Oppo BDP-105 "Sound Quality" Check Thread for Audiophiles - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 79Likes
post #1801 of 2081 Old 02-18-2015, 11:50 PM
linger63's Avatar
Quoted: 86 Post(s)
Liked: 46
Originally Posted by jkbunnell View Post
Hello, I'm new to AVS and this Oppo forum. For what it's worth, I've had the BDP-105D for almost a year. I use it primarily for stereo audio, so I went with Kimber Kable Hero XLRs directly into my Parasound Halo P3 preamp, which in turn is connected with another set of Hero XLRs to a Parasound Halo A23 power amp. After what seemed like a brief break-in period, I've been astonished by the sound (better than my BDP-95, which I moved to a second system in another room).
Hi,
Have you tried hooking up your Kimber Hero XLR's from the OPPO..... STRAIGHT to your Parasound Halo A23.........leaving the Parasound Halo P3 OUT of the chain??
Don't forget to set volume on the OPPO to "variable" and dial it down before you start.
If the cables aren't long enough just join them together!!!
Have a listen............. and be prepared for quite a surprise!!!
Cheers
linger63 is offline
post #1802 of 2081 Old 03-01-2015, 12:37 PM
Beowulf57's Avatar
Hello Folks,
I am burning in my new BDP-105D (does not sound as good as my Linn Unidisk SC, which has a more even, smooth balance, a bit richer, not as bright/edgy in the upper midrange/lower treble and somewhat better deep bass...however the Linn is a well broken in $6K unit with an upgraded Dynamik power supply) and am hoping that the sound will improve. I have about 100 hours on the Oppo at the moment and it has improved during the first 100 hours.
I only use the 2-channel stereo outputs for music listening and HDMI 1 to my Pioneer Elite Plasma for DVD and Blu-ray. Movie sound is either directly from the Oppo 2-channel stereo outputs, or from the Pioneer fed by the Oppo HDMI 1. My preamplifier is a McIntosh C2200 and my system is 2 channel only (mono-block tube amplifiers).
A couple of questions:
1. Is there an advantage to setting SACD to DSD rather than PCM? Does this avoid extra signal processing?
2. In order to ensure SACD DSD, is it necessary to turn off HDMI audio? If yes, this will mean turning it back on to watch DVDs and BDs?
Thanks for any help
Beowulf57 is offline
post #1803 of 2081 Old 03-01-2015, 01:46 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Originally Posted by Beowulf57 View Post
Hello Folks,
Thanks for any help
If there's no plan on your part to utilize the Oppo's speaker configuration menu settings, down-mixing, or crossover while playing SACD's or DSD files, then setting SACD Output to DSD would be the better choice. SACD Output to DSD bypasses all the above Oppo features I mentioned above, and its DACs will convert DSD audio direct to analog output. Setting SACD Output to PCM will convert DSD audio to an interim LPCM, 88.2 kHz, 24 bit stream before converting to analog.
It is "not" necessary to turn off HDMI audio while SACD output is set at DSD. The 105D will mute one or both of its hdmi outputs if the receiving audio sources attached to those interfaces can't decode DSD audio streams.
DanF8500 is offline
post #1804 of 2081 Old 03-01-2015, 04:53 PM
Beowulf57's Avatar
Thumbs up
Thanks DanF8500...glad to hear it is not necessary to turn off HDMI audio. I'll update on the sonic changes as the unit burns in.
post #1805 of 2081 Old 03-01-2015, 05:06 PM
monstosity12's Avatar
Quoted: 25 Post(s)
I plan on getting the oppo 105d and was hoping one could steer me into the right way of upgrading it. I see there are a couple of upgrading websites, which one should I choose. Im new to this. Also, will this improve sound quality. thanks
monstosity12 is offline
post #1806 of 2081 Old 03-02-2015, 08:50 AM
linger63's Avatar
Quoted: 86 Post(s)
Liked: 46
No rush
Hi,
Get your 105D and have a listen to it for a while first.
