Official LG BP630/530/430/330 Owners Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 70 Old 06-24-2014, 03:22 PM
kraftytwo's Avatar
Originally Posted by blakean View Post
I hope this is the right place for this presumably simple question:
I have a LG BP330 Blu Ray Player connected via HDMI to an LG TS913ES 5.1 Surround System. Are these machines capable of playing 24/96 and/or 24/192 Khz audio files at their full capacities? The files themselves play via the USB input on the player, but I have no way of knowing for sure whether the quality is as it should be. And if not the simple USB option, can the files be used properly burned to a dvd, etc...?
I don't think they play with full capacity. Somewhere along the way it is decoded as 96kHz output.
There is not enough data from the manual, but you can presume that.
I don't think the human ear will notice anything above CD resolution 16/44.1 - so it's all good.
kraftytwo is offline
post #62 of 70 Old 06-24-2014, 04:08 PM
Liked: 0
Yes, the manual is quite unhelpful. The specifications for the receiver claim 24/192 capabilities, but the player manual says nothing about hi-res audio. The receiver window merely says "PCM", not noting the 44/96/192.
blakean is offline
post #63 of 70 Old 07-06-2014, 02:08 PM
kctobyjoe's Avatar
Unhappy BP530 issues
Got a BP530 (now three) all refurbs; unit #1 just shut off the other day; after pulling power started again
LG's TVs at least are NOTORIOUS for bad power supply components; specifically capacitors; whether they be a bad manufacturer or under powered it matters not
ANYOHE with similar issues with theirs? Didn't take the unit apart yet
BAD caps in LG units usually BULGE at the top, FWIW
Joe
Giddyup !
kctobyjoe is offline
post #64 of 70 Old 07-17-2014, 11:52 AM
kraftytwo's Avatar
Issue Report here.
Today, to my surprise, the player, after being turned on, it reset itself,
forcing me to go through the setup wizard all over again,
and filling all network settings & other settings I previously had set.
It happened only once. No clue of what triggered this behaviour.
Anyone had the player to behave like this before?
post #65 of 70 Old 09-04-2014, 10:37 PM
lmartinijr1's Avatar
Quoted: 207 Post(s)
Liked: 236
Originally Posted by directorpaul View Post
I have the LG BP530 and have trouble staying connected to Private Sound Mode. I'm using the latest LG remote app on my iPhone 4S to connect, but my phone times out and disconnects from private sound mode. I would expect the sound to continue to stream in standby as it wouldn't make sense for the iPhone screen to stay on during an entire movie. If anyone has any ideas or solutions, let me know. Thanks.
Mine doesn't synch . Dialogue out a whack. Synch adjust on my lg 6100 tv no help. Think the app is crap right now.
lmartinijr1 is offline
post #66 of 70 Old 09-05-2014, 09:32 AM
directorpaul's Avatar
I used the latest app on a Samsung S4- the audio still works when the screen times out, however this is still a slight audio delay- it must be due the wireless router.
The best option is to get wired headphones and plug it directly to the source/TV/receiver. Unfortunately, it was a good selling feature but not a practical one that can be used.
Hopefully they can work out the kinks through an update but I'm guessing it's just the limitations of routing audio through Wi-Fi.
directorpaul is offline
post #67 of 70 Old 12-20-2015, 06:50 PM
Liked: 0
Lg bp530 problems
My friend asked me to look at his lg BP 530 3D blu-ray player he did a firmware update and then he said it would not power on is there a way of like holding a the power button to get it reboot in a safe mode or in factory rest.
BIG5SECURITY is offline
post #68 of 70 Old 12-21-2015, 07:19 AM
Quoted: 23 Post(s)
Liked: 3
Have you tried just unplugging it for about 20-30 seconds then plug in and then see what happens? I have this exact player but fortunately have not had this issue. I checked my manual and didn't see any ability to do a factory reset once it 'bricks'. Best of luck!
bigathetank is offline
post #69 of 70 Old 01-09-2017, 03:39 PM
Liked: 0
Please help me unlocking my LG BP630!
Hello all, I'm facing a weird problem with my blue ray player (purchased in Spain), my girlfriend gave me some DVDs from Argentina as a present, but as Spain is zone 2 and Argentina is zone 1 or 4 I wasn't able to play the discs. I tried going to Settings > Lock > Change region code (with a zone 1 DVD inside), then it asked me for a 4 digit password and password confirmation and I've entered 0000 and 0000, then the player hanged and I had to unplug it and after turn it on again now it only reproduces region 1 or 4 DVDs and not region 2 (Spain) DVDs anymore (something's got saved into some memory but I don't understand what really happened).
I've tried ev'rything, from going to Settings > Others > Factory Reset and to install the latest firmware but no luck in both, when I insert a spanish DVD now it says "Check region code" and it ejects the disc so I'm very frustrated as I'm not being able to leave the player in its original state and I have a lot of zone 2 discs
I truly hope anyone can help me unlocking my device or putting it in its original state (ejecting disc and pressing 0000 and pause does nothing in my player).
Thanks in advance!
krueger31 is offline
post #70 of 70 Old 08-08-2017, 06:27 AM
Liked: 0
BP630 + Hard Drive Connection Issues
I'm trying to connect a hard drive via USB, Seagate Backup Plus 5TB. The hard drive powers on, I can hear it working and see the light on, but it doesn't appear on screen as an option to access. After a few minutes the USb signs appears in the top corner of the display on the TV but that goes and it's still not connected.
The same hard drive works perfectly on my computers and more recent LG TV in a different room. The software is up to date. Is there anything else I can try to get the hard drive to show?
pixielees is offline
Reply Blu-ray Players
Blu Ray Players , Lg , Lg Electronics Bp330 Blu Ray Disc Player With Wi Fi , Lg Electronics Bp530 Blu Ray Disc Player With Wi Fi
