Official Panasonic DMP 79/89/130(UK)/225/230/330 Owners Thread 2013 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #181 of 735 Old 05-27-2013, 09:12 PM
Paul.R.S's Avatar
Quoted: 41 Post(s)
Former BD10, BD55 and current BDT350 owner here.
I don't like what I call the "wedge"-shaped chassis form factor Panny (and Sony) has/have moved to. Am looking at getting my parents last year's BDT220 to replace their slow, 4-year old Sony and facilitate easy viewing of high rez photos on an SD card.
The only reservation that could tilt me towards a 2013 model is Flickr support (the site I use for all of my photo storage): Do any decks in the 2013 line support Flickr?
(I searched the thread for "Flickr" before posting and got no hits.)
Paul.R.S is offline
post #182 of 735 Old 05-30-2013, 11:55 AM
Stereoguy99's Avatar
Hi: Wondering which player is a good match for a TC-P55ST50/50ST60 in terms of pic. quality, loading times,up scaling etc!!! Also has anyone used the monoprice ultra slim HDMI cables w/redmere technology ? Thanks for any info/opinions!!!
Stereoguy99 is offline
post #183 of 735 Old 05-30-2013, 11:58 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3414
Id grab a 230 or 330. The Redmere have glowing reviews, just remember that if the chip fails the HDMI cabkle fails. For short runs, standard Monoprice or Blue Jeans Cable cables are just fine and durable.
gadgtfreek is online now
post #184 of 735 Old 05-30-2013, 01:21 PM
Hi Gadgtfreek: I'm also looking at "passive" HDMI cables from here http://www.mycablemart.com/store/cart.php?m=product_list&c=173 or from here http://www.ncix.com/search/?categoryid=0&q=slim+HDMI+cables what are your thoughts about these???Thanks will likely pick-up the 230 Friday!!!
post #185 of 735 Old 05-30-2013, 02:03 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3414
Those passive thin cables should be just fine in short runs. I am not familiar with the brand though.
post #186 of 735 Old 05-30-2013, 02:16 PM
UHD Addict
aaronwt's Avatar
Quoted: 5630 Post(s)
Liked: 3408
Those HDMi cables from MyCableMart look exactly like the Ultra Slim Redmere cables that Monoprice sells(I have some short ones I got from Monoprice that look identical). The picture also shows that it has a directional arrow like the ones Monoprice sells.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #187 of 735 Old 05-30-2013, 02:17 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3414
I didnt see the arrow, so they are probably not passive.
post #188 of 735 Old 06-02-2013, 08:51 PM
ebasol1's Avatar
Originally Posted by Mactavish View Post
Not a "bad player", I just got my Panasonic 330 BR today, and immediately tested it for this issue, and that's what it does, 1080i on playback from standard BlueRay disks when HDMI "sub" is set to "turn OFF video signal".
For non 3D, standard BR playback, I pondered a solution that would not involve complicated HDMI cable switching or using a switch, and realized all I had to do with my setup, was to return the Pany units setting for HDMI "sub", back to "NORMAL", when viewing a non 3D BlueRay, and this sends out the full 1080P video as well as the Master audio tracks to my NON 1.4 HDMI AVR, a now older Onkyo 906, that has NO 3D capabilities, hence the reason I bought this dual HDMI output deck in the first place. Then I simply change the input on my new Panasonic VT50, to the input from the AVR, no longer from the Pany 330 "main HDMI output". The VT50 has 4 HDMI inputs, which is helpful here. So at least for me, I only have to make one menu setting change, and of course the inputs on the AVR and panel itself for sources. THANKS for pointing out your discovery, not sure why the hardware behaves this way, but there is at least a work around depending on the gear one owns, beats upgrading to a new 3D ready AVR if you can't or don't want to.
Anyone have any update on this problem? My 330 does the same thing, and I hate it! Thanks.
ebasol1 is offline
post #189 of 735 Old 06-05-2013, 06:33 PM
swanny78's Avatar
I have just bought a 330 and I seem to be having similar issues. I have my main video out HDMI connected to my Panny LED TV (not 3D) and the sub connector to my Denon x2000 (3d compatible AVR). DVDs all work fine. However Blu Rays don't. (not tried 3d blu ray as I don't have a 3d TV)
I first noticed after putting my first blu ray in that I got the spinning disc logo as you do on most blu rays then the screen goes blank. I left if for 10 mins thinking its downloading something in the background as its the first Blu Ray. Anyway after a while I switched thru my HDMI inputs on my TV back to the original and a picture appeared and the blu ray loaded the menu screen. It seems switching AV channel kicked it into life. Then I noticed I have no sound. I checked all the settings ie Video turned off on sub HDMI connection and all fine. I flicked my TV's AV channels again and once I moved off the DVD input sound started to come thru the amp (also does it if I disconnect the HDMI from the TV). I just can not seem to get picture and sound on at the same time. It looks to be some HDMI switching issue. I notice that HDMI appears on the DVD player display when I unplug HDMI cable from TV and sound starts. Anyway I have enabled video in sub and I get both pic and sound over a single HDMI connection. I just can not get the friggin dual HDMI to work so one carries the pic to my TV and one the sound to my amp.