You may well decide that an upgrade (mod) is not necessary!!!
Obviously ALL the OPPO mod sites will claim audible improvements in SQ.
I am in Australia and had an older OPPO 83 fully modded by Custom Analogue.
I can comfortably state that it sounded pretty decent BEFORE the mods but AFTER the mods it clearly sounded MUCH better.
Here's Joe's website..........
http://www.customanalogue.com/index.html
I would imagine that a fully modded 105D would sound spectacular.
You DO need to take into A/C the extra $$ as if you decide to upgrade later you will lose most of mod investment when reselling.
Other well known modders of OPPO's include......
http://www.modwright.com/modificatio...dp83se-mod.php
http://www.audiocominternational.com/15-oppo-mods
There are a few more out there also.
Each of them have their own specific mods like reclocking or tube output so, if/when the time comes, some SERIOUS research is required to determine which modders strategy suits YOU the best.
Cheers,
John
linger63 is offline
post #1807 of 2081 Old 03-05-2015, 07:40 AM
Beowulf57's Avatar
After 175 hours of burn-in the Oppo BDP-105D is sounding smoother (upper midrange/lower treble harshness/edge has receded), sweeter and better integrated. I will see what happens with a few more hours...perhaps something startling....
linger63 likes this.
post #1808 of 2081 Old 03-05-2015, 01:01 PM
classicrecording's Avatar
Quoted: 46 Post(s)
Liked: 93
Personally, I agree with you. But there are people who think you are just getting comfortable with the sound and that electronics don't "break in".
classicrecording is offline
post #1809 of 2081 Old 03-05-2015, 01:09 PM
Beowulf57's Avatar
Nah...I compare to my Linn Unidisk SC and the sonic signature has changed.
post #1810 of 2081 Old 03-26-2015, 09:05 PM
ritter's Avatar
I have an OPPO 83 and was planning on replacing the former with the 105D, based on much I what I've read here. Sounds like a very worthwhile upgrade.
My question concerns bi-amping. I'd like to try bypassing the Krell pre pro I currently use and go directly to the amps. I've read where both balanced and unbalanced RCA are active- is that the 7.1 RCAs or the stereo RCAs or all three?
So I presume I use those outputs that are active and adjust for the +6 DB balanced output signal using the gain controls on the amps.
Or, one amp (Krell) has balanced line outs so I could run the amps in series vs. in parallel as at present.
Anyone else using the 105 in a bia-amped set-up? If so, how are you doing it?
I also use 2 x subs (one itself bi-amped) but I should be able to split one of the two sub outs making effectively 3 x sub outs.
I also
ritter is offline
post #1811 of 2081 Old 03-26-2015, 09:41 PM
Smarty-pants's Avatar
Quoted: 749 Post(s)
Liked: 627
^ Seems like you may be making it a bit more complicated than it needs to be...
First, all outputs on the player are active 24/7. So, theoretically you could send a 7.1 channel audio track to one source,
a stereo version of that to another source via the RCA stereo outputs, and yet another stereo version out via the balanced outputs.
You could use the balanced AND unbalanced at the same time, but they still may not sound the same, even after compensating for the 6dB difference.
If I were to do such a setup (bi-amped), I would just put an RCA splitter on each of the RCA outputs and split the signal of each 2 ways to 2 amps.
It may weaken the signal ever so slightly, but as long as the cable runs are short it shouldn't be an issue, and won't truncate the AQ.
Smarty-pants is offline
post #1812 of 2081 Old 03-27-2015, 05:32 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1089 Post(s)
Liked: 1070
If doing this, make sure the Oppo's dedicated stereo outputs are configured as front left/right instead of stereo downmix so that surround content won't be mixed into the dedicated stereo outputs. However, the dedicated stereo outputs and the multichannel outputs have a different DAC configuration, so I wouldn't be inclined to mix them in a situation such as biamping - I'd rather use an RCA splitter (or XLR splitter) as Smarty suggested later in his post.
