Cambridge Audio's Azur 752BD - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #451 of 474 Old 01-05-2016, 03:51 PM
Rinke's Avatar
Quoted: 21 Post(s)
Originally Posted by smaragd View Post
From the Oppo FAQ :
SACD-R support was removed in firmware 50-0323B. (This is the writeable format for home-made discs and copies. Regular SACD is still supported).
The Cambridge Firmware is based on the Oppo firmware so it's safe to say that due to licensing the SACD-R functionality was also removed for this player...
More info here:
http://watershade.net/wmcclain/BDP-103-faq.html
Thanks for the reply Smaragd. That sucks. I have a whole heap of SACD ISO files that I would like to burn to disc to play. Now it means I will have to rip those files down to individual files etc
Rinke is offline
post #452 of 474 Old 01-05-2016, 04:33 PM
guzz46's Avatar
Quoted: 16 Post(s)
Try this program http://sourceforge.net/projects/sacd-extract-gui/
guzz46 is offline
post #453 of 474 Old 01-05-2016, 05:14 PM
Rinke's Avatar
Quoted: 21 Post(s)
Originally Posted by guzz46 View Post
Thanks but that program crashed my pc.
Rinke is offline
post #454 of 474 Old 01-05-2016, 07:51 PM
guzz46's Avatar
Quoted: 16 Post(s)
Strange, I've been using that program on Linux for a long time with no problems at all, try this version instead, I think it you may have to use the command line for this one
https://github.com/sacd-ripper/sacd-ripper/releases
guzz46 is offline
post #455 of 474 Old 01-06-2016, 03:47 PM
Rinke's Avatar
Quoted: 21 Post(s)
Command line??
Rinke is offline
post #456 of 474 Old 01-06-2016, 05:17 PM
guzz46's Avatar
Quoted: 16 Post(s)
Command line??
http://windows.microsoft.com/en-nz/w...-prompt-window
guzz46 is offline
post #457 of 474 Old 01-06-2016, 10:10 PM
Alexdad54's Avatar
Quoted: 12 Post(s)
Try IsoBuster to extract files from an SACD ISO.
http://www.isobuster.com/isobuster.php
or
http://www.computeraudiophile.com/f1...so-image-9591/
Alexdad54 is offline
post #458 of 474 Old 01-07-2016, 10:26 AM
Alexdad54's Avatar
Quoted: 12 Post(s)
Originally Posted by Alexdad54 View Post
Also check out: http://www.audiocircle.com/index.php...msg1373112#new
I'm going to try this one and see if I can play the extracted files via my NAS....
post #459 of 474 Old 01-10-2016, 09:29 PM
Alexdad54's Avatar
Quoted: 12 Post(s)
The software mentioned in this thread extracted dff files from the ISO perfectly. Will be trying playback shortly...
On another topic, has anyone had issues with watching Netflix via the 752 recently?
Since updating the 752's firmware a few days ago, I'm having drop-outs or "a blinking black screen" when watching Netflix which is being routed via my 752. It occurs when using the app on my Xbox One and the W8 app on a mini-pc attached to the 752. No issues when watching Netflix directly on my laptop though.
It seems similar to what happened with Samsung TV's about a year ago when they had their firmware updated so it makes me wonder if something similar is occurring with the 752.
Update: It's now happening no matter what source or file is being used. I get occasional white flashes along the bottom of the screen, intermittent blackouts that last 1-2 seconds and an occasional purple flash. The only change to my system has been the update from CA. Anyone have any ideas as to the causes?
post #460 of 474 Old 02-01-2016, 03:36 PM
guzz46's Avatar
Quoted: 16 Post(s)
I got my 752 back today, they replaced the power supply, and it was still in warranty so it didn't cost me anything, the dealer even gave me a demo unit while it was being repaired.
guzz46 is offline
post #461 of 474 Old 02-02-2016, 04:35 AM
Liked: 1
Good to know . I have two of these....Thanks
uthiker is offline
post #462 of 474 Old 03-03-2016, 07:15 PM
Liked: 2
What format does the hard drive need to be in in order to hook directly to the USB port on the back? I will be transferring movies/songs to an external drive. I need to know what to buy from newegg. I need read/write to/from the Apple and then read with the CA.
Thanks in advance.
Scott.C.McMahon is offline
post #463 of 474 Old 03-28-2016, 09:08 PM
Liked: 0
Just picked up a 752BD a week or so ago, and I was wondering about the 'Split A/V' mode vs. 'Dual A/V' mode. I was under the impression that 'Split A/V' would result in only video going out on HDMI 1 and only audio on HDMI 2. But with my player, I'm noticing that I get both audio and video on HDMI 1 and 2 when setting it to 'Split' mode. So now I'm wondering what the difference is between Split and Dual, since I get both audio and video on both HDMI outputs in either mode....
-Greg
rhythm5 is offline
post #464 of 474 Old 03-29-2016, 03:02 AM
TripleFun's Avatar
Quoted: 28 Post(s)
-Greg
Congratulations on the 752bd.
This is what the manual says on pg 25 ..
2. Dual HDMI Output
Allows you to select the output mode when both HDMI Output ports are
in use. If only one HDMI Output is active, this selection will not apply.
