Question about BD disks playing 24P - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-19-2013, 05:22 PM - Thread Starter
JackB's Avatar
Quoted: 478 Post(s)
Liked: 76
I have a PS3 and a Samsung BD player. In using both I notice that usually I am getting 1080P/60 displayed on the screen instead of 1080P/24. I have set the two players to auto 24P playback(I think that is what it's called) but it doesn't seem to work. I'm wondering if:
1. All BD are not 24P? I thought they were.
2. The auto 24P doesn't work like I think it does.
3. On one system, the PS3 one, the signal is routed through a Denon 602 VP. On the other it goes through an AVR. Could either of these processors be blocking the 24P?
Any experience and advice would be appreciated. For all these years I wonder if I have been missing out on the best quality possible.
Jack
JackB is offline
post #2 of 10 Old 03-19-2013, 05:30 PM
rdgrimes's Avatar
Quoted: 1992 Post(s)
Liked: 1320
Movies are generally 24p. TV shows, concerts and such are often 60i.
Getting 24p delivered to your display does depend on proper HDMI handshaking and supporting hardware.
rdgrimes is online now
post #3 of 10 Old 03-20-2013, 08:53 AM
Angler55's Avatar
If your TV isn't displaying 24P when your blu ray players are set to 24P I would think your TV isn't on the correct setting. I would check the TV manual.
Al
Angler55 is offline
post #4 of 10 Old 03-20-2013, 04:44 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Most TVs will take a 24p signal and convert to 60p to display. You will have to find out (1) if your TV does support 24p display (usually in multiple of 24Hz) (2) how to enable 24p on your TV.
If a TV does not support 24p signal at all (common in low end TVs), it will tell the player to not send the 24p signal in EDID and the players will do so accordingly.
Foxbat121 is online now
post #5 of 10 Old 03-20-2013, 10:32 PM - Thread Starter
JackB's Avatar
Quoted: 478 Post(s)
Liked: 76
The tv is a JVC RS40 and it will take a 24p signal.
Jack
JackB is offline
post #6 of 10 Old 03-21-2013, 04:05 PM
Angler55's Avatar
Well, that being a projector and not a "tv" leaves me with no idea what it will and will not do.
Good luck in your search for an answer.
Al
Angler55 is offline
post #7 of 10 Old 03-21-2013, 04:14 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
That tells us absolutely nothing. Like mentioned above, a lot TVs will take 24p but still convert into 60p. Your best bet is post questions here in JVC RS40 owner's thread http://www.avsforum.com/t/1296327/official-jvc-rs40-x3-owners-thread
post #8 of 10 Old 03-21-2013, 08:08 PM - Thread Starter
JackB's Avatar
Quoted: 478 Post(s)
Liked: 76
Fixed the problem with the PS3 to the RS40. The Denon video processor was set to 1080P not to 1080P/24. I thought it was set to "Auto" where it would pick either one based on input signal. But it didn't have an Auto setting.
Will be checking my Samsung BD player the next time I use it to see if the same situation is present.
Jack
JackB is offline
post #9 of 10 Old 03-22-2013, 05:51 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2682 Post(s)
Liked: 1915
Die, Auto settings, Die!
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #10 of 10 Old 03-22-2013, 06:59 AM
UHD Addict
aaronwt's Avatar
Quoted: 5185 Post(s)
Liked: 3097
Your average users needs an "auto" setting option.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Reply Blu-ray Players
Sony Playstation 3 60 Gb
