DSD direct from oppo 105 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-01-2013, 06:31 AM - Thread Starter
LMario's Avatar
hello
can the oppo play dsd shiny disk directly to powered speakers connected to oppo?
or do i need a dsd compatible processor connected to oppo by hdmi?
sorry but i have placed the tread instead of placing it in the oppo 105 tread
can the administrator move it to the right place please?
mario
LMario is offline
post #2 of 3 Old 02-01-2013, 03:37 PM
Selden Ball's Avatar
Quoted: 3057 Post(s)
Liked: 1496
DSD itself is not allowed to leave a player unless it's encrypted. i.e. it has to be over HDMI.
And then you need a decoder that can handle it. The receivers and pre/pros that I know which can decode it can't apply any digital processing -- no Audyssey or other room correction can be applied, (I read somewhere that the DSD signal actually goes directly into the DACs which drive the receiver's outputs.)
Players are allowed to decode DSD and provide the resulting analog signals on their analog outputs, of course, or as standard resolution PCM. PCM can then be transmitted over HDMI or S/PDIF (optical or coax). Of course, S/PDIF is limited to two channel PCM, while HDMI would be needed for multichannel soundtracks.
Selden
Selden Ball is online now
post #3 of 3 Old 02-01-2013, 04:43 PM
JazzGuyy's Avatar
Quoted: 286 Post(s)
Liked: 267
Originally Posted by LMario View Post
hello
mario
Yes, you can. The Oppo decodes DSD to analog out just fine. You can connect the Oppo directly to your powered loudspeakers via its analog outs.
JazzGuyy is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