The option of using the balanced line outputs on the Krell amp to feed the signal to the other amp would also be a good option.
But what speakers are you looking to biamp, @ritter ? In most cases, there really isn't any benefit and one would usually get better results from just getting a better single amp (or a pair of monoblocks) rather than splitting funds into 2 amps. Just something to think about.
gsr is online now
post #1813 of 2081 Old 03-27-2015, 11:40 AM
ritter's Avatar
Thanks both for the quick reply.
I have B&W 801 S3's as my mains. They are power hungry and require high current amps to control the bass in particular.
I use a Krell amp (500w @ 4 ohms) for the tweeter/ midrange and a Crown K2 for the 12" drivers. At 800w (@ 4 ohms) the K2 has the high current the drivers like and the SQ reflects that. I've tried different iterations but this is the one I like best so far.
I also have another K2 powering a VMPS Larger sub- one side to the 15" and the other to the 12" driver. These amps deliver not only muscle but also great control for big drivers.
I guess I'm inclined to split the balanced outputs of the 105 as I already have the lengths necessary to run to amps (rather than through the Krell's balanced outputs).
ritter is offline
post #1814 of 2081 Old 05-03-2015, 06:32 AM
patchesj's Avatar
Wondering if anyone else has noticed this with DSD material... Everyone seems to agree that the DAC volume control in the 105 works really well at not degrading sound quality. I've recently readjusted the gains on my amps to take my "normal" listening volume on the Oppo from ~35 to ~65. Non-DSD material sounds the same, but there has been a very noticeable increase in the quality/detail of DSD based material. Does anyone know if the DAC uses a different method for volume control with DSD? I would think because of the nature of DSD, the previously described bit dropping doesn't work? The detail increase has been mainly in upper octave sounds, guitar string "attack" and the front end dynamics mainly. Also, much more realistic vocal "air".
I've repeated this a few times and I don't think I'm imagining it. I would like to do more work to raise the Oppo volume control level, but don't have the equipment to test output clipping. I would hope that Oppo has designed everything in a way that would allow you to run near ~0 on the volume and not clip with reference source material. After all, the fixed output setting is at "0"?
Thoughts?
patchesj is offline
post #1815 of 2081 Old 05-05-2015, 05:53 AM
Quoted: 749 Post(s)
Liked: 627
^ You shouldn't get any clipping in the player no matter how high you turn up the volume control.
It is best to have the volume control above the 50% mark to avoid any audio degradation.
Since you have it at 65 now, it is very unlikely that you will hear any difference in AQ by turning it up any more than that.
Here is an official qute I got from the CTO of Oppo Digital a while back...
The BDP-105 uses the ES9018 DAC chip’s digital volume control. The ES9018 DAC has a 135dB dynamic range. The BDP-105 has a 110dB dynamic range. There is a 25dB difference before the noise floor of the player’s analog circuit starts to affect digital dynamic range. For BDP-105 each step of the volume control scale is 0.5dB, so it is best to have the volume control somewhere between 50 and 100.
Setting the volume below 50 does not mean that it will sound poor. It just means that the full potential of the hardware is not utilized.
Jason Liao
OPPO Digital, Inc.
post #1816 of 2081 Old 05-05-2015, 06:13 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2579 Post(s)
Liked: 3270
The Rule of Thumb is to set up your Analog audio path so that you can use an OPPO Volume of 70 or higher. Jason's statement of 50 or higher is the technically correct answer. The extra 20 steps (10 dB) allows some margin in case you really need to lower volume below 70 for some content.
But these limits are related to dynamic range (max content volume over the content noise floor) and how that relates to the noise floor of the player. So if you push it, you are only going to notice it anyway in high quality recordings which feature high range and low noise floor. I.E., you are unlikely to hear it on CDs which have been "compressed" to make EVERYTHING sound loud.