Any help, or guidance, or even acknowledgement that I am not the only one......I am tearing me hair out.
swanny78 is offline
post #190 of 735 Old 06-05-2013, 07:04 PM
Mactavish's Avatar
Liked: 29
If you don't see the "arrow", they are most likely "PASSIVE", the Redmere technology is "active" HDMI. I own both types, and the thin ones that are NON-ACTIVE had NO arrow, and of course the true Redmere's with the built-in chip, DO have arrows for "source/display". I think that is what you meant.
http://blogcritics.org/product-review-redmere-powered-hdmi-cables/
Brief clip from link above:
"The website HDMI.org, in its discussion of “active” versus “passive” cables states that “active cables have built-in electronics to enable long cable runs, and typically these cable require a power supply.”  To us, that seems like a huge pain (and certainly hurts any notion of portability), RedMere’s chip requires no external power supply, and RedMere says that cables with the chip are being made up to 50 feet in length, easily surpassing HDMI.org’s acknowledgment of standard cables hitting a maximum of 10 meters (roughly 33 feet)."
TO ANYONE FYI:
LOTS of good info in a separate, devoted thread here on AVS, that I follow and have posted to if you are interested in Redmere cables.
http://www.avsforum.com/t/1417609/monoprice-redmere-hdmi-cables
Mactavish is offline
post #191 of 735 Old 06-05-2013, 07:06 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3414
Yepp, my comments were backward. I knew what I meant, but I did not say it LOL.
Mactavish likes this.
post #192 of 735 Old 06-06-2013, 10:44 AM
AdamHD's Avatar
Liked: 38
Upgraded my DMP-BDT230 to firmware 1.40 yesterday. Playback issues seem to be resolved. I did not have time to really check a ton of blu-rays, but the issues I was having with the Disney WOW disc and some others are no longer issues anymore. My player used to hang-up (and get completely stuck) between menus and have a black screen while the player display said "play". It no longer does this.
AdamHD is offline
post #193 of 735 Old 06-06-2013, 11:28 AM
Super Moderator
teachsac's Avatar
Quoted: 735 Post(s)
Liked: 1209
Cool. I'll have to hook the 230 back up. Yanked it when I had problems and replaced it with my 320 (rock solid, no problems).
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #194 of 735 Old 06-10-2013, 02:55 PM
sm8680's Avatar
Can someone please tell me if when pressing the fast forward button just once if there's sound for DMPBDT230? I do know that DMPBDT35 and up had this capability. My Last years model dmpbdt320 had this capability. DMPDBT330 doesn't I just tested an open box at a local retailer. They didn't have the dmpbdt230 on the floor to test and wouldn't open one up. We find that if we are watching a crappy movie that sometimes playing it slightly faster with sound saves us time. When in some cases we might stop watching altogether. Please advise.
Steve
sm8680 is offline
post #195 of 735 Old 06-10-2013, 04:27 PM
Super Moderator
teachsac's Avatar
Quoted: 735 Post(s)
Liked: 1209
230 and 330 work exactly the same way in those features. Unfortunately, that feature was lost on this year's models.
S~
teachsac is offline
post #196 of 735 Old 06-10-2013, 05:33 PM
AdamHD's Avatar
Liked: 38
Steve
It does not.
AdamHD is offline
post #197 of 735 Old 06-11-2013, 09:11 AM
mdavej's Avatar
Quoted: 2167 Post(s)
Liked: 953
Originally Posted by AdamHD View Post
It does not.
It doesn't work quite like the OP says. Would you mind trying again, but instead press Play a second time for 1.5x speed, not FFWD. This feature has been on panasonic players for many years. I don't see why they would suddenly drop it now.
mdavej is offline
post #198 of 735 Old 06-11-2013, 01:44 PM
AdamHD's Avatar
Liked: 38
I'll try that later on tonight, and let you know what I find out.
