Remote for a Sony BDP-CX960 megachanger? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-26-2013, 04:47 PM - Thread Starter
StuSegal's Avatar
I just picked up a Sony Blu-ray megachanger to replace my DVD megachanger. Used, missing the remote; anyone know where I can find one?
StuSegal is offline
post #2 of 2 Old 03-27-2013, 12:51 PM
mdavej's Avatar
Quoted: 2213 Post(s)
Liked: 969
$9 RCA RCRP05BR will work fine using DVD code 1516 (21516) and the following EFCs if you are missing any functions. $20 harmony 200 also works fine. Manual programming instructions are in my wiki link.
Code:
power        00079
0       00142
1       00018
2       00014
3       00016
4       00012
5       00019
6       00015
7       00017
8       00013
9       00146
channel up      00097
channel down    00093
exit    00028
menu    00110
program guide   00115
display 00030
up arrow        00174
down arrow      00176
left arrow      00172
right arrow     00179
select  00175
play    00208
pause   00206
rewind  00204
fast fwd        00211
stop    00210
clear   00141
E       00140
Eject   00081
Ch Next 00097
Ch Prev 00093
Advance 00063
replay  00065
All Discs       00067
angle   00255
Audio   00003
closed caption  00252
dimmer  00062
disc next       00061
disc previous   00194
red     00253
blue    00001
green   00130
yellow  00126
group   00195
home    00032
load    00192
options 00173
repeat  00064
scene search    00095
shuffle 00060
sort    00188
subtitle        00252
time    00114
mdavej is offline
Reply Blu-ray Players
Sony Bdp Cx960 400 Disc Blu Ray Disc Changer
