Samsung BD-F7500 Blu-ray Player. - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #181 of 259 Old 02-13-2015, 10:29 AM
sbournazos's Avatar
Quoted: 44 Post(s)
Whats a better BD palyer the BDF7500 or the BDH6500?
Do both support the same formats including DTS-HD Master Audio ?
Do both have the Samsung smart hub where you can add apps?
Not Opera
sbournazos is offline
post #182 of 259 Old 02-13-2015, 10:47 AM
sbournazos's Avatar
Quoted: 44 Post(s)
Originally Posted by jsmiddleton4 View Post
The 7500 or the newer albeit not as featured 6500?
Can get both locally. 7500 is just under 200. 6500 about 140.
7500's are getting thin. Amazon doesn't have them. Local Fry's electronics does.
Hard to decide. It is these Samsung's or Sony's 6200. Everything else been eliminated.
Same issue here. Did you ever decide which one is better?
Do both support the same audio formats including DTS-HD Master Audio?
Do they both have the Samsung smarthub where you can add apps? which one has a better faster processor?
BestBuy has the BDF-7500 for $139.99 and the BDH-6500 for $159.99
post #183 of 259 Old 02-14-2015, 08:39 AM
Musician's Avatar
Quoted: 2329 Post(s)
Liked: 3930
Answer: The BD-F7500
Answer: Yes
Answer: Yes
Which has the faster processor?
Answer: Not provided in the specs but if one was faster than the other, my guess would be that it would be in their flagship BD-F7500.
What really sets the 7500 worlds away from the 6500 is the inclusion of dual HDMI ports that can come in really handy. For example, you can run one to your TV and the other to your receiver. And check out the weight of the 7500 - 4.4 lbs versus 1.1 lbs.
Here are links to Samsung's site for each.
BD-H6500
http://www.samsung.com/us/video/blu-ray-dvd/BD-H6500/ZA
BD-F7500
http://www.samsung.com/us/video/blu-ray-dvd/BD-F7500/ZA
Interesting that the prices you quote has Best Buy selling the BD-F6500 for a cheaper price than the flagship BD-F7500. If you check the Samsung site you'll see the BD-F7500 is the more expensive of the two.
Snap that BD-F7500 up. That's a bargain!
Samsung UN78HU9000 - Firmware 1500.4 SEK-3500U
Samsung UN40HU7000 - Firmware 1210.3
Samsung UBD-K8500 UHD Blu-ray Player
Arris VIP5662W UHD Whole Home DVR
Marantz SR7005 Receiver
Magnepan Speakers & Martin Logan Subwoofer
Musician is online now
post #184 of 259 Old 02-14-2015, 02:52 PM
joe2006's Avatar
The price I see now for BD-F7500 at Bestbuy.com is $209.98 On Sale (Reg: $249.98).
joe2006 is offline
post #185 of 259 Old 02-17-2015, 01:06 PM
Liked: 0
And just became $249 now
Angeleno is offline
post #186 of 259 Old 02-17-2015, 02:24 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3554
Yup, $250 now ... just because we were talking about it. ...No more talk* and the price will go back down where it was.
Samsung is listening (reading) and uses the info as their price stratagem.
taxman48 and Musician like this.
NorthSky is offline
post #187 of 259 Old 02-20-2015, 05:50 AM
Mr. Cinema's Avatar
Can you turn off the front (time) display on this unit?
Mr. Cinema is online now
post #188 of 259 Old 02-26-2015, 07:08 AM
Musician's Avatar
Liked: 3930
Although you can't turn it off completely (unless the unit is turned off obviously) you can control it as follows.
Menu >> System >> General >> Front Display
The following settings are availabe:
Auto = Dim during playback and bright any other time.
Dim = Dim the display window at all times.
Bright = Brighten the display window at all times.