AdamHD is offline
post #199 of 735 Old 06-11-2013, 07:31 PM
curtishd's Avatar
Quoted: 155 Post(s)
Can someone check and see if any of these bluray players can do VUDU captions (subtitles)?
curtishd is offline
post #200 of 735 Old 06-12-2013, 03:55 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
I just got the 330 player on sunday at bestbuy it shows a better image any player in my house,no issues with load time or sound quality
Chise is offline
post #201 of 735 Old 06-12-2013, 04:01 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
Try a the software update I have no issues with the one just brought
Chise is offline
post #202 of 735 Old 06-12-2013, 11:33 AM
Mixdoctor's Avatar
Quoted: 240 Post(s)
Liked: 132
Was about to buy a 330 from Amazon until I read about the1080i bug in which when using the second input for sound the main input goes into1080i instead of 1080p. Since that is the way I want to use it for 3D movies that would be a problem for me.
If this bug is now gone someone let me know.
Sony XBR75X940C
Martin Logan Spires
Seaton Submersive Pair
LG65E6 OLED
Mixdoctor is online now
post #203 of 735 Old 06-12-2013, 01:01 PM
ebasol1's Avatar
The bug is there for me. I haven't heard otherwise.
ebasol1 is offline
post #204 of 735 Old 06-12-2013, 01:55 PM
tokra's Avatar
I just got the PDT-330 myself yesterday and can confirm the same 1080i bug when using V.OFF for the second HDMI sub. Even the Panasonic menu screen goes to 1080i. The workaround is to just activate this feature when watching 3D-movies. The player even asked me when trying to play a 3D-BluRay if I would rather turn off the "offending" device or if it should activat V.OFF (=audio only) for HDMI sub. I just have to turn this setting back to "normal" when I want to watch a standard BluRay. Pretty annoying bug, but at least not a deal-breaker since it is at least possible to see every movie in the highest resolution. Let's hope and wait for a fixed firmware someday...
tokra is offline
post #205 of 735 Old 06-12-2013, 02:12 PM
Mixdoctor's Avatar
Quoted: 240 Post(s)
Liked: 132
Thanks for the info. I guess you can always do the workaround if you already own it, which sounds like maybe reprogramming a universal remote to do the macros, but in my case, since I don't already own it, makes me think something like the Sony s790 is looking a little better. This despite the fact that the 330 does seem to have a few newer features and is cheaper.
Sony XBR75X940C
Martin Logan Spires
LG65E6 OLED
post #206 of 735 Old 06-12-2013, 02:18 PM
tokra's Avatar
Well, I just also dropped a lenghty mail to Panasonic UK with this issue and pointed them to this forum and the other reports. Let's see if I get brushed off as well or if they will acknowledge the issue and provide a firmware update soon. I like the player very much otherwise and as long as there's a viable workaround I can live with it. However should this bug stay unfixed my next player won't be a Panasonic anymore.
tokra is offline
post #207 of 735 Old 06-17-2013, 01:59 PM
eyeful99's Avatar
I know your pains, trying to tediously type in using the left/right cursor, what a PITA!
Anyhow, on my home network, I had a WDLive hard drive (advertised as personal cloud WD2GO) on my network, under Win7 on my setup PC, it appears as drive M:\\mybooklive. Under its own config screen, it appears as "Public"
So its IP is 196.168.1.5
Shared folder is Public
No username needed
No password needed
Click on Connect...
Then it finally load to show folder menu. Now I am able to play smoothly all those BD quality files that was either "cannot play" or did not even appear under DLNA connection. Everything plays as nice as direct USB connection on my BDT330. This makes the player an excellent value, replacing a WDLiveTV media player box, has SD slot for HQ pics, network drive reader/player, web browser VOD Netflix and plays 3D bluray. Mine feeds a single 25 ft HDMI cable to the Epson PJ 5020UB on the ceiling, no need for a HDMI switch box.
eyeful99 is offline
post #208 of 735 Old 06-26-2013, 12:47 PM
Anglo Saxon's Avatar
Hello all
I installed my new DMP-BDT230 today, updated to Firmware 1.26. I'm in the UK and presume the firmware are regionalised as quite a difference with 1.40 in the USA?
Anglo Saxon is offline
post #209 of 735 Old 06-26-2013, 04:12 PM
Super Moderator
teachsac's Avatar
Quoted: 735 Post(s)
Liked: 1209
Yes. Each region has their own firmware.
S~
Anglo Saxon likes this.
teachsac is offline
post #210 of 735 Old 06-26-2013, 04:16 PM
S~
Thank you teachsac
Reply Blu-ray Players
Panasonic Dmp Bd79 Blu Ray Player , Panasonic Dmp Bd89 Wi Fi Blu Ray Player , Panasonic Dmpbdt230 Wi Fi Blu Ray Player , Panasonic Dmpbdt330 Wi Fi Blu Ray Player