The options are:
Split A/V (Recommended) – Use HDMI 1 Out as the dedicated video
output port and HDMI 2 Out as the dedicated audio output port. This
setting will ensure the best possible picture quality and the highest
possible audio resolution.
Dual Display – Send digital audio and video signals to both HDMI
Outputs simultaneously. This setting is only recommended when two
HDMI displays are required, since the surround sound audio signal may
be down-mixed to stereo and the original audio quality may be lost.
Note: The player can automatically adjust the resolution of digital audio
and video signals depending on the capabilities of the connected
television and receivers. For HDMI 1 Out, the dedicated QDEO video
processor will be used unless Source Direct is selected, in which case
QDEO is bypassed.
TripleFun is offline
post #465 of 474 Old 03-29-2016, 07:56 AM
Liked: 0
Hi TripleFun, thanks for replying. Yes, I've read that part of the manual, but my unit seems to behave the exact same regardless of which mode I put it in. The manual makes it sound like the 'Split A/V' mode will give you video only at HDMI 1 and audio only at HDMI 2 (when both ports are in use), but I get both audio and video on both outputs in the split mode. It seems like the player is not really going into split mode at all, but remaining in 'Dual Display' mode no matter what I select.
Greg
rhythm5 is offline
post #466 of 474 Old 03-30-2016, 09:43 AM
Liked: 0
Just curious, for any of you 752BD owners out there who are using both HDMI 1 and 2 outputs and using 'Split A/V' mode, what is the resulting output from each HDMI port? I'm getting both audio/video at each of the two outputs, but I don't think that's what's supposed to happen in the split mode.
Greg
rhythm5 is offline
post #467 of 474 Old 04-01-2016, 11:08 AM
Liked: 0
Well, nevermind...I think I've got the A/V split thing figured out. Both HDMI outputs have to not only be connected but actually 'active' (selected and in use by other components) for the split feature to manifest itself.
Now if I could just figure out why I get an occasional random audio dropout while playing CDs... I'm wondering if a component, like my TV, is doing something that is sending a communication message and interrupting the audio. My TV's CEC control is disabled, though....
Greg
rhythm5 is offline
post #468 of 474 Old 06-09-2016, 10:04 AM
Alexdad54's Avatar
Quoted: 12 Post(s)
I'm getting a bit fed up with the gaps that the 752BD inserts into a lot of my music files (concerts, etc.) and rather than try and batch convert these files into single flac images, I'm looking at getting a Bluesound Node 2 media streamer to insert in between my NAS and the 752.
I have the option of either using the DAC in the Node 2 or running it into the 752 but my question is if I do run it through the 752 for the audio quality it offers, will the 752 play the files it gets from the streamer as gapless or will it still insert these gaps?
I'm assuming that as the Node would take over the streaming duties that there won't be any gaps inserted but am not sure. I can get a Node on a 30-day return basis but thought I would ask here first....
post #469 of 474 Old 06-09-2016, 08:19 PM
deang001's Avatar
I just recently bought a 752BD and love it
At the moment I'm using it with a Denon X2200 and my KEF LS50 speakers as part of a 5.1 surround system.
I'd like to step up a bit and get an amp just for 2 Channel music and remembered when reading the manual that because the 752BD has volume control I can use a Power amp.
I've been thinking about getting a Peachtree sonaAMP. Would this be Ok to use by itself with the 752BD? I think the 752BD, the LS50's and the Peachtree amp would be a nice match.
I'd use the Peachtree totally separately and just have two sets of speaker wires for the LS50's.
http://www.peachtreeaudio.com/sonaam...amplifier.html
deang001 is offline
post #470 of 474 Old 07-04-2016, 05:09 AM
Reynaldo's Avatar
I bought this Bluray Cambridge Azur 752bd I am waiting to get.
Will it be better than my Oppo103 for audio?
Reynaldo is online now
post #471 of 474 Old 07-16-2016, 05:40 AM
Liked: 1
Hi You'll love the sound . I had a 103 and 105 oppo and the 752 beats both. I own two.
uthiker is offline
post #472 of 474 Old 07-16-2016, 11:58 AM
Reynaldo's Avatar
You're right.
Cambridge 752 has arrived and I'm really enjoying the quality of the audio.
post #473 of 474 Old 07-22-2016, 04:29 AM
Reynaldo's Avatar
Has as let the dedicated stereo outputs on DSD?
Or they just work in PCM?
post #474 of 474 Old Today, 06:26 PM
scottm18's Avatar
Anybody have a Cambridge 752 with a still ISO-playing firmware loaded they would be willing to sell? I really want to play my backed-up DVD Audio discs (off disc and ISO are only options) and I stupidly upgraded mine to the point of no return to get DSD playback. Now i have a dedicated DAC so I dont need anything beyond 752BD(CU)-12-0305. I love the sound of it and like to find one that can do it if out there.
scottm18 is online now
Reply Blu-ray Players
Cambridge Audio Azur 752bd Universal Upsampling Blu Ray Dvd Cd Player , Blu Ray Players , Cambridge Audio , Cambridge Audio Azur 751bd 3d Compatible Universal Blu Ray Player Black