It may simply be that the DSD recordings in question here are better recordings, not due to DSD but due to the care taken in the recording process.
--Bob
woof07 likes this.
Bob Pariseau is online now
post #1817 of 2081 Old 05-05-2015, 08:22 AM
Sharp1080's Avatar
Quoted: 618 Post(s)
Liked: 386
This discussion regarding the volume control on the Oppo, reminds me of the "sweet spot" on the volume control on analog preamps years ago. Some things seem stay the same.
Sharp1080 is offline
post #1818 of 2081 Old 06-04-2015, 05:42 AM
Knight7m's Avatar
Quoted: 41 Post(s)
Recently I purchased 105D player, I found the sound of Blu Ray movies close to vinyl's, which is outstanding.
I'm connecting the audio from L/R fronts of 7.1 channel outputs directly to my Krell Phantom II preamp after I deselect all other channels, its process LFE channel which I want it because im listening only to two speakers. However, I wonder is it best connection or should I use the dedicate stereo?
Also is there other setting I need to tweak for optimal SQ. And thank you for answering.
Knight7m is offline
post #1819 of 2081 Old 06-04-2015, 05:55 AM
patchesj's Avatar
Ideally you would use the dedicated L/R outputs (RCA or XLR) for optimum 2 channel listening. However, I've been told that the LFE channel on any ".1" recording will NOT be mixed back into those outputs. It will only be available on the L/R outputs as part of the 7.1 output set.
patchesj is offline
post #1820 of 2081 Old 06-04-2015, 06:28 AM
Read the FAQ!
Liked: 3270
You can use the Dedicated L/R outs in exactly the same way you use the LF/RF outs of the multi-channel Analog set by configuring the Dedicated L/R outs to respond to all the configuration settings that apply to those LF/RF outs. The setting is Stereo Signal FRONT LEFT/RIGHT.
(If you want the Dedicated L/R outs to operate independently of those settings the setting is Stereo Signal DOWN-MIXED STEREO.)
As mentioned, in the independent configuration (Stereo Signal DOWN-MIXED STEREO), the LFE channel of a multi-channel track -- the .1 of 5.1 or 7.1 -- is not included in the down-mix. This is done quite deliberately as including the LFE in the down-mix requires a substantial additional "down-mix attenuation" for the L/R outs which effectively raises their noise floor.
When you use LF/RF alone from the multi-channel set -- or the Dedicated L/R with Stereo Signal DOWN-MIXED STEREO selected -- the LFE content from multi-channel tracks *WILL* be included in the down-mix if you have the Sub out set to OFF. This is true whether the down-mix is selected to Stereo in the Speaker Configuration > Down-Mix setting (a separate setting from the Stereo Signal setting) or if you'v achieved the same thing by manually turning off all the other speaker outs and the Sub out. Indeed, when you select Speaker Configuration > Down-Mix > STEREO, a side effect is that the Subwoofer output is switched to OFF.
However, you can get the same style of down-mix on the LF/RF outs that is applied to the independently configured L/R outs by (1) setting the LF/RF outs to LARGE so no Crossover happens, and (2) turning the Subwoofer back ON after selecting the Down-Mix STEREO. The LF/RF outs will get full frequency range output, and, if you play a multi-channel track, the LFE content will be discarded out the un-wired Subwoofer jack.
This is how I would set things up for Stereo Analog output in the 105 or 105D:
1) Set Stereo Signal FRONT/LEFT RIGHT.
2) In the multi-channel Speaker Configuration, set all speakers to OFF, except for LF/RF set to LARGE. Then set Down-Mix to STEREO. Then, as the last step, go back and turn the Subwoofer back to ON.
3) Wire the Dedicated L/R pair instead of the LF/RF pair. You can use either the RCA or the XLR pair for this.
