. I'm really pleased with my first one, though. It really is absolutely inaudible (except when loading main menus etc, where I hear it just a tad). I sit around 3 feet from my player, too, and have ridiculously sensitive hearing. I don't know how it's possible to have such poor quality control on a device that really has so few moving parts. Crazy.
WilliamG is offline
post #1286 of 3280 Old 08-23-2013, 08:52 PM
bierboy's Avatar
...I'm really pleased with my first one, though. It really is absolutely inaudible (except when loading main menus etc, where I hear it just a tad). I sit around 3 feet from my player, too, and have ridiculously sensitive hearing. I don't know how it's possible to have such poor quality control on a device that really has so few moving parts. Crazy.
I'm with Bill here...my 5100 is virtually silent once it loads. I'm very pleased with it.
Mediacom Digital Cable and OTA HD
Panny TC-P55GT50 -- Denon AVR-1713 -- TiVo Premiere XL4 -- Sony BDP-S5100 -- SlingBox 350 -- Polk 5.1 Speakers -- Logitech Harmony One
bierboy is offline
post #1287 of 3280 Old 08-23-2013, 09:17 PM
WilliamG's Avatar
Quoted: 303 Post(s)
Liked: 172
Who's Bill? And why is there the assumption in America that if your name is William that you go by "Bill"?
I'm only kinda serious (I think...)
WilliamG is offline
post #1288 of 3280 Old 08-23-2013, 09:46 PM - Thread Starter
apw2607's Avatar
Quoted: 114 Post(s)
Liked: 220
^ I made that mistake once ... Never again ;-)
post #1289 of 3280 Old 08-23-2013, 09:51 PM - Thread Starter
apw2607's Avatar
Quoted: 114 Post(s)
Liked: 220
The amazon app is now fixed. Dolby digital 5.1 is back.
gadgtfreek likes this.
post #1290 of 3280 Old 08-23-2013, 10:18 PM
Quoted: 24 Post(s)
Liked: 35
ive a launch day 5100 from amazon. super quiet operation.
Reply Blu-ray Players
bx510 , dolby , m2ts , Sony , Sony Bdp S1100 Blu Ray Disc Player , Sony Bdp S3100 Blu Ray Player , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , Sony Blu Ray Disc Player Bdp S790 , truehd
