Cambridge Audio's Azur 752BD - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #361 of 473 Old 04-13-2015, 04:16 AM
Liked: 0
Hi, I using MakeMKV to create MKV's of my Blu-Rays collection but have some problems with the Cambridge 752BD:
- first the player reported all the "Dolby true HD" tracks stored in a MKV file as MLP.
- also if a MKV file has two or more "DTS-HD MA" tracks, the first is recognized correctly, all others are recognized as simple DTS. No problem if there is only one DTS-HD MA track, or if any other track using other codecs.
I want to clarify that by opening this mkv files with PC software (MPC, mediainfo, mkinfo) all the track are recognized correctly!
phoenix161081 is offline
post #362 of 473 Old 04-13-2015, 05:27 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 949
Ripping questions should go here.
Ripping Blu-Rays II
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #363 of 473 Old 04-13-2015, 06:06 AM
Liked: 0
It isn't a ripping problem, the problem is that Cambridge 752BD not recognize properly hd-tracks in mkv files
post #364 of 473 Old 04-13-2015, 06:36 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 949
TrueHD is based on MLP lossless.
teachsac is offline
post #365 of 473 Old 04-13-2015, 08:37 AM
Liked: 0
It's true, but with the original blu ray the Cambridge sees the TrueHD track, instead with corresponding mkv don't...
However the quality is not affected, the real problem are DTS-HD MA tracks recognized as simple DTS
post #366 of 473 Old 04-13-2015, 08:46 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 949
It could be that when streaming or through USB it reads it as TrueHD. I've seen this mentioned before. Don't remember if it was in this thread or another player's thread. I'd try CA if you haven't already to see what they have to say.
teachsac is offline
post #367 of 473 Old 04-14-2015, 06:20 AM
Liked: 0
Dear Sir, Thank you for contacting Cambridge Audio. The following video formats are supported on the 752BD
MPEG2, MPEG 2 HD, MPEG4, MPEG4 HD, AVC, VC-1, DIVX, XVID, VCD, AVI, AVC, MKV (4.1), DAT, VOB, WMV, MOV, MP4, MPEG-PS, FLV, MTS, M2TS, M2T, M4V
Whilst we strive to maintain maximum file compatibility, because of inconsistencies in how some file formats are generated and a constantly changing industry we CANNOT guarantee the playability of all file formats above.
We cannot support issues in relation to files ripped from official discs. We can only support issues with the original disc itself.
post #368 of 473 Old 04-14-2015, 06:44 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 949
Are you getting 5.1/7.1 with these files when it says MLP?
S~
teachsac is offline
post #369 of 473 Old 04-14-2015, 05:04 PM
Liked: 0
S~
Yes
However, the real problem are DTS-HD MA tracks recognized as simple DTS
post #370 of 473 Old 04-21-2015, 07:24 PM
Liked: 0
I had a 752BD - just sold it.
Good sound. Great picture. Responsive remote.
Only issues:
No Netflix app
No mute (I use it as a pre direct to my amp)
Switching to Oppo 105
Pepperinca is offline
post #371 of 473 Old 04-21-2015, 08:51 PM
TripleFun's Avatar
Quoted: 28 Post(s)
Only issues:
No Netflix app
Please reply in the ways you find the 105 different. In particular, assuming you used 7.1 out on the 752bd, do you notice a difference between the 752bd wolfson and the 105 sabre DACS. Also, do you intend to use the 105 USB DAC processing?
TripleFun is offline
post #372 of 473 Old 04-23-2015, 10:29 AM
Liked: 0
I am waiting on my BDP-105. I will update after I've had a chance to use it for a while.
post #373 of 473 Old 04-23-2015, 02:49 PM
kta
kta's Avatar
I put a Chromcast into the HDMI input of my 752 and it works a treat- gives me Netflix as well as all the other stuff Chromcast streams. I have just acquired an Oppo HA-1 instead which it seems, from an audio perspective, to have a better spec than the 105D.
I also run a Azur 851N so I will be interested in the comparison.
kta is offline
post #374 of 473 Old 04-24-2015, 10:00 AM
Cloverleaf's Avatar
Quoted: 72 Post(s)
Liked: 41
Only issues:
No Netflix app
Yeah, be interested in the comparison. General opinion seems to be that video performance is identical, while the 752BD is better for audio ? Did you get the Oppo for the Darbee ?