I keep mine set to Auto and I can't even tell it's on while a movie is playing. Since the On Screen Menu gives you all the info you are after you could always cover the front display with <GASP> a piece of black electrical tape.
post #189 of 259 Old 02-26-2015, 10:40 AM
Matt2026's Avatar
Quoted: 405 Post(s)
Liked: 15839
Hmmm, I have no [Menu] button my remote but did find the setting. Turning on my player the startup screen for the BD player comes up on my flat screen and I followed this path: Settings >> System >> General >> Front Display
In any case thanks for the info
Name:	BD-F7500 remote.jpg
Regards, Ken (Retired)
9.1) Denon 4520CI; Samsung 55H8000 & BD-F7500; R&LRS/L/R SVS Ultra BS,
Ultra Center; FH & SS Polk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nakamichi RE-2, CDC-4A, CR7A, Denon 300F/Ortofon 2M Bronze;
Matt2026 is online now
post #190 of 259 Old 02-26-2015, 12:23 PM
Musician's Avatar
Liked: 3930
Oops. Glad you found it. I have the UN78HU9000 UHD TV and I am so use to hitting the MENU button to access settings.
Enjoy!
post #191 of 259 Old 02-28-2015, 11:07 PM
wip7's Avatar
Liked: 1
Samsung BD-F7500 chip is Silicon Image Sil9616, this chip also installs no less than Oppo BDP-103D, a DVD worth about 900 euros. It is no coincidence that this player is also available for 7.1 analog outputs, dual HDMI, LAN, etc.
Matt2026 likes this.
wip7 is offline
post #192 of 259 Old 03-01-2015, 10:54 AM
Matt2026's Avatar
Quoted: 405 Post(s)
Liked: 15839
Enjoy!
Hey, thanks again Musician, I am enjoying it. Watched my first movie since setting the unit to Auto Dimming, nice not having that bright display, also used the Dim button on my 4520CI to turn off its display Much nicer in a dark room.
post #193 of 259 Old 03-01-2015, 01:19 PM
NorthSky's Avatar
Liked: 3554
$199 now. ...Canadian dollars, not American dollars. ...In USD that should be about $149.
NorthSky is offline
post #194 of 259 Old 03-04-2015, 12:15 AM
Liked: 0
Hi all, Yesterday, i substitute my bd e 5500 with new bd f 7500, I don't need 3d so, i connected blu ray and other sources via hdmi, and used 4306 monitor out to connect tv, the same way used when used old bd e5500.
The problem is that i lost hdmi signal after few seconds, (used hdmi for both audio and video), sometimes video/audio appear againg, then goes off again.
Some have some suggestion to solve the problem, some have tried same connection?
An alternative is to add a new hdmi and connect directly on tv, and taking audio from digital spdif or analog RCA, but i have to add a 15m hdmi cable... and i don't know if there is enaught space for new cable.
raoul.grasselli is offline
post #195 of 259 Old 03-04-2015, 08:19 PM
Musician's Avatar
Liked: 3930
Thanks for posting that.
Here is a link confirming that it is also in the Oppo 105D...
http://forum.blu-ray.com/showpost.ph...7&postcount=36
And a site (in French) that includes some pictures of the BD-F7500 showing a photo of the Sil9616 chip (see thumbnail).
http://translate.googleusercontent.c...ashAdhOzAVLXxw
We're in good company... or should I say the Oppo's are in good company!
celestica likes this.
post #196 of 259 Old 03-05-2015, 04:20 AM
Liked: 0
Solved!, there was a problem with old hdmi, that had non problem with old bd e 5500, but had a problem with new 7500. Cable canged, hdmi works now!
post #197 of 259 Old 03-06-2015, 05:46 PM
rsoares28's Avatar
Quoted: 113 Post(s)
Liked: 27
Hello, I'm considering this player but i have a question regarding the dual hdmi outs. I currently run my ps3 and htpc through my okyo sr308 then to my Sony hw40es projector.
Would i get better picture quality if i ran the f7500 straight to the Projector and the 2nd hdmi out to the Onkyo for sound??
I dont think my onkyo performs any video upconversion so i'm not sure if it does anything to the image before sending it to the projector
rsoares28 is offline
post #198 of 259 Old 03-07-2015, 11:09 AM
fireman1000's Avatar
Quoted: 32 Post(s)
That's how mine is setup.
fireman1000 is offline
post #199 of 259 Old 03-07-2015, 02:05 PM
Matt2026's Avatar
Quoted: 405 Post(s)
Liked: 15839
The 7.1 outputs were a consideration for me in buying this player. I had read some reviews and it was noted that these discrete outputs are disappearing from players and although I didn't think I would ever use them I figured "why not", can't change my mind later...
