Samsung BD-F5900 Owner's Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #361 of 367 Old 06-30-2015, 02:58 PM
jfishel's Avatar
I'm having a few strange things happen with this player as of last night. Confirmed I am on the latest f/w.
1. When turning on the player for the first time, I will see the Samsung Smart TV boot up logo, but after a few seconds, the picture goes black and the main smart hub menu never appears. TV pops up a message that no video signal is present. No matter what hdmi cable I use or what TV it's plugged into the main menu will never come up from a cold boot. There is one interesting workaround I found: while on the blank screen if I pop in a bluray disc, it automatically starts playing and the picture comes back. I can then stop the disc and the smart hub menu appears like expected. I've tried to reset the player, still exhibits the same symptoms. F/W is up to date. This player worked perfectly at this location for several months (even before the f/w update).
2. When streaming Netflix, connected on wifi to 5ghz AP with very good signal strength I get random dropouts every few minutes.
I'll be contacting Samsung support soon, just wanted to post up here first in case anyone else has experienced this also.
jfishel is offline
post #362 of 367 Old 07-01-2015, 09:46 AM
jfishel's Avatar
I figured out one workaround to the startup issue. I enabled "quickstart" in the settings menu. The player basically stays on all the time now, but in a standby mode instead of off. This seems to be working for me. Not great, but better than having to load a disc and stopping it everytime I want to use the player for something.
jfishel is offline
post #363 of 367 Old 07-01-2015, 03:58 PM
oatmeal769's Avatar
Quoted: 13 Post(s)
For the past 6 months or so mine works fine with Netflix or Amazon for a while, then it blanks out unexpectedly, and I have to unplug the unit to get it to shut down. It will then power up normally, and I can go to a service like netflix. However, it will only play for a couple minutes then freezes again.
Doing a factory reset is the only thing that repairs it, but then I have to go through setup, logging back in to wifi, and logging into Netflix and Amazon.
It will then last like this for a week or two, and start freezing again.
Any ideas?
oatmeal769 is offline
post #364 of 367 Old 12-14-2015, 03:21 PM
garbanzo's Avatar
I have a very strange problem with my BD-F5900. I turn it on and open the tray to load. Then without doing/touching anything else the tray closes, it sounds like it's trying to load for maybe 5 seconds (whether or not there's a disk in the tray) and then the tray opens again. Sometimes it will then close the tray automatically and repeat the load/eject. If I'm trying to watch a BD it may take 5, 10 or 20 attempts before it actually loads the disk. I thought it might be the touch sensor on top so I found another thread for a different model that told how to disconnect the touch sensor. That didn't solve the problem and now, even though it can only be controlled with the remote, the tray still is doing its thing and it's taking many times before the tray will actually stay in and load.
Any help or ideas are appreciated.
garbanzo is offline
post #365 of 367 Old 11-12-2016, 08:42 AM
txakura's Avatar
Liked: 0
SOME Blue-ray discs don't play
I own a Samsung BD-F5900 Blu-ray player, which is connected to a Samsung 65" TV via an Outlaw Audio Model 975 pre-pro. A couple of weeks ago, while my wife and I were watching the Extended Edition of Lord Of The Rings, we stopped while playing the first disc in the "Fellowship of the Ring" set. When we went back to play the next day, all we could get was the little disc spinning around in the center of the screen. We tried all six discs, and none of them would play. Just to narrow down the problem, we played a couple of other blu-ray discs, and they did fine. We've since gone back and tried to play The Lord Of The Rings again, but they still don't do anything. We have also watched an original set (3 discs total) of the earlier non-blu-ray Lord Of The Rings in the same player with success.
Anyone have a clue to the problem?
txakura is offline
post #366 of 367 Old 11-12-2016, 08:13 PM
Ken.F's Avatar
Quoted: 1729 Post(s)
Liked: 1574
You could try doing a full system reset. I'm sorry I don't remember the exact terminology Samsung uses but you should be able to find it in the settings somewhere, possibly in the support menu.
Ken.F is offline
post #367 of 367 Old 11-12-2016, 11:40 PM
txakura's Avatar
Liked: 0
I had a problem with my Tevo player today, and the answer was to do a power reset (unplug from power, wait 15 seconds and plug in again), your response and that got me thinking, and I first checked in "Settings" and found "Software Update", and thought I'd try that, and then do a power reset on the BD-F5900. I would never have expected to find new software for the Blu-Ray player after this long, but there was, and not even just one iteration, either. Ran the software update, and tried to play the discs again - and they worked! Thanks for the response. I probably would have still been trying to figure out what to do without the prompting.
txakura is offline
Reply Blu-ray Players
Samsung Bd F5900 3d Wi Fi Blu Ray Disc Player