Each to their own, but personally I wouldn't swap - I don't like Darbee, and the Oppo 105 is about £500/$760 more here than the 752BD !
Panasonic ZT65 (isf calibrated) / Cambridge Audio 752BD / Sky+ HD / Pioneer LX55 / Tannoy Arena 5.1 / Dual CS506 / Rega Mini Fono / Isotek Mira / Antimode 8033 / QED + Audioquest Cables / Virgin Media 50MB Network /
Cloverleaf is offline
post #375 of 473 Old 04-25-2015, 01:45 PM
Liked: 0
Paddington Blu Ray does not load
Hi Guys,
Bought the Paddington Blu Ray for my daughter from Amazon and it didn't load. Obviously thought it was problem with disc, but same thing happened with replacement. Tried the disc in my old Sony player and it worked fine. Wrote to CA and they concluded that a firmware update was required to rectify the problem and to be patient while this is sorted. All my other blu rays have worked fine, but now while playing Horrible Bosses the picture froze a few times while watching. Starting to wonder if it is a problem with my particular player and nothing to do with a firmware update. What do you think?
Jason Ason Son On N is offline
post #376 of 473 Old 04-27-2015, 07:35 AM
Cloverleaf's Avatar
Quoted: 72 Post(s)
Liked: 41
Originally Posted by Jason Ason Son On N View Post
Hi Guys,
Sounds like cobblers, to be honest. Why would a mainstream BD need a firmware upate in order to play it ? Never come across one that hasn't played on the CA, the only time I had trouble once was trying to play a BD that someone had left greasy fingerprints all over. Quick wipe clean and all was well.
To be fair I have found that if you e mail the support site , they are usually helpful, if a tad slow to reply.
post #377 of 473 Old 05-08-2015, 02:07 PM
Alexdad54's Avatar
Quoted: 12 Post(s)
I was playing with the setup for my 752 to get optimum two-channel quality but I'm afraid I might have messed up the settings and am no longer sure what the consensus is on the "best" configuration.
I currently have the audio settings (based on earlier posts) as:
Large Front speakers (L&R)
5.1 (although I'm only running 2-channel, no sub).
The sound doesn't seem as full as it was and I'm wondering if I should be using different settings.
I have read the instruction manual but I'd appreciate any and all views from owners.
TripleFun likes this.
Alexdad54 is offline
post #378 of 473 Old 05-08-2015, 02:56 PM
TripleFun's Avatar
Quoted: 28 Post(s)
What receiver are you using; how do you make the connection; are you using 'stereo direct' or are you using the receiver's digital processing features?
post #379 of 473 Old 05-08-2015, 06:28 PM
Alexdad54's Avatar
Quoted: 12 Post(s)
Hi,
It's running directly to a Rogue Audio Cronus Magnum integrated amp so no processing being done. I assume that's stereo direct?.
Speakers are set to Large
No sub
Downmix is set to to stereo - should it be LT/RT?
Speakers are connected to the first two outputs in the 7.1 section NOTthe stereo audio out.
post #380 of 473 Old 05-08-2015, 06:56 PM
TripleFun's Avatar
Quoted: 28 Post(s)
stero output
Originally Posted by Alexdad54 View Post
Hi,
No sub
I know someone says they have been having trouble with the stereo output but this reviewer with the 752bd connected to a krell did not seem to have any issues - http://www.audioenz.co.nz/2013/10/ca...io-azur-752bd/
post #381 of 473 Old 05-08-2015, 07:05 PM
Alexdad54's Avatar
Quoted: 12 Post(s)
I'm wondering if there is any other documented benefit to using the 7.1 speaker outs rather than the stereo outs other than than what Inarbi wrote in post#326, suggesting that if using analog stereo to utilize " speakers settings to 5.1, subwoofer on (even if you don't use one), and all speakers to large. If you use analog audio, use the Front Left/right terminals for stereo not the dedicated stereo ones."
