Official Sony BDP-S1100, BDP-S3100, BDP-S4100 and BDP-S5100 - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #1981 of 3281 Old 12-06-2013, 11:28 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 413
Originally Posted by KC-Technerd View Post
The Vizio definitely will output DD from its internal ATSC tuner on the optical, but I'm not certain it will pass DD through from an HDMI input to the optical output.
Some Visio TV along with some newer Sony TVs can accept DD from HDMI and pass it out to optical out. Majority of the TVs out there will only accept PCM 2.0 from HDMI.
Originally Posted by Chris Elm View Post
And am I correct in understanding that the 5100 cannot send a DD signal through coax for my receiver to read 5.1?
Am I also correct in understanding that the 5100 CAN send a DTS signal through coax for my receiver to read 5.1?
It can send both DD 5.1 and DTS 5.1 through coax to receiver if you configured correctly (Digital output to Auto and turn off secondary audio). It just can't send DTS 5.1 to a TV via HDMI (I think I read there is only one TV out there that can accept DTS) or DD 5.1 to TV via HDMI (only select few TVs can accept DD 5.1 via HDMI. See above).
Foxbat121 is online now
post #1982 of 3281 Old 12-06-2013, 11:33 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 413
Originally Posted by speedklz View Post
So if my receiver will do dts but not the HD or MA tracks what should I set the S5100 on to make sure I have the best audio.. I want it at 7.1 or at least 5.1 when the other it not available.. And will this player output full 7.1 and 5.1 on the Digital or toslink out.
Same as all the instructions posted here for HDMI bitstream: Digital Audio to Auto, BD Audio Mix to Off. You will get DD 5.1 or DTS 5.1. 7.1 is not possible. If you play some really old BD discs (1st gen) where only LPCM 5.1 or 7.1 tracks are available, you will only get PCM 2.0.
post #1983 of 3281 Old 12-06-2013, 12:18 PM
speedklz's Avatar
Well this thing may be going back frown.gif My old Toshiba Blueray allows the receiver to do 7.1.
Rotting my brain one movie at a time!
Sony 55A3000
Sony 5100 BD
Mitsu 73837
speedklz is offline
post #1984 of 3281 Old 12-06-2013, 12:37 PM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 145
AFAIK, S/PDIF doesn't support 7.1. Are you sure the receiver wasn't creating 7.1 out of 5.1?
sawfish is online now
post #1985 of 3281 Old 12-06-2013, 12:56 PM
speedklz's Avatar
I will be running it through the HDMI port
Sony 55A3000
Sony 5100 BD
Mitsu 73837
speedklz is offline
post #1986 of 3281 Old 12-06-2013, 01:13 PM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 145
Then what is the problem?
post #1987 of 3281 Old 12-06-2013, 01:21 PM
speedklz's Avatar
No problem.. I was just confused as to how to get the dvd player to decode the HD and MA stuff, as my receiver wont..
Sony 55A3000
Sony 5100 BD
Mitsu 73837
speedklz is offline
post #1988 of 3281 Old 12-06-2013, 01:25 PM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
Remember that it was recently discovered that Sony's BDP-S#100 players do not decode 7.1 Dolby TrueHD audio tracks to produce 7.1 LPCM. They can only decode Dolby TrueHD into stereo LPCM. This limitation is a serious annoyance for people with older AVRs and pre/pros which cannot decode HD audio at all or can't both decode HD audio and apply room EQ at the same time, as well as for those who like to have Audio Mix enabled for the extras and menu sounds.
For those in this situation, I'd have to recommend a Panasonic player instead.
Selden
Selden Ball is offline
post #1989 of 3281 Old 12-06-2013, 01:44 PM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 145
Set the audio output to PCM, and it will do that. At least the S5100 will convert to 7.1 PCM and output it over HDMI. For S/PDIF, you're going to be limited to stereo PCM; it's just the nature of that beast. Leave it at Auto, and it will bitstream DD5.1 and DTS over S/PDIF.
EDIT: The 7.1 PCM output definitely works for DTS-HD. I just verified it with Prometheus. I haven't tried it for Dolby TrueHD, so take the following into account:
post #1990 of 3281 Old 12-06-2013, 01:50 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 413
As stated, Sony's 2013 players won't output anything other than PCM 2.0 on Dolby Digital, DD+ and TrueHD. So, if your old receiver can't decode TrueHD, this player is not for you. You can pick Sony's 2012 models (x90 series) which do decode all Dolby codecs and otherwise almost identical to x100 series (with a few exceptions).
post #1991 of 3281 Old 12-06-2013, 02:04 PM
fev
fev's Avatar
Just got a 5100. How do you set the remote to control the tv power and input? If it is in the manual I missed it.