Note that the Crossover setting is ignored since the only active speakers (LF/RF) are set to LARGE.
When playing Stereo content, all the output will go out the Dedicated L/R jacks.
When playing multi-channel content, all the output of the normal speaker channels will be down-mixed into the Dedicate L/R outs, and any LFE channel content will be discarded.
Folks who mix multi-channel movie tracks put plenty of bass in the normal speaker channels, so I think you will like this better than including LFE in the down-mix and having to compensate for the substantial increase in down-mix attenuation. And indeed, folks who mix multi-channel music tracks frequently put NOTHING in the LFE channel. All their bass is in the normal speaker channels. I.e., their 5.1 or 7.1 track is effectively 5.0 or 7.0 because the .1 channel is silent.
--Bob
DanF8500 likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
post #1821 of 2081 Old 06-04-2015, 09:36 AM
dbphd's Avatar
Quoted: 405 Post(s)
Liked: 150
I agree, the sound from Blu-ray music discs can be superb. I can switch between HDMI-2 and dedicated stereo to a Cary Cinema 12. I prefer HDMI, which uses the Cary DACs and permits speaker crossovers to be set individually. In addition to moving to dedicated stereo for analog from the Oppo, I'd urge OP to try HDMI and both stereo and multi-channel. Multi-channel can provide a greater sense of recording hall ambience. I haven't tried coax or optical from the Oppo 105, but I suspect either could be an alternate to HDMI except for SACD.
db
dbphd is offline
post #1822 of 2081 Old 06-15-2015, 01:34 PM
Liked: 1
Hi folks,
I'm a newbie to the AVS forum and this is my first post.
I've just given away my old SACD player to my nephew and now looking for a new SACD player. The Oppo BDP-105D and the Marantz SA8005 are high on my list.
The BDP-105D seems to have all that I'm looking for (e.g. the ability to play DSD files from USB/computer; it plays DSD to analog without converting to PCM).
Should I pull the trigger on the BDP-105D, or should I wait for a new BDP product from Oppo? (The BDP-105 has been around a couple of years now and I've heard rumors of a new version that supports 4K video etc).
I'm interested in using the BDP-105 for audio only.
exaudi is offline
post #1823 of 2081 Old 06-15-2015, 01:41 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2799 Post(s)
Liked: 2034
Originally Posted by exaudi View Post
Hi folks,
Welcome to AVSForum.
OPPO has said they will not have new player this year and probably not next year either.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #1824 of 2081 Old 06-15-2015, 01:50 PM
Liked: 1
Thumbs up
-Bill
Thanks Bill -- much appreciate it.
I'll be connecting it to my amplifier, and so I won't be using the Video side of the Oppo. However, its good to have a backup Blue-Ray player (just in case our player dies).
exaudi is offline
post #1825 of 2081 Old 06-16-2015, 04:07 PM
dbphd's Avatar
Quoted: 405 Post(s)
Liked: 150
The video processing of the Oppos is excellent. Why wouldn't you use HDMI-1 as well? I take HDMI-1 directly to a projector, and HDMI-2 to a processor for audio. But in the past I've taken analog from the Oppo 105 directly to amps.
db
dbphd is offline
post #1826 of 2081 Old 06-23-2015, 04:33 AM
Knight7m's Avatar
Quoted: 41 Post(s)
--Bob
The 105D does not process (include) LFE channel in dedicate analog stereo output (RCA or XLR) for blu ray disc, but only DVDs.
I tried these settings:
Stereo signal: DOWN-MIXED STEREO and FRONT LEFT/RIGHT.
Speakers configuration > down-mix: LT/RT and Stereo. Sub out: OFF and ON. (after I deselect all other speakers).
I don’t understand why 105D process the sound in DVD perfectly but not blu ray, I'm disappointing because of this.
Anybody have advice how I can fix this.
