HDMI Audio still best? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-16-2013, 01:04 PM - Thread Starter
rtrautner's Avatar
Wondering if HDMI Audio is still recommended as best for CD/SACD playback? Will there be any change in that recommendation after the upcoming upgrade is performed on the unit?
rtrautner is offline
post #2 of 3 Old 01-16-2013, 02:36 PM
JazzGuyy's Avatar
Quoted: 287 Post(s)
Liked: 268
What player is this? You should pose your question in the owner's forum for whatever player it is you have.
JazzGuyy is offline
post #3 of 3 Old 01-18-2013, 09:57 AM
Jon S's Avatar
Quoted: 798 Post(s)
Liked: 259
It depends on the player and the receiver. If the receiver has better DACs, then use HDMI. But if you have a really good player, like a TOTL Oppo or Sony XA5400ES, then have the player use its internal DACs and send the signal to the receiver using the analog outputs. The top Oppos uses stacked DACs for better sound which surpasses almost any receiver's capabilities.
If it's not a BIG screen, it's not a theater...
Jon S is offline
Reply Blu-ray Players