fev is offline
post #1992 of 3281 Old 12-06-2013, 03:28 PM
John4555's Avatar
Just got my Sony BDP-S3100 a few days ago and loving it so far. Quick question when scrolling through the menus is picture ghosting normal? It's very noticeable when switching categories especially (ex. photo to music to video). It's also a little laggy as well. Not a big complaint just checking if this is normal so I can make sure it's not my new TV. Thanks.:)
John4555 is offline
post #1993 of 3281 Old 12-06-2013, 04:42 PM
petrovy's Avatar
My network issue has both myself and Sony support stymied. I have a nice solid wired connection to the S3100....downloaded the latest software no-problem, even the browser works (very poorly) and I was able to go to a few websites, and DLNA over my network works well. Equipment adjacent to this BD, ie PS3 and Oppo 83, work perfectly off the same 4 port switch, with Netflix on the PS3 @ full 1080 highest transmission .The main reason I bought this unit...for Netflix, and all those internet apps in the menu are unattainable !
Under 'Network', only 'Internet Browser' exists...the all important 'Activate Advanced Features...Register Your Device', does not exit, therefore I cannot get to SEN to register. The 'Internet Video' just don't work.
Under 'Sony Entertain Ntwk', the 'Internet Video..Select to Refresh Internet Content' also just don't work.
I have tried everything to fix it: redoing the network connection about 10 times, even tried going wi-fi; rechecking for latest software; resetting this and that; changing and switching internet cables; purging personal info; turning ON and OFF,etc, then spending another 45 min on the phone with Sony.
Any help or input would be appreciated. I have a feeling that no one else has had this problem, and that the new software 'broke ' my menu.
all is good....LNT4671 1005/1001 SQ01 w/old PS3 80G,Oppo 83 & 2400ES into Mirage OS3FS
petrovy is offline
post #1994 of 3281 Old 12-06-2013, 05:06 PM
Kisakuku's Avatar
Quoted: 24 Post(s)
Liked: 72
Have you tried bypassing all your network equipment and plugging the BDP directly into cable / DSL modem? Worth a shot.
Kisakuku is offline
post #1995 of 3281 Old 12-06-2013, 05:06 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 413
It is probably the DNS problem that Sony has been trying to fix for couple months and firmware revisions. Basically, the Sony must use your ISP connection to positively identify that your are inside US in order to provide you any internet video services. It has nothing to do with what's on your LAN but everything to do with how your internet service provider routes all the packets.
Sent from my Nexus 5 using Tapatalk
post #1996 of 3281 Old 12-06-2013, 06:15 PM
Chris Elm's Avatar
Is the issue with using coax S/PDIF the potential lip sync issues (as S5100 can only corrent lip sync issues over HDMI)?
Also, stupid question: what is the connection like for PCM...is it HDMI only?
Chris Elm is offline
post #1997 of 3281 Old 12-06-2013, 06:51 PM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 145
I guess that is a potential issue, but it hasn't been a problem for my Pioneer VSX-21TXH, past Sony LCDs, and now my Panasonic 50ST60, and I do connect my S5100 to the AVR with coax as the AVR doesn't do 3D. I've also run my HTPC with S/PDIF for audio for 7 years with this AVR and Denon and Yamaha AVRs and never had an issue. If there is a problem, it's been beyond my threshold to perceive it, and that includes testing with the audio part of the new Spears and Munsil disc. That said, rarely, there has been isolated source material that has been out of sync, but it's been really rare, and I can say the same thing about Sony LCD TVs playing broadcast TV and using their internal speakers for audio. AVRs usually have an audio delay feature, and XBMC has one as well, so there may be multiple ways to address the problem when it occurs, not just with HDMI Lip Sync.
For multichannel PCM, you will need HDMI. S/PDIF can carry 2ch PCM plus DD5.1 and DTS, which of course are lossy.
post #1998 of 3281 Old 12-06-2013, 06:54 PM
petrovy's Avatar
My network issue has both myself and Sony support stymied. ....the all important 'Activate Advanced Features...Register Your Device', does not exit, therefore I cannot get to SEN to register. The 'Internet Video' just don't work....
Problem solved (sort of), I have allowed 6 hrs for Sony 'specialist' to call me back and they have not, so I arranged for amazon to pick up and replace this item. For $60 this thing is just not worth all the time and effort trying to fix it.
Thanks, good idea. I do have another small Sony BDP-S185 BD player w/Netflix hooked up directly to router in another room, and it works without internet issues. I can try switching locations with the S3100, and if the 3100 still don't work, but the S185 works in the new location, then it is definitely a Sony S1300 issue.
Thanks for the response. Note that I do have 4 items (PS3, Oppo 83, Samsung smart TV, Sony BDP-S185) plus computers, working seamlessly with the internet. But like you say, and what I also think, that the problem may be software in the S1300. Anyway, I will try the thing I mentioned above, before returning the S1300 to amazon.