Knight7m is offline
post #1827 of 2081 Old 06-27-2015, 07:20 PM
bluewizard's Avatar
Quoted: 1728 Post(s)
Liked: 1035
Can someone give me a summary of the Oppo 103 and 105 Streaming capability?
I'm thinking of using this is a Music Only system. Pretty hard to find a Player and Streaming in separate units for that price.
Am I right in assuming there is a Smart Device App to control the Streaming, so I don't necessarily need to TV?
Oppo 103D and 105D as Audio Streamers???
Steve/bluewizard
bluewizard is offline
post #1828 of 2081 Old 06-28-2015, 06:03 AM
JazzGuyy's Avatar
Quoted: 292 Post(s)
Liked: 289
Look at this link: http://watershade.net/wmcclain/BDP-103-faq.html
Also look at the first postings of the 103 and 105 threads for summaries of the features and differences. Streaming capabilities are the same for all units. The 105x models have better DACs and allow for a direct USB connection from a computer to the 105 to use it as a two-channel DAC. These cover most (maybe all) of what you want to know. As far as streaming goes, are you talking about streaming from your computer to an Oppo or are you talking about the Oppos and streaming services? Streaming from your computer using either DLNA or SMB handles all the file formats supported by the Oppos. There are media control apps for both iPhone/iPad and Android but some people think they still need to be improved. Even with these, you may still need some sort of monitor for the best results.
JazzGuyy is online now
post #1829 of 2081 Old 06-28-2015, 03:11 PM
Read the FAQ!
Liked: 3270
Actually the 105D does down-mix LFE content into LF/RF of the multi-channel Analog output set when the Subwoofer is set to OFF, but you'll only get that on LPCM tracks or TrueHD tracks. I.e., it won't work with DTS-HD MA tracks (which I suspect is what you were playing on the Blu-ray discs you tried).
I'm checking into the DTS-HD MA situation to confirm what's really going on here, but I strongly suspect the answer will be it is just DTS being silly again. Not a bug in the OPPO.
You see, DTS mandates how a DTS-HD MA decoder *MUST* handle the decode if a down-mix is required. E.g., if you decode a DTS-HD MA 7.1 track for 5.1 speakers -- and the DTS-HD MA decoder knows you are doing that -- then the decode is subtly different from doing a full decode of the 7.1 track and THEN down-mixing THAT into 5.1. Similarly, I'll bet DTS has mandated that if the subwoofer is OFF -- and the DTS-HD MA decoder knows it -- then the LFE channel content must be discarded; not down-mixed into LF/RF.
If you want to try the LPCM or TrueHD test cases, you can use the 5.1 and 7.1 LPCM test tracks on "AIX Audio Calibration", Blu-ray, the 7.1 TrueHD track on AIX, and the 5.1 TrueHD track on "DVE HD Basics", Blu-ray.
To check the DTS-HD MA case, you can't use the AIX disc, due to the special way it has been authored. (It will only decode its 7.1 DTS-HD MA track for a full 7.1 speaker configuration. I.e., it is trying to make sure you don't get mislead by the variant decoding DTS mandates for a less than 7.1 speaker configuration.)
However, you can use the 5.1, 6.1, and 7.1 DTS-HD MA test tracks on Disney's "WOW World of Wonder", Blu-ray for this.
--Bob
dvzzz likes this.
post #1830 of 2081 Old 06-29-2015, 01:56 AM
bluewizard's Avatar
Liked: 1035
...As far as streaming goes, are you talking about streaming from your computer to an Oppo or are you talking about the Oppos and streaming services? .....
Thanks for the response and the Link. I'm first concerned about AUDIO Streaming, not video or video services. Audio Stream can be from local storage or from the Internet. And I'm referring to Network Streaming, not a direct connect such as USB.
I'm open to any insight anyone can offer on the Audio Streaming aspect.
And I will check out the link you provided.
Steve/bluewizard
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player , Blu Ray Players , Marantz Ud9004 Flagship Universal Player