This is what I switched to but I'm wondering if others have tried it and if there is a consensus on this......
post #382 of 473 Old 05-08-2015, 07:36 PM
TripleFun's Avatar
Quoted: 28 Post(s)
It's a simple mater to set up either configuration. try it and see which works best for you. Then post your findings here for others to consider.
post #383 of 473 Old 05-08-2015, 07:48 PM
Alexdad54's Avatar
Quoted: 12 Post(s)
Well, I guess if no one else has done it then I will.....I'll try on Sunday evening (my only alone time) and report back....I'll do my best to describe what I hear but don't expect "expert" feedback though!
post #384 of 473 Old 05-09-2015, 07:36 AM
Cloverleaf's Avatar
Quoted: 72 Post(s)
Liked: 41
Personally, I just use the dedicated stereo out connectors, and feed it into my Pioneer AV using stream direct setting on the amp to get 2.1 sound. I can't see any benefit in using the surround outputs and downmixing to 2.0 ?? I would strongly suspect that the sound quality would be the same as all outputs use a dedicated Wolfson DAC, but why bother faffing about with the audio settings when you can just use the stereo outputs ? I would only do so if I was out putting 5.1 over analogue into the AV amp.
post #385 of 473 Old 05-10-2015, 03:04 PM
Knight7m's Avatar
Quoted: 41 Post(s)
Does 752 have audio delay option (same option In Oppo 105)? And does reduce P & S quality if increased high ? And thank you for answer.
Knight7m is offline
post #386 of 473 Old 05-10-2015, 03:10 PM
quad4.0's Avatar
Quoted: 132 Post(s)
Liked: 88
Originally Posted by ehlarson View Post
Quote:Originally Posted by BillP
Looks like the same price as the Oppo 105. What are the advantages of one over the other, considering the 752 is based on the 105?
I think Oppo's support is likely to be the biggest difference.
Oppo support- The main reason to buy one! I have experienced fantastic back up from Oppo. Even on Holidays, they will respond. Besides, the Cambridge is just an Oppo knock off.( my opinion)
quad4.0 is offline
post #387 of 473 Old 05-10-2015, 11:30 PM
linger63's Avatar
Quoted: 83 Post(s)
Liked: 46
Agrred........Oppo support is truly outstanding.
Although they have similar architecture the Oppo 105D offers a few extra features over the Cambridge 752BD
They both approach 2 channel analog audio in totally different ways.
The OPPO uses the excellent ESS 9018 Sabre 32 DAC.
The Cambridge uses Wolfson DACS which upsample everything to 24/192
After listening to both.......I preferred the OPPO and bought one.
BillP.........I would recommend that you audition both too as YMMV.
Cheers
linger63 is offline
post #388 of 473 Old 05-11-2015, 02:48 AM
Cloverleaf's Avatar
Quoted: 72 Post(s)
Liked: 41
That's a bit harsh IMHO. The 752BD has a completely different analogue stage, which is actually the most important differentiator between units. After all if you are just going to output bitstream over HDMI you may as well save your cash and buy a budget player. Furthermore, most independent reviewers have come out in favour of the 752BD sound over the Oppo 105. I can't be bothered to link them, but they are easily found.
Support ? Why is support so important, unless the player goes wrong ? Never felt the need to phone or e mail CA during a holiday, but hey, if that rings your bell.....
To be fair, if the cost is about the same for you, then the choice becomes much more difficult - on this side of the pond, the 752BD is around £500 / $780 cheaper, which again IMHO makes it somewhat of a no brainer in comparison to the Oppo.
post #389 of 473 Old 05-11-2015, 02:52 AM
Cloverleaf's Avatar
Quoted: 72 Post(s)
Liked: 41
Yes it does. Can't think of any reason why it would impact on quality.
post #390 of 473 Old 05-11-2015, 10:02 AM
linger63's Avatar
Quoted: 83 Post(s)
Liked: 46
Hi Cloverleaf,
MUST agree....... that is a SERIOUS difference in RRP!!!!
At least you have cheaper UK stuff.
I am in Australia and we get shafted by EVERYONE!!!
Cheers
linger63 is offline
Reply Blu-ray Players
Cambridge Audio Azur 752bd Universal Upsampling Blu Ray Dvd Cd Player , Blu Ray Players , Cambridge Audio , Cambridge Audio Azur 751bd 3d Compatible Universal Blu Ray Player Black
