Subwoofer connection to Oppo 105 - AVS Forum | Home Theater Discussions And Reviews
Old 04-02-2013, 11:02 PM - Thread Starter
drmarg58's Avatar
My home theater system is based on the use of an Oppo 105 without a theater processor. It is connected directly to my five channel amp via rca interconnects. Is it possible to connect my subwoofer LFE directly to the Oppo 105 subwoofer output without having to use a processor? I've connected everything properly but not getting a signal to the sub. Subwoofer is on in the speaker set up. All speakers are set to large which defeats bass management. Any help would be greatly appreciated!
drmarg58 is offline
Old 04-02-2013, 11:20 PM
eusoro's Avatar
Hello, I suggest you post your question in the dedicated oppo bdp105 thread for quicker responses.
eusoro is offline
Old 04-03-2013, 08:43 PM - Thread Starter
drmarg58's Avatar
thank you!
drmarg58 is offline
Oppo Bdp 105 Blu Ray Player
