Need a Blu-Ray Player with 5Ghz wifi band! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-27-2013, 09:45 AM - Thread Starter
Spyderz's Avatar
i am currently running a home network setup with synology ds213 and asus rt-n66u. My computers are running on 5 Ghz band.
Unfortunately my current blu-ray player sony s590 can only run on 2.4ghz and my mkv files have random choppiness on the screen.
i am not sure if the sony s790 runs on 5ghz therefore i am trying to find other alternatives
Spyderz is offline
post #2 of 5 Old 03-27-2013, 10:32 AM
UHD Addict
aaronwt's Avatar
Quoted: 5192 Post(s)
Liked: 3099
Get a wireless bridge that uses 5Ghz.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #3 of 5 Old 03-27-2013, 11:09 AM - Thread Starter
Spyderz's Avatar
space constraint does not permit that..unfortunately
Spyderz is offline
post #4 of 5 Old 03-27-2013, 12:04 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
The older gen Sony comes with 5GHz dual-band wifi but unfortunately, cost cutting means all the new Sony players are 2.4GHz only (maybe except for top of line models). However, I believe Samsung and Panasonic still use dual-band wifi chips. You will have to research it.
Foxbat121 is online now
post #5 of 5 Old 03-28-2013, 04:05 PM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3972
You may never get smooth playback of your MKVs over wireless.....There are so many factors involved that personally I dont think youll see that much of a difference when using the 5Ghz band.....Take a look at the dedicated Networked Media player forum, youll see many if not most have issues streaming wirelessly especially when you start going to higher bitrate MKVs and ISO files......
Ph8te is offline
Reply Blu-ray Players
Synology Ds213 Diskstation Simple Set Up Easy Efficiency , Sony Blu Ray Disc Player Bdp S790
