sync remote with TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-02-2013, 07:10 PM - Thread Starter
jreese83's Avatar
In the center-top area of the remote, there are some TV controls (power, A/V, volume). In the owner's manual, it says those work with a Panasonic TV.
The problem is, I have a Sony TV. Is there any way to sync the remote with my non-Panasonic TV?
jreese83 is offline
post #2 of 5 Old 02-03-2013, 09:33 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Not much to go on. I assume this is for a recent model Panasonic disc player. If so, there is no way to use the remote with anything but Panasonic. You should consider getting a universal remote.
mdavej is offline
post #3 of 5 Old 02-03-2013, 09:44 AM - Thread Starter
jreese83's Avatar
Sorry, I should have been more specific. This is for the DMP-BDT220 Blu-Ray player. It seems like there should be a way to sync the Panasonic remote with my TV, but if not I'll just working with separate remotes (or a universal, like your suggested).
jreese83 is offline
post #4 of 5 Old 02-03-2013, 10:16 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 950
We have talked about this in the player thread. The current Panasonic remotes only control Panasonic TVs.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #5 of 5 Old 02-03-2013, 12:22 PM
mdavej's Avatar
Liked: 940
They removed that ability in 2012, probably to cut costs. So what you're asking is impossible. If you really like the Panasonic remote, get a 2011 or earlier model from Panasonic parts site. It will work a sony tv, among others. IMO your money is better spent on a universal. They start around $15.
mdavej is offline
Reply Blu-ray Players
Panasonic 3d Blu Ray Player Dmp Bdt220
