NetFlix Streaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-03-2013, 03:09 PM - Thread Starter
njrich50's Avatar
On my second oppo 103. Have Netflix streaming problem. It will stream movies ok for about a week and then it will go blank (dark screen) as it starts to load the movie. The unit locks up. Have to power it off and back on, go to restore factory default settings and it will steam movies again for about a week and then the process starts all over again. Replaced the hdmi cables twice. The rest of the function are OK just this Netflix start streaming problem. Played with different settings, clear cache, etc to no avail. Oppo CS is of no real help except to sent me a third unit. So much grief from a 500.00 player! Hope someone here can help me.
New HDMI cables, twice.
Factory stock settings.
Set for split A/V, one to T.V the other to AV
njrich50 is offline
post #2 of 3 Old 02-03-2013, 03:12 PM
H8ter2's Avatar
It may not be the player, how does it work with other functions? I ask because Netflix has had issues with streaming with other devices when there is nothing wrong per say with the device or the service. For instance I was able to stream perfectly fine on my PC, but had issues for awhile on my Ipad until Netflix sent a bug fix. Other then that IDK just figured I would throw that option at you.
H8ter2 is offline
post #3 of 3 Old 02-03-2013, 03:27 PM
Super Moderator
teachsac's Avatar
Quoted: 814 Post(s)
Liked: 1335
Mods ask that you post inside the Oppo thread. Hit post reply, not start new thread.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player