No way should it be such a PITA to get this thing to work.
petrovy is offline
post #1999 of 3281 Old 12-06-2013, 07:49 PM
Chris Elm's Avatar
Selden,
When you say that the 5100 do not decode 7.1 Dolby TrueHD audio tracks to produce 7.1 LPCM, are you referring to the coax output only? If I am understanding this correctly, the player will decode to Dolby TrueHD 7.1 LPCM via HDMI. Do I have that right?
I apologize for the many questions in this regard. I used to be well versed in all of this lossless/lossy audio formats, but have clearly fallen behind the times.
post #2000 of 3281 Old 12-06-2013, 08:01 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
^^ These particular Sony players will only decode Dolby tracks to stereo PCM. Plus, they only have HDMI outputs, no coax or optical or analog. It's just the way Sony designed the players.
Most players will decode up to 7.1 PCM for output over HDMI. Coax and optical connections are always limited to stereo PCM and DD 5.1 or DTS. Those are limitations of the S/PDIF protocol used with such connections.
BIslander is offline
post #2001 of 3281 Old 12-06-2013, 08:36 PM
mdavej's Avatar
Quoted: 2213 Post(s)
Liked: 969
They do have coax.
mdavej is offline
post #2002 of 3281 Old 12-07-2013, 02:02 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Oops. Yes, they do. I see that orange coax output right there on the back of my 5100.
post #2003 of 3281 Old 12-07-2013, 02:52 AM
Luisfc1972's Avatar
Quoted: 290 Post(s)
Liked: 29
im novice to av and ive been reading all reviews. a few say to turn off bd rom feature will help the speed of playing dvds and blu rays. i dont care about extra features so thats fine.
also read people cant get bitstream to work through their receiver? mine is a denon 1712 and i do want to be able to get hd audio out of blu rays with this player.
Luisfc1972 is offline
post #2004 of 3281 Old 12-07-2013, 05:24 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Sony players don't have a bitstream setting. Set the output to Auto (not PCM) and Mix to Off.
marctronixx likes this.
post #2005 of 3281 Old 12-07-2013, 06:52 AM
gibicaseba's Avatar
I got S1000ES I bought the OPPO 103 to see what all the fuss is about I was disappointed the picture quality didn't seem that much different then my s360 so I returned it looks like a cable/sat box but to some that's well built
qhWv
gibicaseba is offline
post #2006 of 3281 Old 12-07-2013, 08:08 AM
speedklz's Avatar
so, just because this player wont decode the DD streams isnt a problem right,because dont most BD have both streams encoded on them? both the dolby and the DTS.
Sony 55A3000
Sony 5100 BD
Mitsu 73837
speedklz is offline
post #2007 of 3281 Old 12-07-2013, 08:24 AM
Liked: 1637
Sorry, but no. The primary audio track on a Blu-ray disc usually is available only as Dolby TrueHD or DTS-HD MA. Only a very few discs provide alternate audio tracks using a different encoding method. When Dolby TrueHD is provided, a separate (hidden) lossy Dolby Digital track normally is sent to the output device if the audio output device can't decode TrueHD. When DTS-HD MA is provided, that audio track is built by adding more information to a lossy "core" DTS track. That lossy core track is sent to the output device if the audio output device can't decode DTS-HD MA.
With other BD players, people who want lossless audio have depended on the player decoding both types of lossless proprietary multichannel HD tracks into lossless multichannel LPCM.
Selden
post #2008 of 3281 Old 12-07-2013, 09:36 AM
speedklz's Avatar
Ok.. So would I still be able to do a 5.1 track.. I just thought that they usually had like a HD or MA track and a regular 5.1 type track..
Sony 55A3000
Sony 5100 BD
Mitsu 73837
speedklz is offline
post #2009 of 3281 Old 12-07-2013, 09:41 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 413
If your AVR has HDMI connection and supports HDMI audio, you should be fine by using the bitstream setting. The HDMI handshake should tell the player that it can only accept DD 5.1 or DTS 5.1 which if work correctly on the player, you will get lossy 5.1 tracks. Try it out. If you haven't purchased the player yet, don't buy it. You can buy any other brands or even older Sony players that can fully decode lossless audio tracks into multi-channel PCM which your receiver should have no problem.
post #2010 of 3281 Old 12-07-2013, 10:45 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Previous generations of Sony players would output in the following priority, based on the HDMI handshake: lossless bitstream to a receiver with the needed decoder, MCH PCM to a receiver capable of handling more than stereo PCM, DD 5.1 or DTS, and then stereo PCM. Foxbat121 - do you know whether these players will drop from TrueHD directly to DD 5.1, even when the receiver can process MCH PCM?
Reply Blu-ray Players
bx510 , dolby , m2ts , Sony , Sony Bdp S1100 Blu Ray Disc Player , Sony Bdp S3100 Blu Ray Player , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi , Sony Blu Ray Disc Player Bdp S790 , truehd
