BD590 won't play bluray & also won't downgrade - help? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-02-2013, 06:09 AM - Thread Starter
ottosmo's Avatar
My BD590 said "upgrade available" so I allowed it to network-upgrade to what turns out to be BD8.97.423 / H90378 / H09LGN.
Now it won't play BluRay discs at all - every one that goes in results in a disc error.
I have downloaded alternate firmware and tried to downgrade but the player is not recognizing the downgrade. Can someone give a hint what I'm doing wrong? Here's what I've tried:
1. Downloaded a .ROM.zip file which unzipped to a .ROM folder with .ROM-00 and .ROM-01 files inside
2. I tried putting the folder (with two files inside) onto a flash drive and inserted into system. The system did not say anything about upgrading.
3. So I tried taking the two files out of the folder and putting the two individual files in home directory of the flash drive. Same result.
4. Then I tried putting the two individual files into the home directory of a CDROM and inserting that. Same result.
5. I unplugged and plugged back in.
6. I used the "initialize" command on the setup screen.
7. Still same results.
BTW I am using an iMac to write to the Flash and also to burn the CDROM. Don't see why that would make a difference but just in case.
Any clues on how to make the player recognize the downgrade image?
Also: does anyone else have experience with this new .423 image? I tried 4 bluray discs on it and all ejected without reading. It actually works fine for Netflix streaming and for DVD but not for Bluray at all.
help?!
thanks
ottosmo is offline
post #2 of 3 Old 03-02-2013, 07:09 AM
Super Moderator
teachsac's Avatar
Quoted: 814 Post(s)
Liked: 1336
Hit the post reply button inside the owner's thread. Not start a new thread.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3 of 3 Old 03-02-2013, 07:12 AM
Super Moderator
DrDon's Avatar
Quoted: 1211 Post(s)
Liked: 2375
S~
Best idea since most of the guys are subscribed to that thread and won't even see this one. Thanks.
Thread closed.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Closed Thread Blu-ray Players
Lg Bd590 250gb Hd Network Blu Ray Disc Player