When I picked up my Samsung 55H8000, after 14 years without a television, and hadn't yet purchased my Denon4520 it dawned on me that the 7500 had those analog outputs which allowed me to use my old sub-woofer along with the TV's speakers. What a difference to TV sound!
post #200 of 259 Old 03-08-2015, 12:26 PM
Michael James's Avatar
Quoted: 76 Post(s)
Can the 7500 bitstream both Dolby TrueHD and DTS-HD?
Is the HDMI 2 still audio only even after the firmware updates?
Michael James
Cincinnati, Ohio
Michael James is offline
post #201 of 259 Old 03-08-2015, 01:00 PM
Quoted: 32 Post(s)
My understanding is yes to both questions.
post #202 of 259 Old 03-08-2015, 10:10 PM
NorthSky's Avatar
Liked: 3554
And it's a fact. ...Both lossless hi-res audio decoders are on board, and are bistream through HDMI.
________
www.youtube.com/watch?v=aUA5lRWAfMI
NorthSky is offline
post #203 of 259 Old 03-10-2015, 05:48 PM
SeanGood79's Avatar
I'm looking into buying this player.
Can anyone confirm if the OSD can be turned off?
I don't want to see PLAY or PAUSE from the player on screen when I push those buttons.
SeanGood79 is offline
post #204 of 259 Old 03-11-2015, 12:34 PM
Quoted: 32 Post(s)
I didn't see anywhere in the settings where this could be turned off, however, the play and pause is at the very top of the screen and transparent and only stays on a second after pressing the buttons. Even when pressing pause, it disappears in a second.
post #205 of 259 Old 03-16-2015, 07:53 PM
Tiki Steve's Avatar
Quoted: 105 Post(s)
Liked: 88
Just recieved this player last week.
It is simply the best BD player!!!
I had a samsung 5900 (went through 3 of them) and constantly had problems.
Load times are about 4x faster, fantastic picture and sound.
The overall layout , buttons etc are much better thought out.
It's near silent while playing (compaired to others)
BD wise and BD wise web seem to look great.
Tho I have found one bug, if left paused till the screen saver comes on, once you resume playing it turns off cinema smooth (still says on), would need to go and turn off them back on. Only seems to do this if screen saver comes on?
Samsung 60" F8500
Samsung BD-F7500
Pioneer 1024K
PSB Image 8C,5T,2B,Alpha
Polk PSW10 (x 2)
Monster HTS5100mkII
Tiki Steve is offline
post #206 of 259 Old 03-16-2015, 08:02 PM
NorthSky's Avatar
Liked: 3554
Awesome, I might get it too; even if I already have all the BR players I need. ...Just for the cool form factor. ...And I can replace my 6900 with it, which is missing too much (too old, only one HDMI, no useful bass management - worst ever, and it's time).
NorthSky is offline
post #207 of 259 Old 03-17-2015, 09:59 AM
Musician's Avatar
Liked: 3930
It looks very stylish next to the the One Connect Box!
post #208 of 259 Old 03-17-2015, 01:34 PM
NorthSky's Avatar
Liked: 3554
...And under my Samsung plasma TV.
Musician likes this.
NorthSky is offline
post #209 of 259 Old 03-20-2015, 11:14 PM
Tiki Steve's Avatar
Quoted: 105 Post(s)
Liked: 88
Does anyone have info on just what BDwise and BDwise web does?
I tried adjusting the BDwise to the same settings as I have for Movie mode and it doesn't look the same, so there must be something (hidden?) that also changes.
So far I seem to prefure the BDwise web setting for most BD play back
Samsung 60" F8500
Samsung BD-F7500
Pioneer 1024K
Polk PSW10 (x 2)
Monster HTS5100mkII
post #210 of 259 Old 03-21-2015, 12:19 AM
NorthSky's Avatar
Liked: 3554
BD Wise
Tiki Steve likes this.
NorthSky is offline
Reply Blu-ray Players
Samsung Electronics Bd F7500 Blu Ray Disc Player
