SONY BDP S590 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-05-2013, 09:42 AM - Thread Starter
sunnymarek's Avatar
Hi,
I purchased a Sony DBP S590 but it doesn't play divx files. I read in another thread here that you have to get an avi fourCC code changer. I used that to set the fourCC description code and the fourCC used codec both to xvid. I burned the file onto a dvd-r but the Sony BD player still doesn't play the file. It says "there is no playable file". Would any of you know what I'm doing wrong ?
Thank you.
sunnymarek is offline
Reply Blu-ray Players
Sony Bdp S590 3d Blu Ray Player , Blu Ray Players
